Bisher bleibt das Menü unberührt, ist aber für weitere Updates geplant, also momentan muss man noch Shrink etc. nutzen.
Übrigens ist das die Newsecke ;), für Fragen bitte im Rebuilderunterforum posten, danke.
Cu Rippraff
Cu Rippraff
DVD-RB 1.03 Pro ist raus!
Zitat von jdobbsAlles anzeigenCHANGES MADE TO PRO VERSION
- Improved the peak bitrate determination algorithm. It now more accurately determines source bitrates and works properly with NTSC interlaced sources.- Fixed a bug that could cause "Runtime Error 380" under some circumstances. This should make audio removal in DVD ReMake Pro compatible with DVD-RB.
- Corrected an error in which source filenames that are a mixture of uppercase/lowercase letters might cause "Error 0003, buffer overflow".
- Corrected a setting that might, under certain circumstances, allow NTSC interlaced ILVU sources to fall out of specifications.
- Fixed an error that under specific conditions could create video streams that exceed maximum bitrates.
- Updated OPV code to help prevent undersizing when encoding NTSC sources or when selecting a GOP size other that 12.
- Fixed an error in which it was possible that an audio glitch might be inserted at a layer break or point where the SCR gets reset to zero.
- Added an option to the "Select ISO Output Options" dialog that will remove the .ISO image from the output path after a successful image burn. This is meant to minimize required disc space, please use it cautiously.
Cu Rippraff
DVD-RB 1.04 Pro ist raus!
- Reorganized the "Options" configuration. It is no longer accessed as a Menu. Now it is accessed via a Tree View on either the tab bar, or, for pre-version 1.00 skins, via an "Options" choice in the "Settings" menu.
The menu had grown too large for easy use. Some "quick access" items remain under the "Settings" menu.- Added a setting under the "Mode" menu in which you can select all Extras for Half-D1. This option will not reduce bitrates for Extras (like Half/Half), but settings selected under "Steal Space from Extras" will be applied. This provides more granularity so the option can be used more effectively.
- Corrected an issue in which certain odd original anomalies might cause timing issues. A special thanks to Magic144 for finding this one.
- Fixed an error that, under certain circumstances, might cause video ticks or stutter at chapter or segment break points.
- Tweaked the muxing algorithm to facilitate better video playback buffering control.
- Changed the default setting for the Viewer/Editor so its calls use long filenames. Some users were having trouble getting it to work properly.
- Updated the Installer to use a newer version of HC Encoder (v0.16, 11/12/2005). This file is also included in the "Update Only" zip file.
- Updated installer to use EclPro v0.52. Includes better compatibility and support for Express versions.
- Corrected an error in which an erroneous input stream might cause DVD-RB to "hang" during PREPARE phase looking for a nonexistent extension start code.
Cu Rippraff
DVD-RB 1.05.1 Pro
Zitat von changelogAlles anzeigenBelow is a summary of the changes/updates associated with this version (Pro release):
- Added "Template" options under the "File" menu. Now you can load and save settings that you find to be especially useful for different types of sources, such as film, anime, cartoon, CG, series discs, etc. All you have to do to create a new template is to set up Rebuilder in the way you'd like to encode a certain type of disc, for example: the CCE or HC bias, matrices, GOP sizes, or filters -- then select "Save Template". If you have settings you find useful for certain source types, post the template on the Rebuilder forum at http://www.doom9.org/ or http://www.dvd-rb.com/ and it may be added to future DVD Rebuilder versions.
- Corrected an error that could result in "Error 0006, Framecount differences..." when working with the null output of some ripping programs.
- Fixed a sizing issue in which unreferenced audio streams that exist in the original VOB files were included in the output -- but weren't properly accounted for in the size calculation.
- Modified the ReJig calling procedure so that DVD-RB uses less processor time during calls. This should speed up ReJig.
- Change the GOP setting for HC encoder so that if version 0.16 or greater is used, "*GOP 12 2" is not forced for FILM sources.
- Added dummy pre-command and "Exit" post-command to the IFO generated by "Movie Only" encodes. It seems there are certain players that will not play correctly unless a command table is present. A special thanks to rayvt for finding the cause and cure of this problem.
- Corrected an error which might cause DVD-RB to "hang" at the 100% during PREPARE.
- Revamped the keyfile process. Too many folks were having trouble using the .RBK files. Now DVD Rebuilder will download the keyfile itself. The keyfile is also now linked to an individual computer via System ID. I've tried to make it as painless as possible. Please read the HELP information in the registration dialog. A new EXE file called Reg-RB.EXE is included in the DVD-RB directory and it can be run to get the system id and download your key for any computer upon which you wish to run Rebuilder.. It is called automatically by DVD-RB when needed. There is a default limit of 5 System IDs allowed for each registered e-mail address.
Professional Edition 1.05.2
December 30th, 2005
ZitatAlles anzeigenChanges:
- Corrected an error in which VIDEO_TS file for a Movie Only disc could have a wrong value set in the First Play PGC table.
- Corrected the PGC Program Table size for the IFO created in Movie-Only mode so it's length is always a multiple of two. This cause playback problems in at least one player model.
- Lowered the default VBR minimum bitrate for CCE to 300 (from 500). It was set to 500 in v0.83 in order to circumvent problems with CCE 2.70.
These seem to be no longer present, but as a precaution code was added to dynamically increase the to value to 500 in the event of problems.
Also added code that will automaticlly adjust it back up to 500 if an encoding pass fails. The lower value should result in slightly better overall picture quality as fewer bits are wasted on low demand scenes.- Fixed an error in the registration process in which using uppercase characters (the first time) in the e-mail field might make the registration fail repeat upon each load.
- Reduced the aggressiveness of the layer break removal, as some Sony Players appear to be very strict in how they handle streams marked with the "seamless" flag. If you wish to override this setting, add "AGGRESSIVE_LAYER_BREAK_REMOVAL=1" to the "[Options]" area of the REBUILDER.INI file.
- Updated HCBatch.exe to the most recent version.
- Increased GOP buffer size to help reduce the likelihood of buffer overflows (0003 and 0004) on some rare sources. Note, though, that 0003 and 0004 are indicators of a malformed source -- and most typically indicate a corrupted source file. This is usually due to preprocessing.
- Modified the CCE Advanced Settings dialog so it uses sliders instead of dropdown boxes.
DVD-RB 1.06 Pro ist raus.
Zitat von jdobbsAlles anzeigenChanges:
- Added support for DGDECODE v1.4.5. This update includes many enhancements/bug fixes and makes DVD-RB's support consistent with Neuron2's most current release. Support for MPEG2DEC3DG and DGDECODE v1.1.0 remains. This update includes a fix which corrects a rare problem in which an encoder may "freeze" while trying to encode a segment. The DVD-RB Installer now includes and installs DGDECODE v1.4.5 by default.
- Added coding for handling "garbage" sectors that were found to have caused problems during the PREPARE phase on at least one disc. Thanks to SpazzHH for finding a disc in which it was repeatable.
- Modified the AVS position of the trim() command. Performing the trim after the insertion of some optional filters can give better results.
- Updated some cosmetic features for consistency. Changed slider for HC Bias, and added TextColor variable to CCE settings Skin.
- Corrected a Button Over Video (BOV) issue. In some very active streams BOV may not have been reproduced properly.
- Corrected an error in the REBUILD module that could misinterpret certain input streams and as a result, throw a "ERROR 006: DVD-RB...framecount
differences" error.- Fixed a problem in which an extremely unlikely set of circumstances might cause audio to move out of sync over the course of a segment.
- Fixed a bug in which remapping audio while set to "Movie-Only" mode would cause a Runtime Error 9.
- Added a module that performs key download via web in the event of direct connection failure.
- Removed annoying "VOB Count" warning in Movie-Only modes.
Cu Rippraff
DVD-RB 1.06.1 Pro ist raus.
ZitatAlles anzeigen
Changes:- In order to facilitate the changed iDCT options
of DGDECODE v1.4.5, the iDCT selection table is
now changed depending upon the version selected.- Updated the skins to reflect newer button format
on the [Blockierte Grafik: http://technik.movie2digital.de/alink.gif] CCE Settings dialog.- Added the selected reduction percentage to the
"Steal Space from Extras is enabled" line that
is displayed and logged.- Corrected a bug in which certain parameters were
not being loaded correctly when starting by
double-clicking on a .RBP file.- Fixed a bug related to field order detection and
encoding introduced in v1.06 in which a specific
set of (unusual) circumstances might cause the
order to be incorrectly detected.- Updated routines to take advantage of newer [Blockierte Grafik: http://technik.movie2digital.de/alink.gif] CCE
abilities (v2.69 and greater) to output bottom
field first (BFF) [Blockierte Grafik: http://technik.movie2digital.de/alink.gif] interlaced streams. Now when
the original stream is BFF -- the new stream can
retain this characteristic.- Enhanced the REBUILD engine so it will now accept
field based picture structures. This might
improve ProCoder encoding of [Blockierte Grafik: http://technik.movie2digital.de/alink.gif] interlaced streams
(if enabled). It will also stop Error #0006 when
using ReJig or "No Compression" on streams that
use that structure.- Fixed the "BlankText" INI parameter so it will
work with Half-D1 sources that are being blanked.
DVD-RB 1.07 Pro ist raus!
Zitat von jdobbsAlles anzeigenFebruary 6th, 2006 (v1.07)
CHANGES MADE TO PRO VERSION- Implemented menu encoding. This new feature will now scan and reencode menu segments in the same way as standard title sets. This should save some space, allow for more efficient use of space, and improve quality. It is especially useful on titles that have large amounts of space used by menus. The default setting encodes any menu that is over 50MB. This can be overridden by setting a value for the "hidden" parameter "VTSM_MIN_SIZE" in the [Options] area of the REBUILDER.INI. It works similar to the "VTS_MIN_SIZE" parameter. It is recommended that you keep the default setting, as encoding segments that smaller than 50MB usually only increases encoding time without significantly improving qualty. If you prefer no menu encoding at all, this feature can be disabled or enabled via the "Settings" menu.
- Added code to enable multiple encoder instances. The feature is available under the "Settings" menu. On multiple core computers and some very fast single core computers using hyperthreading this will take advantage of unused processor time. This concept has been proven in concept using HC encoder, QuEnc, and ProCoder (via ECLPRO) in Rumbah's "DualDVDRB" software. Please note that if your computer already runs at 100% of its processor time this option will not likely improve your speed and in fact may make it slightly slower. But, on some processors and some encoders it has been reported to increase speeds by as much as 30-50%.
Heavy Kudos to Rumbah for exploring and proving this concept via "DualDVDRB."- Corrected "Runtime Error 55" that could occur if attempting to force-close DVD-RB during encoding.
- Corrected a reference to "32-Bit Floating Point" in the iDCT choices for DGDECODE v1.4.5. It actually is "64-Bit Floating Point".
- Corrected an error in which the intra_DC_precision setting could be set incorrectly in CCE Basic and CCE SP v2.50 under some circumstances.
- Fixed an error in which the "Enable Output" option wasn't being properly reset on project loads or during batch encoding.
- Added Menu Segments to Segment Editor so they can be blanked or slideshow adjusted. Be careful, as disabling a menu background can sometimes make the function of the menu impossible to understand. Menu segments are listed as "VTM_nn" in the editor.
- Updated the installer to include HC Version 0.17.
In der Update.zip ist eine Rebuilder.ini drin, die ich nicht verwenden würde, falls man eine eigene angepasste hat, da die logischerweise überschrieben wird.
Nachtrag: Auf meine Intervention und weil sich ein engl. User bereits seine original ini zerschossen hatte, hat jdobbs die ini wieder aus dem Paket rausgenommen, also nicht wundern.
Cu Rippraff
DVD-RB 1.07.1 Pro ist raus!
ZitatAlles anzeigen
The following changes were made for this update:- IMPORTANT BUG FIX: Corrected an error in the Menu Encoding module in which some menus may be encoded without audio.
- IMPORTANT BUG FIX: Corrected an error in which the encoding process can "hang" while doing an ILVU segment.
- Modified OPV maximum bitrate calculation during the prediction phase in order to prevent possible "OPV VBV ovf" errors.
- Updated the Installer to use a version of ECLPRO that supports multiple instances.
- Corrected iDCT "64-Bit SSE2MMX" to "32-Bit SSE2MMX"
- Fixed an error in which he HalfD1 checkmark was not properly resetting upon new source load.
DVD-RB 1.07.2 ist raus.
Zitat von jdobbs- Fixed a bug that could cause subpictures that are selected for removal to be also incorrectly removed from Menus. This could make the menu selections fail to function.
- Corrected an error in which on rare occasions the output BUP file be incorrectly updated during a certain type of menu encode sequence.
- Corrected some bugs associated with menu encoding and Half-D1/Anamorphic conversion. Also disabled filters for menu encodes.
Cu Rippraff
DVD-RB 1.08.1 ist raus.
ZitatAlles anzeigen
- NEW FEATURE: Added automatic detection and extraction
of segments that don't need reencoding. This makes it
it possible, e.g., for "Steal Space from Extras",
"Half-D1/Half Space", Menu Encoding, or possibly even
simple removal of a large audio track to allow the main
feature's video to be kept completely intact. Included
a "Force Reencode" selection under the "Options" menu
which will override this feature when you wish filters
to be applied.
- Added a "Force No Reencoding" to the Video Segment
Editor/Viewer.
- Added a selection under the "Settings" menu that
allows you to choose to size for DVD-5 (single
layer) or for DVD-9 (dual layer) output.
- Added an option under the "Settings" menu that allows
you to set the process priority of the encoder to
NORMAL or IDLE (low) priority. This can be useful for
times when you are using your computer for other
purposes while encoding.
- Corrected registration bug introduced in v1.08.
- Several bug fixes are also included. Please read the
REBUILDER.TXT file included in the download for more
details.
DVD-RB 1.09 Pro ist raus.
Zitat von jdobbsAlles anzeigenMarch 18th, 2006 (v1.09)
CHANGES MADE TO PRO VERSION- NEW FEATURE: Support for closed captions. Now DVD-RB will extract closed caption data from the original DVD and remultiplex it into the MPEG stream during REBUILD. Note that, although this new code has been tested, it is new and therefore should be considered beta for this version. For that reason it can only be enabled by adding the "hidden" setting "CLOSED_CAPTIONS=1" to the [Options] area of the REBUILDER.INI file. WARNING: Many software players do NOT play CC correctly. Please do not post bug reports unless you first also try to play the original disc with the software player (e.g. PowerDVD 6.0 seems to have problems with certain CC).
- ENHANCEMENT: Added code to enhance the functioning of automatic "no reencoding" feature introduced in v1.08. Now any space reallocated due to "Steal Space" or the "Half/Half" functions that is not needed to enable the
"no reencoding" extraction is returned to the Extras. This allows you to "overkill" in order to force extraction -- but the amount of actual reduction will only be what is truly necessary.- Fixed an error in which specific circumstances could cause highlights in a menu to not display when the rebuild of the menu cell immediately follows another cell that uses the same VOBID/CELLID combination.
- Corrected a bug in which, under unusual circumstances, a one byte difference can occur between matching BUP and IFO files.
- Fixed an error that could occur very rarely and cause a report of error: "00032 00009 -- error reading IFO".
- Fixed a bug in which restarting the ENCODE phase following a previous completion was not reseting the progress flag, causing problems in future pauses.
- Corrected some inconsistencies with the way menus are handled in the Segment Viewer/Editor.
- Fixed a problem in which selecting "Movie and Menus" could very rarely blank a menu that is a part of a VTS other than the one containing the feature.
- Added a "Close at REBUILD Completion" option to the Mode menu and a "Close at Batch Completion" option to the file menu. These will close DVD-RB -- but will not shutdown the computer.
- Updated the ECLPRO version to v1.00RC1. This version has been reported to correct the "presets" issue seen by some users when using the "Multiple Encoder" option with ProCoder.
Cu Rippraff
ähm wo isn mein post hin - hatte das doch schon geschrieben mit der 1.09 ...
Edit by Rippraff: oh vergessen, das noch zu schreiben, das war ich => PN
DVD Rebuilder 0.97 free ist raus.
uses up-to-date versions of supporting software (HC 0.17, EclPro 0.52, ReJig 0.5f), should be faster when ReJig is used and it fixes a number of bugs.
:nein: Hier mal das komplette Changelog der RB Free 0.97.
Zitat von jdobbsAlles anzeigen- Fixed an error that, under certain circumstances, might cause video ticks or stutter at chapter or segment break points.
- Updated the Installer to use a newer version of HC Encoder (v0.17). This file is also included in the "Update Only" zip file.
- Updated the installation package to install ReJig v0.5f. This version includes several updates that give quality improvements that were implemented by DragonGodz.
- Corrected a problem in which the calculated bitrate may exceed the original and as a result make the stream incompatible with the audio on some sources. This would have shown itself as "stutter" during playback.
- Corrected an error in the REBUILD module that could misinterpret certain input streams and as a result, throw a "ERROR 006: DVD-RB...framecount differences" error.
Das ganze gibt es als empfohlene Installer-Version oder auch als Update only (falls man schon mit der 0.96 arbeitet).
Cu Rippraff
1.09.2
ZitatAlles anzeigen
March 27th, 2006 (v1.09.2)
- Fixed an error in the closed captions code that could
corrupt the MPEG stream causing blocky video playback.
Please note that the closed captioning code should
still be considered "beta" and should only be enabled
by those wishing to test and verify its integrity.
- Fixed a bug in which closed captions were not being
enabled in the IFO file for movie-only encodes.
- Fixed a problem that could make Closed Captions play
haphazardly when used against a telecined source.
- Corrected an error in which Closed Caption data was
being incorrectly inserted for "No Compression" and
ReJig modes.
- Corrected a problem in which an IFO that has no PGCs
defined could cause DVD-RB to stop with an error
message ("0032 0009").
- Corrected the syntax of the status output when setting
for DVD-9. The log incorrectly says "DVD-5".
April 30th, 2006 (v1.09.3)
ZitatAlles anzeigenBelow is a summary of the changes/updates associated with this version (Pro release):
- Added direct support for AutoQMatEnc. Please note that DVD-RB only enables support when it can determine the application path. It will assume the default path "c:\program files\autoqmatenc\autoqmatenc.exe" unless overridden via registry entry. AutoQMatEnc can be downloaded from http://www.autoqmatenc.com. [Added note:] The path can also be entered in the "[Paths]" section of the INI file. Using "AUTOQMATENC="
- Updated the installation package to include the latest HC Encoder version (v.18).
- Fixed a bug in which cells that contain no video data might result in "VOB/CELL not found" during rebuild.
- Fixed an error in which ILVU video segments that are extracted (because the disc will fit) can become corrupt and cause strange playback behavior.
- Corrected an error in which "garbage" data following null or padding sectors could result in unpredictable timing and/or desynchronization.
- Fixed "Error 53" that could occur when no M2V file was created during the ENCODE phase after three tries. The error was typically caused by an incorrect encoder path and should have issued a more informative "Failed to Create an M2V" file and exited gracefully.
- Corrected sizing calculations on discs containing null or padding sectors (usually inserted by a decrypter) to help prevent possible (slight) undersizing.
- Added code to reduce the likelihood of "Error #0006" on streams that contain embedded MPEG garbage. Also, as investigation showed that these only happen in "orphaned" MPEG sections (following "null sectors" created by a decrypter) that are never actually decoded, the error message has been removed and replaced by a warning in the STATUS window/log.
- Added code to remove DVD-RB from a minimized state just before executing a shutdown sequence. There are reports that the shutdown dialog "freezes" with the "5 seconds" text showing when attempted while minimized.
- Implemented a change that can reduce the likelihood of "Error #0003, buffer overflow" on oddly formatted source streams.
- Fixed an error in which it is feasible (but rare) that logging of a start code at the very end of a VTS might be missed during PREPARE.
- Corrected an error in CC processing that could cause an error "0068 0005" when a new GOP with CC data starts at the very end of a video packet.
- Made several process improvements to the handling of sequence_end_codes and associated end actions.
- As closed captioning support appears to be stable, it has been removed from "beta" status and can now be enabled/disabled from the "Settings" menu.
- Added code to avoid confusion by disabling menu selection of encoders for which no path is present in the setup.
Version 1.10 PRO ist raus
ZitatAlles anzeigen
July 1st, 2006 (v1.10)
CHANGES MADE TO PRO VERSION- Newly updated and improved Segment Editor/Viewer. You can now adjust reduction percentages using a slider. The new viewer also improves the viewability and ease of use for editing and makes several other future features possible. Note that the editor is BETA. It is meant to be tested (only) in this version. For that reason you must manually select "Use Beta (test) Viewer/Editor" under the "Settings" menu to enable it.
- Corrected an error in menu reencoding in which some STILL menus might show momentarily (on certain specific players) and then exit.
- Changed defaults in the Viewer/Editor so that "Show Extras Only" is no longer the default.
- Fixed a bug in which extraction of ILVU sections when a source requires no encoding might receive "corrupt" source warnings and report other unpredictable errors.
- Corrected an error in which the AutoQMatEnc version many not be collected when the path is obtained from the INI file.
- Removed the "Special Error Processing" option. It no longer serves a purpose.
- Corrected an error in which some small VTSs may not be blanked or stilled when selecting "Movie and Menu Only" or "Movie, Menus, and Slideshow Extras".
- Fixed a bug in which the value set into vobu_se_e_ptm could be incorrectly calculated and might possibly result in odd menu behavior on some players.
- Corrected a bug in which the number of passes selection in the AutoQMatEnc advanced screen was disabled when CCE Basic was checked.
- Improved the method for inserting NAVPACKs related to STILL processing.
- Added a horizontal scroll bar to filter editor so long filters are kept on one line during editing.
- Added code to prevent a very rare cell transition timing anomaly that can occur when the source contains an irregularity.
- Updated QuEnc version included in the installer to v0.70
- Other minor bug and cosmetic fixes.
War noch ein Bug drin => 1.10.1 PRO ist raus
Zitat von jdobbsAlles anzeigen- Corrected an error in which clicking on the MENUS option when no menus were being reencoded could cause a "Runtime Error 13". (v1.10.1)
The fully installable version (preferred) of this version can be downloaded at this link.
A zip file that contains only the updates since the last version (but is not installable) can be downloaded at this link.
Note to all:
Download only if you are a DVD-RB registered VIP user. These versions will only work on your computer if you are a registered DVD-RB Professional Edition VIP user..
Cu Rippraff
Der neue Editor ist offensichtlich noch beta... 1.10.2 Pro ist raus
Zitat von jdobbsHISTORY:
July 3rd, 2006 (v1.10.2)CHANGES MADE TO PRO VERSION
- Fixed a problem with the new editor in which automatic blanking and slideshow that is executed when "Movie and Menus" or "Move, Menus, and Slideshow Extras" was not reallocating saved space to the feature. This only happened when "Use Beta (test) Viewer/Editor" was selected.
Extreme undersizing of output could occur.- Corrected a bug introduced in v1.10 that was related to the new Viewer/Editor. This bug could result in "Corrupt stream" message when using one of the "Movie and Menus" or "Move, Menus, and Slideshow Extras" modes was selected. It could also cause these modes to fail.
Cu Rippraff
