Info:
VobBlanker is a tool to blank/remove VTS video titles(like dvd extras), Replace titles with an external one, Strip audio tracks, IFO tables adjusting, including "the famous" TMAPTI, Works per VTS: can process a single VTS, some VTS or the complete DVD.
Changelog:
Vers 1.2.0.2 (23-05-2004)
- Added: Load/Save project
- Minor changes in File Open/Save and BrwoseForFolder Dlgs.
- Cutting titles: Now you can discard the selection and keep the rest.
- New Blank Cells: VobBlanker generates now a diferent Cell per resolution
(4 PAL cells and 4 NTSC cells)
- Video attributes management:
1.- VobBlanker allows now to change IFO video attributes
2.- VobBlanker detects mismatches between replacing and
replaced titles video attribues
3.- Blank cells are hacked with the correct DAR
Known issue: Preview (DVD2AVI) is managed using Windows SendMessage. If some messages are sent in a short time (when selecting the cell) Preview not always process them correctly. For this reason, Preview has not its buttons hidden which was initialy my intention.
Vers 1.1.0.1 (12-05-2004)
- Preview: Finally!! using DVD2AVIdg110 "as it is".
- Cutting titles ability: You can select a start and an end point per PGC
- Popup menus in lists (mouse right click).
Vers 1.0.0.10 (26-04-2004)
- Bug Fix: VTS sector pointer 0xC0 was not 0 if Menu does not exist. Introduced in 1.0.0.9.
Vers 1.0.0.9 (22-04-2004)
- Bug Fix: Only one message when replacing title with more cells than the original
- Bug Fix: bug in V/C ids when replacing title with less cells than the original
- Bug Fix: VTS sector pointer 0xC0 was 0 if Menu lenght=0.
- Improvement: Dialog now can be resized.
Vers 1.0.0.8 (28-03-2004)
- Bug Fix: Shows PGCs instead of Titles
Vers 1.0.0.7 (24-03-2004)
- Bug Fix: Crash if VTSM_PGCI_TU does not exist
Vers 1.0.0.6 (22-03-2004)
- Audio Strip capabilities
- Global progress bar
- Some coding for preview pane, but still not done
Vers 1.0.0.4 (10-03-2004)
- Logging disabled (enabled if argc >1)
- Total size (initial & Final) Boxes
Vers 1.0.0.3 (08-04-2004)
- NTSC fps bug. (always 25 fps).
- Change in columns width
- New column, showing the number of title's angles.
- Two different PUOPs checks, one for *.VOB (Menus and titles)
and other one for IFOs (Menus and Titles PGCs)
- PUOPs in Menu-PGCs are now removed (if checked).
Vers 1.0.0.2 (06-02-2004)
- First beta
Download:
http://www.posunplugged.com/jsoto oder http://www.iespana.es/jsoto
Diskussion:
forum.doom9.org
VobBlanker
Version 1.4.0.1 ist draussen...
http://www.posunplugged.com/jsotoZitat[font=verdana, arial, helvetica] Here is the changelog
Vers 1.4.0.1 (22-08-2004)
Added: Help file included. My English is not very good, but I hope it is enough to be understood.
Added: New option of processing a PGC using a Cell based selection. Each cell can be individually blanked, keep or replaced by a new one.
Added: Change post into precommands, following 2COOL's guide. Solid and Conditional Breaks in precommand area are converted into goto commands.
Added: Adjust navigational pointers and audio/video pointers inside VOBs. No more IFOEdit mock strip is needed (I hope)
Added: Warning in the case of Multiangle or ILV Cells when open VIDEO_TS.IFO. VTSs are now marked as SKIP
Added: Logs steps when processing IFOs
Added: Warning if cutting in a not closed GOP.
Added: Deactivating audio in IFO when stripping.
Changed: TMAPTI calculation loop has been improved (mainly in performance)
BugFix: CLI mode was always activating the creation of debug log files.
BugFix: A lot of bugs in Audio Attrib/Strip dlgs
-Size of audio tracks in Attrib dlg were wrong
-Size of audio tracks in the case of reused cells were wrong
-Active streams in each title
-Many more...
BugFix: Discontinuity in TMAPTI table was not correctly filled.
BugFix: Duration of last VOBU in a Cell was not added when calculating the Cell duration. This error was cummulated in PGC duration. In any case I believe it does not affect...
BugFix: Popup menu in Cells Dlg (extract cell) didn't work.
BugFix: Size calculations (and progress bar) now take into account menus processing setting
BugFix: Size calculations are now based on ADT table instead of PGC. This should fix the size estimation errors in the case of ILV cells.
BugFix: Preview/cut in an ILV cell.
BugFix: Cell elapsed time in VOBs correction when cuting titles (both cases)
BugFix: TMAPTI was not correctly filled when cutting titles.
BugFix: Cut titles feature had been completely broken in 1.3.0.3
BugFix: Crash when processing VIDEO_TS.IFO if VMGM_PGCI_UT=0 (like in simple & no-menu DVDs, i.e. created with dvdauthor or dvdshrink)[/font]
