PgcEdit - Aktuelle Version
  • 0.6.1beta10 (September 12, 2005)
    E. Create New Cell: When a new VOB file is created, if the PAL/NTSC standard don't match the standard of the titleset's title domain, the user is prompted to change the standard.
    E. Erzeugen einer neuen Cell: Wenn eine neue VOB Datei geschaffen wird und es nicht des PAL/NTSC Standard{Norm} des Titleset entspricht, wird der Benutzer aufgefordert, den Standard{Norm} zu ändern.
  • Update:
    PgcEdit 0.6.1 Beta11
    Changelog:
    A. = Added feature
    R. = Removed
    E. = Enhancement
    F. = Fixed bug
    0.6.1beta11 (September 17, 2005)
    A. New function "File -> Replace VTST Titles" to replace the current VTST domain by an imported one. Can be used to replace a VTST domain after a reencoding or a shrink of a title with DVDShrink in reauthor mode.
    E. The GUI of the Remap Title Numbers function has been enhanced.
    E. Renamed the preview option "Start Preview automatically when playing a cell?" to "Open Preview automatically when playing a cell?".
    F. Trace mode: In "Next PB" mode, the playback stopped when entering the post commands of a dummy PGC. Now, the playback stops only if there is a pre/ post breakpoint on the dummy PGC.
    Oh ha! Hiermit ist ja eine sehr interessante und nützlich Funktion hinzugekommen. Für mich zumind. absolut wertvoll.
  • Update:
     PgcEdit 0.6.1 Beta12
    Changelog:
    A. = Added feature
    R. = Removed
    E. = Enhancement
    F. = Fixed bug
    E. New option in the "Replace VTST Titles" function to keep everything from
    the original PGC, except the stuff directly related to the VOBs.
    F. It was possible to crash the BOVs menu viewer/editor if the scan for BOVs
    of the current titleset was interrupted.
  • PgcEdit 0.6.1 final ist raus! :)
    Gibt's hier.
    Cu Rippraff
    Blumige Grüße, Rippraff
  • PgcEdit 0.6.2 beta1 ist raus.
    Gibt's hier.
    Cu Rippraff
  • PgcEdit 0.6.2 final ist raus. :)
    Zitat von r0lZ
    • E. PGC Editor's cells flags: The Access Restricted and the VOBU Still flags are now availables in the Cells Type Flags editor, rather than directly in the cells list. Previously, only the VOBU Still was available. The Type Flags button contains now two values, one for each byte. Also, some of the flags labels have been changed to reflect more closely the official terminology.
    • E. PGC Editor: Added tooltips on the cell command number fields to display the current cell command. The cell commands numbers higher than the number of cell commands currently defined are now highlighted in pink. Similarily, the Prev/Next/GoUpPGCN link values are highlighted in pink if the target PGC doesn't exist.
    • E. Enable All Operations now prompts the user if he wants to remove also the Access Restricted flags on the cells of the current PGC, when this flag is set on some cells. Warning: the Access Restricted flag is especially used by the Sony ARccOS protection. In this case, it should not be removed.
    • E. Changed the listbox/entry default color to use the Windows default. Added Option -> User Interface -> White Listbox Background also under Windows and Mac OSX.
    • E. Burn DVD: a new selector button has been added to select the DL media type from the main dialog. The Sectors in L0 value in the Burn Setup window is now ignored when burning a DL+R.
    • E. Since ImgBurn is now stable and doesn't require the layer break sector number in his settings anymore, the dialog asking if the user wants to copy the layer break value in the clipboard has been removed when ImgBurn is used, and when a DL DVD-R is used.
    • E. Burn DVD: when the log is displayed, the Save button uses now by default the same filename as the ISO, but with a _log.txt extension.
    • A. A new menu "Options -> Install -> Install a plugin" has been added to help the novice user to install a PgcEdit plugin.
    • E/F. The standalone version of PgcEdit now uses freeWrap version 6.1. This solves the problem of the mouse double-clicks being passed through the file open/save or folder selection dialogs to the underlying window.
    • F. The Kill PGC playback function now appends a LinkPGCN command at the end of the pre-commands when the NextPGC link is non-zero and doesn't point to itself. Without this command, the PGC was sometimes played.
    • F. Fixed the bug in Remove Cells function of the PGC Editor that caused the function to silently fail in some occasions.
    • F. The Prohibited User Operations window was sometimes pushed below the main window when the Input Value button was used.
    • F. Import Title Closing Clip crashed if the current PGC was a PGC without a Title number.
    • F. Fixed a problem on some Windows systems where the web browser executable was wrongly considered as not executable by TCL/TK.
    • F. Burn DVD: Workaround for a problem with mkisofs on some systems: Mkisofs reports sometimes an "Invalid node - -m" error when the backup folders are not deleted. Now, when this error occur, a dialog pops-up, asking if you want to delete the backups, continue w/o deleting the backups, or cancel.
    Gibt's hier.
    Cu Rippraff
  • PgcEdit 0.6.3beta2 ist raus (beta1 hatte einen Bug und wurde gleich wieder gefixt).
    Gibt's hier.
    Cu Rippraff
  • PgcEdit 0.6.3beta3 ist raus mit einem weiteren Fix:
    F. Workaround for the pskill.exe problem with McAfee antivirus. It is now encrypted in the standalone executable, so that McAfee doesn't complain. McAfee may still complain when the real file is copied in the bin folder.
    Cu Rippraff
  • PgcEdit 0.6.3beta4 ist raus mit einem weiteren Fix:
    F. Kill PGC Playback: The Set, SetCLnk, CSetCLnk or CSetLNK command with a Link to a cell, program or chapter were not trapped. Now, a dialog pops up to warn the user.
    Cu Rippraff
  • PgcEdit 0.6.3beta5 ist raus mit folgenden Änderungen:
    0.6.3beta5 (December 17, 2005) <= wohl eher 09.01.06 ;)
    A. It is now possible to bypass a menu with buttons with Kill Playback. The user is prompted to select the button to simulate.
    A. Pgc EDitor -> Create new blank cell and VOB/Cell ID remapping: Added an option to reuse the last tiny blank cell at the end of the VOB file (only when that cell has been created previously by PgcEdit.)
    A. Pgc EDitor -> Create new blank cell: New interface. It is now possible to insert the cell at the beginning of the PGC.
    E. When importing titles in a DVD with parental managment, the user is now prompted to remove the parental managment of the original DVD, and when importing a menu, it is prompted to clear the parental managment IDs of the menu PGCs, if there are IDs in the menu.
    Gibt's hier.
    Cu Rippraff
  • PgcEdit 0.6.3beta6 ist raus.
    Zitat von r0lZ
    0.6.3beta6 (January 24, 2005)
    Gibt's hier.
    Cu Rippraff
  • Update:
    PgcEdit 0.6.3 Final
    Ich habe anhand der Changelog keine Änderungen zur letzten Beta festgestellt. Wer das trotzdem kurz nachlesen möchte,
    findet die letzten Changelogs wie üblich im 1. Post des Threads.
  • Es hatte sich noch ein alter Bug erneut eingeschlichen, der mit 0.6.3.1 gleich wieder gefixt wurde.
    Zitat von r0lZ
    0.6.3.1 (January 29, 2005)
    F. Burn DVD: If the user cancels the layer break selection dialog, the dialog is closed, but the OK and Cancel button of the main burn dialog are still disabled. There is no way to close this dialog, and the user must kill PgcEdit. This problem has been introduced in v0.6.3, and is now fixed.
    Gibt's hier.
    Cu Rippraff
  • 0.6.4beta1 ist raus.
    Zitat von r0lZ
    0.6.4beta1 (February 7, 2005)
    A. Menu Editor: New function "Edit -> Copy button position only" to copy the current button position. Paste it with "Paste Current Button".
    A. Menu Editor: New functions "Button -> Increase / Decrease Button Number" to move the current button in the list of buttons.
    F. PGC Editor - Create New Cell: Disabling the option to create the backup of the VOB file did not work.
    F. The "New 'Play All' PGC" function was broken. Also, there is now a check to warn the user if the number of programs in the new PGC is greater than 127 or the number of chapters greater than 99.
    Gibt's hier.
    Cu Rippraff
  • Update:
    PgcEdit 0.6.4 Beta 3
    CHANGELOG
    0.6.4beta3 (February 12, 2005)
    E. Calls Cross Reference: A menu that is normally callable with a remote
    button (menu type = RootM, SubpicM, AudioM, AngleM or ChapterM) is now
    considered as unreferenced if all titles of the same VTS are unreferenced.
    F. The target of some Jump_VTS_TT and Jump_VTS_PTT was not found by the find
    target routine. This caused some bugs in the Go to calling command, Calls
    cross references, Find jumps to nowhere, Jump to target and Highlight
    target functions.
  • Update:
    PgcEdit 0.6.4 Beta 5
    CHANGELOG
    0.6.4beta5 (February 26, 2005)
    A. Added a preview checkbox in the upper left corner of the main window.
    When ticked, selecting a PGC manually starts the preview automatically.
  • Die 2. und 3. Beta am selben Tag...
    PgcEdit 0.6.4 Beta 6
    CHANGELOG
    0.6.4beta6 (February 26, 2005)
    E. Read DVD: Added a check for illegal entries in VMG_TT_SRPT table (Title
    assigned to a non existing PGC or 2 Titles assigned to the same PGC.) If
    the bad Title is the last one in the table, it is optionally removed,
    but the user must still fix the VM commands, if needed.
    F. Small bug in the Jump To PGC Upon DVD Insert function, introduced in 0.6.3
    fixed: the resume cell of the CallSS command inserted in the beginning of
    the pre-commands of the resume title was wrong.
    Update:
    PgcEdit 0.6.4 Beta 7
    CHANGELOG
    0.6.4beta7 (February 26, 2005)
    A. New function Info -> Jumps from VMG to Current VTS to find out the global
    references to the current VTS. (This function doesn't show the references
    from the current VTS to itself.) Useful to verify if the last VTS is still
    referenced and to reroute the references before removing it.
