Logfile from 4. September 2004, for DVD: testfilm
+---Ripping
| \---DVD Decrypter 3.2.3.0
| +---Mode
| | IFO
| \---Stream Procesing
| \---Enable Stream Processing
| Demux 0xE0 Video: MPEG-2 / 720x480 (NTSC) / 4:3 -> Filesize = 3.907.014 KB
| Demux 0x80 Audio: AC3 / 2Ch / 48kHz / 192kbps / DRC / English / DELAY = 0ms -> Filesize = 168.402 KB ~ 4.100.000 KB
\---Video
+---Indexing
| \---DGIndex 1.0.12
| +---Video
| | +---iDCT Algorithm
| | | 64-bit Floating Point
| | +---Field Operation
| | | None
| | \---YUV->RGB
| | PC-Scale
| \---File
| Preview [F5] -> Aspect Ratio = 4:3 / Frame Rate = 29.970 fps / Video Type = NTSC / Frame Type = Interlaced (artifacts in preview) / Info = T (Top Field First)
+---Cropping & Resizing
| \---GordianKnot 0.28.8
| Movie length = 215161 frames @ 29.970 fps = 01:59:39.213
| Videobitrate for 1 CD @ 716800 KB = 734 kbps (1 audiostram @ 64630 KB, Calculate Frame-Overhead=false, 1x VBR MP3)
| Film-pixel = 688x468 Pixels -> Crop(Left=18,Top=6,Right=14,Bottom=6)
| Desired resolution = 416x304 Pixels
| Crop for lowest Aspect Error = 688x458 Pixels -> Crop(Left=18,Top=10,Right=14,Bottom=12)
| Aspect Error = 0.0% (follow ITU-R BT.601 Standard)
| Average Bits / Pixel in a Frame = 0.194 -> 5% Compressibility Check w. following Codec Settings -> Second Pass Compared to Compressibility-Test = 81.2% of 0.238 Average Bits / (Pixel * Frame) in the Comressibility-Test
+---Frameserving
| \---AviSynth 2.55 (final 2004-08-31)
| \---Script
| LoadPlugin("DGDecode.dll") # Version 1.0.12
| LoadPlugin("TomsMoComp.dll") # tomsmocomp_25_dll_20030629
| MPEG2Source("DGIndex.d2v",iPP=true)
| TomsMoComp(-1,5,0)
| Crop(18,10,688,458)
| BicubicResize(416,304,0,0.5)
+---Writing Application
| \---VirtualDubMod 1.5.10.1 build 2439
| \---VIDEO
| | Fast Recompress
| \---Compression
| XviD MPEG-4 Codec
\---Encoder
\---XviD MPEG-4 Codec - Koepi's binaries (1.0.1-05062004 Final Release)
+---Profile @ Level
| \---AS @ L5 -> more
| +---Profile
| | +---Profile @ Level
| | | AS @ L5
| | +---Quantization type
| | | MPEG
| | +---Adaptive Quantization
| | | (x)
| | +---Interlaced Encoding
| | +---Quarter Pixel
| | | (x)
| | +---Global Motion Compensation
| | | (x)
| | \---B-VOPs
| | \---(x)
| | +---Max consecutive BVOPs
| | | 2
| | +---Quantizer ratio
| | | 1.50
| | +---Quantizer offset
| | | 1.00
| | +---Packed bitstream
| | \---Closed GOV
| \---Aspect Ratio
| \---Pixel Aspect Ratio
| Square (default)
+---Encoding type
| \---Twopass - 1st pass -> more
| +---Stats filename
| | testfilm.pass
| +---Full quality first pass
| \---Discard first pass
| (x)
+---Encoding type
| \---Twopass - 2nd pass -> more
| +---Stats filename
| | testfilm.pass
| +---intra-frames tuning
| | +---I-frame boost
| | | 0
| | +---I-frames closer than...(frames)
| | | 1
| | \---...are reduced by (%)
| | 0
| +---Overflow treatment
| | +---Overflow control strength
| | | 0
| | +---Max overflow improvement (%)
| | | 1
| | \---Max overflow degradation (%)
| | 1
| \---Curve compression
| +---High bitrate scenes degradation (%)
| | 0
| \---Low bitrate scenes improvement (%)
| 0
+---Target size (kbytes)
| 654211 (-> XviDs Bitrate Calculator)
+---Zones
| \---Start frame #
| | 0
| +---Rate control
| | \---Weight
| | 1.00
| \---Static
| +---Begin with keyframe
| | (x)
| +---Greyscale encoding
| +---Chroma optimizer enabled
| | (x)
| \---BVOP sensitivity
| 0
\---Advanced Options...
+---Motion
| +---Motion Precision
| | +---Motion search precision
| | | 6 - Ultra High
| | +---VHQ mode
| | | 4 - Wide Search
| | +---Use chroma motion
| | | (x)
| | \---Turbo ;-)
| \---Other
| +---Frame drop ratio
| | 0
| +---Maximum I-frame interval
| | 300
| \---Cartoon Mode
+---Quantization
| +---Quantizer restrictions
| | +---Min I-frame quantizer
| | | 1
| | +---Max I-frame quantizer
| | | 31
| | +---Min P-frame quantizer
| | | 1
| | +---Max P-frame quantizer
| | | 31
| | +---Min B-frame quantizer
| | | 1
| | \---Max B-frame quantizer
| | 31
| \---Trellis quantization
| (x)
\---Debug
+---Performance optimazions
| Automatically detect optimazions
+---FourCC used
| XVID
+---OutputDebugString debug level
| 0x0
\---Print debug info on each frame
Alles anzeigen
- Die Quelle hat sowohl wenn ich sie direkt, als auch wenn ich sie via AviSynth über DGIndex in VirtualDubMod lade, 215161 Frames (=1:59:39.213). Nach der Codierung enthält das resultierende AVI nur 215160 Frames (1:59:39.179).
Warum? - Frame 0 der Quelle ist lt. Vorschau von VirtualDub Frame 1 des Ziels usw. Normales B-Frame Decoder Lag, oder muß ich gar anfangen die Audiospur anzugleichen?
