habe ein Problem mit ReAuthorist und BatchCCEWS.
ich hab ne film mit ca. 2 h stunden laufzeit und einer VTS / PGC aber reAuthorist zeigt 10 sekunden an und daher ne Bitrate > 19000.
und in BatchCCEWS steht ne durchschnittsbitrate von 500 und max 7610.
sind die 500 nicht viel zu wenig ?
Hier das log:
(22:07:43) --------------------------------------------------------------------------------
(22:07:43) | DoItFiggity4Yiggity! v.1.4.7.0 - By Eyes`Only |
(22:07:43) Begin Log File
(22:07:43) Welcome to DoItFast4U! v.1.4.7.0 - By Eyes`Only
(22:07:43) | AVS and OS Detection |
(22:07:43) Avisynth Version Detected= 2.5.4.0
(22:07:43) Checking AVS Scripts...
(22:07:43) OS Kernel = NT (good!)
(22:07:43) Checking for CDROM/DVDROMS... Found Drives= F: G:
(22:07:43) Non-Right-click activation. Using last working directory: D:\DIF4Uoutput
(22:07:43) (If you don't know what this means, READ THE GUIDE!)
(22:07:43) | Begin Analyzing DVD |
(22:07:43) | Analyzing IFO Structure |
(22:07:43) Checking for Angles in VTS 01...
(22:07:43) VTS 1 PGC 1 Minutes= 0
(22:07:43) | Determine Disc Label |
(22:07:43) DVD Label = "DVD_1"
(22:07:43) | Check For Web Update |
(22:07:43) Checking for updates...
(22:07:43) Updates Check Skipped ( Help->Check For Updates to turn this on )
(22:07:43) | Check Directories |
(22:07:43) Install Directory = C:\Programme\DoItFast4U
(22:07:43) Current Directory = C:\
(22:07:43) Zeroing out Memory at: mseodqfr5Cpxqgr0u1frp
(22:07:43) Checking For Duplicate VobIDs...
(22:07:43) | Check For Duplicate VobIDs |
(22:07:43) No Duplicate VobIDs Found.
(22:07:43) | Find Main Movie |
(22:07:43) Automatically selected 1 as largest VTS.
(22:09:39) --------------------------------------------------------------------------------
(22:09:39) | Beginning Demux! |
(22:09:39) | Performing Pretests |
(22:09:39) | Delete Directory |
(22:09:39) | Next VTS |
(22:09:39) Current Dir= d:\DIF4Uoutput
(22:09:39) DVD Drive= G:
(22:09:39) | Add VTS Number to Directory |
(22:09:39) Autocreating Directory: d:\DIF4Uoutput\VTS01
(22:09:39) | Start DVD Decrypter |
(22:09:39) DVDDEC Version 3.2.1.0 Location= C:\Programme\GordianKnot
(22:09:39) Compatible version of DVDDec [3.1.8.0+] detected (3.2.1.0)
(22:09:39) Split Mode= auto VobID_Demux=0 CellID_Demux=0
(22:09:39) Using DVD Decrypter to Demux VTS 01 PGC 01 ANGLE 01
(22:20:33) Finished Using DVD Decrypter for VTS 01 PGC 01 ANGLE 01
(22:20:33) --------------------------------------------------------------------------------
(22:20:33) | Process M2V |
(22:20:33) Analyzing Video...
(22:20:44) Total Odd / Even = 1002 / 0 = Odd/Top/A dominant and 0.00% progressive
(22:20:44) Flag found at position 174
(22:20:44) Diagnose Field Order = 1
(22:20:44) Analyzing Video... Header Flag= "Interlaced/TFF" Analysis= "Interlaced/TFF"
(22:20:44) File to rename= VTS_01_PGC_01_1 - 0xE0 - Video - MPEG-2 - 720x576 (PAL) - 16~9 - Letterboxed.M2V
(22:20:44) vid= 0, pgc= 01, ang= 1, vob= _0, cel= 01_ darloc= 16~9
(22:20:44) Rename to= VTS__01_P01.I-TFF.16~9_1.M2V
(22:20:44) VTS_01_PGC_01_1.VOB found and MoveFileEx successful
(22:20:44) --------------------------------------------------------------------------------
(22:20:44) | Rip Subs from DVD |
(22:20:44) Substreams = 0 1
(22:20:44) renerr= 183 vobid= 0 sub= 1 y= 1
(22:20:50) Vobsubbing PGC 1 Angle 1
(22:20:50) --------------------------------------------------------------------------------
(22:20:50) | Process Ripped Subs |
(22:20:50) Starting sub processing
(22:20:50) VTS_01_VSUB_P1A1.sub
(22:20:50) Processing Substream 0 in VTS_01_VSUB_P1A1 (please wait... 21% done)
(22:21:04) Deleting VTS_01_VSUB_P1A1-00-Deutsch.forced.sst (empty .sst)
(22:21:04) Processing Substream 1 in VTS_01_VSUB_P1A1 (please wait... 23% done)
(22:21:17) Deleting VTS_01_VSUB_P1A1-01-Deutsch.forced.sst (empty .sst)
(22:21:17) Sub Processing Complete
(22:21:17) --------------------------------------------------------------------------------
(22:21:17) | Rename DTS Files |
(22:21:17) DTS File to rename= VTS_01_PGC_01_1 - 0x8A - Audio - DTS - 6ch - 48kHz - DRC - Deutsch - DELAY 0ms.DTS
(22:21:17) Renaming DTS...
(22:21:17) | Create DVD2AVI Projects |
(22:21:17) Executing DVD2AVI on VTS__01_P01.I-TFF.16~9_1.M2V
(22:23:38) --------------------------------------------------------------------------------
(22:23:38) | Create Avisynth Files |
(22:23:38) Writing AVS for VTS__01_P01.I-TFF.16~9_1.AVS using Normal Template
(22:23:38) Analyzing AVS
(22:23:38) 240 frames, fps=24.000000, mins=0.166667
(22:23:38) Added 0.166667 minutes to Main Calculations (Total is now 0.166667)
(22:23:38) | Calculate Minutes |
(22:23:38) Total extras minutes= 0.000000
(22:23:38) Total MainVTS minutes= 0.166667
(22:23:38) | Create VIDEO_TS Folder |
(22:23:38) Creating d:\DIF4Uoutput\VIDEO_TS directory using unused VTSes
(22:23:38) -This may take a while!-
(22:23:38) Copied VIDEO_TS.IFO (1 of 6 files) 16% Complete
(22:23:38) Copied VIDEO_TS.BUP (2 of 6 files) 33% Complete
(22:23:51) Copied VIDEO_TS.VOB (3 of 6 files) 50% Complete
(22:23:51) Copied VTS_01_0.BUP (4 of 6 files) 66% Complete
(22:23:51) Copied VTS_01_0.IFO (5 of 6 files) 83% Complete
(22:24:04) Copied VTS_01_0.VOB (6 of 6 files) 100% Complete
(22:24:04) Finished copying unused VTSes
(22:24:04) Extras Assets= 0 bytes, DVDR Size= 4700000000
(22:24:04) Main VTS Assets= 1620232184, Chosen DVDR Size= 4700000000, Video_TS Directory= 320278528 bytes
(22:24:04) --------------------------------------------------------------------------------
(22:24:04) | Create CCEData.txt and Calculate Bitrates |
(22:24:04) Final Bitrate Calculations...
(22:24:04) (Doesn't work with HDD Demux mode, all other modes supported now!)
(22:24:04) CCE Recommended values: MAIN: AvgBitrate= 0
(22:24:04) CCE Recommended values: EXTRA: AvgBitrate= 2000
(22:24:04) (See CCEData.txt for detailed information.)
(22:24:04) -
(22:24:04) Creating REJIGdata.txt file for use with Rejig 0.4b+
(22:09:39) Compatible version of DVDDec [3.1.8.0+] detected (3.2.1.0)Benutze mal die aktuelle Version (3.5.1.0) fürs Demuxen.
Zitat(22:23:38) Writing AVS for VTS__01_P01.I-TFF.16~9_1.AVS using Normal Template
(22:23:38) Added 0.166667 minutes to Main Calculations (Total is now 0.166667)Dein Hauptfilm hat nur 240 frames!
Zitat(22:24:04) Extras Assets= 0 bytes, DVDR Size= 4700000000
(22:24:04) Main VTS Assets= 1620232184, Chosen DVDR Size= 4700000000, Video_TS Directory= 320278528 bytesDein VIDEO_TS Ordner hat schon 3,2 GB, dann bleibt für dein Hauptfilm nur noch 1,6 GB übrig.
Zitat(22:24:04) CCE Recommended values: MAIN: AvgBitrate= 0
(22:24:04) CCE Recommended values: EXTRA: AvgBitrate= 2000Überprüfe mal alle Einstellungen in DoItFast4u und benutze den aktuellen Decribbler. Eventuell Main VTS und Extras ausversehen verdreht ?
die video_ts enthält 320 mb (320.278.528 bytes) nicht 3,2 gb.
es lag am DoItFast4u, mit ner älteren version ging es, nur bei der neuesten gibt es diesen fehler
jetzt ist alles perfekt -
Ja natürlich hast recht.
Man sollte nicht mehr so spät vorm Rechner sitzen.
Könntest eventuell mal probieren und in DIF4U 1.4.7 die Stream Diagnose abschalten.Vielleicht hat er Probleme mit dem Teil. -
Hi, also ich wollte mal fragen ob bei Xerves scho was neues rausgekommen ist, da ich das selbe Prob hab, ich hab auch nur immer 10 Sekunden-Dateien.
Wäre um Hilfe sehr dankbar.
@ (Tobi): Das Abschalten der Stream Diagnose hat bei mir nix gebracht, trotzdem THX!
Greez
nimm ne ältere version.
damit geht es einwandfrei -
von was jetzt genau ne ältere Version? Sorry wenn ich grad n bissi auf dem Schlauch steh.
greez
DoItFast4U!
Ich sage vielen Dank werde das mal testen, greez
