Zitat18/07/2005 [Matroska] Show the first jpeg attachment as video if the file has no video tracks. [General] Eliminated a crash in ffdshow when switching video tracks and/or segments.
Haali Media Splitter
noch eins hinterher:
Zitat18/07/2005 [General] Fixed wrong rgb order in jpeg reader.
31/07/2005 [General] Map wmv3 to WMV3 fourcc in avi, so wm9 video works. Bitrate graph should be more accurate now, and labels are scaled to display dpi. Changed queue sizes so they try to use the entire file buffer.
Zitat02/08/2005 [General] Buffering code rewrite, this should eliminate the occasional problems introduced in recent versions.
update:
Zitat15/08/2005 [MP4] Added support for QT files with 5.1 AAC audio. [Matroska] Improved mode2cd support.
Regelmässige updates so wünschen wir uns das!
Zitat18/08/2005 [General] Fix occasional errors in subtitle switching that appeared in the previous build.
ein paar updates:
Zitat# 04/09/2005 [General] Added an API to get some codec timings, fixed a bug that occasionally happened in graphs without clock (never happens during normal playback).
# 03/09/2005 [General] Fix wmv9 support that was broken in the previours release.
# 31/08/2005 [General] Added limited video size and AR runtime change support for ordered chapters. [AVI] Try to remove garbage from start of mp3 tracks like MS splitter does. -
update:
Zitat18/09/2005 [General] Try to select a default track first if it matches the language preferences.
18/09/2005 [General] SSA font sizes can be scaled in splitter options now, frames are now dropped when fastforwarding so faster speeds are possible. [Matroska] Better handling for some invalid/unsupported Matroska files, zlib upgraded to 1.2.3. -
05/10/2005 I've made quite a lot of changes all around the code, so this build is released separately for those who want to test it: MatroskaSplitterTest. A Matroska muxer is now included in the package. Bug/test reports are appreciated.
11/10/2005 [Matroska] Added a DirectShow Matroska muxer. Fixed a broken audio language priorities setting. Added support for reading some more broken/incomplete matroska files. [MP4] Added support for reading some nonstandard 3ivx files.
23/10/2005 [MP4] Added primitive edit lists support. [Matroska] Improved muxer. [General] Added tracksets. They allow selecting both audio+subs tracks with a single click in the splitter menu. To use them add tags with name TRACKSET and value "video_track_id audio_track_id subs_track_id three_letter_language [optional name]". Track id '.' means don't change track, 'x' means turn off track (valid for subs only). Example:
<Tags>
<Tag>
<Simple>
<Name>TRACKSET</Name>
<String>. 72784144 1640508160 jpn</String>
</Simple>
<Simple>
<String>. 3634403394 x eng</String>
</Simple>
</Tag>
</Tags> -
Zitat von kurt
Zitat:Wie kann man denn den muxer nutzen? Ich finde den unter graphedit nicht. Dort ist nur der splitter und der will ja immer eine quelldatei als input.
ac-chan:
Guck mal das Du die aktuelle Version installiert hast, dann sollteste den Muxer in Graphedit finden. (ist wohl mit in der splitter.ax Datei)
(von dem build davor gab es wohl Versionen mit und ohne den Muxer drinne )Cu Selur
Ok Selur, das war es.
# 25/10/2005 [General] Fixed a serious bug that slipped in yesterday.
# 25/10/2005 [Matroska] Added theora support. -
# 30/10/2005 [General] Fixed yet another glitch in subtitle language priorities.
# 06/11/2005 [General] Added ogg parser.
# 10/11/2005 [AVI] Discard dropped frames in the parser. [OGM] Accept some more weird files.
# 14/11/2005 [General] Fixed creating shortcut in installer, a few other minor improvements.
# 13/11/2005 [General] A lot of internal code restructuring. [Muxer] Added support for packed bitstream input with more than one b-frame. [AVI,OGM,Matroska] Read more tags from files, added an option to display muxer name as a Rating tag. -
