weiter geht's
Zitat von Doom9Alles anzeigen
Version history0.1.9.6, 06/19/2005
new: intro credits (to be encoded at the same quantizer as the end credits) can be configured for all 4 supported codecs
new: graphical zone creator for x264. Creating zones was never easier. Sophisticated logic detecs zone intersections, intersection with intro or end credits and prevents you from starting to encode if your zone setup is in some way incorrect
new: both credits and zones can be used together (credits used to overwrite zones in the last release)
new: opening an avisynth script no longer opens the preview window if this is not desired (can be configured in the settings). In order to still open the preview you can double click on the filename of the scriptchanged: zones are no longer saved in profiles
changed: opening a new avisynth script cancels all configured zones as they are source bound (you certainly want to configure new zones for another source)bugfix: audio encoding status update is working again (was broken in 0.1.9.5)
bugfix: process priority configured in the settings is used
bugfix: auto-encode after queue is taken from the settings (was always done before)
bugfix: more mp4 muxing errors are catched
bugfix: x264 subq was always 1 lower than specified.
