MeGUI Encoding-Frontend: aktuelle Versionen
  • Vers. 0.3.3.1
  • Vers. 0.3.3.2
    0.3.3.2
    - [HDBDStreamExtractor] changed default file input type
    - [InputBox] set initial focus to text box. Feature request #2938589
    - [InputBox] if text box has focus pressing "enter" will call the ok event and "escape" the cancel event
    - [tsMuxeR] fix final m2ts file creating in OneClick. Bug #2936118
  • 0.3.3.3
    - (zathor) [prettyformatting] input and output filename spelling match in oneclick. Feature request #2938926
    - (zathor) [mkvmergemuxer] iso639-2-code will be used for the language during muxing. Bug #2944894
    - (zathor) [vobinputwindow] + [videoutil] disabled "select audio tracks" if dgindex is used and the stream is no program stream. Bug #2941323
  • 0.3.3.4
    - (zathor) [audioencodingtab] "_new" will be appended to the file name if input and output are the same. Bug #2531321
    - (zathor) [muxprovider] + [tsmuxer] added mp4 support to the video input types. Feature request #2945805
  • 0.3.3.7
    0.3.3.7
    - (zathor) [jobcontrol] error handling added. Bug #2279852
    - (zathor) [x264encoder] corrected scenecut handling. Bug #2942446
    - (zathor) [logitem] error handling added. Bug #2947565 + #2925500
  • 0.3.4.2
    - (zathor) [avisynthprofileconfigpanel] if clever anamorphic encoding is enabled the dropdown box will be also enabled
    - (zathor) [avisynthwindow] openning a file also triggers the clever anamorphic encoding event. Bug #2957647
    - (zathor) [updatewindow] set file changed time of extracted files
    - (zathor) [updatewindow] files which need a reboot will also be backuped if selected
    - (zathor) update icsharpcode.sharpziplib.dll
  • Vers. 0.3.4.3
    Einmal editiert, zuletzt von LigH (14. März 2010 um 20:56) aus folgendem Grund: Kosmetik
  • 0.3.4.4
    - (zathor) [mp4boxmuxer] + [commandlinejobprocessor] changed the way the remaining time is estimated. Bug #2124705
    - (zathor) [mainform] updatecopier.exe will only be elevated if necessary
    - (zathor) simplified updatecopier.exe
  • MeGUI unterstützt jetzt auch FFmpegSource2.
    0.3.4.6
    - (zathor) [AviSynthWindow] FFVideoSource will be used automatically if a corresponding ffindex file exists
    - (zathor) [MeGUISettings] fixed ffms file not found problem
    0.3.4.5
    - (zathor) [MainForm] renamed "DG Creator" to "File Indexer"
    - (zathor) added FFMS (FFmpegSource2) to the file indexer
  • 0.3.4.7
    - (zathor) [updatecacher] + [updatewindow] + [mainform] added offline install capability
    - (zathor) [updatecacher] + [updatewindow] zip files will be verified before extracting
    - (zathor) [updatecacher] improved proxy support
    - (zathor) user.config will be migrated to new version if possible
    - (zathor) [x264encoder] mbtree can be disabled while fast preset is active
  • Vers. 0.3.4.8
    0.3.4.8
    - [ffmsReader] + [ScriptServer] FFVideoSource defaults to the YV12 colorspace
    - [VideoUtil] improved the ConvertToYV12() handling
  • Vers. 0.3.4.9
    0.3.4.9- x264 - some CQP mode adjustments- x264 - added superfast preset support (requires x264 revision 1509 or higher)
  • Vers. 0.3.4.10
  • 0.3.4.11
    - (zathor) [dar] + [archooser] enhanced itu values
    - (zathor) [oneclicksettings] changed the default output resolution to 720
    - (zathor) [oneclickwindow] custom ar can be applied if "keep input resolution" is selected
    - (zathor) [oneclickwindow] "keep input resolution" disables "signal ar"
  • Vers. 0.3.4.12
    0.3.4.12
    - [OneClickConfigPanel] "Keep Input Resolution" disables "Signal AR"
    - [JobQueue] CTRL+A selects all queue items. Feature request #2981335
    - [JobQueue] SHIFT+UP or DOWN to move an queue item, UP or DOWN to navigate in the list
    - user.config settings will also be migrated for queue settings and custom AR, file size and FPS
  • Vers. 03.4.13
  • 0.3.4.14
