Vers. 0.3.3.0
0.3.3.0
- (zathor) [OSInfo] Fix crash if OS is Windows 2000
Vers. 0.3.3.0
0.3.3.0
Vers. 0.3.3.1
ZitatAlles anzeigen
0.3.3.1
- [VobinputWindow] added mts as supported file extensions
- [MainForm] added information to the main window title if auto update is activated and the development server is used
- [VobinputWindow] Removed warning if no audio can be found. Feature request #2847468
- [JobWorkerWindow] Temporary worker will be closed automatically. Feature request #2928875
- [DAR] + [ARChooser] added 4:3 and 16:9 DAR
Vers. 0.3.3.2
0.3.3.2
- [HDBDStreamExtractor] changed default file input type
- [InputBox] set initial focus to text box. Feature request #2938589
- [InputBox] if text box has focus pressing "enter" will call the ok event and "escape" the cancel event
- [tsMuxeR] fix final m2ts file creating in OneClick. Bug #2936118
0.3.3.3
Zitat- (zathor) [prettyformatting] input and output filename spelling match in oneclick. Feature request #2938926
- (zathor) [mkvmergemuxer] iso639-2-code will be used for the language during muxing. Bug #2944894
- (zathor) [vobinputwindow] + [videoutil] disabled "select audio tracks" if dgindex is used and the stream is no program stream. Bug #2941323
0.3.3.4
Zitat- (zathor) [audioencodingtab] "_new" will be appended to the file name if input and output are the same. Bug #2531321
- (zathor) [muxprovider] + [tsmuxer] added mp4 support to the video input types. Feature request #2945805
0.3.3.5
- (zathor) [Calculator] Targeting "File Size" in the bitrate calculator defaults to automated 2-pass mode. Feature request #2951153
0.3.3.7
ZitatAlles anzeigen0.3.3.6
- (zathor) update mediainfo library and its wrapper to the latest release (0.7.28)
- (zahtor) [updatewindow] moved the mediainfo files to a separate download package
- (zathor) [calculator] encoding mode will only be changed if profile encoding mode is const. Quality or const. Quantizer. Bug #2952574
- (zathor) [dgireader] enhanced error handling
- (zathor) [sourcedetector] enhanced error handling in analyseff. Bug #2810830
- (zathor) [calculator] settings can only be applied if bitrate > 0. Bug #2812840
- (zathor) [avisynthwindow] enabling clever anamorphic encoding applies immediately the selected settings. Bug #2827053
Zitat0.3.3.7
- (zathor) [jobcontrol] error handling added. Bug #2279852
- (zathor) [x264encoder] corrected scenecut handling. Bug #2942446
- (zathor) [logitem] error handling added. Bug #2947565 + #2925500
0.3.4.1
0.3.4.1- [x264encoder] added support for new nal-hrd (requires x264 revision 1442 or higher)
0.3.4.2
Zitat- (zathor) [avisynthprofileconfigpanel] if clever anamorphic encoding is enabled the dropdown box will be also enabled
- (zathor) [avisynthwindow] openning a file also triggers the clever anamorphic encoding event. Bug #2957647
- (zathor) [updatewindow] set file changed time of extracted files
- (zathor) [updatewindow] files which need a reboot will also be backuped if selected
- (zathor) update icsharpcode.sharpziplib.dll
Vers. 0.3.4.3
ZitatAlles anzeigen- [HDStreamExtractorIndexer] improved mpls parsing
- [BitrateCalculator] fixed overflow for very long video durations
- update MediaInfo library and its wrapper to the latest release (0.7.29)
- [MainForm] suspend the update progress until the profiles have been imported
- [x264Encoder] + [x264ConfigurationPanel] changed the default b-pyramid value to normal (requires x264 revision 1455 or higher)
- [JobWorkerWindow] enhanced error handling
- [AudioEncoderInterface] earlier preprocessing status update
- [tsMuxeR] ISO639-2-Code will be used for the language during muxing
- [tsMuxeR] fixed muxing of srt files. Bug #2958514
- [x264] removed the lossless checkbox, changed turbo to "fast first pass", changed thread-input, cosmetics
- [tsMuxeR] + [CommandlineMuxer] changed the way the projected filesize is estimated
0.3.4.4
Zitat- (zathor) [mp4boxmuxer] + [commandlinejobprocessor] changed the way the remaining time is estimated. Bug #2124705
- (zathor) [mainform] updatecopier.exe will only be elevated if necessary
- (zathor) simplified updatecopier.exe
MeGUI unterstützt jetzt auch FFmpegSource2.
Zitat0.3.4.6
- (zathor) [AviSynthWindow] FFVideoSource will be used automatically if a corresponding ffindex file exists
- (zathor) [MeGUISettings] fixed ffms file not found problem0.3.4.5
- (zathor) [MainForm] renamed "DG Creator" to "File Indexer"
- (zathor) added FFMS (FFmpegSource2) to the file indexer
0.3.4.7
Zitat- (zathor) [updatecacher] + [updatewindow] + [mainform] added offline install capability
- (zathor) [updatecacher] + [updatewindow] zip files will be verified before extracting
- (zathor) [updatecacher] improved proxy support
- (zathor) user.config will be migrated to new version if possible
- (zathor) [x264encoder] mbtree can be disabled while fast preset is active
Vers. 0.3.4.8
Zitat0.3.4.8
- [ffmsReader] + [ScriptServer] FFVideoSource defaults to the YV12 colorspace
- [VideoUtil] improved the ConvertToYV12() handling
Vers. 0.3.4.9
0.3.4.9- x264 - some CQP mode adjustments- x264 - added superfast preset support (requires x264 revision 1509 or higher)
Vers. 0.3.4.10
ZitatAlles anzeigen
0.3.4.10
- [x264Encoder] --aud will only be appended if selected in the configuration dialog. Bug #2979294
- [OneClickSettings] the MKV container is enabled by default
- [x264ConfigurationPanel] fixed wrong vbvmaxrate value after profile switching
- [OneClickWindow] fixed keep input resolution behavior
- [VideoEncodingComponent] improved error handling
- [FilmCutter] changed default transition type in AVS Cutter to "No transition". Fade transition will blend in/out 10 frames. Bug #2913546
0.3.4.11
Zitat- (zathor) [dar] + [archooser] enhanced itu values
- (zathor) [oneclicksettings] changed the default output resolution to 720
- (zathor) [oneclickwindow] custom ar can be applied if "keep input resolution" is selected
- (zathor) [oneclickwindow] "keep input resolution" disables "signal ar"
Vers. 0.3.4.12
0.3.4.12
- [OneClickConfigPanel] "Keep Input Resolution" disables "Signal AR"
- [JobQueue] CTRL+A selects all queue items. Feature request #2981335
- [JobQueue] SHIFT+UP or DOWN to move an queue item, UP or DOWN to navigate in the list
- user.config settings will also be migrated for queue settings and custom AR, file size and FPS
Vers. 03.4.13
ZitatAlles anzeigen
0.3.4.13
- [HDBDStreamExtractor] DTS output type option for DTS-MA or DTS-HR extracts only the core DTS track. Feature Request #2695340
- [x264Encoder] fixed rc-lookahead. Bug #2991069
- [OSInfo] improved .NET 4.0 detection. Bug #2988751
- [x264Settings] changed the default b-pyramid value to normal
- [x264Config] fixed the log file button
- [UpdateWindow] added platform type
- [UpdateWindow] only the platform matching updates will be downloaded
- if the x64 MeGUI build is used only x64_64.exe is referenced
0.3.4.14
ZitatAlles anzeigen
- (zathor) changed the way windowstate, location and size are saved and applied for MainForm, JobWorker, Changelog and WorkerSummary
- (zathor) [x264Config] changed "Fast first pass" to "Slow first pass"
- (zathor) [ProfileConfigurationWindow] + [Calculator] + [Changelog] changed style to FixedToolWindow (no resize, no minimize)
- (zathor) [Calculator] settings can be applied if bitrate > 0
- (zathor) [JobControl] enhanced the adding of new jobs
- (zathor) [AudioEncodingTab] "_new" will be appended to the file name if the output file already exists
- (zathor) If targeting file size in AutoEncode or One-Click the encoding mode of the selected video profile will be switched temporarily to automated 2/3pass
- (zathor) [JobControl] + [JobWorkerWindow] fixed a problem with several workers running the same job
- (zathor) [JobControl] + [JobWorkerWindow] only one audio encoding at a time. Bug #2996413
- (zathor) [FileBar] set focus to the open dialogue
- (zathor) [VideoCodecSettings] + [x264Settings] removed unnecessary variables
- (zathor) renamed VobInputWindow to FileIndexerWindow, renamed several of the indexer classes
- (zathor) [FileIndexerWindow] display of source media information added
- (zathor) [FileIndexerWindow] based upon the source media the recommended indexer will be preselected
- (zathor) [tsMuxeR] fixed failed muxing in rare cases
- (zathor) [BitrateCalculator] add BPP and Quality Estimate calculation support w/ complexity slider. Patch by JarrettV (#2999751)
- (zathor) [BitrateCalculator] improved audio and unlimited extra calculation support. Patch by JarrettV (#2999751)
- (zathor) [BitrateCaluclator] the encoding mode of the selected video profile will be switched to automated 2/3pass if necessary
- (zathor) [x264ConfigurationPanel] simplified the main page, improved the tooltip help
