bisher wurde mir immer zu Verbatim DVDs geraten. Nun muss ich folgendes hier lesen:
There are two types of CMC MAG AE1 disks that you will find, and not only on the Titaniums. This applies to all and any brand of media using the CMC MAG AE1 dye. On the recording side, check out what is written on the blue ring near the centre hub.
The best, and absolutely excellent CMC MAG AE1 media have just a four digit serial/batch number, such as "0405"
Nothing alse is written on that blue ring.
The MID code for this type is:
Quote:
00000000 00 AA 00 00 01 40 C1 FD 9E D8 52 00 02 55 0D 0E .....@....R..U..
00000010 88 9A 80 00 03 43 4D 43 20 4D 41 00 04 47 2E 20 .....CMC MA..G.
00000020 41 45 31 00 05 00 00 00 00 00 02 00 06 09 0D 11 AE1.............
The other CMC MAG AE1 disks,, and only just average quality, have a string such as "CMDR4.7G-CAEWM03-036 0202"
The MID code for these:
Quote:
00000000 00 AA 00 00 01 40 C1 FD 9E D8 52 00 02 54 0D 0E .....@....R..T..
Notice the only difference in the MID is what I have highlighted in red. These two types are as different as chalk and cheese for burning quality.
If you can get the first type above, then go for it. The second type are nowhere near as good.
Any brand can be either type. I've seen Ridisc printable, Ridata, Datasafe printable, Datawrite yellow, Titanium grey, Titanium printable, Titanium full face printable, Titanium silver printables and Tufdisk all with both codes. Even two tubs of the same brand delivered at the same time had one tub of each type.
I think the two types come out of different factories, and are simply supplied equally to any company who orders CMC MAG AE1. It's just pot luck which you get.
Klarerweise habe ich die zweiten angeführten bekommen "nowhere near as good" klasse Sache.
CMC MAG AE1 wurde ausgelesen.
Sind diese nun wirklich schlecht??
Danke
Tom
