Ich denke hier ist der Thread besser aufgehoben.
AvsP(mod): AviSynth-Editor mit integrierter Vorschau
02.10.2006
Update
AvsP 1.2.0
http://www.avisynth.org/qwerpoi/Download.htmldeutsche Sprachdatei AvsP 1.2.0
http://forum.gleitz.info/showpost.php?p=301023&postcount=14 -
avisynth.org is zur Zeit down (seit gestern). Hier gibt es einen Mirror für AvsP v1.2.0: http://rapidshare.de/files/35670265/AvsP_v1.2.0.zip.html
Update
AvsP 1.2.1Zitat* custom syntax highlighter, more than 30 individually configurable fonts/colors
* added ability to override all fonts with a monospaced font (suggested by Richard Berg)
* added recent files menu (suggested by check)
* added shortcut for moving lines up/down (suggested by communist)
* added method to disable video preview (suggested by Alain2)
* added option to specify initial line margin width (suggested by nibbles)
* added optional arguments to pass to external player
* updated several macro functions, see new examples and macros_readme.txt for info
* added option to disable frequent calltips, show only upon typing open parentheses
* added ability to use keyboard shortcut for filter help file (suggested by Alain2)
* added option to wrap the text (suggested by Alain2)
* added option to highlight current line (suggested by Alain2)
* added 25% and 50% zoom levels (suggested by communist)
* moved line-by-line update mode to menu option, to allow for keyboard shortcut
* changed data format for options files to editable text files
> fixed minor bug with improper video updating (thanks nibbles)
> fixed small mistakes with some messages (thanks zemog)
> fixed minor bug with tabs and spaces
> fixed minor bug with session saving/loading
> cleaned up minor issues with tooltip code
11.10.2006
Update Sprachdatei AvsP 1.2.1 für Germanen
24.10.2006
AvsP v1.3.0
http://forum.doom9.org/showthread.php?p=871134#post871134
und Update für die deutsche Sprachdatei :cool:
25.10.2006
Update AvsP v1.3.1
Changelog
* click and drag video preview similar to Acrobat Reader* store last program size and position (suggested by Alain2)
* minor improvements to window layout code
* refresh video appropriately when creating new scripts
* fixed bug with unicode characters in slider labels (thanks Rippraff)
deutsche Sprachdatei : (keine Änderungen gegenüber 1.3.0, nur Version geändert)
03.11.2006
AvsP v1.3.2
http://forum.doom9.org/showthread.php?t=115506
Changelog
http://forum.doom9.org/showthread.php?p=895463#post895463Übersetzung ist in Arbeit...
update deutsche Sprachdatei für AvsP v1.3.2
http://forum.gleitz.info/showpost.php?p=301023&postcount=14Nachtrag : Nochmals einen Fehler korrigiert und erneut hochgeladen.
Avsp steht jetzt unter unter GPL -
Nachtrag : Nochmals einen Fehler koregiert ...
korrigiert ;D -
Fr_An
koregiert wurde korrigiert :redface:
Danke ! -
AvsP 1.3.3
http://www.avisynth.org/qwerpoi/Download.htmlChangelog
http://forum.doom9.org/showthread.php?p=900021#post900021Update deutsche AvsP Sprachdatei 1.3.3
Zitat von changelog* support for separate video window zoom fit
* updated included core filter definitions to AviSynth v2.56
* added menu options for goto next/previous bookmark (suggested by Alain2)
* option to quickly show AviSynth function definition dialog (suggested by Alain2)
* added new tag for separators in slider window (suggested by krisq)
* minor rearrangement of menu items for clarity (suggested by Fizick)
* fixed several issues with zoom fit feature (thanks foxyshadis, zemog, doxville, Alain2)
* fixed small bug with slider validation (thanks zemog)
16.12.2006
Update deutsche Sprachdatei auf AvsP 1.3.4
* added more font and color options (suggested by Alain2)
* added customizable keyword lists (suggested by Alain2)
* updated filter information with internal clip properties and functions
* improved autocompletion for functions with no arguments
* added several new macro functions (ExecuteMenuCommand, GetBookmarkList, GetAvs2aviDir, GetSliderTexts)
* added slider optimization macro with complete genetic algorithm implementation
* added option to associate .avs files with AvsP (suggested by foxyshadis, JoeTF)
> fixed minor issue with potential conflicting keyboard shortcuts (thanks Alain2)
mehr dazu auf Doom9 -
16.01.2007
Update der AvsP Sprachdatei auf 1.3.5 für die Gleitzer Germanen
AvsP 1.3.6
Zitat* saved files no longer lose user slider/toggle tag info (suggested by foxyshadis)
* prompt to reload modified files when loading a session (suggested by foxyshadis)
* added visual bookmarks along the video slider (suggested by doxville, avid_avs_user)
* added trim selection editor (suggested by Zarxrax, doxville, avid_avs_user)
* added option to not load bookmarks on startup (suggested by avid_avs_user)
* added crop editor options to insert at cursor, copy to clipboard (suggested by krisq)
* improved end of script detection for crop editor
* reorganized video menu for clarity (suggested by avid_avs_user)
* improved save image dialog with specific extensions (suggested by foxyshadis)
* created windows 98 compatible version (suggested by affter333)
> fixed crash when creating a new tab while crop editor is shown
> fixed small bug on program exit with multi-monitor setup (thanks foxyshadis)
> fixed several issues with syntax highlighting (thanks Alain2)
21.02.2007
Update der AvsP Sprachdatei auf 1.3.6
Also bei mir macht die neue Version Probleme.
Nach dreimaligen Aktualisieren stürtzt AvsP ohne Fehlermeldung ab Habe nur ich das Problem oder können das noch andere bestätigen? -
-doc-
Kann ich nicht bestätigen. falls sich das Problem noch nicht gelöst hast,mach doch einen Thread in der Avisynth-Abteilung raus. In den News sollen nur News stehen,keine Diskussionen,etc... -
