smartLabs tsMuxeR: Transport Stream muxer
  • Neues Tool, was für den ein oder anderen sicherlich interessant sein dürfte:
    Supported output formats:
    - TS
    - M2TS
    - Blu-ray
    Supported video codecs:
    - H.264
    - VC-1
    - MPEG2
    Supported audio codecs:
    - AAC
    - AC3 / E-AC3(DD+)
    - Dolby True HD (for streams with AC3 core only)
    - DTS/ DTS-HD
    - LPCM
    Supported subtitles:
    - M2TS Presentation graphic stream
    - SRT text subtitles
    Supported containers and formats:
    - elementary stream
    - Transport stream TS and M2TS
    - Program stream EVO/VOB/MPG
    - Matroska MKV/MKA
    Additional features currently implemented:
    * Ability to set muxing fps manually and automatically
    * Ability to change level for H.264 streams
    * Ability to shift a audio and subtitle tracks
    * Ability to extract DTS core from DTS-HD
    * Ability to extract AC3 core from Dolby True HD
    * Ability to join files.
    * Ability to change fps for a subtitle tracks.
    * Ability to convert between Blu-ray LPCM format and WAVE files.
    * Writing language information to the Blu-ray disk and to the TS/M2TS language descriptor.
    * Ability to cut source files
    * Ability to split output file
    * Ability to detect audio delay for TS/M2TS/MPG/VOB/EVO sources
    * Ability to remove pulldown info from stream
    * Ability to open Blu-ray playlist (MPLS) files
    * Ability to convert SRT subtitles to PGS
    History
    * Version 1.2.0:
    - Added M2TS muxing
    - Fixed stream type detection function (sometimes some audio/video streams were not found)
    * Version 1.1.5
    - The first release
    Doom9
  • * Version 1.2.6:
    - Added Dolby True HD support
    - Added MPEG audio layer 1/2/3 support
    - Fixed a bug in the M2TS parsing module. Sometimes TS frames were lost.
    - Fixed a bug in the Matroska parsing module. Short NAL unit len codes for H.264 tracks did not work
    tsMuxeR
  • *Version 1.4.5
    History
    * Version 1.4.5
    - Fixed blu-ray folders names
    - Added chapters for Blu-ray muxing
    * Version 1.4.3(b)
    - Added Blu-ray muxing mode
    - Added demuxing mode
    - Added Presentation Graphic stream support
    - Added language descriptor support
    * Version 1.2.9
    - Fixed MKV parsing module. Some MKV files did not work (lace sice invalid detected for xiph laces, this cause access violation error)
    * Version 1.2.8
    - Fixed AC3 stream detection. Some AC3 streams were not recognized (broken in version 1.2.6 only)
    * Version 1.2.6
    - Fixed a bug in the Matroska parsing module. Short NAL unit len codes for H.264 tracks did not work.
    Doom9
  • * Version 1.4.6
    - Fixed a bug with synchronization of a H.264 stream and audio. This bug was appear on some streams only. When there was this bug, In a log were printed many messages "B-pyramid level 2 detected","B-pyramid level 3 detected" e.t.c.
    The new version 1.5.0(b) is ready.
    - Added LPCM support. LPCM tracks can be remuxed, demuxed to WAV or muxed from WAV files.
    Doom9
  • * Version 1.5.1
    - Issue with TRUE-HD tracks demuxing fixed.
    * Version 1.6.3(b)
    -Bug fixed: PTS/DTS timing for MPEG2 streams without GOP headers filled wrong
    -Bug fixed: CBR muxing mode since version 1.6 worked wrong
    -Bug fixed: trim function did not work for minutes measure unit
    -Ability to detect audio delay for TS/M2TS/MPG/VOB/EVO sources added
    -Drag&drop for GUI added
    Doom9
  • update
    New version 1.7.1(b) is ready.
    - Bug fixed: Now pulldown info correctly processed.
    - Ability to remove pulldown info from stream added. All video codecs are supported: H.264, VC-1, MPEG2.
    - Some small bug fixes and improvements. Also tsMuxeR package size is decreased and dependings to other libraries have been removed.
    * Version 1.7.3(b)
    - Improved M2TS splitting in Blu-ray mode
    - bug fixed: some H.264 streams in version 1.7.1/1.7.2 did not work.
    Doom9
    * Version 1.7.6(b)
    - Ability to open Blu-ray playlist (MPLS) files added. Also, when MPLS file is opened, chapters list automatically imported.
    When MPLS is processed, "Clean Break" for connection_condition=5 correctly processed. It is actually for large playlists (10 M2TS files and more).
    - bug fixed: some H.264 streams in version 1.7.1/2/3 did not work in PS3. It is the same problem it was corrected in version 1.7.3. Fixed again.
    - bug fixed: Issue with muxing PGS stream from several source files (i.e. append mode) fixed.
  • * Version 1.8.4(b)
    - Ability to convert SRT to PGS added.
    - Some minor bugfixes.
    Doom9
  • es wurde weiterentwickelt:
    Good NEWS For all those trying to solve the true hd and vc1 problems on main movie only discs, there is a new TSMUXER released today. It is version 1.8.18.
    I havent tried it yet as its fresh from the designer. It is supposed to fix the true hd problem.
    I will be testing over the next few days, and would like others to test and post results here if possible.
    link to download is ftp://213.221.6.90/tsMuxer/
    have fun
    regards
    changelog:
    1.8.15 - fixed bug with TRUE-HD stream
    1.8.16 - fixed bug with long srt subtitles
    1.8.17 - fixed bug with extracting TRUE-HD core (bug appear in mux mode only, demux works fine)
    1.8.18 - fixed bug with "bitstream exeption" occurring in some streams
    also einfach die alte tsmuxer.exe mit der neuen überschreiben, GUI zeigt noch alte Version an... ein komplettes Paket (mit GUI update) soll bald erscheinen...
  • 1.8.19 gibts nun auf obiger seite zum download... kein changelog, kein GUI update...
