Neues Tool, was für den ein oder anderen sicherlich interessant sein dürfte:
Supported output formats:
- TS
- M2TS
- Blu-ray
Supported video codecs:
- H.264
- VC-1
- MPEG2
Supported audio codecs:
- AAC
- AC3 / E-AC3(DD+)
- Dolby True HD (for streams with AC3 core only)
- DTS/ DTS-HD
- LPCM
Supported subtitles:
- M2TS Presentation graphic stream
- SRT text subtitles
Supported containers and formats:
- elementary stream
- Transport stream TS and M2TS
- Program stream EVO/VOB/MPG
- Matroska MKV/MKA
Additional features currently implemented:
* Ability to set muxing fps manually and automatically
* Ability to change level for H.264 streams
* Ability to shift a audio and subtitle tracks
* Ability to extract DTS core from DTS-HD
* Ability to extract AC3 core from Dolby True HD
* Ability to join files.
* Ability to change fps for a subtitle tracks.
* Ability to convert between Blu-ray LPCM format and WAVE files.
* Writing language information to the Blu-ray disk and to the TS/M2TS language descriptor.
* Ability to cut source files
* Ability to split output file
* Ability to detect audio delay for TS/M2TS/MPG/VOB/EVO sources
* Ability to remove pulldown info from stream
* Ability to open Blu-ray playlist (MPLS) files
* Ability to convert SRT subtitles to PGS
History
* Version 1.2.0:
- Added M2TS muxing
- Fixed stream type detection function (sometimes some audio/video streams were not found)
* Version 1.1.5
- The first release
