LameXP v4.04 Beta-11:
ZitatAlles anzeigenChanges between v4.03 and v4.04:
* Added support for the QAAC Encoder, requires QuickTime v7.7.1 or newer (see FAQ doc for details)
* Added Chinese and Taiwanese translations, thanks to 456Vv <123@456vv.com>
* Added experimental support for dcaenc, created by Alexander E. Patrakov <patrakov@gmail.com>
* Added CSV export/import for Meta tags (see context-menu on the "Source Files" tab)
* Added a button to modify the current output folder path in an edit box
* Updated Qt runtime libraries to v4.8.0 (2011-12-15), compiled with MSVC 10.0
* Updated LAME encoder to v3.99.5 Final (2012-02-28), compiled with ICL 12.1.7 and MSVC 10.0 (details)
* Updated MediaInfo to v0.7.54 (2012-03-13), compiled with ICL 12.1.7 and MSVC 10.0
* Updated SoX to to v14.4.0 (2012-03-04), compiled with ICL 12.1.7 and MSVC 10.0
* Updated mpg123 decoder to v1.13.6 (2011-03-11), compiled with GCC 4.6.1
* Updated Monkey's Audio binary to v4.11 (2011-04-20)
* Updated Musepack decoder to revision 475 (2011-08-10), compiled with ICL 12.1.6 and MSVC 10.0
* Updated GnuPG to v1.4.12, compiled with GCC 4.6.1
* Updated language files (big thank-you to all contributors !!!)
* Implemented coalescing of update signals to reduce the CPU usage of the LameXP process (details)
* Run more than four instances in parallel on systems with more than four CPU cores (details)
* Improved handling of different character encodings for Playlist and Cue Sheet import
* Tweaked directory outline on "output folder" tab for improved performance (hopefully)
* Improved LameXP inter-process communication by adding queue support
* Workaround for a bug that causes MediaInfo to not detect the duration of Wave files (64-Bit only)
* Prevent LameXP from blocking a system shutdown (encoding process is aborted, if necessary)
* Improved internal handling of MediaInfo output, including extraction of cover art
* Fixed a very rare "live-lock" situation in early initialization code
