LameXP v4.09 Alpha-8:
ZitatAlles anzeigenChanges between v4.08 and v4.09 [unreleased]:
* Upgraded build environment to Microsoft Visual Studio 2013 RTM
* Complete overhaul of the file analyzer, resulting in up to 2.5x faster file import speed
* Reworked the application initialization code, resulting in notably faster startup speed
* Improved file analyzer to retain the original ordering of files imported from a playlist
* Improved internal encoder API, so each encoder can define its own configuration options
* Improved splash screen and working banner, using "sheet of glass" effect on supported OS
* Improved dropbox widget, including proper multi-monitor support
* Updated mpg123 decoder to v1.16.0 (2013-10-06), compiled with GCC 4.8.1
* Updated GNU Wget binary to v1.14.0 (2012-08-05), compiled with GCC 4.8.1
* Updated GnuPG to v1.4.15 (2013-10-05), compiled with GCC 4.8.1
* Fixed a resource (file descriptor) leak in "static" builds, didn't cause much harm though
* Various bugfixes and code improvements
ZitatAchtung: Benutzer, die von Version "Alpha-6" oder neue updaten möchten, müssen das Update dieses Mal evtl. manuell herunterladen und installieren! Aufgrund eines Fehlers in Version "Alpha-6" kann es passieren, dass der Installer zwar korrekt per Auto-Update heruntergeladen wird, dann aber nicht (richtig) gestartet werden kann. Stattdessen erscheint eine Fehlermeldung über eine fehlende Datei. Worst-Case also :nein:
