*updated*
- x264, mencoder, mplayer
sx264vc_rev305.rar
*updated*
sx264vc_rev305.rar
rev306
*fixed*
- vbv was not set correctly when using crf encoding
*changed*
- changed some debug&console output
sx264_rev306.zip
Ps.. So, das war es für heute, wer heute noch nen bug findet darf ihn erstmal behalten.
rev311
*fixed*
- some output glitches (hopefully :))
- audio delay getting lost
sx264_rev311.zip
rev312
*fixed*
- mkv muxing
*changed*
- (l)pcm audio handling (!still not handled properly!)
sx264_rev312.zip
sx264_rev314.zip
changelog?
war ein Typo->kein Changelog gibt auch schon wieder ne neue Version :
rev315
*added*
- 'chapter encode':
when 'dvd-input' and 'queue jobs' is enabled this option will add a job for each chapter of the currently selected title on the dvd
The name of the job will be generated accoring to the outputfile specified + _Title_CURRENT-TITLE-NUMBER_Chapter_CHAPTER-NUMER.OUTPUTFORMAT
sx264_rev315.zip
Die hat aber auch einen Bug, bzgl. dem "synchron halten" der JobListe, vor allem wenn man sie nicht nutzt. -> weiß aber wo das Problem liegt und werde es morgen Nachmittag fixen.
rev316
*fixed*
- problem with jobQueue
sx264_rev316.zip
rev317
*cosmetics*
- removed obsolete bframe rdo button
- adjusted resttime
*fixed*
- didn't initialize max Chapter for first title
sx264_rev31z.zip
rev319
*fixed*
- another jobQueue-Bug
- mkv muxing bug
sx264_rev319.zip
rev323
*cosmetics*
-not changing 'Status:' to Outputname
*fix*
- audio extraction, pcm audio killed it
sx264_rev323.zip
rev326
*added*
- 'title encode':
when 'dvd-input' and 'queue jobs' is enabled this option will add a job for each title on the dvd
The name of the job will be generated accoring to the outputfile specified + _Title_CURRENT-TITLE-NUMBER.OUTPUTFORMAT
(probably needs some tweaking, but it's a start)
*cosmetics*
- added dxva POPUP
*fixed*
- deactivate PopUps saved properly
sx264_rev326.zip
rev335
*fixed*
- bluRay restriction -> adjust size
- problem grabbing chapter infos from some dvds
*changed*
- setting DebugOutput to OutputPath
-'-vo null' instead of '-novideo'
*cosmetics*
- a bunch of ui changes
sx264vc_rev335.rar
sx264_rev335.zip
rev341
*fixed*
- dts audio handling
*changed*
- always trying to grab AudioIDs
- using mencoder for audio extraction
sx264_rev341.zip
rev342
*fixed*
- sizeCalculation for presets & dvdContent
- rest time to encode, length has to be taken from model currently in queue not from current model,.. DOH
- encoding progress, has to be taken from model currently in queue not from current model,.. DOH
- bug when grabbing size of input video (wrong typ-casting :/)
aus dem MediaInfo Changelog:
ZitatLPCM in VOB: more attributes (channels count, sampling rate, bitrate)
#2186682, MPEG-2 Video: Wrong PAR and DAR for Panasonic MPEG2 Files
:rock::daumen::rock: -> morgen im Laufe des Tages noch mal LPCM-Support überarbeiten
..das klingt gut, dann habe ich am wochende wieder was zum spielen
rev347
*fixed*
- lpcm passthrough and encoding thanks to mediinfo 0.7.7.8
- BluRay restriction adjustments
*added*
- systrayIcon (no real funcionallity atm)
*update*
- x264 version to 1028
- mediainfo v0.7.7.8
sx264_rev347.zip
sx264vc_rev347.rar
rev349
*cosmetics*
- fixed some typos&co
*fixed*
- adjustment to new audiosize during 2pass encoding
- calculation of 'max references at level' & 'max keyFrameInterval for BluRay' (both were to restrictive)
sx264_rev349.zip
rev360
*added*
- pgc -> vts mapping via lsDVD/vstrip_ifo
*changed*
- always extracting audio on passthrough if audio is not raw audio
sx264vc_rev360.rar
