Hallo!
Bekomme immer folgende Fehlermeldung, wenn ich eine DVD mit Menü und mehreren .vobs erstellen möchte:
Microsoft Windows [Version 6.0.6001]
Copyright (c) 2006 Microsoft Corporation. Alle Rechte vorbehalten.
C:\Users\Chris\Documents\GFDOutDir\Temp>Time: 16.02.2009 11:17:51
(shrink and) mux video and audio files
INFO: [mplex.exe] mplex version 1.9.0 (2.2.7 $Date: 2006/02/01 22:23:01 $)
INFO: [mplex.exe] File e:\Gilmore Girls\Staffel 1\Episode 4\DVD\Gilmore_Girls_2009-02-05_115907.001.m2v looks like an MPEG Video stream.
INFO: [mplex.exe] File e:\Gilmore Girls\Staffel 1\Episode 4\DVD\Gilmore_Girls_2009-02-05_115907.001.mp2 looks like an MPEG Audio stream.
INFO: [mplex.exe] Video stream 0: profile 8 selected - ignoring non-standard options!
INFO: [mplex.exe] Found 1 audio streams and 1 video streams
INFO: [mplex.exe] Selecting dvdauthor DVD output profile
INFO: [mplex.exe] Multiplexing video program stream!
INFO: [mplex.exe] Scanning for header info: Video stream e0 (e:\Gilmore Girls\Staffel 1\Episode 4\DVD\Gilmore_Girls_2009-02-05_115907.001.m2v)
INFO: [mplex.exe] VIDEO STREAM: e0
INFO: [mplex.exe] Frame width : 720
INFO: [mplex.exe] Frame height : 576
INFO: [mplex.exe] Aspect ratio : 4:3 display
INFO: [mplex.exe] Picture rate : 25.000 frames/sec
INFO: [mplex.exe] Bit rate : 7045600 bits/sec
INFO: [mplex.exe] Vbv buffer size : 229376 bytes
INFO: [mplex.exe] CSPF : 0
INFO: [mplex.exe] Scanning for header info: Audio stream c0 (e:\Gilmore Girls\Staffel 1\Episode 4\DVD\Gilmore_Girls_2009-02-05_115907.001.mp2)
INFO: [mplex.exe] MPEG AUDIO STREAM: c0
INFO: [mplex.exe] Audio version : 1.0
INFO: [mplex.exe] Layer : 2
INFO: [mplex.exe] CRC checksums : no
INFO: [mplex.exe] Bit rate : 24576 bytes/sec (192 kbit/sec)
INFO: [mplex.exe] Frequency : 48000 Hz
INFO: [mplex.exe] Mode : 0 stereo
INFO: [mplex.exe] Mode extension : 0
INFO: [mplex.exe] Copyright bit : 0 no copyright
INFO: [mplex.exe] Original/Copy : 1 original
INFO: [mplex.exe] Emphasis : 0 none
INFO: [mplex.exe] SYSTEMS/PROGRAM stream:
INFO: [mplex.exe] rough-guess multiplexed stream data rate : 7391896
INFO: [mplex.exe] target data-rate specified : 10080000
INFO: [mplex.exe] Setting specified specified data rate: 10080000
INFO: [mplex.exe] Run-in delay = 7200 Video delay = 7200 Audio delay = 10800
INFO: [mplex.exe] New sequence commences...
INFO: [mplex.exe] Video e0: buf= 0 frame=000000 sector=00000000
INFO: [mplex.exe] Audio c0: buf= 0 frame=000000 sector=00000000
INFO: [mplex.exe] Scanned to end AU 64193
INFO: [mplex.exe] STREAM e0 completed
INFO: [mplex.exe] STREAM c0 completed
INFO: [mplex.exe] Multiplex completion at SCR=231100708.
INFO: [mplex.exe] Video e0: completed
INFO: [mplex.exe] Audio c0: completed
INFO: [mplex.exe] VIDEO_STATISTICS: e0
INFO: [mplex.exe] Video Stream length: 1114432364 bytes
INFO: [mplex.exe] Sequence headers: 5350
INFO: [mplex.exe] Sequence ends : 1
INFO: [mplex.exe] No. Pictures : 64194
INFO: [mplex.exe] No. Groups : 5350
INFO: [mplex.exe] No. I Frames : 5350 avg. size 69935 bytes
INFO: [mplex.exe] No. P Frames : 16050 avg. size 18679 bytes
INFO: [mplex.exe] No. B Frames : 42794 avg. size 10292 bytes
INFO: [mplex.exe] Average bit-rate : 3472000 bits/sec
INFO: [mplex.exe] Peak bit-rate : 7046000 bits/sec
INFO: [mplex.exe] BUFFERING min 15 Buf max 158218
INFO: [mplex.exe] AUDIO_STATISTICS: c0
INFO: [mplex.exe] Audio stream length 61626240 bytes.
INFO: [mplex.exe] Syncwords : 106990
INFO: [mplex.exe] Frames : 106990 padded
INFO: [mplex.exe] Frames : 0 unpadded
INFO: [mplex.exe] BUFFERING min 15 Buf max 587
INFO: [mplex.exe] MUX STATUS: no under-runs detected.
C:\Users\Chris\Documents\GFDOutDir\Temp>Time: 16.02.2009 11:21:45
*creating MMback.m2v
C:\Users\Chris\Documents\GFDOutDir\Temp>Time: 16.02.2009 11:25:12
*mux to MMback.mpg
INFO: [mplex.exe] File C:\Users\Chris\Documents\GFDOutDir\Temp\MMBackg.m2v looks like an MPEG Video stream.
INFO: [mplex.exe] File d:\Downloads\02 - The Las - There She Goes.wav.MP2 looks like an MPEG Audio stream.
INFO: [mplex.exe] Scanning for header info: Video stream e0 (C:\Users\Chris\Documents\GFDOutDir\Temp\MMBackg.m2v)
INFO: [mplex.exe] Bit rate : 7000000 bits/sec
INFO: [mplex.exe] Scanning for header info: Audio stream c0 (d:\Downloads\02 - The Las - There She Goes.wav.MP2)
INFO: [mplex.exe] Bit rate : 20480 bytes/sec (160 kbit/sec)
INFO: [mplex.exe] Frequency : 44100 Hz
INFO: [mplex.exe] rough-guess multiplexed stream data rate : 7311896
++ WARN: [mplex.exe] Stream e0: data will arrive too late sent(SCR)=7314 required(DTS)=7200
++ WARN: [mplex.exe] Video e0: buf= 99212 frame=000001 sector=00000049
++ WARN: [mplex.exe] Audio c0: buf= 0 frame=000000 sector=00000000
INFO: [mplex.exe] Scanned to end AU 1154
INFO: [mplex.exe] Multiplex completion at SCR=4153490.
INFO: [mplex.exe] Video Stream length: 14044710 bytes
INFO: [mplex.exe] Sequence headers: 77
INFO: [mplex.exe] No. Pictures : 1155
INFO: [mplex.exe] No. Groups : 77
INFO: [mplex.exe] No. I Frames : 77 avg. size106349 bytes
INFO: [mplex.exe] No. P Frames : 309 avg. size 8115 bytes
INFO: [mplex.exe] No. B Frames : 769 avg. size 4353 bytes
INFO: [mplex.exe] Average bit-rate : 2431600 bits/sec
INFO: [mplex.exe] Peak bit-rate : 2841200 bits/sec
INFO: [mplex.exe] BUFFERING min 18 Buf max 232156
INFO: [mplex.exe] Audio stream length 923689 bytes.
INFO: [mplex.exe] Syncwords : 1768
INFO: [mplex.exe] Frames : 975 padded
INFO: [mplex.exe] Frames : 793 unpadded
INFO: [mplex.exe] BUFFERING min 15 Buf max 536
**ERROR: [mplex.exe] MUX STATUS: Frame data under-runs detected!
*creating menufile MMMenu.mpg
DVDAuthor::spumux, version 0.6.14-GfD-2.
Build options: gnugetopt iconv freetype
Send bugs to <gfd@boraxsoft.de>
STAT: 0:00:00.000
INFO: PNG had 2 colors
INFO: Constructing blank img
INFO: Pickbuttongroups, success with 1 groups, useimg=1
INFO: Found EOF in .sub file.
INFO: Max_sub_size=5434
INFO: 1 subtitles added, 0 subtitles skipped, stream: 32, offset: 0.12
Kann mir da jemand weiterhelfen? Bin leider in diesem Bereich nicht allzu bewandert!
