Mal etwas aufholen ... aktuell ist jetzt
Version 1.2.1
Bug fix: Menu commands to switch between playback output devices not entirely working.
Bug fix: Incorrect decode of odd/malformed Vorbis files.
Bug fix: Archive Reader DLL was accidentally made dependant on MSVCR100.DLL in 1.2.
Improved compatibility with malformed AIFF files.
Bug fix: 1.2 regression - some filesystem operations in monitored folders would cause foobar2000 to crash.
1.2
Support for streaming to arbitrary UPnP MediaRenderer devices through the new UPnP output component.
FFmpeg is now used for MP3, AAC and Vorbis decoding
Extended playback thread priority options in Advanced Preferences.
New: Converter “Quick Convert” dialog, for simplified casual conversions without advanced features.
New: Menu commands to switch between playback output devices.
New: Component installer now shows component licenses when available.
Package license.txt or license.rtf with the component to get it shown on install.
License not shown when autoupdating components.
Equalizer is now an open-source component, separate from the standard DSP array.
1.1.18
Hot fix: deadlock detection feature has been disabled due to newly documented harmful side effects.
No more crash when playing during a machine standby cycle.
1.1.17
Converter works on non-seekable sources again, such as Internet streams.
Fixed rare crash bug with “full file buffering”.
Fixed oscilloscope inversion bug
Improved media library relative path handling in portable installs.
Ctrl+A now works in generic text popup dialogs (popup_message API).
Crash reporting improvements for hopefully more meaningful data about deadlocks.
Updated zlib to 1.2.7.
1.1.16
Worked around playback/output preferences crash on Windows 2003.
ID3v2 tagging compatibility improvements:
Non-compliant ID3v2.3 TYER allowed by default since various other popular software does it.
Option to write “rating” as TXXX for the few people who want it.
Fixed properties dialog field copy/paste inconsistency when copying specific fields from single to multiple files.
ReplayGain scanner: added additional warnings when trying to scan a very large group of tracks as a single album.
ReplayGain scanner: addressed extreme memory usage when scanning a large group of tracks as a single album.
Cleaned up *****ded cuesheet handling code.
Faster FLAC tag updates when full file rewrite is necessary.
Sanitized FLAC tag updating behaviors in low-memory conditions.
The File Operations component now be used to create links to files, in addition to copying/renaming/moving (beta 2).
Improved album art loading performance with huge libraries and complicated lookup patterns (beta 2).
1.1.15
Added basic MusicBrainz tagging capability to the audio CD ripper.
CD ripper can now look up CD information automatically each time a new CD is about to be ripped.
Worked-around shell integration incompatibility with Windows 8.
Converter performance tweaks for multi-core encoding (beta 2).
Resolved incompatibility with Matroska files processed with mkvclean (beta 2).
ID3v2: “rating” tags now compatible with Windows Media Player (beta 2).
Resolved Converter incompatibility with new Opus encoder (beta 2).
Worked-around drag&drop incompatibility with Windows explorer read-only optical media (final).
Added an advanced preferences option to minimize the app on [x] close (final).
Worked-around NSIS installer incompatibility with Windows 8 address space layout randomization (final).
Alles anzeigen
