DGDecNV Build 2007 haben wir bereits übersprungen... dank einheitlicher CUDA-Unterstützung sind MPEG2- und MPEG4-AVC-Decoder mittlerweile in DGMultiSource() vereint.
Nun gibt es DGDecNV Build 2008:
QuoteDisplay More* Redesigned the SPS/PPS heuristics for AVC streams in DGIndexNV. This fixes cases of bad decoding when navigating on the timeline for streams that: 1) Have SPS/PPS's remote from the seek point. 2) Re-use SPS/PPS IDs for NALUs with different content. The fix dramatically improves things for such streams, but it may not be perfect because it is, after all, a heuristic. Note that this problem did not affect serving video through the Avisynth script; it affected only navigating the timeline in DGIndexNV (but see below).
* The SPS/PPS heuristics fix also fixes bad video demuxing for the same cases described above.
* Added tooltips for the navigation buttons and navigation bar in DGIndexNV.
* Fixed a problem that caused the DGIndexNV GUI and the DGI file to disagree about the frame size in some rare cases.
* The Detect PIDs dialog now shows the PIDs in both decimal and hexadecimal.
* The Quick Start guide was revised to use DGMultiSource() by default. A second Quick Start guide is provided for DGSource()/CUVID Server usage.
Außerdem wurde DGAVCDec von Donald Graft's Website entfernt... eine Wiederauferstehung wird es wohl erst geben, wenn klar ist, ob DiAVC als Ersatz-Decoder für libavcodec implementiert wird.
