TEncoder - Multi-threaded Mencoder/ffmpeg GUI
  • Erstmals im Oktober 2011 im doom9-Forum vorgestellt, mittlerweile in Version 2.1 erhältlich.
  • Version 2.2
  • Version 2.3
  • Version 2.4
  • Version 2.5
  • Version 2.6
  • Version 2.7
  • Version 2.8
  • Version 2.9
  • Version 3.0
  • Version 3.1
    Change Log
    --3.1
    -Added: Turkish translation (Translators, please see "To translators.txt")
    -Added: Profiles are now stored in different files under "Profiles" folder
    -Added: User created Profiles will be saved in a differen directory
    -Added: Custom video and audio options to profiles
    -Added: Container options to profiles
    -Added: Parent folder of input file will be created in the output folder
    -Added: Option to use 32bit FFmpeg eventhough the OS is 64bit
    -Added: New skin "Mint"
    -Fixed: FFMpeg could not open AVS files (thx to goorawin)
    -Fixed: Some settings were not saved
    -Fixed: Preview window taskbar progress state problem
    -Fixed: When a profiles was added/deleted/edited, profile lists would become empty
    -Updated: AlphaControls to 8.04
    -Updated: FFMpeg to 20-11-2012
    -Updated: MPlayer and MEncoder to SB43
  • Version 3.2
  • Version 3.3
  • Version 3.3.1 (Hotfix)
    Zitat von ozok
    -Fixed: "Index out of bounds" error while adding files (thx to bug reporters)
    -Updated: FFMpeg to latest from http://ffmpeg.zeranoe.com/builds/
    https://sourceforge.net/projects/tencoder/
    http://forum.doom9.org/showthread.php?t=162724
  • Version 3.4
    Version 3.4.1 (Hotfix)
    Zitat von ozok
    -Fixed: Copying video while encoding audio caused extension to be wrong (thx to woody345)
    -Fixed: Couldn't copy video without encoding audio
    -Fixed: Couldn't encode to huffyuv with MEncoder
  • Und es geht gleich weiter mit dem nächsten Meilenstein:
    Version 3.5
    Version 3.5
  • Version 3.6
    Zitat von ozok
    -Added: Seperate 32bit and 64bit builds and setups
    -Added: Preview button (thx to Bluedraft )
    -Fixed: Prores quality option labels were wrong (thx to CyberOtter)
    -Fixed: Range editor allowed duration to be zero
    -Fixed: "+1 Sec" buttons couldn't increase their range to max
    Aktueller Download bei http://www.downloadbestsoft.com/TEncoder-Video-Converter.html
