Es geschehen noch Wunder ... heute hat madshi tatsächlich eine lang erwartete neue Version herausgebracht, und wir wollen hoffen, dass es noch weitere geben wird.
eac3to v3.25 — http://madshi.net/eac3to.zip
- fixed: option "-down6" didn't handle 6.1 tracks properly
- fixed: option "-down6" for 7.1 content lowered side channels in volume
- fixed: 6.1 DTS/E-AC3 libav decoding resulted in incorrect 70f channel mask
- fixed: a couple of funny AC3 channel configs resulted in swapped channels
- fixed: option "-check" failed for SRT subtitles
- fixed: MKV tracks without language information didn't default to "English"
- fixed: 16bit MLP decoding didn't work at all
- fixed: DTS 2.1 decoding had empty sub channel when using ArcSoft decoder
- fixed: muxing h264 video streams without VUI eventually crashed
- fixed: SMPTE 302M 20bit PCM tracks didn't extract properly
- improved AC3 seamless branching handling by detection of identical frames
- improved DTS seamless branching handling by detection of identical frames
- updated to latest ffmpeg/libav revision
- added support for libav DTS 6.1 and 7.1 decoding (only in core, no DTS-HD)
- added support for encoding all AC3 channel configurations
- added support for demuxing Blu-Ray primary E-AC3 tracks (AC3 core)
- libav is now the default decoder for AC3 and E-AC3
- option "-down2" is now deprecated, but still supported
- option "-downDpl" mixes down to Dolby Pro Logic II
- option "-downStereo" mixes down to standard stereo
- added support for mixing any channel configuration to stereo/DPL
- DPL downmixing doesn't lower volume, anymore (except when clipping occurs)
- editing audio tracks by adding silence is now less restrictive
- trying to mux right eye stream to MKV errors out now, instead of crashing
- doing "eac3to 1) movie.mkv" for 3D BDs now properly skips right eye stream
- FLAC encoding is now done with optimized block sizes for "LossyWAV" files
- encoder bitdepth for lossy DTS tracks is no longer displayed
- option "-test" no longer checks mkvtoolnix
