Habe folgendes OptionsFile:
-oH:\\Output\\Test.mkv--append-to1:0:0:0,2:0:1:0,3:0:2:0,4:0:3:0,5:0:4:0,6:0:5:0,7:0:6:0,8:0:7:0--clusters-in-meta-seek--engageno_simpleblocks--disable-lacing--engageno_cue_duration--engageno_cue_relative_position--default-duration0:24000/1001p--compression-1:none--forced-track0:yes--default-track0--no-audio--no-subtitles--no-chapters--no-attachments--no-buttonsH:\\Temp\\Test-001.264--default-duration0:24000/1001p--compression-1:none--forced-track0:yes--default-track0--no-audio--no-subtitles--no-chapters--no-attachments--no-buttonsH:\\Temp\\Test-002.264--default-duration0:24000/1001p--compression-1:none--forced-track0:yes--default-track0--no-audio--no-subtitles--no-chapters--no-attachments--no-buttonsH:\\Temp\\Test-003.264--default-duration0:24000/1001p--compression-1:none--forced-track0:yes--default-track0--no-audio--no-subtitles--no-chapters--no-attachments--no-buttonsH:\\Temp\\Test-004.264--default-duration0:24000/1001p--compression-1:none--forced-track0:yes--default-track0--no-audio--no-subtitles--no-chapters--no-attachments--no-buttonsH:\\Temp\\Test-005.264--default-duration0:24000/1001p--compression-1:none--forced-track0:yes--default-track0--no-audio--no-subtitles--no-chapters--no-attachments--no-buttonsH:\\Temp\\Test-006.264--default-duration0:24000/1001p--compression-1:none--forced-track0:yes--default-track0--no-audio--no-subtitles--no-chapters--no-attachments--no-buttonsH:\\Temp\\Test-007.264--default-duration0:24000/1001p--compression-1:none--forced-track0:yes--default-track0--no-audio--no-subtitles--no-chapters--no-attachments--no-buttonsH:\\Temp\\Test-008.264--default-duration0:24000/1001p--compression-1:none--forced-track0:yes--default-track0--no-audio--no-subtitles--no-chapters--no-attachments--no-buttonsH:\\Temp\\Test-009.264--compression-1:none--no-videoH:\\Temp\\Test_AudioCut.mkv
Wenn ich dann:
aufrufe erhalte ich:
ZitatError: The file no. 1 ('H:\Temp\Test-002.264') is not being appended. The argument for '--append-to' was invalid.
-> irgendwas ist also an dem '--append-to'-Aufruf nicht richtig, aber was?
die allgemeine Syntax ist doch:
sprich, der '--append-to"-Teil muss an den Anfang und sollte doch eigentlich stimmen,...
Was ich will ist:
- Die .264 files aneinander hängen und dabei sicher sein, dass die TimeCodes entsprechend der "--default-duration 0:24000/1001p" gesetzt werden und nicht aus den Files generiert werden solle, weshalb ich die Files nicht mit '+' einfach aneinanderhängen kann.
- Den Audio stream und eventuelle Untertitel&Co die im "irgendwasIstFalsch_AudioCut.mkv" enthalten sind dazu multiplexen, so dass ich am Ende einen Video stream + die streams aus 'irgendwasIstFalsch_AudioCut.mkv' in einem Container habe.
