mkv zu xvid via File Indexer ..
MeGui macht noch den Audio Encode und wenn es dann zum Video Encoding geht popt das Fenster kurz auf und dann war es dass
Can't open avi/avs file E:\Filme zum encoden\Test\test\test123.mkv.avs
hab ne Log gemacht
[Error] Log
-[Information] Versions
--[Information] MeGUI: 2776 x86
--[Information] System Information
---[Information] Operating System: Windows Server 2008 R2 Standard x64 SP1 (6.1.65536.7601)
---[Information] .NET Framework: 4.0 (4.0.0.0)
---[Information] .NET Framework: 4.7 (4.7.02558)
--[Information] Component Information
---[Information] Haali Media Splitter: 1.13.138.14 (14-04-2013)
---[Information] Haali DSS2: not installed
---[Information] ICSharpCode.SharpZipLib: 0.85.5.452 (08-08-2008)
---[Information] MediaInfo: 17.10.0.0 (02-11-2017)
---[Information] MessageBoxExLib: 1.0.2218.28317 (20-12-2008)
---[Information] SevenZipSharp: 0.64.3890.29348 (02-01-2011)
---[Information] 7z: 9.20 (18-11-2010)
--[Information] AviSynth Information
---[Information] AviSynth Wrapper
----[Information] Version: 1.0.2721.0
----[Information] Date: 30-04-2017
----[Information] Interface: 3
----[Information] not installed
---[Information] AviSynth portable
----[Information] File Version: 0.1
----[Information] Date: 29-06-2017
----[Information] Name: AviSynth+ 0.1 (r2508, MT, i386)
----[Information] Version: AviSynth+ 0.1 (r2508, MT, i386)
----[Information] AviSynth+: true
----[Information] MT: true
----[Information] Status: active
-[Information] Update detection
--[Information] [11/17/2017 3:08:20 PM] Using cached update config and server: https://megui.org/auto/
--[Information] [11/17/2017 3:08:20 PM] No package requires an update
-[Information] FileIndexer
--[Information] [11/17/2017 3:08:52 PM] MediaInfo
---[Information] [11/17/2017 3:08:52 PM] File: E:\Filme zum encoden\Test\test\test123.mkv
---[Information] General
----[Information] Format: Matroska
----[Information] FormatString: Matroska
----[Information] FileSize: 2495397599
----[Information] PlayTime: 01:33:51.062
---[Information] Video
----[Information] ID: 1
----[Information] StreamOrder: 0
----[Information] Width: 1280
----[Information] Height: 688
----[Information] FrameCount: 135010
----[Information] FrameRate: 23.976
----[Information] FrameRateOriginal:
----[Information] FrameRateMode: CFR
----[Information] ScanType: Progressive
----[Information] Codec: V_MPEG4/ISO/AVC
----[Information] CodecString: AVC
----[Information] Bits Depth: 8
----[Information] Format: AVC
----[Information] AspectRatio: 1.860
----[Information] AspectRatioString: 1.85:1
----[Information] Delay: 0
----[Information] Title: encounters-arreunfe_720p
----[Information] Language:
----[Information] LanguageString:
----[Information] Default: Yes
----[Information] DefaultString: Yes
----[Information] Forced: No
----[Information] ForcedString: No
---[Information] Audio
----[Information] ID: 2
----[Information] StreamOrder: 1
----[Information] Format: DTS
----[Information] FormatProfile:
----[Information] FormatSettingsSBR:
----[Information] FormatSettingsPS:
----[Information] Muxing Mode:
----[Information] SamplingRate: 48000
----[Information] SamplingRateString: 48.0 kHz
----[Information] Channels: 6
----[Information] ChannelsString: 6 channels
----[Information] ChannelPositionsString2: 3/2/0.1
----[Information] BitRateMode: CBR
----[Information] Title: German DTS 5.1 @ 1 509 kb/s
----[Information] Language: de
----[Information] LanguageString: German
---[Information] Chapters
----[Information] 00:00:00.000: en:00:00:00.000
----[Information] 00:07:32.994: en:00:07:32.994
----[Information] 00:16:27.653: en:00:16:27.653
----[Information] 00:23:46.717: en:00:23:46.717
----[Information] 00:30:33.040: en:00:30:33.040
----[Information] 00:38:34.979: en:00:38:34.979
----[Information] 00:46:38.504: en:00:46:38.504
----[Information] 00:54:24.261: en:00:54:24.261
----[Information] 01:02:42.342: en:01:02:42.342
----[Information] 01:09:08.436: en:01:09:08.436
----[Information] 01:16:43.140: en:01:16:43.140
----[Information] 01:25:50.812: en:01:25:50.812
-[Information] Log for job1 (ext, test123.mkv -> )
--[Information] [11/17/2017 3:08:56 PM] Started handling job
--[Information] [11/17/2017 3:08:56 PM] Preprocessing
--[Information] [11/17/2017 3:08:56 PM] MediaInfo
---[Information] [11/17/2017 3:08:56 PM] File: E:\Filme zum encoden\Test\test\test123.mkv
--[Information] [11/17/2017 3:08:56 PM] Job command line: "E:\MeGUI x86\tools\mkvmerge\mkvextract.exe" "E:\Filme zum encoden\Test\test\test123.mkv" tracks 1:"E:\Filme zum encoden\Test\test\test123 - [0] German.dts" --ui-language en
--[Information] [11/17/2017 3:08:56 PM] Process started
--[Information] [11/17/2017 3:08:56 PM] Standard output stream
---[Information] [11/17/2017 3:08:56 PM] Extracting track 1 with the CodecID 'A_DTS' to the file 'E:\Filme zum encoden\Test\test\test123 - [0] German.dts'. Container format: Digital Theater System (DTS)
--[Information] [11/17/2017 3:08:56 PM] Standard error stream
--[Information] [11/17/2017 3:09:00 PM] Postprocessing
---[Information] [11/17/2017 3:09:00 PM] Deleting intermediate files
--[Information] [11/17/2017 3:09:00 PM] Job completed
-[Information] Log for job2 (idx, test123.mkv -> test123.mkv.lwi)
--[Information] [11/17/2017 3:09:00 PM] Started handling job
--[Information] [11/17/2017 3:09:00 PM] Preprocessing
--[Information] [11/17/2017 3:09:00 PM] Job command line: "C:\Windows\system32\ping.exe" 127.0.0.1 -t
--[Information] [11/17/2017 3:09:00 PM] Process started
--[Information] [11/17/2017 3:09:00 PM] Standard output stream
--[Information] [11/17/2017 3:09:00 PM] Standard error stream
--[Information] [11/17/2017 3:09:00 PM] AviSynth script
---[NoImage] LoadPlugin("E:\MeGUI x86\tools\lsmash\LSMASHSource.dll")
---[NoImage] LWLibavVideoSource("E:\Filme zum encoden\Test\test\test123.mkv")
--[Information] [11/17/2017 3:09:05 PM] MediaInfo
---[Information] [11/17/2017 3:09:05 PM] File: E:\Filme zum encoden\Test\test\test123.mkv.lwi
---[Information] Indexed File: E:\Filme zum encoden\Test\test\test123.mkv
--[Information] [11/17/2017 3:09:05 PM] Postprocessing
---[Information] [11/17/2017 3:09:13 PM] Deleting intermediate files
--[Information] [11/17/2017 3:09:13 PM] Job completed
-[Information] AutoEncode
--[Information] E:\Filme zum encoden\Test\test\test123.mkv-muxed.avi
---[Information] [11/17/2017 3:10:02 PM] No Target Size (use profile settings)
---[Information] [11/17/2017 3:10:02 PM] Split Size: null
---[Information] Eliminating duplicate filenames
----[Information] [11/17/2017 3:10:02 PM] Video output file: E:\Filme zum encoden\Test\test\test123.mkv.m4v
----[Information] [11/17/2017 3:10:02 PM] Muxed output file: E:\Filme zum encoden\Test\test\test123.mkv-muxed.avi
----[Information] [11/17/2017 3:10:02 PM] Encodable audio stream 0: E:\Filme zum encoden\Test\test\test123 - [0] German.ac3
-[Information] Log for job3 (audio, test123 - [0] German.dts -> test123 - [0] German.ac3)
--[Information] [11/17/2017 3:10:02 PM] Started handling job
--[Information] [11/17/2017 3:10:02 PM] Preprocessing
--[Information] [11/17/2017 3:10:02 PM] MediaInfo
---[Information] [11/17/2017 3:10:02 PM] File: E:\Filme zum encoden\Test\test\test123 - [0] German.dts
----[Information] FormatString: DTS
----[Information] FileSize: 1062158944
----[Information] [11/17/2017 3:10:02 PM] The language information is not available for this track. The default MeGUI language has been selected.
--[Information] [11/17/2017 3:10:02 PM] Trying to open the file with LWLibavAudioSource()
--[Information] [11/17/2017 3:10:07 PM] Successfully opened the file with LWLibavAudioSource()
--[Information] [11/17/2017 3:10:12 PM] AviSynth script
---[NoImage] ClearAutoloadDirs()
---[NoImage] AddAutoloadDir("E:\MeGUI x86\tools\avs\plugins")
---[NoImage] LWLibavAudioSource("E:\Filme zum encoden\Test\test\test123 - [0] German.dts")
---[NoImage] # detected channels: 6
---[NoImage] # detected channel positions: 3/2/0.1
---[NoImage] 32==Audiobits(last)?ConvertAudioTo16bit(last):last
---[NoImage] return last
--[Information] [11/17/2017 3:10:12 PM] Command line used: -i - -y -acodec ac3 -ab 448k "{0}"
--[Information] [11/17/2017 3:10:12 PM] AviSynth script environment opened
--[Information] [11/17/2017 3:10:17 PM] Script loaded
--[Information] [11/17/2017 3:10:17 PM] Output Decoder
---[Information] [11/17/2017 3:10:17 PM] Channels: 6
---[Information] [11/17/2017 3:10:17 PM] Bits per sample: 16
---[Information] [11/17/2017 3:10:17 PM] Sample rate: 48000
--[Information] [11/17/2017 3:10:17 PM] Job command line: E:\MeGUI x86\tools\ffmpeg\ffmpeg.exe -i - -y -acodec ac3 -ab 448k "E:\Filme zum encoden\Test\test\test123 - [0] German.ac3"
--[Information] [11/17/2017 3:10:17 PM] Process started
--[Information] [11/17/2017 3:10:17 PM] Standard output stream
--[Information] [11/17/2017 3:10:17 PM] Standard error stream
---[Information] [11/17/2017 3:10:17 PM] ffmpeg version 3.4 Copyright (c) 2000-2017 the FFmpeg developers
---[Information] [11/17/2017 3:10:17 PM] built with gcc 7.2.0 (GCC)
---[Information] [11/17/2017 3:10:17 PM] configuration: --enable-gpl --enable-version3 --enable-sdl2 --enable-bzlib --enable-fontconfig --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libfreetype --enable-libmp3lame --enable-libopenjpeg --enable-libopus --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libtheora --enable-libtwolame --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxml2 --enable-libzimg --enable-lzma --enable-zlib --enable-gmp --enable-libvidstab --enable-libvorbis --enable-cuda --enable-cuvid --enable-d3d11va --enable-nvenc --enable-dxva2 --enable-avisynth --enable-libmfx
---[Information] [11/17/2017 3:10:17 PM] libavutil 55. 78.100 / 55. 78.100
---[Information] [11/17/2017 3:10:17 PM] libavcodec 57.107.100 / 57.107.100
---[Information] [11/17/2017 3:10:17 PM] libavformat 57. 83.100 / 57. 83.100
---[Information] [11/17/2017 3:10:17 PM] libavdevice 57. 10.100 / 57. 10.100
---[Information] [11/17/2017 3:10:17 PM] libavfilter 6.107.100 / 6.107.100
---[Information] [11/17/2017 3:10:17 PM] libswscale 4. 8.100 / 4. 8.100
---[Information] [11/17/2017 3:10:17 PM] libswresample 2. 9.100 / 2. 9.100
---[Information] [11/17/2017 3:10:17 PM] libpostproc 54. 7.100 / 54. 7.100
---[Information] [11/17/2017 3:10:17 PM] Guessed Channel Layout for Input Stream #0.0 : 5.1
---[Information] [11/17/2017 3:10:17 PM] Input #0, wav, from 'pipe:':
---[Information] [11/17/2017 3:10:17 PM] Duration: N/A, bitrate: 4608 kb/s
---[Information] [11/17/2017 3:10:17 PM] Stream #0:0: Audio: pcm_s16le ([1][0][0][0] / 0x0001), 48000 Hz, 5.1, s16, 4608 kb/s
---[Information] [11/17/2017 3:10:17 PM] Stream mapping:
---[Information] [11/17/2017 3:10:17 PM] Stream #0:0 -> #0:0 (pcm_s16le (native) -> ac3 (native))
---[Information] [11/17/2017 3:10:17 PM] Output #0, ac3, to 'E:\Filme zum encoden\Test\test\test123 - [0] German.ac3':
---[Information] [11/17/2017 3:10:17 PM] Metadata:
---[Information] [11/17/2017 3:10:17 PM] encoder : Lavf57.83.100
---[Information] [11/17/2017 3:10:17 PM] Stream #0:0: Audio: ac3, 48000 Hz, 5.1, fltp, 448 kb/s
---[Information] [11/17/2017 3:10:17 PM] encoder : Lavc57.107.100 ac3
---[Information] [11/17/2017 3:11:24 PM] video:0kB audio:307949kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.000000%
--[Information] [11/17/2017 3:11:24 PM] MediaInfo
---[Information] [11/17/2017 3:11:24 PM] File: E:\Filme zum encoden\Test\test\test123 - [0] German.ac3
----[Information] Format: AC-3
----[Information] FormatString: AC-3
----[Information] FileSize: 315340032
----[Information] PlayTime: 01:33:51.072
----[Information] [11/17/2017 3:11:24 PM] The language information is not available for this track. The default MeGUI language has been selected.
--[Information] [11/17/2017 3:11:24 PM] Postprocessing
---[Information] [11/17/2017 3:11:24 PM] Deleting intermediate files
----[Information] [11/17/2017 3:11:24 PM] Successfully deleted E:\Filme zum encoden\Test\test\test123 - [0] German.dts.lwi
--[Information] [11/17/2017 3:11:24 PM] Job completed
-[Error] Log for job4 (video, test123.mkv.avs -> )
--[Information] [11/17/2017 3:11:24 PM] Started handling job
--[Information] [11/17/2017 3:11:24 PM] Preprocessing
--[Information] [11/17/2017 3:11:24 PM] AviSynth input script
---[NoImage] #deinterlace
---[NoImage] #crop
---[NoImage] LanczosResize(720,384) # Lanczos (Sharp)
---[NoImage] #denoise
--[Information] [11/17/2017 3:11:31 PM] resolution: 720x384
--[Information] [11/17/2017 3:11:31 PM] frame rate: 24000/1001
--[Information] [11/17/2017 3:11:31 PM] frames: 135010
--[Information] [11/17/2017 3:11:31 PM] aspect ratio (avs): 15:8 (1.875)
--[Information] [11/17/2017 3:11:31 PM] Job command line: "E:\MeGUI x86\tools\xvid_encraw\xvid_encraw.exe" -i "E:\Filme zum encoden\Test\test\test123.mkv.avs" -pass1 "E:\Filme zum encoden\Test\test\test123.mkv.stats" -bitrate 1550 -max_key_interval 250 -turbo -vhqmode 4 -bvhq -qtype 1 -nopacked -masking 1 -notrellis -imin 1 -bmin 1 -pmin 1 -threads 8 -par 1
--[Information] [11/17/2017 3:11:31 PM] Process started
--[Information] [11/17/2017 3:11:31 PM] Standard output stream
---[Information] [11/17/2017 3:11:31 PM] xvid_encraw - raw mpeg4 bitstream encoder written by Christoph Lampert
--[Information] [11/17/2017 3:11:31 PM] Standard error stream
---[Information] [11/17/2017 3:11:31 PM] Trying to retrieve width and height from input header
---[Information] [11/17/2017 3:11:31 PM] Can't open avi/avs file E:\Filme zum encoden\Test\test\test123.mkv.avs
--[Error] [11/17/2017 3:11:31 PM] Process exits with error: 0xFFFFFFFF (-1)
--[Information] [11/17/2017 3:11:31 PM] Job completed
Alles anzeigen
