Hallo zusammen!
Nach längerer Pause hat sich mal wieder was beim BSPlayer getan, aktuell ist Version 1.00 RC1 Build 805 vom 27.01.04
Changes:
ZitatAlles anzeigenVersion 1.00 RC1 Build 805 released (27 Jan 2004)
- Support for subtitles in OGM files was broken, fixed
- Broken audio stream switching, fixed
Version 1.00 RC1 Build 804 released (26 Jan 2004)
- Fixed some bugs with OGM files
- Fixed -asX command line option
- If for ex. second audio stream was choosen and next movie has only one audio stream there was no sound, fixed
- 'Add directory' playlist command, didn't add custom defined extension, fixed
- Fixed problem with taskbar
- Fixed bug with subtitles in Matroska files (part of previous subtitle was visible)
- Fixed bug with 'scrambled' subtitles and OSD when 'Draw to overlay surface' option was enabled
* In full screen skins when you move mouse over seek bar, it now shows time and % instead of only %
* Window moving should be more smooth under Win9x now (like in 0.86 versions)
+ Added support for (SRT) subtitles embeded in AVI files (created for ex. with AVIMux GUI)
+ Added option to choose file name in 'Export bookmarks' dialog
+ Added support for multiple audio streams in MPEG files
+ It's now possible to assign double click to actions
+ Added option to load custom fonts for skins (look in .\Base\skin.ini file for syntax)
Das ganze gibt's hier.
Cu Rippraff
