ZitatAlles anzeigenChangelog:
*1.005b
-Added some error trapping to the gui.
-Added a frame stepper to the visual chapter editor.
-Removed msdxm.ocx from the installer. Every windows user should already have this on their system anyway. If the user chooses to install the runtime files, the installer will still re-register the msdxm and associated files.
-Updated pxsup2dast to the Aug 14 version.*1.005
-Fixed bug in the menu editor, that caused alignment problems with monitors larger than 1024x768.
-Added an auto-chapter creator.
-Added a new form to the menu editor, allowing the user to define more parameters to the menu when it times out.
-Added function that allows projects to be opened without using fully qualified paths. (meaning projects can be shared now, from computer to computer, or folder, to folder)
-Added dscaler5 to the installer.
DVDAuthor + GUI ( WIN32 )
Changelog konnte ich leider nicht finden.
=> Installieren, da ist es dabei.
Zitat*1.006test - 1.007
-replaced version 6 of dscaler, with version 5. version 6 had some alignment problems with the menu editor.
-Added the XML encoding form. This may be useful for users that aren't using standard characters (a-z, A-Z, 0-9, spaces, dashes, etc)
-Added a cleanup routine that cleans up unused folders before authoring.
-The sup color defaults are stored in the registry so a user doesn't need to rekey them every time. -
Update:
DVDAuthorGUI v1.008
DVDAuthorGUI v1.008bChangelog:
*1.008
-Fixed a bug in the 'load project' code. Previously, if a menu didn't have buttons, it was loading the buttons from the previous menu.
-Changed the sup dialog to say "SubtitleCreator' format, since pxsup2dast seems to be more compatible with sup files generated with that.
-Added a dialog that prompts the user before closing the menu editor dialog box.
-using better code to check the existence of the project files in the project loader.
-Updated the tips pdf with some helpful tips and ideas for creating good menus.*1.008b
-Fixed a small problem with the code that checks the existence of the project files when loading the dva. -
Update...
Gui for dvdauthor Version 0.99
Changelog spar ich mir (wäre zu lang).
Wichtig (auch für andere dvdauthor GUIs):
- Neue dvdauthor version, welche den 11000 Sekunden Bug behebt (Bisher Absturz von dvdauthor bei Filmlänge > 11000 Sekunden ~ 3 Stunden 5 Minuten).Weiteres hier:
http://www.videohelp.com/~gfd/GUI_DVDauthor_01.html -
Danke Borax.
Dies ist allerdings der Thread zu einer anderen GUI für den DVD Author.
Zumindest bisher.Ich bin nun nicht völlig sicher ob man das besser trennen sollte.
MfG
Naja, nicht ganz. War 'früher' schon gemischt. Siehe Post 10, 13... GFD ist hier im Board aber anscheinend nicht so beliebt.
Hast recht, hab ich übersehn. Ich trenne nur immer alles gern voneinnander... jedes in seinem Thread. Is halt so bei mir. :zunge:Zitat von boraxGFD ist hier im Board aber anscheinend nicht so beliebt.
Naja, so sicher bin ich mir da nicht.
Bei mir war es nur so, das ich nicht mit der Bedienung klar kam auf die schnelle. Müsst ich mir schon mal wieder anschauen.Gruss
Es gibt schon eine 0.6.13 und hier die Win Version
DVDAuthor
0.6.14: February 24, 2007
popen mode must be 'r' or 'w', not 'rb' or 'wb'
make spuunmux escape filenames in xml file
properly skip padding bytes in pack header in spuunmux
only allow spuunmux to process mpeg-2 files
fix bug in setting the resolution field of VTS/VMGMDownload Windows Version Cygwin und MingW Version
MingW Version nur dvdauthor.exe Cygwin komplett mit dvdunauthor (legale version)
(0.6.14: February 24, 2007) DVDAuthor Version mit mingw kompiliert
incl (dvdauthor, mpeg2desc, spumux, and spuunmux.exe)
Mehr war mir zur Zeit nicht möglich. Es sind keine DLLs usw erforderlich.
Es fehlt also nur DVDUnauthor.exe. Dieser meckert aber wegen den dvdread Header Dateien rum das irgendwelche Funktionen nicht da sind.
neue version von mjpegtools fuer mingw: http://www.savefile.com/projects/808656084
- libraries auf neuesten stand gebracht
- png2yuv speicherproblem korrigiert -
dvdauthor 0.6.14-GfD-2 (http://www.savefile.com/projects/808564094):
- Letztstand der verwendeten libraries
- verlaengern der vobunit nur bei 'single frame mpegs'mjpegtools (http://www.savefile.com/projects/808656084):
- im Log keine vollstaendigen Pfade schreiben -
Bitte beschränkt euch darauf, in diesem News-Beitrag nur aktuelle Versionen zu nennen.
Diskussionen darüber, wie man den DVDAuthor und seine GUIs am besten modifizieren und portieren kann, passen doch besser in die Softwareentwicklung:
GUI for dvdauthor Version 1.05
enthält die dvdauthor mingw Version von ssbssa. Alles weitere siehe Signatur.
GUI for dvdauthor Version 1.07
Ein paar Bugfixes:
- CPU Abhängigkeit (Crash bei manchen CPUs) bei mjpegtools mingw version (png2yuv, mplex...) entfernt (Dank ssbssa)
- Fehler bei mplex: "Need to split output but there appears to be no %d in the filename pattern" behoben (Dank ssbssa) -
Eine neue version of DVDAuthor ist da:
ZitatHello,
now I have taken all commits of Lawrence D'Oliveiro until 2009-11-23 from his site
http://github.com/ldo/dvdauthor/commits/
and I have made an (un)official release 0.6.17 of dvdauthor.You can find my source packages and patch package here:
http://www.joonet.de/dvdauthor/ftp/And my debian packages can be found here:
http://www.joonet.de/dvdauthor/debian/Ciao, Joo
Kann jemand eine windows (mingw) build machen?
Danke,
The Mask
(un)official release DVDAuthor 0.6.17
