Neue Version 0.9.4: http://www.videolan.org/
VideoLan Client - Aktuelle Version
Mittlerweil ist Version 0.9.6 aktuell: http://www.videolan.org/
Schon wieder eins: 0.9.7 http://www.chip.de/downloads/VLC-media-player_13005928.html
Und noch einer: VLC media player 0.9.8a
http://www.chip.de/downloads/c1_d…8552881&v=3600&http://www.chip.de/downloads/VLC-media-player_13005928.html
Neue Version: VLC 0.9.9 http://www.videolan.org/
VLC media player 1.0.0 - Goldeneye
- Free, Open Source and cross-platform
- Independent of systems codecs to support most video types
- Live recording
- Instant pausing and Frame-by-Frame support
- Finer speed controls
- New HD codecs (AES3, Dolby Digital Plus, TrueHD, Blu-Ray Linear PCM, Real Video 3.0 and 4.0, ...)
- New formats (Raw Dirac, M2TS, ...) and major improvements in many formats...
- New Dirac encoder and MP3 fixed-point encoder
- Video scaling in fullscreen
- RTSP Trickplay support
- Zipped file playback
- Customizable toolbars
- Easier encoding GUI in Qt interface
- Better integration in Gtk environments
- MTP devices on linux
- AirTunes streaming
- New skin for the skins2 interface
1.0.5
Zitatchanges between 1.0.4 and 1.0.5:
--------------------------------decoders:
* subrip extra styles improvements
* fix potential crashes in ssa and svg decodersmac os x interface:
* improved support for the 2009 apple remotewindows port:
* use of gcc 4.4.2 to compile instead of gcc 4.2. This might slightly increase performance and fix x264 issuestranslations:
* portuguese brazilian, lithunanian, romanian, ukranian, japanese, bengali, walloon, galician, danish, khmer, polish, slovenian, vietnamese, finnish russian, slovak translation updates
* new malayalam, macedoninan, nynorsk translationschanges between 1.0.3 and 1.0.4:
--------------------------------audio outputs:
* fix deadlocks in the audio output core
* make pulseaudio the default output if availablevideo outputs:
* fix fullscreen mode with kde 4.3.3 and other window managers
* fix incompatibility with cairo-dock and compositinginput:
* fix dvb scanning regression from vlc 1.0.3
* support for xz-compressed byte stream (lzma algorithm)playlist:
* support for .m3u8 playlist files (utf-8 m3u)unix:
* support for xcb-keysyms version 0.3.4 or higher
* fix globalhotkeys on freebsdqt4 interface:
* fix opening v4l version 1 devices
* fix default destination ports in the streaming wizardtranslations:
* new walloon translation
* swedish, ukrainian and french translation updateschanges between 1.0.2 and 1.0.3:
--------------------------------video outputs:
* fix video quality when resizing the video on windows vista and 7, due to
regressions in most popular drivers
* new deinterlacers modules based on yadif and yadif(x2) algorithmsdecoders:
* windows version supports now natively the wma professional codec, as it
didn't work in the packaged version of 1.0.2
* fix downmixing of particual 4.0 ac-3 audio tracksencoders:
* x264 has profile-limitter, like:
#transcode{vcodec=h264,venc=x264{profile=baseline,level=12}..}input:
* update for appletrailers lua script
* fixes on the rar stream filter
* fix for e-ac3 in atsc/ts streams
* various fixes for v4l and v4l2
* fix a crash in mjpeg demuxerservice discovery:
* new udev module for linuxqt4 interface:
* fixes on the playlist and the stream output panelstranslations:
* french, galician, korean, polish, russian, romanian, slovak and ukrainian updateschanges between 1.0.2 and 1.0.3-rc:
* various fixes for v4l and v4l2service discovery:
* russian, korean, ukrainian, french, polish, slovak and galician updateschanges between 1.0.1 and 1.0.2:
* native support for wma professional, without the use of the win32 dlls
* fix issues in subtitles, especially ssa ones
* various fixes on theora and oggdemuxers:
* various fixes for epg support in mpeg-ts demuxer
* fixes for potential stack overflow in .avi, .mp4 and .asf demuxersaccess:
* fixes for v4l2 devices
* fixes for dvb-c channels-scanningqt interface:
* fix some playlist sorting issuesmac os x interface:
* fixed a crash when updating vlc
* fixed a crash related to qtkit when opening video files (10.6 only)
* added the ability to play 2nd media in sync to the primary item (input-slave)
* added the "quit after playback" featuremac os x port:
* the "delete preferences" script is now delivered as a universal binary
with native code for powerpc, intel and intel 64bit
* full 64bit runtime compatibility on both mac os x 10.5 and 10.6
- no support for goom and sdl
- limited text rendering support
- this port is still considered as experimental despite its binary release.Encoders:
* mpeg2 transrate stream output removed
* x264 default-values closer to x264.exe defaults.
* x264 rc-behaviour fixes:
- if user defines qp-value, cqp-mode is used
- otherwise if user defines vb=0, crf-mode is used
- otherwise abr-mode is used
* x264 set vbv-bufsize/vbv-maxsize better if user hasn't defined these:
- abr mode set vbv-max-bitrate=bitrate
- vbv-bufsize is bitrate * seconds between keyframes (keyint/fps)changes between 1.0.0 and 1.0.1:
--------------------------------demuxers:
* fix wmv/asf issues that caused audio to drop
* various fixes for ac3, mp3, dts and stability for wav format
* fix seek in rtsp in conformity to rfc 2326
* fix dailymotion access script
* fix crashes in xspf files handler
* fix seeking and timing issues in some flv files on windows versionaccess:
* add extra caching for files on network shares
* prevent integer underflow in real pseudo-rtsp module, discovered by tixxdz, dzcore labs, algeriadecoders:
* fix seeking in mpeg2 video files
* improve ssa subtitles rendering
* update most codecs for the windows and mac versionmuxers:
* fix sound recording of .flv files with mp3 audioqt interface:
* possibility to change the opacity level of the fullscreen controller
* fix various crashes and video_ts folders openingmac os x interface:
* added options to disable support for apple remote and media keys
* fixed options for volume, last.fm password and subtitle encoding
* fixed redraw issues when autosizing the video window
* preferences panel now includes help through tool-tips
* more reliable information and messages panels
* fix various crasheswindows port:
* the zvbi module is now available for windows, for complete teletext supporttranslations updates for brazillian, french, german, korean, norwegian nynorsk, lithuanian
VideoLAN hat ein Release Candidate von Version 1.1.0 veröffentlicht. Dies kann nun auch DXVA 2 bzw. VAAPI nutzen, um MPEG-4 AVC, MS VC-1 und MPEG-1/2 beschleunigt zu decodieren, und auch VP8 und damit WebM sollen unterstützt werden.
Dies wird nun wohl leider die Veröffentlichung der Version 1.0.6 behindern, in der einige Sicherheitslücken in 1.0.5 korrigiert werden sollten. Weitere Informationen darüber bei heise.
1.1.0
Changes between 1.0.5 and 1.1.0:
--------------------------------Important changes for users:
* On Linux, known bugs in the ALSA library might prevent audio output. Update to alsa-lib v1.0.23-2-g8d80d5f or later, or use the libpulse audio output plugin instead of the ALSA one (if you have PulseAudio).Important changes for packagers:
* The module cache has moved to ${libdir}/vlc/. The module cache can now be generated at install time except if you use staged installation. In the later case, you can generate the module cache in your post-inst script by invoking 'vlc-cache-gen'. If the module cache is not present and vlc can't write in ${libdir}/vlc/, it will result it vlc taking a long time to launch each time.
* Most X11-related plugins now use XCB instead of Xlib. VLC now uses - xproto, - xcb, xcb-shm, xcb-xv, xcb-randr (from libxcb), - xcb-keysyms (from xcb-utils), - x11-xcb (from libx11) - only for GLX support.
* On X11 platforms, a _working_ version of xdg-screensaver is typically required to inhibit the screensaver during video playback.Access:
* Support for the sftp protocol
* Support for CDDB servers for Audio-CD on the Windows port
* New memory input (imem) access and access_demux module to feed VLC from data in memory
* New avio module to use libavformat capabilities for network streams, like rtmp://
* Port of the screen module from Xlib to XCB
* Port of the dc1394 module from libdc1394 to libdc1394 v2.0Decoders:
* Support for DxVA2 for H.264 decoding on GPU on Windows Vista and 7
* Support for VAAPI for H.264 decoding on GPU on GNU/Linux
* Support for Audio/Video decoders and encoders using OpenMAX IL components for DSP* Support PGS subtitles for Blu-Ray
* Support for HD-DVB subtitles - Display Definition Segment
* Invmem module improvements
* Support for Atrac1 audio codec
* Support for SSE3 and SSE4 capabilities in some codecs
* Multiple improvements for subtitles styles in .SRT and .SSA
* Support for native decoding of Windows Media Speech (Voice) audio codec
* Support for AMR-NB audio codec on the Windows and Mac port
* Support for Indeo5 video codec
* Improvements on the FLAC format (7.1 channels and 88.2/176.4/192 kHz support)
* Direct rendering is used more often with H.264 in avcodec module
* Support for MPEG-4 ALS lossless audio codec
* Support for VP8 codec
* Support for 7.1 channels in vorbis audioDemuxers:
* Many fixes on Matroska support (notably seeking) and support for Webm format
* Support for .aob files from DVD-Audio (MLP and LPCM) (Full disc support is NOT present yet)
* Support for ADPCM in .flv streams
* Support for TwinVQ (.vqf) and AMV (.amv) files
* Various EGP improvements
* Support for *****ded subtitles in OpenDML and legacy .avi files
* Metadata and cover art improvementsVideo Output:
* Rewrite of the video output core and most video outputs
* Added desktop mode to the Direct3D output module. It differs from DirectX desktop mode, because it hides the desktop icons, but reacts to mouse clicks.
* New x11, glx and xv modules based on XCB
* New deinterlacing modes based on yadif and yadif(x2)
* New audio/video filter to show audio level on the video output
* Enhanced AtmoLight filter with hardware support forClassic AtmoLight (http://www.vdr-wiki.de/wiki/index.php/Atmo-plugin)Quattro AtmoLight (use just 4 Classic AtmoLights as one)MoMoLight (http://www.ambilight4pc.com/momolight/momolight.html)Simple serial DMX controller (http://www.ulrichradig.de/ search for DMX)Extensions:
* New content extensions framework for luaAudio filters:
* Chorus/Flanger audio filter
* 3F1R to stereo down-mix filter
* Dolby mixer, parameterized equalizer, trivial mixer, scaletempo, bandlimitedresampler, linear resampler, ugly resampler, converter_fixed, DTS to SPDIFand A/52 to SPDIF filters have been upgraded to the "audio filter2" API
* NEON assembly audio converter module
* Converter filters have been rewritten and extended to support s32 as inputPlaylist:
* WPL and ZPL playlist support
* Lua scripts for Mpora, Vimeo playback and Rockbox FM radios
* New Play-And-Pause function to stop playback on latest video image
* Podcast images are now displayedService discovery:
* Service discoveries can now be written in lua
* Service discovery for Picture/Music/Video user directories
* Service discovery based on libudev
* Shoutcast Service discoveries are now removedEncoders:
* x264, add psy-rd parameter and change default settings
* x264, add profile-limitter same way as x264.exe has, for example#transcode{vcodec=h264,venc=x264{profile=baseline,level=1.2},vb=384,width=320,height=176}
* x264, defaults to crf=23 as x264.exe-does, if bitrate is given, uses ABR and if qp-value is set uses CQP
* libx264-version 0.76 or higher is required
* x264 has tune/preset parameters supportedStream output:
* New smem module, streaming to memory
* Allow duplicate outputs to be merged, like: --sout "#duplicate{dst=transcode{vcodec=mp2v},select=es=0,dst=transcode,select=es=1}:std{...}"Interfaces:
* Renamed the legacy rc, telnet and http interfaces to oldrc, oldtelnet and oldhttp.
* rc, telnet and http are now implemented using the lua interface system.
* qt4 interface contains new iconview and listview mode for playlistVisualization:
* Support of .milk visualization files using projectM librariesMac OS X Port:
* Vastly improved VLCKit framework
* A new dialog provider for libvlc-internal interaction without full interface
* Improved update detection and installation by using the Sparkle framework by Andy Matuschak et al.
* New CoreText based text renderer replacing the former ATSUI renderer
* New Video output module (mostly targetting VLCKit)
* Optimised behavior when using the 2009 Apple RemoteWindows port:
* Integration in Windows 7 taskbar
* Playback of .Midi files is supported through fluidsynth's moduleMaemo port:
* Multiple improvements for N900 compliance and efficiency
* Support for HW accelerated video decoding on N900
* Improvements to the maemo/hildon interfaceMisc:
* new sqlite module
* --save-config command line option not supported anymore.
* Fixed and reenabled netsync module.
* Improved Solaris portBindings:
* new C++ wrapper around libVLC: libVLCpp
* phonon-VLC backend is now usableRemoved modules:
* csri codec: use the libass module instead.
* galaktos visualisation: use the new projectM module instead.
* showintf: Useless in Qt and on Mac OS X
* transrate: broken since too long
* Xlib x11, Xlib xvideo, Xlib glx: Use the new XCB modules instead.
* HAL: Use libudev instead.
* gtk_main, gtk_main2, gnome_main, gnome_main2 and pda interfaces
* WinCE, BeOS and qnx interfaces
* opie, qte and qte_main interfaces
* linear_resampler and trivial_resampler are removed: use the ugly one.
* XvMC accelerated modules: use VAAPI instead.
* MGA (Matroska) for Linux: use Linux Framebuffer (or X) instead.
* opengllayer: use macosx_video instead.
* cddax: use cdda instead.
* cmml and tarkin codecs are removed because they are dead codecs.
* realaudio codecs: use libavcodec
* access_file removed in favor of filesystem
* RTMP input and output: use avio module -
1.1.3
ZitatAccess and demuxers:
* fixes for FTP relatives path and FTP directory support
* fix for podcasts parsing
* DVD: fix an assert error and various memory leaksTaglib:
* fix NULL dereferences, as reported by FortiGuard Lab,
CVE-2010-2937 / VideoLAN-SA-1004Playlist:
* fix a regression where the wrong entry was played
* fix m3u playlists exportsSkins2:
* fix video autoresize behaviourTranslations:
* Update translations for Dutch, Sinhala, Hebrew, Estonian, Spanish and BengaliWindows and Mac:
* Update of many codecs libraries, fixing bugs and improving speedMac:
* architecture-specific installations will now be replaced by specific updatesBSD:
* Add AltiVec detetion for OpenBSD/powerpc -
1.1.4 test
ZitatWin32:
* Fix a security issue when loading DLLs, especially in Qt4 and dmo modules,
See VideoLAN-SA-1005
* Fix folders opening from the interfaceTranslations:
* Update translations for Lithuanian, Bengali, Slovak, French, Dutch, Ukranian
Polish, Simplified Chinese, German and Galician -
1.1.5
ZitatSecurity:
* Fix a Windows crash on accessing Network Shared files/drives,VideoLAN-SA-1006Access:
* Support for RTP access for H264 streams by specifying the demux in the MRLServices Discovery:
* Integration in the playlist, of a list of web shows, provided by channels.comDemuxers:
* Game Music Emu (GME) plugin rewritten, using the proper C API
* DVDnav and DVDread fixes for encoding and misc issues
* Playback of live http .Webm streams
* Taglib thread-safety fixDecoders:
* Fix decoding of H264 using DxVA2 using Intel IGP, thanks to the donation from "Puget Systems"Skins:
* Add an icon to VLC on LinuxVideo Output:
* fix a bug that could lead to 100% CPU usage on XCBInterfaces:
* fix for Qt bug where VLC didn't exit properly on some Windows XP configuration
* fixes on luatelnet and luarcMiscellaneous crashes and fixes in various plugins (telnet, live555, theora and
TS-mux, Qt)libLVC:
* add libvlc_media_new_fd() to play directly file descriptors (not Win32/Win64)
* Miscellaneous fixesTranslations:
* Update translations for Walloon, Lithuanian, Spanish, Turkish, Estonian, Dutch, Bengali, German, Polish, Brazillian Portuguese, Japanese, Italian, Galician, French and Ukrainian
* Major update and activation on Windows of Modern Greek
* New Asturian translation -
1.1.6
Zitat* Security updates in codecs and demuxers
* Support for RTP/PCM 24bits, audio/L24
* Support for MPC SV7/SV8 on Windows and MacOS builds
* Faster Webm/VP8 decoding
* Support for Midi on MacOS
* Major updates in most language translations* Support for projectM visualisation on Windows
* KDE and PulseAudio integration improvements
* Subtitles fixes and improvements
* Improvements in visualisations and interfaces
* Codecs updates
* Many miscellaneous fixes -
1.1.7
ZitatLinux port:
* Integration with the KDE GUI platform is disabled due to KDE bugs #234484 and #260719.Mac OS X port:
* Updated live555 library to fix playback of RTSP and Freebox streams
* Running VLC in 64bit mode requires Mac OS X 10.6.0 or later for speed and stability reasonsDemuxers:
* Fix for Matroska / WebM remote code execution vulnerability. VideoLAN-SA-1102Translations:
* Update for Hebrew, Japanese, Danish and Russian translations -
1.1.8
Mac OS X Interface:
* New UI graphics by Damien ErambertInterfaces:
* Oldrc interface is again the default RC interface, on Windows
* Luarc, luahttp and luatelnet fixes
* Qt and Mac OS X fixes
* numerous Skins2 fixes, notably winamp2 skinsEncoder:
* new libschroedinger-based Dirac codec encoder, faster than the current oneAccess/Demuxers/Codecs:
* Subtitles auto-detection is back for .txt files
* vod/rtsp server and rtsp input fixes
* mp4 demuxer improvements
* ogg, rstp input, video filters minor fixes
* taglib's replaygain is fixed for mp3
* vobsub support has an improved auto-detection
* fix a crash in malformed ape filesMiscellaneous fixes in:
* Pulseaudio audio output, notably for usb cards
* Stacktraces are now limited in size on Windows
* Video resolution is now limited to 8192x8192, for security reasons
See CORE-2011-0208
* Configure and build system improvements
* DirectShow and BDA build headers have been updatedTranslations:
* Update for Finnish, Galician, Dutch, Chinese, German, Japanese, Lithuanian, Slovak, French, Polish, Estonian, Brazillian Portuguese and Hebrew
* New icelandic translation -
Gefährliche Sicherheitslücken ....
1.1.9
ZitatWindows and Mac OS X:
* Update of external library modplug, to address a security issueDemuxers:
* mp4: Fix heap-based buffer overflow (VideoLAN-SA-1103)Mac OS X Interface:
* Miscellaneous interface look adjustments
* Improve Apple Remote handling
* Fixe bugs in the Streaming / Transcoding wizard
* Layout fixes in the Preferences and Controls windows
* Fix incomplete list of hotkeys in the Preferences dialog
* Fix quitting through Apple Events (Dock menu, App Switcher, AppleScript, etc.)Mac OS X Port:
* Fix Growl local notification plugin
* VLC bundle now includes the Growl framework
* Fixes for eyeTV
Translations:
* Updates of Lithuanian, Estonian, Chinese, Japanese, Bengali, Dutch, Polish, German, Galician, Traditional Chinese translations
* New Luganda Translation -
1.1.10
* Update of external library modplug, to address multiple security issuesMac OS X Interface:
* Improved Media Key handling based upon SPMediaKeyTap by Spotify AB
* Fix for various crashes and small issuesDemuxer:
* Fix heap corruption / integer overflow in XSPF playlist parserAudio output:
* PulseAudio output re-written due to unstability of the current oneWin32 port:
* Remove the fontconfig dependency from the freetype moduleMiscellaneous fixes in:
* Windows 7 taskbar buttons
* Qt interface
* asx, live555, dvdnav demuxer
* RTP output and XML export
* Subtitles colours when using GPU decoding on Windows
* v4l2 accessTranslations:
* Update of Norwegian Bokmål, Slovak, Afrikaans, Luganda, Brazillian Portuguese, Irish, Thai, Estonian, Chinese, Polish, Dutch, German, Galician, Bulgarian, Lithuanian and Japanese translations
* Initial Basque, Zulu, Peul, Amharic, Acoli, Chiga translations -
1.1.11
ZitatSecurity:
* Fix buffer overflows in the RealMedia demuxer (CVE-2011-2587) and the AVI one (CVE-2011-2588).Mac OS X:
* Fixed scrolling direction if the input device's signal is inverted
* Update Auhal audio output to the latest API
* Fix images disappearing issue on the interface
* Reduced installation size by up to 30 MB
* Resolved conflict between iTunes and VLC wrt Media Key handlingMozilla/ActiveX webplugin:
* Fullscreen mode is fixed on Win32
* Very simple fullscreen controller is visible on Win32Demuxers/Meta Readers:
* Better support for cover art *****ded in mp4, wmaMuxers/Output:
* Fix AVI muxer so the generated files are readable on other playersExtensions:
* Multiple fixes for crashes and malfunctionning issues
Qt Interface:
* Fix quitting on Linux
* Fix opening of VIDEO_TS folders through the open disc dialog on Windows
* MiscellaneousWin32 port:
* Update of codecs, fixing the mpeg-2 decoder crashTranslations:
* Update of Slovak, Lithunanian, Russian, Brazillian Portuguese, Serbian -
2.0
ZitatChanges between 1.1.13 and 2.0.0:
---------------------------------Important notes:
* The licenses of libVLC and libVLCcore have changed from GPLv2+ to LGPLv2.1+
* Start/end titles/chapters are now specified with # rather than @ to fix
conflicts with some URLs and file names. For instance, this plays a DVD
from the 2nd chapter of the 1st title up to the 4th chapter of the 3rd
title: vlc dvd://#1:2-3:4
* The 40+ --*-caching options were simplified and dumbed down to 4 options:
- --file-caching specifies caching for local files,
- --network-caching specifies caching for network resources,
- --live-caching specifies caching for capture devices and
- --disc-caching specifies caching for local optical media.
All values are expressed in milliseconds as in previous versions.
* HTTP server IP address, port, and TLS configuration is now centralized:
- The --http-host option sets the address, e.g. "--http-host=[2001:db8::1]".
By default, both :: and 0.0.0.0 are used.
- The --http-port and --https-port options set the port numbers.
By default, 8080 is used for HTTP, and 8443 for HTTPS.
- The TLS credentials are configured with --http-cert (public certificate),
--http-key (private key), --http-ca (optional CA) and
--http-crl (optional CRL).
* RTSP server IP address and port are updated similarly.
Use --rtsp-host and --rtsp-port respectively.
* The --miface-addr option does not exist anymore. To select the multicast
output interface, use --miface instead, e.g. --miface=eth0.
* The Windows version will only work with Windows XP SP2 or later.
Windows 2000 SP4, Windows XP < SP2, Windows 2003 SP0 are now unsupported.
* The Mac OS version will require Quartz Extreme compatible machines.Important changes for packagers:
* The default builds now assume that the operating system uses UTF-8 for
its file systems and files content (except the Windows port). If this is
not acceptable, pass --enable-non-utf8 to the configure script.
Non-UTF-8 file systems support will be removed in future versions.
* The VLC plugins path can be overridden with the VLC_PLUGIN_PATH environment
variable. The --plugin-path command line option was removed.
* The default tarballs are now compressed with XZ/LZMA: .tar.xz
* OSS support is not compiled on Linux by default, pass --enable-oss to the
configure script if you use OSSv4 or really want to use OSS emulation.
* The webplugins have moved to: git://http://git.videolan.org/npapi-vlc.gitCore:
* Major Video Core and Outputs rework and rewrite:
Subtitles, subpictures and OSD can now be sized and blent inside outputs
x11 (Unix), OpenGL (Unix) and Direct3D (Windows) are such video outputs.
* Almost every video filter can now be transcoded
* Playback rate doesn't get resetted to 1 between items anymore
* Option --sub-filter was renamed --sub-source
* Port to Android, iOS, OS/2 and Win64.Access:
* Multiple files are now supported inside RAR files
* Experimental support for ClearQam devices in the BDA/DTV module
* DVB-S scanning support on Unix
* DVB-C scanning on Unix scans correct modulation/symbolrate if needed
* Support for freq and video standard selection in DirectShow
* Support for VDR recordings (http://www.tvdr.de/) folders
* Experimental Blu-Ray Discs support using libbluray
* HTTP Live Streaming (IETF draft) playback support
* Blackmagic DeckLink SDI cards input support (Linux only currently)
* Linear Systems (HD-)SDI cards input support (Linux)
* PulseAudio audio input support
* Support for RTP dynamic payload types by specifying the payload format
in an option (no autodetection): only Theora supported for now
* Basic HTCPCP implementation for Coffee Pot control
* Support for all QTKit-compatible video input devices, aka QTCapture
* Support for all QTKit-compatible audio input devices, aka QTSound
* Support for capturing partially hidden windows in the X11 Screen input
* MPEG DASH (Dynamic Adaptive Streaming over HTTP) support
* Support for HTTPS is now fixed in the Windows portCodecs:
* One can now use ffmpeg-mt in conjunction with vlc, to split decoding load
on multiple cores. H.264, VP3, VP8, JPEG-2000, Mpeg-4 ASP/DivX and RV3/RV4
are notably concerned.
* Important fixes for RealVideo 3.0 and 4.0 playback, notably in MKV
* Experimental Hardware decoding using Broadcom CrystalHD cards
* New module for decoding EBU subtitles (.stl)
* Support for 9bits and 10bits H.264/AVC decoding
* Support for 20-bits PCM and DAT-12 (digital magnetic tapes) from RTP
* New module for Dirac encoding, using the faster libschroedinger
The Schroedinger module should be prefered to the Dirac one
* Support for WMV Images, aka WMVP and WVP2, as used by Photo Story
* Support for Lagarith Lossless video codec
* Support for ProRes 422 video codec in 10bits
* Support for DNxHD (VC-3) and JPEG-2000 in 10bits
* EIA-608 closed captions improvements
* Support for JPEG-2000 and Motion JPEG-2000 in the Windows and Mac binaries
* Experimental support of IOMX for OpenMAX IL codecs on Android
* One can use "mp2 " fourcc to encode in mpeg1/2 layer 2Demuxers:
* New images demuxer supporting jpeg, png, targa, xcf, git, tiff, bmp, pcx, lbm
* C64 SID file playback support of using sidplay2
* Support for images/cover art in wma/wmv/asf files
* Improvements in .ape files metadata reading and writing
* New demuxer module for EBU subtitles (.stl)
* Support for caf, mtv, awb, f4v, amr, vro (DVD-VR) files
* Ogg, flv, mxf, amr seeking improvements
* Major improvements in Matroska (mkv) chapters/segments handling and seeking
* Support for duration and better seeking in Mpeg-TS files (.ts, .m2ts, .mts)
* Mov improvements, notably for aspect-ratio handling and Audio DV tracks
* Improved support of tracker files
* Real Media (.rm and .rmvb) demuxer is now based on libavformatInterfaces:
* Qt: effects dialogs rework
* Qt: new CoverFlow-like view of the playlist
* Qt: port to MacOS X platform
* Qt: various interface improvements, notably on the seek bar
* Skins2 / Qt: misc improvements and usability fixes
* Skins2: fullscreen controller support, relative placement support
and important cleanups and optimisations
* Mac OS X: re-written Main Window, which also includes the Video Windows
It is available in 2 looks, one grey (Lion style) and one black (QTX style)
* Mac OS X: new Audio Effects panel adding Compressor and Spatializer filters
* Mac OS X: new Track Synchronization panel
* Mac OS X: new Video Effects panel for color and geometry adjustments
* Mac OS X: re-written Open Disc functionality with automatic media detection
* Mac OS X: support for the native fullscreen mode on OS X Lion
* Mac OS X: enhanced AppleScript support
* Mac OS X: support for lua extensions
* The rc and telnet lua interfaces were merged into a new "cli" interface
* lua: the recommended way to run custom interface scripts is now to pass
-I luaintf --lua-intf myscript
* ncurses: heavy refactor of the complete interface
* dbus: Upgrade to an mpris2 compliant interface, see http://www.mpris.org
* dbus: Rewrite of the main loop to use a more efficient poll-based model
* webUI/http: Rewrite of the web interface, using jQuery
* webUI/http: some requests are now supported in JSON in addition to XML
* webUI/http: path values for input and output are deprecated in favour of uri
* Qt/Win32: the update system now downloads the updates in the temp folder
* Qt: preferences are now searchable
* Qt: the fullscreen controller is now stackable, full-width, at the bottomVideo Output:
* New video output based on Direct2D for Windows 7 and Vista (with Platform Update)
* New video output for iOS platform
* Experimental work in progress on a video output using EGL
* Adaptation of the OpenGL layer for OpenGL ES 1.1
* Various vmem improvements
* OpenGL video output now accepts YUV as input and uses fragment programs for
chroma conversion between YUV and RGB
* New video output for Android platform, based on Surface
* Support for 9/10bits output in the OpenGL output
* Updated OpenGL video output for Mac, requires a Quartz Extreme capable machine
* New video output based on kva API for OS/2Audio Output and Filters:
* New audio output based on AudioQueue API for iOS
* New audio output in memory (amem)
* Important simplification and improvements in the core audio output
* New audio output based on OpenSL ES API for Android
* New audio resampler using Speex (DSP)
* New audio resampler using the Secret Rabbit Code (a.k.a. libsamplerate)
* New Compressor filter, a dynamic range compressor
* New simplistic Karaoke filter
* New audio output based on kai API for OS/2
* Automatic handover from S/PDIF to PCM with PulseAudio 1.0Video Filter:
* New gradfun filter for debanding videos using dithering
* Rewrite of the grain filter, faster and with better quality
* New posterize filter for lowering the number of colors
* Atmo ambilight: improve Fnordlicht support up to 254 channels
* New sepia filter for creating sepia effect in videos
* New deinterlacer mode Phosphor, a framerate doubling CRT TV simulator
* New deinterlacer mode IVTC, to do live inverse telecine for NTSC films
* New subsdelay filter to change subtitles delay
* New anti-flickering filter
* New OpenMAX DL IPCS filter for color space conversion and resizing
* New video filter for denoising, based on the famous hqdn3d filter
* Major improvements in the freetype text-rendering module, notably supporting
blackbox and customizable shadow.
NB: The freetype module is now used by default on the Mac OS X instead of
the quartztext module, which can still be enabled manually.
The Win32 font selection was improved too.Stream output:
* New livehttp-module for HTTP Live Streaming (IETF draft) output
example: vlc inputfile :sout="#transcode{vcodec=h264,acodec=mp3,
venc=x264{profile=baseline},width=320,vb=256,ab=96}:std{
access=livehttp{index=public_html/iphonestream.m3u8,
index-url=http://url-to-iphonestreamfile-###.ts},mux=ts{use-key-frames},
dst=public_html/iphonestreamfile-###.ts}"
* Support for Vorbis and Theora in RTP
* Major rework of VoD support
* New delay module, to introduce delays of one ES, when streaming:
#delay{id=12,delay=500}:standard...
* New setlang, setid modules to change lang or id of one ES, when streaming:
#setid{id=12,new-id=42}:std...
* New langfromtelx module, to change lang of one ES, when streaming, based on
a telextex page: #langfromtelx{id=12,magazine=7,page=0x99,row=1}:std...
* New select module, to replace an existing ES with another ES in the same track
#duplicate{dst=bridge-out{id=1},select=video,dst=bridge-out{id=0xa3},select=audio}
#transcode{...}:bridge-in{id-offset=0}:select{disable=0}:setid{id=0,newid=0xa3}:autodel:std{...}
* New libavformat/avio access_output module for network streamingServices Discovery:
* Search API to be able to query distant search APIs from the interfaces
* Upnp module was ported to Win32libVLC:
* New capabilities for libVLC:
** libvlc_media_player_navigate for DVD navigation
** libvlc_audio_filter_list_get, libvlc_video_filter_list_get to get the
list of available audio and video filters
** libvlc_audio_set_format, libvlc_audio_set_format_callbacks,
libvlc_audio_set_callbacks
allow grabbing audio data from a chosen memory location in real-time.Removed modules:
* asademux, subsass: use libass
* fake, invmem: use the new image demuxers
* hal, v4l, gapi, omapfb, hd1000a, hd1000v: obsolete unmaintained modules
* id3tag: use taglib
* upnp: use upnp_intel
* removal of old telnet interface in favor of the new lua CLI
* removal of http interface in favor of luahttp
* removal of the noise filter
* removal of the SDL audio output, use the native outputs
* growl_udp: use Growl for local notifications on the Mac. UDP support will be
removed in Growl's next release, too.
* removal of the OSSO screensave module, use the MCE oneTranslations:
* Update of translations for most languages.
* New Telugu and Kurmanji translations.Changes between 1.1.12 and 1.1.13:
----------------------------------Security:
* Heap overflow in TiVo demuxer fixed.
* Same default ACL for HTTP requests as for the rest of the HTTP interface.Audio outputs:
* PulseAudio channels mapping (non-stereo) fix.
* PulseAudio stream accidental overflow recovery.Video outputs:
* XVideo support for mixed CPU/GPU endianess (especially on PowerPC).
* XVideo support for automatic color keying.
* xosd Xlib initialization failure fix.Decoders:
* Camtasia decoding fix.Qt interface:
* Rare crash while seeking fixed.
* V4L2 video standard selection fixed.Translations:
* Update of Chinese simplified, Estonian, German and Polish languages.Changes between 1.1.11 and 1.1.12:
----------------------------------Audio outputs:
* Mac OS X / auhal: multiple fixes for the Digital Audio output (S/PDIF)
including support for OS X Lion
* Multiple fixes and improved synchronization for PulseAudio support
* Support for AC-3 and DTS passthrough with PulseAudio 1.0Unix port:
* Fix build compatibility with taglib < 1.6 and Xulrunner 1.9.1Misc:
* Fix crashes with Japanese locale on OS X
* Minor fixes for Webplugin under Win32, AVI demuxer, smem and AudioScrobbler
* Fix crash in HTTP and RTSP server (stream output or Web interface)Translations:
* Update of Breton, Chinese Simplified and Basque -
