wie immer ohne Changelog!
Funktioniert diesmal sogar auch über das NeroProductSetup Update!
Nero - aktuelle Version
The Nero update in September will have updated Nero Digital/Ateme AVC high profile codec (the above comparison uses the old codec build). I have Recode2 version with HP 8x8 transform support installed in my HD, so it is a sure thing finally.
Quelle: http://forum.doom9.org/showpost.php?p=852800&postcount=1Endlich!
Nero Burning Rom 6.6.1.15c
[url=http://www.winfuture.de/downloadstart,1185789560,1307.html]Download[/url]
version 7.10.1.0 http://www.nero.com/nero7/deu/nero7-demo.php ist die aktuellste...
seit heute neu: nero 8
Nero Digital AAC Encoder v1.3.3.0 (2008-09-17)
We just released a new version of our command line AAC encoder, decoder and MPEG-4 tagger applications on our website.
The download can be found here: http://www.nero.com/eng/downloads-…o-aac-codec.php
Note that the version numbers and release notes have not been updated yet. This will happen soon, when translation into all languages is done.Release notes for version 1.3.3.0:
neroAacEnc:
- Improved multichannel encoding
- Solved compatibility issues with some hardware devices
- Improved CBR bitrate control
- Ignore wave file length of 0 on -ignorelength
- Solved issue with very long files and -2pass
- Removed special SSE compile, all optimizations have been merged with the normal compile
- Linux version speed optimized
- Encoder exits gracefully and writes valid MP4 file on ctrl+c
neroAacDec:- Fixed incorrect channel output for 7.1 encodings
neroAacTag:- Linux version available
Das dürfte der richtige Link sein da der obige nicht funktioniert!!
Die URL hat sich im Zuge der neuen Nero-Homepage geändert. Hoffen wir, dass sie jetzt erstma konstant bleibt...
Hmm... mir ist erst gerade aufgefallen das es nun Nero in Version 9 gibt.
9.4.26.0 (October 09, 2009)
ZitatNero CoverDesigner (4.4.17.0)
Changes/Bugfixes:
* Fields are now selectable within the properties menu of the tracklist/directory tool
Nero Recode (4.4.38.1)
Changes/Bugfixes:
* Preview image is sharper when using the “Recode DVDs or main Movies to DVD'” option
Nero Vision (6.4.17.0)
New Features:
* Enhanced support for .WTV file format (Windows Media Center TV Pack 2008 and Windows 7 operating system
Changes/Bugfixes:
* Aspect ratio can now be adjusted when the resolution is set to automatic
* DVD RAM no longer displays as copy protected
* Autorun menu action behaves correctly after burning
* Nero Vision imports files from web cleanlyNero WaveEditor (5.4.37.1)
Changes/Bugfixes:* Status Bar now includes seconds and milliseconds time
Recording Console Timer displays correctlyNero Webinstaller (4.4.18.8)
Changes/Bugfixes:
* SetupX.exe is no longer blocked by Windows Defender in Windows Vista® after rebooting
* Installation files can be easily located on PC.
* Repaired Nero 9 startup failure after updating Norton Internet Security with NavShExt.dll version 16.5.0.134 or after running Windows Defrag 11.5 -
