PgcEdit 0.6.4 beta9 ist raus.
Changes:
Zitat von r0lZ0.6.4beta9 (March 18, 2005)
A. Preview: In trace mode, it is now possible to kill the playback of the current PGC from the preview window.E. Burn DVD: Added a check to ensure that mkisofs.exe is configured in the Burn Setup dialog. Some guys used ImgTool.exe instead!
E. Burn DVD: Added new burn speeds in the speed selector dropdown menu.
E. Menu Viewer/Edit Command button: In expert mode, the "Modify the command for the 2 (or 3) groups?" prompt is not displayed anymore, except when the original commands are not identical in all groups.
E. When loading a new DVD, the Fix number of streams in VMGM/VTSI_MAT tables function do not prompt the user any more to fix the Menu domains with one subpic stream defined but never used by the menu PGCs, because it's legal and frequent on commercial DVDs, and this warning confused some users. However, this check is still made when the Fix number of streams is called from the "DVD" menu, and when opening the Domain Streams Attributes GUI.
W. Added several workarounds for a (possible) bug in TitleWriter: TitleWriter assigns several Title numbers to the same PGC. Now, PgcEdit should support this strange (if not illegal) way to use the VMG_TT_SRPT table.
Gibt's hier.
Cu Rippraff
