DAEMON Tools 4.0.3 x86 und X64
Denkt an die Adware!
Änderungen sind auf der Neuigkeitenseite beschrieben.
ZitatDenkt an die Adware!
ach das ist der haken bei der v4.x versionen
ich habe noch die v3.47
was ist denn daran soo besser das ich mir es runter laden müsste
die emulation wuerde ich sagen.:D
DAEMON Tools v4.09
ZitatAlles anzeigen- Support for StarForce 4.70.
- Support for compressed and encrypted *.mds images which soon will be created by Alcohol and DAEMON Tools Pro.
- Support for compressed and encrypted *.isz images created by UltraISO.
- Fixed some minor issues with image autorun, autostart option etc. (also HKCU is used now instead of HKLM).
- Added "Check for updates" option (periodically checks for new version at each tray start).
- Internal virtual drive engine enhancements.
- Fixed installation problems on Dell systems with Embassy Trust Suite
* encrypted *.isz images created by UltraISO
darauf habe ich gewartet FEINE Sache des!
Und MagicISO kann verschlüsselte UIF-Images erzeugen. Das allerdings scheint ein proprietäres Format zu sein, welches DaemonTools bisher nicht kennen.
Changes in version 4.0.9.1:
- Fixed daemon.dll loading problem with some third party addons.
- Fixed problem reported with *isz images.
- Added some new language strings to lang1033.dll on request from translators.
DAEMON Tools 4.12
ZitatAlles anzeigenWhat's new:
- SPTD 1.55;
- Added new languages;
- Some GUI features to DT Panel;
- Automount option behaviour;Bugs fixed:
- Some minor GUI bugs;
- Setup bugs
DAEMON Tools Lite V. 4.30.0
ZitatWhat's new (compared to DT Lite 4.12.4):
- Updated and improved images engine;
- Adware free! (no more "ad sponsor" check box in setup)
- Languages updates;
- Some minor GUI bugs fixed.
DT Pro version 4.30.0301
- Speed optimization;
- Ability to burn images onto physical CD/DVD/HD DVD/Blu-ray discs (for Advanced version);
- Erase rewritable discs;
- File Associations for supported images;
- Blu-ray and HD DVD devices supporting;
- Image topology information dialog.
V. 4.30.1 Lite:
ZitatAlles anzeigenDAEMON Tools Lite V. 4.30.1 is released
Dear DT Community,The new version of DAEMON Tools Lite is available:
DAEMON Tools Lite Version 4.30.1(included is SPTD version 1.56)
We recommend to upgrade to the latest version as usual.
What's new (compared to DT Lite 4.30.0):
Bugs fixed:
- Image engine fixes;
- B6T images and mini-images mounting fixes;
V. 4.30.0302 Pro:
ZitatRelease Notes, version 4.30.0302:
What's new:
Bugfix release:
- Burning and convertor memory using optimization;
Adware-Module sind seit V4.30.0 Lite nicht mehr enthalten. Dennoch aufpassen, es werden einem immer noch nicht unbedingt notwendige Sachen angeboten (Startseite, Standard-Suchdienst), die man abwählen darf.
DAEMON Tools Lite Version 4.30.4
ZitatAlles anzeigenWhat’s new in this version:
* Windows 7 beta supporting (SPTD 1.58);
* Protected images creation: “Password” field on Disc Imaging dialog;
* Compressed images creation: “Compress” option on Disc Imaging dialog;
* “Image Catalog” item was moved to the first level of Main Menu;
* MDF-file type association option;
* Languages updates.Bugs fixed:
* Devices speeds detection;
* Lite-ON DHXXXXX drives supporting;
* Large RAID volumes issue;
* Mounting B6T DVD images;
* Setup improving: Unicode supporting;
* Some minor interface bugs.
4.35.5 (October 30, 2009)
ZitatAlles anzeigen- SPTD 1.62;
- Full Windows 7 support;
- Windows Sidebar gadget for easy accessing of general DAEMON Tools Lite features;
- DAEMON Tools Lite Panel was removed;
- GUI redesign and improvement;
- No need in “Run as Administrator” option for the first DAEMON Tools Lite start;
- Revised License pages in Setup;
- Languages updates.Bugs fixed:
- Problem with image mounting from RAID volumes larger than 2 Tb;
- Some issues with opening image file on mounting;
- Showing Wait Dialog in command line mode;
- Inability to mount *.mdf image without *.mds file;
- Problem with SPTD installation from DAEMON Tools Lite setup in silent mode;
- Some minor bugs.
4.35.6
Zitatwhat's new:
- new mdx (media data extended) format supporting;
- daemon tools windows sidebar gadget skin selection;
- drag'n'drop support in windows sidebar gadget;
- added "open mount'n'drive manager on start" option;
- added "-help" command line switch;bugs fixed:
- sandisk usb flash drive with u3 and disc imaging engine incompatibility;
- some minor bugs.
4.40.1
- Even better main window;
- DAEMON Tools driver (Basic Emulation) for working without SPTD;
- SPTD 1.76 (Advanced Emulation);
- Support of Portable Installation;
- Authorization request when mounting network shared images;
- Unable to start adapter after first installation on fresh Windows;
- Issue with detecting an external USB HDD with virtual CDROM drives;
- Not saving DVD Region of a device after reboot;
- Nonoptimal CPU using;
- Handles' leaks in Sidebar Gadget;
- Minor bugs.
4.40.2
ZitatBugs fixed:
- Rare BSODs when Advanced Emulation mode is disabled;
- Error 1500: driver initialization issue at startup.
4.41.3
ZitatWhat's new:
- Support of APE image files;
- DT as a new virtual device is added to perform Basic Emulation;
- Improvement of portable installation;
- SPTD 1.78.Bugs fixed:
- Incompatibility of DAEMON Tools and Power2Go, PowerDVD;
- Ignoring Locked Applications during uninstallation;
- Rare disappearing of sidebar gadget after reboot.
4.45.1
- Support of FLAC image files;
- Flexible scheme of adding DT and SCSI virtual devices (maximum 4 in total);
- Separate Autostart option;
- Drag-and-drop of folders that contain image files;
- Improvements in auto update process;
- SPTD 1.79.Bugs fixed:
- Incompatibility with McAfee;
- GUI issues with some RTL languages (Arabic, Hebrew etc);
- Crash with Danish language;
- Command line parameter get_count returns quantity of virtual devices of specific type by default;
- Minor bugs.
4.45.2
ZitatWhat's new:
- SPTD 1.80 (support of Windows 8).
- Redesigned installation wizard.
- Catalan language added to the list of supported languages.Bugs fixed:
- Sidebar Gadget: automount issue.
- Minor bugs.
4.45.3
ZitatWhat's new:
- Setup changes.
Bugs fixed:
- Some minor bugs.
