--- Container Information ---
Base Type (e.g "AVI"): AVI(.AVI)
Subtype (e.g "OpenDML"): OpenDML (AVI v2.0),
Interleave (in ms): 40
Preload (in ms): 512
Audio alignment("split across interleaves"): Split
Total System Bitrate (kbps): 0
Bytes Missing (if any): 0
Number of Audio Streams: 1
--- Video Information ---
Video Codec Type(e.g. "DIV3"): DX50/divx
Video Codec Name(e.g. "DivX 3, Low-Motion"): DivX 5.0
Video Codec Status(e.g. "Codec Is Installed"): Codec(s) are Installed
Duration (hh:mm:ss): 00:42:26
Frame Count: 63640
Frame Width (pixels): 704
Frame Height (pixels): 288
Frame Aspect Ratio (e.g "1.3333"):
Frame Aspect Ratio (e.g. "4:3"):
Pixel Aspect Ratio ("SAR"):
Display Aspect Ratio ("DAR"): 2.444
Frames Per Second: ***ERROR***
Video Bitrate (kbps): 1851
MPEG-4 ("MPEG-4" or ""): MPEG-4
B-VOP ("B-VOP" or ""): B-VOP
--- Audio Information ---
MPEG Stream ID (e.g. "0xbd"):
MPEG VOB file Substream(e.g. "0x80"):
Audio Codec (e.g. "AC3"): 0x2000(AC3, Dolby Laboratories, Inc) AC3
Audio Codec Status (e.g. "Codec Is Installed"): Codec(s) are Installed
Audio Sample Rate (Hz): 48000
Audio Bitrate(kbps): 448
Audio Bitrate Type ("CBR" or "VBR"): CBR
Audio Channel Count (e.g. "2" for stereo): 5
Auf dem PC läuft er super.
Auf einem Standalone (Centum Gemnini 322) ruckelt es bei Kamerschwenks.
Ton und Bild haken. Hat der Centrum da ein Bitraten Problem, wenn ja, wo liegt die Grenze der erlaubten Bitrate ungefähr?
