Matrix Editor Version 1.06 ist raus.
Download: http://dvd-rb.dvd2go.org/modules.php?na…download&cid=24
ZitatAlles anzeigen[font=verdana, arial, helvetica] Changelog:
* Now it can import Matrices from .txt files (as long as the files have spaces between the values and they can't have blank lines)
* New languages: German (thanks Rockby!), French (thanks SAPSTAR!) and Italian (Thanks Rebuman!)
* The Matrices' description/info are also translated.
* The custom matrices' description/info is saved - on the previous version if the user pressed the button "Restore Default Matrices" the info of the custom matrices (created by user) would be lost... not anymore - This fix is not retro-compatible, so you must save a copy of you custom descriptions so you can re-insert them after update!!!
* Fix a (stupid) error - after creating or editing a Matrix it could only be saved once from the editing/creating dialog - my thanks to Rockby to point this out.
* Added a button on Languages dialog with the name "Update Languages" - that's what it does and you must click it to have access to the new languages.
* Dragongodz's "QuEnc Lower Bitrate (QLB)" has been updated to version 1.2 - you must click "Restore Default Matrices" under setup window... just don't forget what I said before about the custom matrices' Info.[/font]
