0.3.0.3011
ZitatAlles anzeigen0.3.0.3011
- (ateeq) [videoutil] mediainfo track id has changed to decimal for all tracks
- (ateeq) [scriptserver] add spline64resize option0.3.0.3010
- (kurtnoise) removed cropdialog form from projects files. This is not used anyway...
- (kurtnoise) revert rev805...shame on me (#2231667).
- (kurtnoise) [besplitter] one frame is missing for end value (#2283781)
- (kurtnoise) [besplitter] use dot instead of comma for start & end values (#2283781)
- (kurtnoise) updated mediainfo library and its wrapper to the latest release (0.7.7.8)
- (ateeq) [x264configurationpanel] fix to correctly apply last p4x4 change to level 3.1 and unrestricted0.3.0.3009
- (sharktooth) [avscreator] resize filter now disabled by default. Avs presets settings will not be overridden though
- (ateeq) [x264configurationpanel] fix domacroblockadjustments for p4x4 compliance at level 3+ when all option is selected0.3.0.3008
- (sharktooth) [avisynthwindow.cs] default resize values now equal to the source file resolution values
- (sharktooth) [x264encoder.cs] --filter -> --deblock
- (ateeq) [x264settings] add macroblockoptions
- (ateeq) [x264configurationpanel] set/get macroblockoptions to/from profiles0.3.0.3007
- (ateeq) [x264configurationpanel] set updating to avoid triggering spurious events during x264 profile switching
- (ateeq) [videoconfigurationpanel] change visibility of updating variable
- (ateeq) [avisynthwindow] remember current frame unless loading a new video
- (ateeq) [videoplayer] add startframe parameter to loadvideo to allow starting with specific frame
- (ateeq) [settingsform] add missing cleardefaultoutputdir eventhandler link
- (ateeq) [autoencodewindow] change muxedoutput to filebar
- (ateeq) [filebar] set file dialog initialdirectory to where current filename is located
- (ateeq) [jobcontrol] allow dependent jobs to run on jobstatus.skip
- (ateeq) [videoplayer] help c# with memory management by disposing bitmap as soon as we're finished with it
- (ateeq) [jobcontrol] remove job from parent/required job's enabledjobs list (fixes #2124850)
- (ateeq) [avisynthwindow] delay openscript until asw is closed to prevent archooser race condition with videoplayer
- (ateeq) [archooser] fix to keep user selected ars0.3.0.3006
- (ateeq) [dar] alternative sar fraction calculations for slightly better accuracy
- (ateeq) (adaptivemuxer) allow splitting to same container with adaptive muxer
- (ateeq) [adaptivemuxwindow] fix to work with previous basemuxwindow changes
- (ateeq) [amgmuxer.cs] file splitting fix and don't number unless splitting
- (ateeq) [basemuxwindow.cs] add defaultoutputdir and mainform visibility change
- (ateeq) [muxwindow.cs] remove duplication of mainform between muxwindow and basemuxwindow0.3.0.3005
- (ateeq) removed filename passed to new vobinputwindow as setconfig passes it anyway. This way openvideo isn't called twice.
- (ateeq) clear queue without prompting if all jobs are done
- (ateeq) oneclick fixes
- (ateeq) mod16 undercrop for anamorphic encoding
- (ateeq) delay setting status to done till after postprocessing
- (kurtnoise) [progresswindow] trigger the high priority warning for all windows os, not only vista.
