Neues Tool: RatDVD
Vielen Dank :daumen:
ne schon klar http://www.cafepress.com/ratdvd
[Blockierte Grafik: http://storetn.cafepress.com/9/23923899_F_store.jpg]
Na sicher. Irgendwie muss man doch Geld verdienen.
16.05.2005
Released imdbexport COM server source for imdb access
Released rattag.dll and tagging XML scheme for everyones use
Updated the 'Play ratDVD' section with 7 fully ratDVD compatible players
http://www.ratdvd.dk/ -
Release Notes ratDVD v0.6.1122:
* Minor bugfix regarding playback for issue introduced in v0.6.1119 concerning players other than Media PlayerRelease Notes ratDVD v0.6.1119:
* Repackaging for license compliance -
Release Notes ratDVD v0.7.1239:
* Language fixes and additions (Chinese Simplified, Finnish)
* Fixed some bugs in Content Based Filename Creation
* Set Content Based Filename Creation to default
* Better search pre-selection for tagging
* Removed log file from .ratDVD files (log is only written to temp folder) -
Und diese Version gab es letzte Woche:
Release Notes ratDVD v0.7.1235:
------------------------------New Features:
Added Direct burning capability *1
Added ISO creation engine *1
Added MCE (Windows Media Center Edition 2005) support
*ratDVD files are listed as video files
*full control with mouse and remote control
Codec quality/speed optimizations
Added advanced codec options
*Ignore scaler
*Use alternate quantization model
*MV Search Path
*P Bonus
Multi-Language support
*ar - Arabic
*ca - Catalan
*cz - Czech
*de - German
*dk - Danish
*en - English
*es - Spanish
*fr - French
*gr - Greek
*hu - Hungarian
*it - Italian
*nl - Dutch
*pl - Polish
*pt - Portuguese
*pt_BR - Portuguese (Brazil)
*ro - Romanian
*ru - Russian
*sr - Serbian
*sk - Slovak
*th - Thai
*tr - Turkish
*uk - Ukranian
ratDVD naming scheme
*Automatic content based naming extension
Tag editing while adding tagging
Shut down after convert
Setting for conversion task priority
Custom sounds
*For successful completions
*For failed completions
Remote Control Support with WM_Input interface
*Allows usage of WM_Input compatible remote controls (like the Microsoft Media center remote control) to control ratDVD playback.
New default quality set to 105
New maximum quality to 120
Source import plug-in architecture
*Allows extensions for different source material (e.g. ISO Images, all kind of optical media, etc.)
Destination export plug-in architecture
*Allows extensions for all kind of different output targets (e.g. ISO Images, or transcoding to other formats, etc.)
Custom action at end of successful conversion process
*Allows a higher degree of automation (e.g. automatic batch conversions, transfers in ratDVD archives, etc.)Bug fixes:
Playback fixes:
*Chapter change after seek was sometime not correct
*Wrong time display in Media Player
*Acceptance of only known video render filters solves problems with some codec packs/ffdshow
*Fix for illegal NAV pack positions that sometimes happens in DVD Shrink created discs
*Fix for wrong subtitle display on some movies
*Wrapping of navigation component as COM module – can now be used from all programs system wide
*Fix for wrong audio/subtitle switching at next chapter after seek
*Fix for changing aspect ratio change with VMR9 (Video Mixing Renderer)
*Fix for graph stopping in certain situations
Support for >4GB images
Fix for “list index out of bounds” conversion issue for some moviesKnown Issues:
Seek bar in Media Player
*No reset at new title start
*Does not reflect complete length with some movies
Resume ratDVD function in MCE2005 starts movie from the beginning*1 – Nero needs to be installed for ISO creation / DVD burning functionality
Diese Rubrik heißt "News", nicht "Oldies"!
Databox -
ratDVD v0.75.1331
http://www.ratdvd.dk/downloads/ReleaseNotes-0.75.1331.txt
Features:
Detailed analyze of DVD stream data with preview and graph on video and other content streams:
-Enables the display of all streams with exact size data
-Enables automatic destination size estimation when stream selection is changed
-Bitrate graph for video and other(audio, subpicture, navigation) streams -
Hat schon jemand Tests mit ratdvd unternommen. Ich bin eben durch Zufall auf dieses Proggi gestoßen und auf der Homepage kommen sie aus dem strunzen (wie man bei uns im Rheinland sagt) garnicht mehr raus.
Ist das Tool zu gebrauchen oder eher an Fall für die Mülltonne?
Danke Dir, bin aber zwischenzeitlich schon selbst draufgestossen. Leider gehen die Meinungen wiedermal stark auseinander, so daß ich es wohl oder übel selbst mal testen muß.
12.09.2005
ratdvd 0.76 released
27.09.2005
ratDVD 0.77.1506 vorgestellt
Neue Profile ermöglichen die Definition von eigenen Regeln für Qualität, Bitrate sowie das entfernen, konvertiren und beibehalten von Tonspuren und Untertiteln in Abhängigkeit von vorhandenen Formaten und Spracheinstellungen.
Spracheinstellungen für ratDVD Wiedergabe
Wiedergabe erfolgt nun durch Import Plug-Ins
Bugfixes
http://www.ratdvd.de/
Databox -
Zitat von T-Online
:: Downloads[Blockierte Grafik: http://www2.oncomputer.t-online.de/c/56/45/18/5645188,tid=t.jpg] Schrumpfkur für Video-DVDs
Die Freeware "ratDVD" komprimiert Video-DVDs inklusive aller Menüs und Extras in eine einzelne Datei - mit kaum sichtbarem Qualitätsverlust. mehrNa.., wer sagt´s denn..:
Die Teletubbies sind auch schon aufgewacht und dahintergekommen, dass es da was "Neues" gibt..! Hätte DATABOX (über meinem Post) aber auch merken müssen, dass da was "Neues" in seinem Postkasten liegt.., gelle, Postmeister Databox..? (Kleiner Scherz.., aber..., in Hinblick auf dein Avatar....)
Gruß, Rudi -
Tja Rudi,
es lag bestimmt mal wieder ganz unten im Kasten und wurde deshalb erst jetzt entdeckt.:D
Databox -
