Zitat* mkvmerge: new feature: Added support for handling AVC/h.264 tracks in MPEG program streams.
ist in dem oben gelinkten Build ebenfalls enthalten
08.03.2007
Zitat2007-03-08 Moritz Bunkus <moritz@bunkus.org>
* mkvmerge: The MPEG program stream reader will now sort the tracks it finds first by their type (video > audio > subs) and then by their stream ID.
* mkvmerge: Disabled the support for DTS tracks in MPEG program streams because DTS HD is not supported yet.
* mkvmerge: enhancement: Implemented a major speed-up for reading
Zitat2007-03-12 Moritz Bunkus <moritz@bunkus.org>
* mkvmerge: bug fix: Fixed a problem with concatenating more than two subtitle files.
akapuma
mkvtoolnix-unicode-2.0.2-build20070426-1.rar (Pre-Version)
ZitatAlles anzeigen2007-04-26 Moritz Bunkus <moritz@bunkus.org>
mkvmerge: bug fix: Added support for handling SEI NALUs in AVC/h.264 elementary streams so that "key frames" can be detected even if no IDR slices are present.2007-04-19 Moritz Bunkus <moritz@bunkus.org>
mkvmerge: bug fix: Fixed the VobSub reader so that "delay:" lines with negative timecodes are accepted. Fix for bug 241.2007-04-18 Moritz Bunkus <moritz@bunkus.org>
mkvmerge: bug fix: Improved the file type detection code for MPEG transport streams.2007-03-23 Moritz Bunkus <moritz@bunkus.org>
mkvmerge: bug fix: Fixed a problem reading normal AC3 tracks from MPEG program streams.2007-03-22 Moritz Bunkus <moritz@bunkus.org>
mkvmerge: bug fix: Fixed an issue with negative/huge timecodes after splitting AVC/h.264 video.2007-03-16 Moritz Bunkus <moritz@bunkus.org>
mkvmerge: enhancement: The SRT reader allows "." as the decimal separator as well as ",".
akapuma
mkvtoolnix-unicode-2.0.2-build20070530-1.rar
Zitat2007-04-30 Moritz Bunkus <moritz@bunkus.org>
mkvmerge: bug fix: Another bug fix for handling various AC3 and E-AC3 files in MPEG program streams.
akapuma
verwende das Tool zum ersten mal und habe auch gleich die letzte Build geladen aber wenn ich das ganze Starten will kommt diese Meldung:
libiconv.dll konnte nicht gefunden werden. Neuinstallation behebt das Problem.
wie starte ich das ganze jetzt ?
vielleicht erst das hier installieren (http://www.bunkus.org/videotools/mkv…0.2-1-setup.exe)
und dann das update darüber kopieren? Programmstart ist normalerweise mit der mmg.exe möglich
ok danke funktioniert jetzt.
Das von kurt beschriebene Vorgehen ist korrekt. Nur die Releases enthalten alle benötigten DLLs. Die pre-Builds hingegen enthalten nur die sich potenziell verändernden Dateien. Deswegen muss ein pre-Build immer in ein Installationsverzeichnis entpackt werden.
ZitatAlles anzeigenHey,
I've just released mkvtoolnix v2.1.0:
The source code:
http://www.bunkus.org/videotools/mkv…x-2.1.0.tar.bz2The Windows Unicode binary:
http://www.bunkus.org/videotools/mkv…2.1.0-setup.exeThe other binaries are available from the home page:
http://www.bunkus.org/videotools/mkvtoolnix/
Here's the ChangeLog since the previous release:
2007-08-19 Moritz Bunkus <moritz@bunkus.org>* Released v2.1.0.
2007-08-16 Moritz Bunkus <moritz@bunkus.org>
* mkvmerge: enhancement: Added support for reading MP2 audio tracks from OGM files. Patch by Mihail Zenkov (see AUTHORS).2007-08-15 Moritz Bunkus <moritz@bunkus.org>
* mkvextract: enhancement: Added support for extracting Dolby Digital Plus (EAC3) tracks.
* mkvmerge: bug fix: SPS and PPS NALUs are no longer removed from AVC/h.264 streams. Hopefully a fix for bug 231.2007-07-19 Moritz Bunkus <moritz@bunkus.org>
* mkvmerge: enhancement: Fixed SSA/ASS detection for files produced by Aegis Sub which doesn't include a line with '[script info]' in the file.2007-07-07 Moritz Bunkus <moritz@bunkus.org>
* mmg: enhancement: Added another option how mmg choses the directory if automatic output filename creation is on. Implements all suggestions as listed in bug 248.2007-07-05 Moritz Bunkus <moritz@bunkus.org>
* mmg: enhancement: Moved the complete 'settings' tab to its own dialog accessible via the 'Settings' option in the 'File' menu.2007-06-30 Moritz Bunkus <moritz@bunkus.org>
* mmg: new feature: Added a buton 'remove all' which removes all input files and tracks leaving all other options as they are. Fix for bug 248.
* mmg: new feature: Added an option for setting the default output directory if the automatic setting of the output file name is turned on. Fix for bug 248.
* mkvmerge: enhancement: DTS code: Some tools (e.g. Surcode) can create DTS files which are padded with zero bytes after each DTS frame. These zero bytes are now skipped without printing a warning.
* mmg: enhancement: mmg can now be called with any file name as an argument. If it ends with 'mmg' then the file will be loaded as a 'mmg settings file'. Otherwise mmg will 'add' it. Fix for bug 243.2007-06-27 Moritz Bunkus <moritz@bunkus.org>
* mkvmerge: bug fix: The OGM reader uses the OGM's timestamps for video tracks. Before it would just use the current frame number multiplied by the FPS.
* mkvmerge: enhancement: The OGM reader now uses the AVC/h.264 video packetizer for AVC/h.264 tracks so that the aspect ratio can be extracted from it.2007-06-25 Moritz Bunkus <moritz@bunkus.org>
* mkvmerge: bug fixes: Fixed a couple of memory leaks.2007-06-24 Moritz Bunkus <moritz@bunkus.org>
* mkvmerge: new feature: Added better checks if two tracks can be appended to the passthrough packetizer so that tracks that are otherwise not known to mkvmerge can still be appended (e.g. V_VC1). Fix for bug 244.2007-06-23 Moritz Bunkus <moritz@bunkus.org>
* mmg: The NALU size length can now be chosen for all AVC tracks, not only for those that are handled by the 'AVC ES packetizer'.
* mkvmerge: bug fix: The 'default track' flag was set to 'yes' for tracks read from Matroska files even if 'no' was specified on the command line.
* mkvextract: new feature: Added support for the 'header removal' encoding scheme.2007-06-21 Moritz Bunkus <moritz@bunkus.org>
* mkvmerge: new feature: The NALU size length of an AVC/h.264 track can now be changed even if the source is not an elementary stream (e.g. for MP4 and Matroska files).2007-06-19 Moritz Bunkus <moritz@bunkus.org>
* mkvmerge: enhancement: Added support for RealAudio v3 in RealMedia files. Patch by Aurelian Jacobs. Fix for bug 246.2007-06-11 Moritz Bunkus <moritz@bunkus.org>
* mmg: Moved the command line to a separate dialog and reduced the main window's height.2007-04-30 Moritz Bunkus <moritz@bunkus.org>
* mkvmerge: bug fix: Another bug fix for handling various AC3 and E-AC3 files in MPEG program streams.2007-04-26 Moritz Bunkus <moritz@bunkus.org>
* mkvmerge: bug fix: Added support for handling SEI NALUs in AVC/h.264 elementary streams so that "key frames" can be detected even if no IDR slices are present.2007-04-19 Moritz Bunkus <moritz@bunkus.org>
* mkvmerge: bug fix: Fixed the VobSub reader so that "delay:" lines with negative timecodes are accepted. Fix for bug 241.2007-04-18 Moritz Bunkus <moritz@bunkus.org>
* mkvmerge: bug fix: Improved the file type detection code for MPEG transport streams.2007-03-23 Moritz Bunkus <moritz@bunkus.org>
* mkvmerge: bug fix: Fixed a problem reading normal AC3 tracks from MPEG program streams.2007-03-22 Moritz Bunkus <moritz@bunkus.org>
* mkvmerge: bug fix: Fixed an issue with negative/huge timecodes after splitting AVC/h.264 video.2007-03-16 Moritz Bunkus <moritz@bunkus.org>
* mkvmerge: enhancement: The SRT reader allows "." as the decimal separator as well as ",".2007-03-12 Moritz Bunkus <moritz@bunkus.org>
* mkvmerge: bug fix: Fixed a problem with concatenating more than two subtitle files.2007-03-08 Moritz Bunkus <moritz@bunkus.org>
* mkvmerge: enhancement: Implemented a major speed-up for reading MPEG-1/2 and AVC/h.264 tracks from MPEG program streams.2007-03-05 Moritz Bunkus <moritz@bunkus.org>
* mkvmerge: enhancement: Fixed the MPEG PS reader so that it will just skip blocks whose headers it cannot parse instead of aborting.
* mkvmerge: new feature: Added support for handling AVC/h.264 tracks in MPEG program streams.2007-03-02 Moritz Bunkus <moritz@bunkus.org>
* mkvmerge: new feature: Added support for EAC3 tracks in MPEG program streams.
* mkvmerge: new feature: Added support for EAC3/DD+ (Dolby Digital Plus) files and tracks (raw EAC3 files or inside Matroska with CodecID A_EAC3).
------------------------------------------------------------Have fun.
Mosu
Neue pre-Version:
mkvtoolnix-unicode-2.1.0-build20071222-1.rar
ZitatAlles anzeigen2007-12-22 Moritz Bunkus <moritz@bunkus.org>
* mkvmerge: bug fix: OGM files with non-Theora video tracks caused mkvmerge to fail since 2.1.0, or the resulting file was unplayable. Fix for bug 267.2007-10-11 Moritz Bunkus <moritz@bunkus.org>
* mkvmerge: bug fix: Accept other Theora header versions than 3.2.0 as long as the major version is 3 and the minor 2. Fix for bug 262.2007-09-02 Moritz Bunkus <moritz@bunkus.org>
* mkvmerge: bug fix: MPEG PS reader: Fixed the resyncing mechanism during normal reads. Another fix for bug 259.* mkvmerge: bug fix: MPEG PS reader: mkvmerge tries to resyncto the next MPEG start code in case of error during stream detection. Fix for bug 259.
2007-08-31 Moritz Bunkus <moritz@bunkus.org>
* mkvmerge: SVQ1 video tracks read from QuickTime files are output as V_MS/VFW/FOURCC tracks and not as V_QUICKTIME tracks. Fix for bug 257.2007-08-30 Moritz Bunkus <moritz@bunkus.org>
* avilib: bug fix: Fixed a segmentation fault if reading the first part of an index failed but a second/other index part is present. Fix for bug 256.
akapuma
neue pre-Version
mkvtoolnix-unicode-2.1.0-build20080102-1.rar
2007-12-31 Moritz Bunkus <moritz@bunkus.org>
* mkvmerge: bug fix: Rewrote the timecode application code. Additionally force the "previous cluster timecodes" that libmatroska uses to the current timecode. This seems to get rid of libmatroska's assertions about the local timecode being to small/big to fit into an int16. It also seems to get rid of some of mkvmerge's errors about the packet queue not being empty.
Neue pre-Version:
mkvtoolnix-unicode-2.1.0-build20080302-1
ZitatAlles anzeigen2008-02-29 Moritz Bunkus <moritz@bunkus.org>
* mkvmerge: new feature: Added support for handling AC3 in WAV in ACM mode.2008-02-28 Moritz Bunkus <moritz@bunkus.org>
* mkvmerge: new feature: Added support for reading AC3 from QuickTime/MP4 files. Fix for bug 254.2008-02-27 Moritz Bunkus <moritz@bunkus.org>
* mkvmerge: new feature: Added support for handling AC3 in WAV in IEC 61937 compatible streams (aka SPDIF mode).* mkvmerge: new feature: Added support for WAV files with multiple data chunks.
* mkvmerge: bug fix: Fixed a cause for the error message "no data chunk found" by fixing the skipping of 'fmt ' chunks.
2008-02-23 Moritz Bunkus <moritz@bunkus.org>
* mkvmerge: new feature: Added support for AAC-in-AVI with CodecID 0x706d as created by mencoder. Fix for bug 266.2008-02-20 Moritz Bunkus <moritz@bunkus.org>
* mkvmerge: bug fix: Rewrote the OGM reader code. Another part of a fix for bug 267.
akapuma
Hello users,
I've released a new version of MKVToolNix, v2.2.0. It contains major bug fixes (a lot of crashes with should be gone) and a couple of new features.
Here are the usual links to the most interesting downloads:
The source code:
http://www.bunkus.org/videotools/mkvtoolnix/sources/ mkvtoolnix-2.2.0.tar.bz2
The binaries for Windows 2000, XP or newer:
http://www.bunkus.org/videotools/mkv…2.2.0-setup.exe
The program home page:
http://www.bunkus.org/videotools/mkvtoolnix/index.html
Binaries for a couple of Linux distributions are available from the home page. The users of Debian and Ubuntu that use my Apt repositories should note that I've renamed my package to match the official package names in Debian and Ubuntu. You can get this release of MKVToolNix with "apt-get install mkvtoolnix mkvtoolnix-gui".
As always I'll finish with the ChangeLog between the previous release 2.1.0 and this release.
Have fun
Regards,
Mosu
2008-03-04 Moritz Bunkus <moritz@bunkus.org>
* Released v2.2.0.
* mkvmerge: bug fix: Rewrote the timecode application code. Additionally force the "previous cluster timecodes" that libmatroska uses to the current timecode. This seems to get rid of libmatroska's assertions about the local timecode being to small/big to fit into an int16. It also seems to get rid of some of mkvmerge's errors about the packet queue not being empty, and it fixes a couple of crashes with file splitting.
* mkvmerge: bug fix: MPEG PS reader: mkvmerge tries to resync to the next MPEG start code in case of error during stream detection. Fix for bug 259.
* mkvmerge: enhancement: SRT files that contain coordinates in the timecode line are supported. The coordinates are discarded automatically (as S_TEXT/SRT doesn't support them), and a warning is shown.
Zitat2008-03-09 Moritz Bunkus <moritz@bunkus.org>
* mkvmerge: new feature: Added support for skipping ID3 tags in AAC and AC3 files. Fix for bug 204.
* mkvmerge: new feature: Added support for DTS-HD (both "master audio" and "high resolution").
Zitat2008-04-03 Moritz Bunkus <moritz@bunkus.org>
* mkvmerge: bug fix: Fixed writing to UNC paths on Windows. Fix for bug 275.
http://www.bunkus.org/videotools/mkvtoolnix/win32/pre/
akapuma
Hey guys,
here's another release of mkvtoolnix, 2.3.0 this time. There are a couple of new features and a few important bug fixes along with the smaller improvements and changes. The change description from freshmeat.net reads as follows:
ZitatNewly supported features include DTS-HD tracks (both "high definition" and "master audio"), Ogg Kate text subtitles, skipping of ID3 tags in AAC and AC3 files, Vorbis-in-AVI, delaying any track type and floating point WAV files. Several bugs were fixed including timecode handling for various track types and use cases, A/V desynchronization in VOBs, wrong VobSub packets and more.
Please note that with 2.3.0 I stop providing binaries for a couple of distributions myself. These include: Ubuntu 6.06 and 6.10; OpenSuSE 10.0; Windows 95/98/ME/NT (meaning that there will be no more
non-Unicode binary for Windows). This does not mean that mkvtoolnix cannot be built on these platforms, just that you'll have to do it yourself.
A note for those who want to compile mkvtoolnix themselves: mkvtoolnix' library requirements have changed slightly. It now uses Boost's regex library instead of the PCRE library. mkvtoolnix can be linked against wxWidgets 2.6.x and 2.8.x as long as the 2.8 version has been built with 2.6 compatibility enabled (building definitely fails with 2.8 without 2.6 compatibility).
Here are the links:
...to the home page:
...to the source code:
http://www.bunkus.org/videotools/mkv…x-2.3.0.tar.bz2
...to the Windows binary:
http://www.bunkus.org/videotools/mkv…2.3.0-setup.exe
As always, binaries for other Linux and Unix distributions are available from the home page.
Last but not least the full ChangeLog since the previous release 2.2.0:
------------------------------cut------------------------------
2008-09-08 Moritz Bunkus <moritz@bunkus.org>
* mkvmerge: all: On Unix/Linux rpath linker flags have been removed again (they were actually removed before the release of v2.3.0).
2008-09-07 Moritz Bunkus <moritz@bunkus.org>
* Released v2.3.0.
2008-09-06 Moritz Bunkus <moritz@bunkus.org>
* mkvmerge: bug fix: improved the timecode calculation for MP3 tracks read from MP4 files. Another part of the fix for bug 165.
2008-09-03 Moritz Bunkus <moritz@bunkus.org>
* mkvmerge: bug fix: mkvmerge honors the timecode offsets of all streams in a MPEG program stream (e.g. VOB file) fixing audio/video desynchronization. Fix for bug 295.
2008-08-30 Moritz Bunkus <moritz@bunkus.org>
* mkvmerge: Switched from the PCRE regular expression library to Boost's RegEx library.
2008-08-23 Moritz Bunkus <moritz@bunkus.org>
* mkvmerge: bug fix: DTS-in-WAV handling (14 to 16 bit expansion)was flawed. Fix for bug 288.
* mkvmerge: new feature: Added support for Vorbis in AVI (format tag 0x566f). Fix for bug 271.
* mkvmerge: new feature: Added support for PCM tracks withfloating point numbers (CodecID A_PCM/FLOAT/IEEE). Patch byAurelien Jacobs (see AUTHORS).
2008-08-21 Moritz Bunkus <moritz@bunkus.org>
* mkvmerge: bug fix: The fix to the timecode handling for AVC tracks in MP4 files from 2008-04-16 caused certain other MP4 filesto not be read correctly. The video tracks were found, but no frames were read. Fix for bug 294.
* mkvmerge: new feature: Added support for Ogg Kate subtitles. Patch by ogg.k.ogg.k@googlemail.com.
2008-08-20 Moritz Bunkus <moritz@bunkus.org>
* mkvmerge, mmg: The option "--delay" was removed. The option "--sync" now only modifies the timecodes of a given track. mkvmerge does not pad audio tracks with silence. "--sync"works with all track types now, but using a stretch factor otherthan 1 with audio tracks might not work too well during playback. mmg's inputs for "Delay" and "Stretch by" can be usedwith all track types. Fix for bug 287.
2008-08-19 Moritz Bunkus <moritz@bunkus.org>
* mkvmerge: enhancement: mmg outputs a more informative errormessage for known but unsupported input file types (e.g. ASF, FLV,MPEG TS) instead of the cryptic "file identification failed".
* mkvmerge: bug fix: The VobSub reader would sometimes read too many bytes for a single SPU packet. Part of a fix for bug 245.
2008-05-16 Moritz Bunkus <moritz@bunkus.org>
* mkvmerge: bug fix: Using BZIP2 compression resulted in broken streams. Patch by Aurelien Jacobs (see AUTHORS).
2008-05-15 Moritz Bunkus <moritz@bunkus.org>
* mkvmerge: new feature: Improved support for WAV files biggerthan 4 GB which only contain a single DATA chunk and a wronglength field for this DATA chunk (e.g. eac3to creates such files).
2008-05-14 Moritz Bunkus <moritz@bunkus.org>
* mkvmerge: bug fix: Certain Matroska files with dis-continuous streams (e.g. subtitles) caused huge memory consumption. Fix for bug 281.
2008-04-22 Moritz Bunkus <moritz@bunkus.org>
* mkvmerge: bug fix: mkvmerge will output a proper error message if it is called with ASF/WMV files instead of detecting other kinds of streams (e.g. AVC ES streams). Fix for bug 280.
2008-04-20 Moritz Bunkus <moritz@bunkus.org>
* mkvmerge: bug fix: Fixed an assertion in the OGM reader occuringfor OGM files with *****ded chapters. Fix for bug 279.
* mkvmerge: all: On Unix/Linux rpath linker flags are added for library paths given in LDFLAGS and configure's "--with-extra-libs" options.
2008-04-16 Moritz Bunkus <moritz@bunkus.org>
* mkvmerge: bug fix: Fixed wrong timecodes for MP4 files thatcontain video tracks with B frames and edit lists. Fix for bug277. Patch by Damiano Galassi (see AUTHORS).
2008-04-14 Moritz Bunkus <moritz@bunkus.org>
* mkvmerge: bug fix: mkvmerge will not strip leading spaces in SRT subtitles anymore.
* mkvmerge: bug fix: Tuned the file type detection for MPEG ESstreams. Fix for bug 265.
* mkvmerge: bug fix: Fixed writing to UNC paths on Windows. Fixfor bug 275.
Have a nice day
Mosu
