0.7.52
ZitatAlles anzeigen+ Georgian translation
+ MXF with referenced files: if the referenced file is not available, trying to open local files
+ MPEG Video: GOP size for I-Frame only streams
+ MXF: support of CEA-608 in ancillary data for some other formats than MPEG Video, if there is no B-frame
+ LXF: support of SMPTE ST291/CDP/CEA-608/CEA-708 in ancillary data
+ WAV: better handling of files not having word alignment
x DV: crash (division by zero) in some cases
x DV: DVCPRO HD was sometimes not detected (low bitrate)
x MXF: Crash if AFD field has an invalid value
x MXF: Wrong endianess for some big endian PCM streams
x MXF: some MXF referencing files have wrong duration
x MXF: duration was wrong with some specific files
x DVD-Video: detection of 20-bit and 24-bit PCM
x XML output: it was sometimes containing some invalid characters
x MPEG-4: considering default char set as ISO-8859-1
x MXF: better handling of referencing files having the same ID for all tracks
x MXF: Handling of MXF files with wrong FooterPartition field
x MXF: Some captions (not starting at the beginning of the file) were not detected
x WAV: duration was missing is some cases
x RMP3 support was broken
