HI Leute,
das könnte eventuell auch in das Avisynth-Forum passen, ich denke aber dass mein Problem eher mit einem fehlenden Splitter o.ä. zusammenhängt.
Ich will mit avisource + seasaw ältere Videos (XviD, im AVI-Container) abspielen nur werden die nach seeking in mpc asynchron. Fehlt mir ein passender Splitter? Decodet wird mit ffdshow (audio + video) und der Prozessor sollte das eigentlich auch in Realtime schaffen.
Bsp:
AviSource("C:\Movies\seesaw\xxx.avi")
#ConvertToYV12()
#trim(1,158)
[B]a= last
b=a.removegrain()
SeeSaw(a,b, NRlimit=3, NRlimit2=4, Sstr=1.5, Slimit=5, Spower=5, Sdamplo=6, Szp=16)[/B]
[size=8]# SeeSaw v0.3e (02 Jan 2006)
# (Full Name: "Denoiser-and-Sharpener-are-riding-the-SeeSaw" )
# This function provides a (simple) implementation of the "crystality sharpen" principle.
# In conjunction with a user-specified denoised clip, the aim is to enhance
# weak detail, hopefully without oversharpening or creating jaggies on strong
# detail, and produce a result that is temporally stable without detail shimmering,
# while keeping everything within reasonable bitrate requirements.
# This is done by intermixing source, denoised source and a modified sharpening process,
# in a seesaw-like manner.
# This version is considered alpha.
# Usage:
# a = TheNoisySource
# b = a.YourPreferredDenoising()
# SeeSaw( a, b, [parameters] )
# You're very much encouraged to feed your own custom denoised clip into SeeSaw.
# If the "denoised" clip parameter is omitted, a simple "spatial pressdown" filter is used.
# Fiddled together by Didée, for your pleasure.
# ======= Main function =======
function SeeSaw( clip clp, clip "denoised",
\ int "NRlimit",int "NRlimit2",
\ float "Sstr", int "Slimit", float "Spower", float "SdampLo", float "SdampHi", float "Szp",
\ float "bias", int "Smode", int "sootheT", int "sootheS", float "ssx", float "ssy")
ssx = default( ssx, 1.0 ) # supersampling factor x / SeeSaw doesn't require supersampling urgently.
ssy = default( ssy, ssx ) # supersampling factor y / if at all, small values ~1.25 seem to be enough.
NRlimit = default( NRlimit, 2 ) # absolute limit for pixel change by denoising
NRlimit2 = default( NRlimit2, NRlimit+1) # limit for intermediate denoising
Sstr = default( Sstr, 1.5 ) # Sharpening strength (don't touch this too much)
Slimit = default( Slimit, NRlimit+2 ) # positive: absolute limit for pixel change by sharpening
# negative: pixel's sharpening difference is reduced to diff=pow(diff,1/abs(limit))
Spower = default( Spower, 4 ) # exponent for modified sharpener
Szp = default( Szp, 16+2 ) # zero point - below: overdrive sharpening - above: reduced sharpening
SdampLo = default( SdampLo, Spower+1 ) # reduces overdrive sharpening for very small changes
SdampHi = default( SdampHi, 24 ) # further reduces sharpening for big sharpening changes. Try 15~30. "0" disables.
bias = default( bias, 49 ) # bias towards detail ( >= 50 ) , or towards calm result ( < 50 )
Smode = default( Smode, ssx<1.35 ? 11 : ssx<1.51 ? 20 : 19 )
sootheT = default( sootheT, 49 ) # 0=minimum, 100=maximum soothing of sharpener's temporal instableness.
# (-100 .. -1 : will chain 2 instances of temporal soothing.)
sootheS = default( sootheS, 0 ) # 0=minimum, 100=maximum smoothing of sharpener's spatial effect.
Szp = Szp / pow(Sstr, 1.0/4.0) / pow( (ssx+ssy)/2.0, 1.0/2.0 )
SdampLo = SdampLo / pow(Sstr, 1.0/4.0) / pow( (ssx+ssy)/2.0, 1.0/2.0 )
ox=clp.width
oy=clp.height
xss = m4(ox*ssx)
yss = m4(oy*ssy)
NRL = string( NRlimit )
NRL2 = string( NRlimit2 )
NRLL = string( int(round( NRlimit2 * 100.0/bias - 1.0 )) )
SLIM = string( abs(Slimit) )
BIAS1 = string( bias )
BIAS2 = string( 100-bias )
#ZRP = string( abs(Szp) )
#PWR = string( abs(Spower) )
#DMP = string( SdampLo )
denoised = defined(denoised) ? denoised : yv12lutxy(clp,clp.removegrain(4,-1),"x "+NRL+" + y < x "+NRL+" + x "+NRL+" - y > x "+NRL+" - y ? ?",U=2,V=2)
NRdiff = yv12lutxy(clp,denoised,"x y - 128 +","x y - 128 +","x y - 128 +",U=3,V=3)
tame = yv12lutxy(clp,denoised,"x "+NRLL+" + y < x "+NRL2+" + x "+NRLL+" - y > x "+NRL2+" - x "+BIAS1+" * y "+BIAS2+" * + 100 / ? ?")
head = tame.sharpen2(Sstr,Spower,Szp,SdampLo,SdampHi,4)
# head = head.maskedmerge(tame,tame.prewitt(multiplier=1.0).expand().removegrain(20))
(ssx==1.0 && ssy==1.0) ? repair(tame.sharpen2(Sstr,Spower,Szp,SdampLo,SdampHi,Smode),head,1,-1,-1)
\ : repair(tame.lanczosresize(xss,yss).sharpen2(Sstr,Spower,Szp,SdampLo,SdampHi,Smode),head.bicubicresize(xss,yss,-.2,.6),1,-1,-1).lanczosresize(ox,oy)
Soothe(last,tame,sootheT,sootheS)
sharpdiff= yv12lutxy(tame,last,"x y - 128 +",U=1,V=1)
(NRlimit==0) ? clp : \
yv12lutxy(clp,NRdiff,"y 128 "+NRL+" + > x "+NRL+" - y 128 "+NRL+" - < x "+NRL+" + x y 128 - - ? ?",
\ "y 128 "+NRL+" + > x "+NRL+" - y 128 "+NRL+" - < x "+NRL+" + x y 128 - - ? ?",
\ "y 128 "+NRL+" + > x "+NRL+" - y 128 "+NRL+" - < x "+NRL+" + x y 128 - - ? ?",U=3,V=3)
Slimit>=0 ? yv12lutxy(last,sharpdiff,"y 128 "+SLIM+" + > x "+SLIM+" - y 128 "+SLIM+" - < x "+SLIM+" + x y 128 - - ? ?",U=2,V=2)
\ : yv12lutxy(last,sharpdiff,"y 128 = x x y 128 - abs 1 "+SlIM+" / ^ y 128 - y 128 - abs / * - ?",U=2,V=2)
return( last )
# ======= Modified sharpening function =======
function sharpen2(clip clp, float strength, int power, float zp, float lodmp, float hidmp, int rgmode)
STR = string( strength )
PWR = string( 1.0/float(power) )
ZRP = string( ZP )
DMP = string( lodmp )
HDMP = (hidmp==0) ? "1" : "1 x y - abs "+string(hidmp)+" / 4 ^ +"
yv12lutxy( clp, clp.RemoveGrain(rgmode,-1,-1), \
"x y = x x x y - abs "+ZRP+" / "+PWR+" ^ "+ZRP+" * "+STR+" * x y - 2 ^ x y - 2 ^ "+DMP+" + / * x y - x y - abs / * "+HDMP+" / + ?",U=2,V=2)
return( last )
# ======= Soothe() function to stabilze sharpening =======
function Soothe(clip sharp, clip orig, int "sootheT", int "sootheS")
sootheT = default(sootheT, 25 )
sootheS = default(sootheS, 0 )
sootheT = (sootheT > 100) ? 100 : (sootheT < -100) ? -100 : sootheT
sootheS = (sootheS > 100) ? 100 : (sootheS < 0) ? 0 : sootheS
ST = string( 100 - abs(sootheT))
SSPT = string( 100 - abs(sootheS))
yv12lutxy(orig,sharp,"x y - 128 +","x y - 128 +","x y - 128 +", U=1,V=1)
(sootheS==0) ? last
\ : yv12lutxy( last, last.removegrain(20,-1,-1),
\ "x 128 - y 128 - * 0 < x 128 - 100 / "+SSPT+" * 128 + x 128 - abs y 128 - abs > x "+SSPT+" * y 100 "+SSPT+" - * + 100 / x ? ?", U=1,V=1)
(sootheT==0) ? last
\ : yv12lutxy( last, last.temporalsoften(1,255,0,32,2),
\ "x 128 - y 128 - * 0 < x 128 - 100 / "+ST+" * 128 + x 128 - abs y 128 - abs > x "+ST+" * y 100 "+ST+" - * + 100 / x ? ?", U=1,V=1)
(sootheT > -1) ? last
yv12lutxy(orig,last,"x y 128 - -","x y 128 - -","x y 128 - -",U=1,V=1)
# mergechroma(sharp) # not needed in SeeSaw
return( last )
# ======= MOD4-and-atleast-16 helper function =======
function m4(float x) {x<16?16:int(round(x/4.0)*4)}
[/SIZE]
Alles anzeigen
Hat irgendjemand eine Idee?
