Grummel, Grummel,.. changelog gibt es mal wieder anscheinend nicht
smartLabs tsMuxeR: Transport Stream muxer
dafür aber .24
aktuell ist nun http://www.smlabs.net/tsMuxer/tsMuxeR_1.8.26(b).zip
paar Fixes für BD output usw.: http://forum.doom9.org/showthread.php?p=1260795#post1260795
Cool bei http://www.smlabs.net/tsmuxer_en.html gibt es auch ein linux updte auf die 1.8.24
Version 1.8.30(b):
- Bug fixed: ts/m2ts splitting fixed
- Bug fixed: FINE/COARSE table in clpi file fixed
- Bug fixed: track type for DD+ fixed
- Bug fixed: Append button in GUI fixed
- Bug fixed: Drag&drop for macOsX fixed
- Bug fixed: some other minoir bug fixed
Version 1.8.24(b):
- Bug fixed: Plenty of minoir bug fixed
- Bug fixed: Dolby True-HD issue on hardware players fixed
- Feature: Tags for SRT subtitles support - tags for changing font, color, size, etc.; tag's syntax is similar to HTML;
- Feature: United cross-platform GUI - Windows, Linux, MacOS.
http://www.smlabs.net/tsMuxer/tsMuxeR_1.8.35(b).zip
--> neue GUI und AVCHD Unterstützung
neue version (1.9.1) auf der Homepage: http://www.smlabs.net/tsmuxer_en.html
ZitatTwo new features added: Sony wave64 support and mkv chapters.
Also, this version includes new experimental feature: parameter "secondary" for video streams. This options allows to mux PIP video stream. tsMuxeR centers PIP streams on the screen by vertical position. Possible this function allows to resolve problem with cropped video in future. This options available in tsMuxer only and does not provided in tsMuxerGUI.
edit:
+ neue Beta: http://www.smlabs.net/tsMuxer/tsMuxeR_1.9.2(b).zip
New version of tsMuxeR is available:
https://localhost/www.smlabs.net…eR_1.9.8(b).zipChange list:
- added option "--insertBlankPL" which allows to add short black video (near 0.5 second) before main video. It is sovles the problem of "green bar" for cropped video on some players such PS3.
- Added options --mplsOffset and --m2tsOffset for changing M2TS and MPLS files enumeration.
- video_format field in MPLS file now always filled, including cropped video....
neue Version
ZitatVersion 1.9.9:
* Bug fixed: Fixed problem with DTS-HD Master Audio on Popcorn player.
* Bug fixed: Fixed problem with interlaced VC-1 streams (stream not detected).
* Added compatibility with H.264 camcorders(pic_order_cnt_type 2 now supported).
* added option "--insertBlankPL" which allows to add short black video (near 0.5 second) before main video. It is sovles the problem of "green bar" for cropped video on some players such PS3.
* Added options --mplsOffset and --m2tsOffset for changing M2TS and MPLS files enumeration.
* video_format field in MPLS file now always filled, including cropped video.
* Empty folders are no longer created in AVCHD mode (CERTIFICATE, JAR e.t.c) -
neue Alpha:
I almost finish MP4/MOV support in tsMuxeR.
Now I have tested codecs:
- AVC video
- AAC audio
- AC3 audio
- text subtitles
Also I have fix problem with AAC in MKV container.
Now this version is needed in addition testing with more codecs.While new version has alpha status:
https://localhost/www.smlabs.net…R_1.10.0(a).zip -
new version of tsMuxeR is available: http://www.smlabs.net/tsmuxer_en.html
Version 1.10.3:
* Added MOV/MP4 container support
* Added ability to scale PGS subtitles
* Added MPL file support
* Several minor bugs fixedAlso, I have added donate button.
Hab kein Changelog gefunden..
