  • Dann lerne mal lieber zunächst die Fachbegriffe (wie Telecine / Inverse Telecine = IVTC), und was ihre technischen Ursachen sind. So etwas klappt nämlich nur unter bestimmten Voraussetzungen fast verlustlos und ohne Asynchronität zwischen Video und Audio.
    Und außerdem haben viele Programme von Freizeitprogrammierern nicht umsonst eine Logdatei-Ausgabe, manchmal sogar eine, die man per Schalter besonders ausführlich machen kann, damit die Fehlerursachen gefunden werden können.
  • Hybrid rev 2011.12.28.1
    *changed*
    • muxing: not using ID 1 for NeroAACEnc input but ID 0
    • "auto add first" now also works for raw audio input
    • audio: dts-byteswap enabled as default
    • mac: switched to static builds (and included FrameCounter binary to the .app folder)
  • Hybrid rev 2011.12.29.1:
    *changed*
    • audio: positive delay will not be fixed through tsMuxer is 'fix delay with delaycut' is enabled
    • audio: adjusted to latest dcaenc -> needs dcaenc from 2011.12.30 or later
    *added*
    • audio: option to fix crc error with delaycut without fixing the delay
    • muxing: allowing wav/pcm in .avi
    *fixed*
    • audio: delayCut + audio passthrough handling
    • audio: pcm handling
    • audio: if audio&video container differ, make sure mencoder is not used during audio extraction or encoding
  • Hybrid rev 2012.01.13.1:
    *changed*
    *fixed*
    • x264: mixup in x264 command line importer (--bitrate and --crf were mixed up)
    • audio: don't fix crc on mpa files with delaycut when no delay is fixed (until bug in delaycut is fixed),
      see: http://forum.doom9.org/showthread.php?p=1548269#post1548269
    • dvd: queue titles + chapter generation
    • general: make sure subtitle&chapters are clear on drag&drop input
    • dvd/queueChapters/queueTitles: fixed (no automated subtitle passthrough for queueChapters)
    • mux: mvk->mp4 && mp4->mp4: avc remux problem
    • subtitle: wrong subtitle extension srt vs. ass on extraction
    • subtitle: tx3g handling
    • extract: wrong mp4 trackID problem
    • subtitle: DVD/QueueTitle and subtitle handling
    • audio: job handler: dcaenc output check
    *added*
    • subtitle: skip subtitle option, subtitle extractor will not rerip files already present at target destination
    • mkv: stretch detection option, which will cause Hybrid to analyse the input with mkvinfo and show stretch related infos if present
  • Hybrid rev 2012.01.15.1:
    *fixed*
    • audio: delay handling was broken due to several problems
    • windows: old avsInfo version was included in the packages
    • preview: error regarding 'Interlacing' when using bob
    • filter: 'deinterlacer' not always getting properly enabled due to 'force deinterlace'
    *changed*
  • Hybrid rev 2012.01.26.1:
    *added*
    • subtitle: basic .ass styling support (use existing .ass files and overwrite some of the styling info); only basic support since I do not know much about .ass (got no complex examples&co; will do more if people want it and provide some samples)
    • subtitle: .ass muxing into mp4 support (subtitle will be coverted to ttxt)
    *fixed*
    • subtitle: first internal subtitle stream was also *****ded when an external one was *****ded
    • x264: zone deletion did not directly update CL
    • x264: loading a profile with none@unrestricted caused an error
    • audio: don't resample on pcm extraction
    • vp8: progress bar indication during encoding
    *changed*
    • audio: max delay from 5000ms -> 60000ms
    • general: removed close affirmation for 'jobs->on queue finished->close' even if 'Config->Internals->Handling->Warn on close' is enabled
    • extended handling of stretched audio&video streams from mkv sources
    • subtitle: libass is now always used when *****ding text based subtitles
    • audio: adjusted calls to delaycut 1.4.3.5.7
  • Hybrid rev 2012.01.31.1:
    *added*
    • audio: flac -> compression level option
    • audio: 6.1->stereo/5.1 downmix
    *changed*
    • subtitle: removed -nofontconfig from mplayer/mencoder calls
      (+ windows installer: added fontconfig content to fonts folder)
    *removed*
    • x264: 2pass crf: confuses people
  • Spiele mit dem Gedanken eine Avisynth Script Creation (basierend auf ffmpegSource2 und DirectShowSoure, letzteres nur vür vc-1 interlaced) und ein paar Filter zu Hybrid hinzuzufügen. (windows only)
    Da ich selber aber in den letzten Jahren kaum Avisynth genutzt habe (außer QTGMC wenn Yadif miese Ergebnisse erzeugt) habe ich mich gefragt:
    Was für Avisynth Filter vermissen Leute in Hybrid?
    Persönlich vermisse ich nur QTGMC, aber eine rudimentäre Scripterstellung&Co nur für meine sporalische QTGMC Nutzung ist definitiv overkill.
    -> würde mich über Feedback freuen.
  • Hybrid rev.2012.02.15
    *added*
    • audio: option to enable '--multi-threaded' for sox
    • filtering: experimental option to analyze input for interlacing
    *fixed*
    • audio: dts-es accidentally detected as dts not dts-hd
    *removed*
    *changed*
    • audio: added '-analyzeduration 14M' when handling .flv files with ffmpeg
  • Hybrid rev. 2012.03.01
    *fixed*
    • chapter: dvd chapters not filtered for title
    • input: not analyzing avisynth input properly due to changes in avsInfo
    • missing version info for mkvmerge/mkvextract due to missing version info of old delayCut versions
    • interlace check not allowed to to twice with different percentages
    • some cosmetic bugs,..
    • video: cuda <> x264 <> filter: Blu-ray compatibility
    *changed*
    • analysis: modified interlace detection
    *experimental*
    • (windows only) avisynth script generation:
      Added some Avisynth support into Hybrid, which enables Hybrid to generate AvisynthSkripts and add use some of it's filters.
      negative points:
      • processing with avisynth stays is mainly in Yv12 (so it is not recommend to use it for anything but 4:2:0 output)
      • 32bit Avisynth 2.6 MT (to speed up the whole thing) is used, so too complex or memory consuming scripts might cause problems
      • Avisynth support is by default deactivated for DVD input support since due to the fact that there isn't a source filter plugin that allows to handle complete DVDs and select a video stream by PGS and angle. If you enable Config->Internals->Handling->'Avisynth for DVD input', the Avisynth support will be enabled, but you will always end up with the first PGS from the DVD which might cause problems.
      • you can't edit the script manually
      positiv points:
      • a bunch of additional filters (ColorMatrix, QTGMC, TIVTC, Decomb, RemoveGrain, Unblock, Deblock_QED, DeHalo_Alpha, dfttest, fft3dfilter, fft3dgpu,..)
      • frame accurate preview when using Avisynth
      if you want to try it, simply download this and extract it into your Hybrid folder. (this includes all .dlls and scripts Hybrid can use atm.)
  • Hybrid rev 2012.03.06.1:
    *fixed*
    • dvd: ntsc dvds not properly deteced as telecine
    • jobs: "auto delete finished" and "on queue finish" collided
    • avisynth filter view: with crop, resize, letterbox
    *changed*
    • audio: enabled NeroAacEnc for Linux64bit again
    • generate name: when 'Adjust output path to source path' output will be adjusted on a per file basis
    *added*
    • avisynth: FastLineDarken, Hysteria (avisynthExtension updated)
  • Hybrid rev 2012.03.15.1:
    *fixed*
    • analysis: tweaked analysis a bit more for telecine detection
    • tags: audio tagging with passthrough (for aac audio)
    • subs: crash on non utf-8 .ass/.srt to .ttxt subtitle
    • audio: to not adjust audio delay for encoder with Mkvmerge&NeroAacEnc since mkvmerge will do the job
    • audio: 'Enable audio mkv default for each source' conflicting with 'Set as default for mkv output' when enabled after source was loaded and 'Pass-through audio default/force flags'
    • audio: max bitrate mixup is qaac was enabled, but not target format not aac
    • subtitle: extract pgs subtitle from mkv file
    *changed*
    • audio: better compensate aac encoder delay
    • avisynth: update to flash3kyuu_deband_1.5.0
    • preview: removed 'distributor()' from generated avisynth scripts during preview; preview will be slow but otherwise some script, source combinations won't show up properly (no problem during encoding though)
    *addded*
    • audio: support for fhgaacenc (windows only)
  • Hallo Selur
    ich hoffe hier bin ich richtig.
    gemäss Deinem Hinweis
    habe ich mich auf die Suche begeben,da in Deinem DL-Ordner in Bezug auf "fhgaac.enc"
    nichts zu finden war.
    gefunden habe ichs dann hier
    https://github.com/tmkk/fhgaacenc/downloads
    Wäre es möglich dass Du in Deinem Downloadordner auch einen passenden Link reinsetzen könntest ?
    Das wegen den Lic-Gründen mit dem nero AAC wusste ich,hasts ja auch schon bei der ersten Hybrid-Version beschrieben,aber bei dieser Erweiterung "fhgaac.enc" habe ichs überlesen.
    Nun klappts.Danke.
