Hybrid rev 2014.07.03.1:
*fixed*
- DivX265: progress indication (percentage wasn't shown)
- ui: automatic loading of custom styling)
*changed*
- tools: tool arrangement under windows, to avoid problems which occurred on systems with missing run-times. Tools are now split over three locations:
- program folder: here are all the static tools
- 'dynamic'-sub-folder: here are all the tools which are only available as a. 32bit and b. dynamically linked
- 'dynamicX'-sub-folder: here are all the tools which are available as 32bit and 64bit versions and dynamically linked
*NOTICE*
- Windows: it's recommend to uninstall old Hybrid versions (settings do not have to be removed) before installing this or a newer version
