Hybrid rev 2015.08.26.1:
*fixed*
- audio: extracting pcm_bluray audio with ffmpeg, buy making sure a conversion to the right pcm format is used
- audio: ffmpeg->qaac, channel dropping due to wrong input format specification
- audio: limit fhgaacenc vbr to 1-5 since 6 doesn't seem to work
- general: limit output precision (e.g. 1.4 did end up as 1.3999999999999 with QT 5.5 sometimes otherwise)
- input: mkv-asp-workaround adjustment
- input: NVEncC 'hevc', removed level&profile setting
- tools: windows build contained mplayer&mencoder build which were missing some libraries (e.g. libdvdread)
- x264/x265: minimize command line
*added*
- crop: added 'use FFmpeg'-option to the autocrop options
- avisynth: control over which matrix is used during RGB->YUV conversions
- internal: handling of avisynth through ffmpeg, to handle non Yv12 color spaces
*changed*
- general: changed to MSVC 2015 as compiler for the Windows builds and compiling under Windows 10
Note: Windows users should deinstall any old Hybrid version before installing this build
