1.1.7 beta 5
ZitatThis is a hotfix release to address beta 4 regression with MP4 tagging.
1.1.7 beta 5
1.1.7 beta 6
Zitathis update improves MP4 tag handling robustness and more properly addresses the beta 4 regression.
1.1.7
ZitatAbility to add/remove *****ded pictures in media files - currently supports: MP3, MP4, FLAC, WMA, WavPack, Musepack, Vorbis and APE.
Improved bitrate reporting accuracy for various audio formats.
Updated ReplayGain scanning code to the latest version of libebur128.
1.1.8 beta 1
ZitatAlles anzeigenWorked-around a reported security problem with certain WAV files and buggy system codecs.
Skip silence DSP improvements.
Improved MP3 tag handling (ID3v2) compliance:
More compliant WXXX parsing.
More compliant ID3v2.4 date handling.
Compressed 2.3 tags are now readable.
Due to heavy structural changes relevant code, please watch out for MP3 tagging regressions.
1.1.8 beta 2
ZitatVarious regressions from the previous version have been corrected.
1.1.8 beta 3
ZitatThis update addresses various bugs related to Musepack file format handling.
1.1.8 beta 4
ZitatThis update improves "album artist" metadata compatibility for FLAC & Vorbis formats. Details are included in the change log.
This is an experimental change; reports of scenarios where compatibility has been degraded are welcome.
1.1.8 beta 5
Zitathas been released.
Support for playing WebM audio (beta 5)
Support for iTunes gapless information in MP3 files (beta 5)
1.1.8 beta 6
ZitatIt corrects a preferences crash regression from beta 5.
1.1.8
Due to heavy structural changes in relevant code, please watch out for MP3 tagging regressions.
Musepack decoding bug fixes. (beta 3)
Fixed a converter bug with writing multichapter files. (beta 3)
Improved FLAC/Vorbis metadata compatibility with other software. (beta 4, beta 5)
Affected fields: “album artist”, “totaltracks”, “totaldiscs”.
The old behavior can be restored with an Advanced Preferences switch.
1.1.9
ZitatAdded WAV file format tagging support.
Implemented experimental support for 16-bit floating-point WAV files.
Fixed ID3v2 handling bugs from 1.1.8.
1.1.9 beta 2
ZitatThis update fixes more MP3 tagging regressions from 1.1.8 and refines the WAV tagging feature.
1.1.11 beta 1
1.1.11
ZitatAlles anzeigenImproved built-in crossfading functionality, new fading configuration in Preferences / Output.
Fading functionality available with built-in DirectSound mode only.
New .fb2k-component file type extension for foobar2000 component packages.
Fixed some potential security issues.
Added type-find in the default playlist view.
Added support for album art in APEv2 tags on MP3 files.
Fixed more WAV handling bugs.
1.1.10
ZitatApple Lossless Audio Codec (ALAC) decoding support is now included out-of-the-box, using the newly published Apple library.
Fixed WAV handling bugs introduced in 1.1.9.
Worked around buggy Asus Xonar drivers, volume control no longer requires toggling specific options in the driver control panel.
Various stability fixes.
New “about” dialog.
1.1.11 beta 2
ZitatVarious beta 1 quirks have been sanitized.
This version introduces an experimental deadlock detection feature - the application will automatically terminate and produce a crash report after long periods of apparent UI unresponsiveness.
Please always send reports of any crashes that you encounter, chances are that they can be worked-around in the next version or forwarded to the developer of the problematic component.
1.1.11 beta 3+4
ZitatVarious UI responsivity bugs have been fixed using the telemetry data from beta 2 - thanks to everyone who submitted crash reports.
Update: Now at beta 4. The short-lived beta 3 had a major stability problem that should be fixed now - special thanks to the 15 people who submitted crash reports so quickly.
1.1.11 beta 5
ZitatThis update includes incremental bug fixes over beta 4 as well more customizable fading.
1.1.11
Converter update - now you can restrict specific encoder to run in one thread only.
Experimental deadlock detection (beta 2)
After long periods of apparent UI unresponsiveness, the application will automatically terminate and produce a crash report.
Cleaned up advanced preferences for MP3 tagging (beta 2)
“Force preferred tagging scheme” option gone - use the “MP3 tag types” dialog to convert between different tag types.
1.1.12
ZitatAlles anzeigenFixed Musepack HTTP streaming bugs.
Fixed incorrect MP3 decoder behavior on certain rare files.
Fixed crash reporter dialog crash (duh).
Detection of proxy server settings from Internet Explorer.
Improved crash report generation for infinite recursions / stack overflows.
Fixed multi-channel FLAC encoding (channel mask now gets preserved).
Fixed multi-channel WavPack decoding (channel mask now gets preserved).
Now possible to use HDCD & DTS decoder components with ALAC.
Changed MP3 tag reading behaviors when multiple tags are present.
ID3v2 content now takes priority over APE and then ID3v1.
Various time-consuming operations such as conversion or ReplayGain-scanning now prevent the computer from automatically going to sleep (opt-out).
1.1.12
Dies ist doch noch eine Beta:
Zitatfoobar2000 v1.1.12 beta 2
Wenn man der offiziellen Webseite Glauben schenkt.
1.1.13
ZitatFixed ID3v2 regressions from version 1.1.12
Fixed playback-getting-stuck bugs with fade-on-track-advance enabled.
ID3v2 compliance changes: multiple TXXX allowed again, semicolon used for multiple genre separator.
Changed ID3v2.3 TYER/TDAT handling, now merged into one DATE field formatted as YYYY-MM-DD.
Fixed incorrect volume control behavior when cycling output methods.
Aktuelle Stable-Version:
1.1.14a
ZitatAlles anzeigenAdded support for the IETF Opus codec.
Improved compliance of ReplayGain tagging for Opus files (beta 2).
More robust handling of ID3v2.3 TDAT frames (beta 2).
Added Opus encoding support in Converter (requires external opusenc.exe binary) (beta 3).
Fixed a deadlock when reading strange/corrupted zip files (final).
Fixed a rare deadlock related to updating tags on the file being currently played.
Fixed a rare deadlock related to starting/stopping playback.
__foobar2000 v1.1.14a has been released. A regression that slipped into 1.1.14 final has been corrected; thanks to all the people who submitted crash telemetry so quickly. We apologize for the inconvenience.
