Hallo
Es wurde hier schonmal das SubtitelProblem im Forum angesprochen. Aber anscheinend hat keiner eine plausible Lösung parat Ich habe (als Newbie) das volle DVD Reauthoring Verfahren mit den Big3 gemacht und scheitere immerwieder an Scenarist. Er gibt mir folgende Feher raus.
Info
Info Creating DVD Files
Warning Sub-Picture (stream 1 in Track "VTS_01_PGC_01") is across scene boundary at 01:10:27;00
Warning Sub-Picture (stream 5 in Track "VTS_01_PGC_01") is across scene boundary at 01:10:27;00
Warning Sub-Picture (stream 8 in Track "VTS_01_PGC_01") is across scene boundary at 01:10:27;00
Error Track(VTS_01_PGC_02) Sub-Picture stream 1 does't have Sub-Picture data.
Error Track(VTS_01_PGC_02) Sub-Picture stream 5 does't have Sub-Picture data.
Error Track(VTS_01_PGC_02) Sub-Picture stream 8 does't have Sub-Picture data.
Error Track(VTS_01_PGC_04) Sub-Picture stream 1 does't have Sub-Picture data.
Error Track(VTS_01_PGC_04) Sub-Picture stream 5 does't have Sub-Picture data.
Error Track(VTS_01_PGC_04) Sub-Picture stream 8 does't have Sub-Picture data.
Error Track(VTS_01_PGC_06) Sub-Picture stream 1 does't have Sub-Picture data.
Error Track(VTS_01_PGC_06) Sub-Picture stream 5 does't have Sub-Picture data.
Error Track(VTS_01_PGC_06) Sub-Picture stream 8 does't have Sub-Picture data.
Warning Sub-Picture (stream 2 in Track "VTS_02_PGC_02") is across scene boundary at 00:00:35;13
Warning Sub-Picture (stream 2 in Track "VTS_02_PGC_03") is across scene boundary at 00:03:20;04
Error Track(VTS_02_PGC_04) Sub-Picture stream 2 does't have Sub-Picture data.
Warning Sub-Picture (stream 2 in Track "VTS_02_PGC_05") is across scene boundary at 00:00:11;13
Warning Sub-Picture (stream 2 in Track "VTS_02_PGC_06") is across scene boundary at 00:00:24;07
Error Track(VTS_02_PGC_07) Sub-Picture stream 2 does't have Sub-Picture data.
Warning Sub-Picture (stream 2 in Track "VTS_02_PGC_09") is across scene boundary at 00:00:34;00
Error Track(VTS_02_PGC_10) Sub-Picture stream 2 does't have Sub-Picture data.
Warning Sub-Picture (stream 2 in Track "VTS_02_PGC_11") is across scene boundary at 00:00:15;21
Warning Sub-Picture (stream 2 in Track "VTS_02_PGC_12") is across scene boundary at 00:00:39;14
Error Track(VTS_02_PGC_13) Sub-Picture stream 2 does't have Sub-Picture data.
Warning Sub-Picture (stream 2 in Track "VTS_02_PGC_15") is across scene boundary at 00:00:44;13
Error Track(VTS_02_PGC_16) Sub-Picture stream 2 does't have Sub-Picture data.
Warning Sub-Picture (stream 2 in Track "VTS_02_PGC_17") is across scene boundary at 00:02:13;14
Error Validate From DB failed
Error DVD files could not be created
Ich verzweifle langsam. Es handelt sich bei den Subtitels alle um angelich vorhandene Files, jedoch sehe keine Einträge (schwarze Streifen), wie bei dem Hauptfilm. D.h. Die Subtitle Felder sind leer, aber nicht als Dummy angegeben.. ist das vielleicht der Fehler? Kann man die Untertitel einfach löschen? Oder wie macht man dies korrekt?
Liegts vielleicht an etwas ganz anderem? Vielleicht daran, dass ich den Film (Mumie1) nicht als Iterlaced mit Progressiv anstatt mit Alternate Scan (bei DoCCE4U) encodet habe?!
Kennt einer eine Lösung? Im Doom9.org Forum taucht das Problem eigentlich ganicht auf.. liegts vielleicht wirklich an PAL?
