... doch: In meinem allerersten Beitrag habe ich sofort von 20-25.000 geschrieben
Die Clip spiele ich von einer internen Platte ab
System Information
Time of this report: 6/23/2013, 13:07:07
Machine name: FUCHS
Operating System: Windows XP Home Edition (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_qfe.130503-0418)
Language: German (Regional Setting: German)
System Manufacturer: MEDIONPC
System Model: MS-7204
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: Intel(R) Pentium(R) D CPU 3.00GHz (2 CPUs)
Memory: 3070MB RAM
Page File: 978MB used, 4288MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.5512 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Display Tab 2: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: The file tbhsd.sys is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Sound Tab 3: The file tbhsd.sys is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Sound Tab 4: The file tbhsd.sys is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Sound Tab 5: The file tbhsd.sys is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Sound Tab 6: The file tbhsd.sys is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Sound Tab 7: The file tbhsd.sys is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Sound Tab 8: The file tbhsd.sys is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Sound Tab 9: The file tbhsd.sys is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Sound Tab 10: The file tbhsd.sys is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Sound Tab 11: The file tbhsd.sys is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Sound Tab 12: The file tbhsd.sys is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Sound Tab 13: The file tbhsd.sys is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce 6700 XL
Manufacturer: NVIDIA
Chip type: GeForce 6700 XL
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0147&SUBSYS_03501462&REV_A2
Display Memory: 128.0 MB
Current Mode: 1280 x 1024 (32 bit) (60Hz)
Monitor: (Standardmonitor)
Monitor Max Res:
Driver Name: nv4_disp.dll
Driver Version: 6.14.0013.0783 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 2/8/2013 05:03:00, 4494336 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: Nicht zutreffend
Mini VDD: nv4_mini.sys
Mini VDD Date: 2/8/2013 05:02:44, 12648960 bytes
Device Identifier: {D7B71E3E-4207-11CF-DD74-5D2303C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0147
SubSys ID: 0x03501462
Revision ID: 0x00A2
Revision ID: 0x00A2
Video Accel: ModeMPEG2_C ModeMPEG2_D ModeWMV9_B ModeWMV9_A
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Current Mode: 2048 x 1536 (32 bit) (60Hz)
Monitor Max Res:
WHQL Logo'd: Yes
Vendor ID: 0x10DE
Device ID: 0x0147
Revision ID: 0x00A2
Revision ID: 0x00A2
Registry: OK
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Description: Realtek HD Audio output
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0882&SUBSYS_10EC0882&REV_1001
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: RtkHDAud.sys
Driver Version: 5.10.0000.5211 (English)
WHQL Logo'd: Yes
Date and Size: 1/13/2006 18:13:18, 4137984 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 8000, 192000
Static/Strm HW Mix Bufs: 33, 32
Static/Strm HW 3D Bufs: 33, 32
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: Yes, Yes
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Description: Audials Sound Capturing
Default Sound Playback: No
Default Voice Playback: No
Hardware ID: root\tbhsd
Manufacturer ID: 1
Product ID: 65535
Type: WDM
Driver Name: tbhsd.sys
Driver Version: 6.00.3400.0000 (English)
WHQL Logo'd: No
Date and Size: 7/20/2012 00:21:20, 39016 bytes
Other Files:
Driver Provider: RapidSolution Software
Cap Flags: 0xB5B
Min/Max Sample Rate: 44100, 44100
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Registry: OK
Manufacturer ID: 1
Product ID: 65535
Type: WDM
WHQL Logo'd: No
Other Files:
Cap Flags: 0xB5B
HW Memory: 0
Registry: OK
Manufacturer ID: 1
Product ID: 65535
Type: WDM
WHQL Logo'd: No
Other Files:
Cap Flags: 0xB5B
HW Memory: 0
Registry: OK
Manufacturer ID: 1
Product ID: 65535
Type: WDM
WHQL Logo'd: No
Other Files:
Cap Flags: 0xB5B
HW Memory: 0
Registry: OK
Manufacturer ID: 1
Product ID: 65535
Type: WDM
WHQL Logo'd: No
Other Files:
Cap Flags: 0xB5B
HW Memory: 0
Registry: OK
Manufacturer ID: 1
Product ID: 65535
Type: WDM
WHQL Logo'd: No
Other Files:
Cap Flags: 0xB5B
HW Memory: 0
Registry: OK
Manufacturer ID: 1
Product ID: 65535
Type: WDM
WHQL Logo'd: No
Other Files:
Cap Flags: 0xB5B
HW Memory: 0
Registry: OK
Manufacturer ID: 1
Product ID: 65535
Type: WDM
WHQL Logo'd: No
Other Files:
Cap Flags: 0xB5B
HW Memory: 0
Registry: OK
Manufacturer ID: 1
Product ID: 65535
Type: WDM
WHQL Logo'd: No
Other Files:
Cap Flags: 0xB5B
HW Memory: 0
Registry: OK
Manufacturer ID: 1
Product ID: 65535
Type: WDM
WHQL Logo'd: No
Other Files:
Cap Flags: 0xB5B
HW Memory: 0
Registry: OK
Manufacturer ID: 1
Product ID: 65535
Type: WDM
WHQL Logo'd: No
Other Files:
Cap Flags: 0xB5B
HW Memory: 0
Registry: OK
Manufacturer ID: 1
Product ID: 65535
Type: WDM
WHQL Logo'd: No
Other Files:
Cap Flags: 0xB5B
HW Memory: 0
Registry: OK
Sound Capture Devices
Description: Realtek HD Audio input
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xFFF
Description: Realtek HD Digital input
Default Sound Capture: No
Default Voice Capture: No
Cap Flags: 0x41
Format Flags: 0xFFF
Description: 713x BDA Analog Audio Capture
Driver Name: 3xHybrid.sys
Driver Version: 1.03.0003.0001 (English)
Date and Size: 12/6/2005 12:16:00, 826752 bytes
Cap Flags: 0x41
Format Flags: 0xCC0
Cap Flags: 0x41
Format Flags: 0xCC0
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
Audials Sound Capturing, Software (Kernel Mode), Output, DLS, Internal
Audials Sound Capturing (10), Software (Kernel Mode), Output, DLS, Internal
Audials Sound Capturing (11), Software (Kernel Mode), Output, DLS, Internal
Audials Sound Capturing (12), Software (Kernel Mode), Output, DLS, Internal
Audials Sound Capturing (2), Software (Kernel Mode), Output, DLS, Internal
Audials Sound Capturing (3), Software (Kernel Mode), Output, DLS, Internal
Audials Sound Capturing (4), Software (Kernel Mode), Output, DLS, Internal
Audials Sound Capturing (5), Software (Kernel Mode), Output, DLS, Internal
Audials Sound Capturing (6), Software (Kernel Mode), Output, DLS, Internal
Audials Sound Capturing (7), Software (Kernel Mode), Output, DLS, Internal
Audials Sound Capturing (8), Software (Kernel Mode), Output, DLS, Internal
Audials Sound Capturing (9), Software (Kernel Mode), Output, DLS, Internal
Microsoft MIDI-Mapper [Emuliert], Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft GS Wavetable SW Synth [Emuliert], Hardware (Not Kernel Mode), Output, No DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Maus
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Tastatur
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: USB Advance Mouse
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x046E, 0x52E6
FF Driver: n/a
Device Name: USB Wireless HID Receiver
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x04F2, 0x0420
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB-Root-Hub
| Vendor/Product ID: 0x8086, 0x27CA
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 4/14/2008 01:15:38, 59520 bytes
| Driver: usbd.sys, 8/4/2004 14:00:00, 4736 bytes
Gameport Devices
PS/2 Devices
+ HID-Tastatur
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
| Driver: kbdhid.sys, 4/14/2008 08:28:38, 14720 bytes
| Driver: kbdclass.sys, 4/14/2008 08:28:38, 25216 bytes
+ HID-Tastatur
| Service: kbdhid
+ Terminalserver-Tastaturtreiber
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 4/14/2008 08:53:28, 40840 bytes
+ PS/2-kompatible Maus
| Matching Device ID: *pnp0f13
| Service: i8042prt
| Driver: i8042prt.sys, 4/14/2008 08:25:36, 52992 bytes
| Driver: mouclass.sys, 4/14/2008 08:19:38, 23552 bytes
+ HID-konforme Maus
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
| Driver: mouhid.sys, 8/18/2001 04:22:44, 12288 bytes
+ HID-konforme Maus
| Service: mouhid
+ Terminalserver-Maustreiber
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.6311)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.6311)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.6311)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.6311)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
DirectPlay Voice Wizard Tests: Full Duplex: Passed, Half Duplex: Passed, Mic: Passed
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Modem Service Provider: Creatix V.92 Data Fax Modem
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 Serial Service Provider: COM2
DirectPlay8 Serial Service Provider: COM3
DirectPlay8 TCP/IP Service Provider: Drahtlose Netzwerkverbindung - IPv6 - fe80::212:bfff:fe63:f88b
DirectPlay8 TCP/IP Service Provider: Teredo Tunneling Pseudo-Interface - IPv6 - fe80::ffff:ffff:fffd
DirectPlay8 TCP/IP Service Provider: Automatic Tunneling Pseudo-Interface - IPv6 - fe80::5efe:
DirectPlay8 TCP/IP Service Provider: Drahtlose Netzwerkverbindung - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1,4 KBit/s
Voxware SC06 6,4 KBit/s
Voxware SC03 3,2 KBit/s
MS-PCM 64 KBit/s
MS-ADPCM 32,8 KBit/s
Microsoft GSM 6.10 13 KBit/s
TrueSpeech(TM) 8,6 KBit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 46.2 GB
Total Space: 80.0 GB
File System: NTFS
Model: ST3250824AS
Drive: D:
Free Space: 0.5 GB
Total Space: 3.0 GB
File System: NTFS
Model: ST3250824AS
Drive: E:
Free Space: 0.9 GB
Total Space: 7.0 GB
File System: FAT32
Model: ST3250824AS
Drive: F:
Free Space: 1.4 GB
Total Space: 6.5 GB
File System: NTFS
Model: ST3250824AS
Drive: G:
Free Space: 31.4 GB
Total Space: 115.0 GB
File System: NTFS
Model: ST3250824AS
Drive: I:
Free Space: 28.7 GB
Total Space: 194.5 GB
File System: NTFS
Model: Maxtor 6B200P0
Drive: K:
Free Space: 120.2 GB
Total Space: 715.4 GB
File System: NTFS
Model: SAMSUNG HD753LJ
Drive: N:
Free Space: 343.3 GB
Total Space: 603.9 GB
File System: NTFS
Model: ST310005 28AS USB Device
Drive: R:
Free Space: 191.0 GB
Total Space: 350.0 GB
File System: NTFS
Drive: S:
Free Space: 34.3 GB
Total Space: 155.2 GB
File System: NTFS
Model: WDC WD32 00JB-00KFA0 USB Device
Drive: T:
Free Space: 27.3 GB
Total Space: 150.0 GB
File System: NTFS
Drive: V:
Free Space: 87.4 GB
Total Space: 110.2 GB
File System: NTFS
Drive: W:
Free Space: 21.4 GB
Total Space: 110.0 GB
File System: NTFS
Drive: X:
Free Space: 14.2 GB
Total Space: 85.0 GB
File System: NTFS
Drive: Z:
Free Space: 6.8 GB
Total Space: 26.9 GB
File System: NTFS
Model: ST3250824AS
Drive: H:
Model: SONY DVD RW DW-G121A
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.5512 (German), 4/14/2008 01:10:48, 62976 bytes
Drive: J:
Model: SF1190M UDK853F SCSI CdRom Device
System Devices
Name: Intel(R) 82801G (ICH7 Family) Ultra ATA Storage Controllers - 27DF
Device ID: PCI\VEN_8086&DEV_27DF&SUBSYS_72041462&REV_01\3&2411E6FE&0&F9
Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (German), 8/18/2001 04:30:42, 3328 bytes
Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.5512 (German), 4/14/2008 01:10:30, 24960 bytes
Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.5512 (English), 4/14/2008 01:10:32, 96512 bytes
Name: Intel(R) 82801G (ICH7 Family) SMBus Controller - 27DA
Device ID: PCI\VEN_8086&DEV_27DA&SUBSYS_72041462&REV_01\3&2411E6FE&0&FB
Driver: n/a
Name: Microsoft UAA-Bustreiber für High Definition Audio
Device ID: PCI\VEN_8086&DEV_27D8&SUBSYS_72041462&REV_01\3&2411E6FE&0&D8
Driver: C:\WINDOWS\system32\DRIVERS\hdaudbus.sys, 5.10.0001.5013 (English), 4/13/2008 23:06:06, 144384 bytes
Name: Intel(R) 82801G (ICH7 Family) USB2 Enhanced Host Controller - 27CC
Device ID: PCI\VEN_8086&DEV_27CC&SUBSYS_72041462&REV_01\3&2411E6FE&0&EF
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.5512 (English), 4/14/2008 01:15:36, 30208 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.5512 (English), 4/14/2008 01:15:38, 143872 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.5512 (German), 4/14/2008 08:52:32, 77312 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.5512 (English), 4/14/2008 01:15:38, 59520 bytes
Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.5512 (English), 4/14/2008 08:52:12, 7168 bytes
Name: Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27CB
Device ID: PCI\VEN_8086&DEV_27CB&SUBSYS_72041462&REV_01\3&2411E6FE&0&EB
Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.5512 (English), 4/14/2008 01:15:36, 20608 bytes
Name: Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27CA
Device ID: PCI\VEN_8086&DEV_27CA&SUBSYS_72041462&REV_01\3&2411E6FE&0&EA
Name: Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C9
Device ID: PCI\VEN_8086&DEV_27C9&SUBSYS_72041462&REV_01\3&2411E6FE&0&E9
Name: Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C8
Device ID: PCI\VEN_8086&DEV_27C8&SUBSYS_72041462&REV_01\3&2411E6FE&0&E8
Name: Intel(R) 82801GB/GR/GH (ICH7 Family) Serial ATA Storage Controller - 27C0
Device ID: PCI\VEN_8086&DEV_27C0&SUBSYS_72041462&REV_01\3&2411E6FE&0&FA
Name: Intel(R) 82801GB/GR (ICH7 Family) LPC Interface Controller - 27B8
Device ID: PCI\VEN_8086&DEV_27B8&SUBSYS_00000000&REV_01\3&2411E6FE&0&F8
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.5512 (German), 4/14/2008 08:28:04, 37632 bytes
Name: Intel(R) 945G/GZ/GC/P/PL PCI Express Root Port - 2771
Device ID: PCI\VEN_8086&DEV_2771&SUBSYS_00000000&REV_81\3&2411E6FE&0&08
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.5512 (German), 4/14/2008 08:32:14, 68224 bytes
Name: Intel(R) 945G/GZ/GC/P/PL Processor to I/O Controller - 2770
Device ID: PCI\VEN_8086&DEV_2770&SUBSYS_00000000&REV_81\3&2411E6FE&0&00
Driver: n/a
Name: Intel(R) 82801 PCI Bridge - 244E
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_00000000&REV_E1\3&2411E6FE&0&F0
Name: Creatix V.92 Data Fax Modem
Device ID: PCI\VEN_11C1&DEV_0620&SUBSYS_062011C1&REV_00\4&1AF1648C&0&28F0
Driver: n/a
Name: Medion SAA7131, Hybrid Capture Device 2
Device ID: PCI\VEN_1131&DEV_7133&SUBSYS_000816BE&REV_D1\4&1AF1648C&0&20F0
Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.5512 (English), 4/14/2008 01:15:16, 60160 bytes
Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.5512 (English), 4/14/2008 01:49:42, 146048 bytes
Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.2600.5512 (German), 4/14/2008 01:15:16, 49408 bytes
Driver: C:\WINDOWS\system32\wdmaud.drv, 5.01.2600.5512 (English), 4/14/2008 08:53:10, 23552 bytes
Driver: C:\WINDOWS\system32\ksuser.dll, 5.03.2600.5512 (German), 4/14/2008 08:52:14, 4096 bytes
Driver: C:\WINDOWS\system32\kstvtune.ax, 5.03.2600.5512 (German), 4/14/2008 08:53:08, 61952 bytes
Driver: C:\WINDOWS\system32\ksxbar.ax, 5.03.2600.5512 (English), 4/14/2008 08:53:08, 43008 bytes
Driver: C:\WINDOWS\system32\kswdmcap.ax, 5.03.2600.5512 (German), 4/14/2008 08:53:08, 91648 bytes
Driver: C:\WINDOWS\system32\vidcap.ax, 5.01.2600.5512 (English), 4/14/2008 08:53:08, 28672 bytes
Driver: C:\WINDOWS\system32\vfwwdm32.dll, 5.01.2600.5512 (German), 4/14/2008 08:52:32, 54272 bytes
Driver: C:\WINDOWS\system32\iyuv_32.dll, 5.01.2600.5908 (German), 11/27/2009 18:08:01, 48128 bytes
Driver: C:\WINDOWS\system32\msh263.drv, 5.01.2600.5512 (German), 4/14/2008 08:53:10, 299008 bytes
Driver: C:\WINDOWS\system32\msyuv.dll, 5.03.2600.5908 (English), 11/27/2009 19:11:57, 17920 bytes
Driver: C:\WINDOWS\system32\BdaPlgIn.ax, 5.03.2600.5512 (German), 4/14/2008 08:53:08, 18432 bytes
Driver: C:\WINDOWS\system32\MSDvbNP.ax, 6.05.2600.5512 (English), 4/14/2008 08:53:08, 56832 bytes
Driver: C:\WINDOWS\system32\PsisRndr.ax, 6.05.2600.5512 (English), 4/14/2008 08:53:08, 33280 bytes
Driver: C:\WINDOWS\system32\PsisDecd.dll, 6.05.2600.5512 (English), 4/14/2008 08:52:24, 363520 bytes
Driver: C:\WINDOWS\system32\drivers\BdaSup.sys, 5.03.2600.5512 (English), 4/14/2008 01:16:22, 11776 bytes
Driver: C:\WINDOWS\system32\tsbyuv.dll, 5.01.2600.5908 (English), 11/27/2009 18:08:01, 8704 bytes
Driver: C:\WINDOWS\system32\drivers\3xHybrid.sys, 1.03.0003.0001 (English), 12/6/2005 12:16:00, 826752 bytes
Driver: C:\WINDOWS\system32\34CoInstaller.dll, 2/27/2003 10:07:20, 3072 bytes
Name: Medion SAA7131, Hybrid Capture Device 1
Device ID: PCI\VEN_1131&DEV_7133&SUBSYS_000716BE&REV_D1\4&1AF1648C&0&08F0
Name: VIA RAID Controller - 3249
Device ID: PCI\VEN_1106&DEV_3249&SUBSYS_32491106&REV_50\4&1AF1648C&0&00F0
Driver: C:\WINDOWS\system32\DRIVERS\viamraid.sys, 5.01.6000.0574 (English), 1/22/2008 08:02:24, 117248 bytes
Name: VIA OHCI-konformer IEEE 1394-Hostcontroller
Device ID: PCI\VEN_1106&DEV_3044&SUBSYS_204D1462&REV_80\4&1AF1648C&0&18F0
Driver: C:\WINDOWS\system32\DRIVERS\ohci1394.sys, 5.01.2600.5512 (English), 4/14/2008 01:16:20, 61696 bytes
Driver: C:\WINDOWS\system32\DRIVERS\1394bus.sys, 5.01.2600.5512 (English), 4/14/2008 01:16:20, 53376 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nic1394.sys, 5.01.2600.5512 (English), 4/14/2008 01:21:26, 61824 bytes
Driver: C:\WINDOWS\system32\DRIVERS\arp1394.sys, 5.01.2600.5512 (English), 4/14/2008 01:21:26, 60800 bytes
Driver: C:\WINDOWS\system32\DRIVERS\enum1394.sys, 5.01.2600.0000 (English), 8/17/2001 14:46:40, 6400 bytes
Name: Realtek RTL8139-Familie-PCI-Fast Ethernet-NIC
Device ID: PCI\VEN_10EC&DEV_8139&SUBSYS_204C1462&REV_10\4&1AF1648C&0&10F0
Driver: C:\WINDOWS\system32\DRIVERS\RTL8139.sys, 5.398.0613.2003 (English), 8/3/2004 23:31:34, 20992 bytes
Name: NVIDIA GeForce 6700 XL
Device ID: PCI\VEN_10DE&DEV_0147&SUBSYS_03501462&REV_A2\4&11C8B129&0&0008
Driver: C:\Programme\NVIDIA Corporation\Drs\dbInstaller.exe, 6.14.0013.0783 (English), 2/8/2013 05:02:42, 182272 bytes
Driver: C:\Programme\NVIDIA Corporation\Drs\nvdrsdb.bin, 2/8/2013 05:03:02, 1072424 bytes
Driver: C:\Programme\NVIDIA Corporation\CPLInstallerCache\NvCplSetupInt.exe, 1.00.0001.0000 (German), 2/8/2013 05:02:54, 77663992 bytes
Driver: C:\Programme\NVIDIA Corporation\license.txt, 2/8/2013 05:03:00, 21898 bytes
Driver: C:\Programme\NVIDIA Corporation\OpenCL\OpenCL.dll, 1.00.0000.0000 (English), 2/8/2013 05:02:44, 65536 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nv4_mini.sys, 6.14.0013.0783 (English), 2/8/2013 05:02:44, 12648960 bytes
Driver: C:\WINDOWS\system32\nv4_disp.dll, 6.14.0013.0783 (English), 2/8/2013 05:03:00, 4494336 bytes
Driver: C:\WINDOWS\system32\nvapi.dll, 6.14.0013.0783 (English), 2/8/2013 05:02:56, 2389504 bytes
Driver: C:\WINDOWS\system32\nvcompiler.dll, 6.14.0013.0783 (English), 2/8/2013 05:02:56, 17551360 bytes
Driver: C:\WINDOWS\system32\nvcuda.dll, 6.14.0013.0783 (English), 2/8/2013 05:02:58, 7536640 bytes
Driver: C:\WINDOWS\system32\nvcuvenc.dll, 6.14.0013.0783 (English), 2/8/2013 05:02:42, 1869088 bytes
Driver: C:\WINDOWS\system32\nvcuvid.dll, 6.14.0013.0783 (English), 2/8/2013 05:02:58, 2581792 bytes
Driver: C:\WINDOWS\system32\nvdata.data, 2/8/2013 05:03:08, 2816504 bytes
Driver: C:\WINDOWS\system32\nvinfo.pb, 2/8/2013 05:02:44, 15449 bytes
Driver: C:\WINDOWS\system32\nvoglnt.dll, 6.14.0013.0783 (English), 2/8/2013 05:03:02, 19189760 bytes
Driver: C:\WINDOWS\system32\nvopencl.dll, 6.14.0013.0783 (English), 2/8/2013 05:02:42, 5967872 bytes
Driver: C:\WINDOWS\system32\nvdispco32.dll, 2.00.0026.0004 (English), 2/8/2013 05:03:02, 1010464 bytes
Driver: C:\WINDOWS\system32\nvdispgenco32.dll, 2.00.0016.0002 (English), 2/8/2013 05:02:56, 892704 bytes
DirectX Components
ddraw.dll: 5.03.2600.5512 German Final Retail 4/14/2008 08:52:10 279552 bytes
ddrawex.dll: 5.03.2600.5512 English Final Retail 4/14/2008 08:52:10 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/4/2004 14:00:00 10496 bytes
d3d8.dll: 5.03.2600.5512 German Final Retail 4/14/2008 08:52:10 1179648 bytes
d3d8thk.dll: 5.03.2600.5512 English Final Retail 4/14/2008 08:52:10 8192 bytes
d3d9.dll: 5.03.2600.5512 English Final Retail 4/14/2008 08:52:10 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 8/4/2004 14:00:00 436224 bytes
d3dim700.dll: 5.03.2600.5512 English Final Retail 4/14/2008 08:52:10 824320 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 8/4/2004 14:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 8/4/2004 14:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 8/4/2004 14:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/4/2004 14:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 German Final Retail 8/4/2004 14:00:00 33040 bytes
dplayx.dll: 5.03.2600.5512 English Final Retail 4/14/2008 08:52:10 229888 bytes
dpmodemx.dll: 5.03.2600.5512 German Final Retail 4/14/2008 08:52:10 24064 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 8/4/2004 14:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.5512 German Final Retail 4/14/2008 08:52:10 57856 bytes
dplaysvr.exe: 5.03.2600.5512 English Final Retail 4/14/2008 08:52:44 29696 bytes
dpnsvr.exe: 5.03.2600.5512 German Final Retail 4/14/2008 08:52:44 17920 bytes
dpnet.dll: 5.03.2600.6311 English Final Retail 11/2/2012 04:02:36 375296 bytes
dpnlobby.dll: 5.03.2600.5512 English Final Retail 4/14/2008 08:50:28 3072 bytes
dpnaddr.dll: 5.03.2600.5512 English Final Retail 4/14/2008 08:50:28 3072 bytes
dpvoice.dll: 5.03.2600.5512 German Final Retail 4/14/2008 08:52:10 214016 bytes
dpvsetup.exe: 5.03.2600.5512 English Final Retail 4/14/2008 08:52:44 83456 bytes
dpvvox.dll: 5.03.2600.5512 German Final Retail 4/14/2008 08:52:10 116736 bytes
dpvacm.dll: 5.03.2600.5512 German Final Retail 4/14/2008 08:52:10 21504 bytes
dpnhpast.dll: 5.03.2600.5512 English Final Retail 4/14/2008 08:52:10 35328 bytes
dpnhupnp.dll: 5.03.2600.5512 English Final Retail 4/14/2008 08:52:10 60928 bytes
dpserial.dll: 5.00.2134.0001 German Final Retail 8/4/2004 14:00:00 54032 bytes
dinput.dll: 5.03.2600.5512 German Final Retail 4/14/2008 08:52:10 163328 bytes
dinput8.dll: 5.03.2600.5512 German Final Retail 4/14/2008 08:52:10 186368 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 8/4/2004 14:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 German Final Retail 8/4/2004 14:00:00 395264 bytes
joy.cpl: 5.03.2600.5512 German Final Retail 4/14/2008 08:53:08 69632 bytes
gcdef.dll: 5.01.2600.0000 German Final Retail 8/4/2004 14:00:00 78336 bytes
pid.dll: 5.03.2600.5512 English Final Retail 4/14/2008 08:52:24 35328 bytes
dsound.dll: 5.03.2600.5512 German Final Retail 4/14/2008 08:52:10 367616 bytes
dsound3d.dll: 5.03.2600.5512 English Final Retail 4/14/2008 08:52:10 1293824 bytes
dswave.dll: 5.03.2600.5512 English Final Retail 4/14/2008 08:52:10 19456 bytes
dsdmo.dll: 5.03.2600.5512 English Final Retail 4/14/2008 08:52:10 181248 bytes
dsdmoprp.dll: 5.03.2600.5512 German Final Retail 4/14/2008 08:52:10 74240 bytes
dmusic.dll: 5.03.2600.5512 German Final Retail 4/14/2008 08:52:10 104448 bytes
dmband.dll: 5.03.2600.5512 English Final Retail 4/14/2008 08:52:10 28672 bytes
dmcompos.dll: 5.03.2600.5512 English Final Retail 4/14/2008 08:52:10 61440 bytes
dmime.dll: 5.03.2600.5512 English Final Retail 4/14/2008 08:52:10 181248 bytes
dmloader.dll: 5.03.2600.5512 English Final Retail 4/14/2008 08:52:10 35840 bytes
dmstyle.dll: 5.03.2600.5512 English Final Retail 4/14/2008 08:52:10 105984 bytes
dmsynth.dll: 5.03.2600.5512 English Final Retail 4/14/2008 08:52:10 103424 bytes
dmscript.dll: 5.03.2600.5512 English Final Retail 4/14/2008 08:52:10 82432 bytes
system.dll: 1.01.4322.2502 English Final Retail 1/11/2013 22:02:50 1232896 bytes
Microsoft.DirectX.Direct3D.dll: 9.05.0132.0000 English Final Retail 3/6/2011 20:11:36 473600 bytes
Microsoft.DirectX.Direct3DX.dll: 5.04.0000.3900 English Final Retail 3/6/2011 20:11:29 2676224 bytes
Microsoft.DirectX.Direct3DX.dll: 9.04.0091.0000 English Final Retail 3/6/2011 20:11:30 2846720 bytes
Microsoft.DirectX.Direct3DX.dll: 9.05.0132.0000 English Final Retail 3/6/2011 20:11:31 563712 bytes
Microsoft.DirectX.Direct3DX.dll: 9.06.0168.0000 English Final Retail 3/6/2011 20:11:31 567296 bytes
Microsoft.DirectX.Direct3DX.dll: 9.07.0239.0000 English Final Retail 3/6/2011 20:11:32 576000 bytes
Microsoft.DirectX.Direct3DX.dll: 9.08.0299.0000 English Final Retail 3/6/2011 20:11:32 577024 bytes
Microsoft.DirectX.Direct3DX.dll: 9.09.0376.0000 English Final Retail 3/6/2011 20:11:33 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.10.0455.0000 English Final Retail 3/6/2011 20:11:33 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.11.0519.0000 English Final Retail 3/6/2011 20:11:34 578560 bytes
Microsoft.DirectX.Direct3DX.dll: 9.12.0589.0000 English Final Retail 3/6/2011 20:11:36 578560 bytes
Microsoft.DirectX.DirectDraw.dll: 5.04.0000.2904 English Final Retail 3/6/2011 20:11:37 145920 bytes
Microsoft.DirectX.DirectInput.dll: 5.04.0000.2904 English Final Retail 3/6/2011 20:11:37 159232 bytes
Microsoft.DirectX.DirectPlay.dll: 5.04.0000.2904 English Final Retail 3/6/2011 20:11:37 364544 bytes
Microsoft.DirectX.DirectSound.dll: 5.04.0000.2904 English Final Retail 3/6/2011 20:11:37 178176 bytes
Microsoft.DirectX.AudioVideoPlayback.dll: 5.04.0000.2904 English Final Retail 3/6/2011 20:11:36 53248 bytes
Microsoft.DirectX.Diagnostics.dll: 5.04.0000.2904 English Final Retail 3/6/2011 20:11:36 12800 bytes
Microsoft.DirectX.dll: 5.04.0000.2904 English Final Retail 3/6/2011 20:11:35 223232 bytes
dx7vb.dll: 5.03.2600.5512 German Final Retail 4/14/2008 08:52:10 619008 bytes
dx8vb.dll: 5.03.2600.5512 German Final Retail 4/14/2008 08:52:10 1227264 bytes
dxdiagn.dll: 5.03.2600.5512 German Final Retail 4/14/2008 08:52:10 2113536 bytes
mfc40.dll: 4.01.0000.6151 English Beta Retail 9/18/2010 08:52:56 954368 bytes
mfc42.dll: 6.02.8081.0000 English Final Retail 2/8/2011 15:33:28 978944 bytes
wsock32.dll: 5.01.2600.5512 German Final Retail 4/14/2008 08:52:34 24576 bytes
amstream.dll: 6.05.2600.5512 English Final Retail 4/14/2008 08:52:08 70656 bytes
devenum.dll: 6.05.2600.5512 German Final Retail 4/14/2008 08:52:10 59904 bytes
dxmasf.dll: 6.04.0009.1133 German Final Retail 4/14/2008 08:52:10 500278 bytes
mciqtz32.dll: 6.05.2600.5512 German Final Retail 4/14/2008 08:52:16 35328 bytes
mpg2splt.ax: 6.05.2600.6333 English Final Retail 1/2/2013 08:49:00 148992 bytes
msdmo.dll: 6.05.2600.5512 English Final Retail 4/14/2008 08:52:18 14336 bytes
encapi.dll: 5.03.2600.5512 English Final Retail 4/14/2008 08:52:12 20480 bytes
qasf.dll: 11.00.5721.5145 English Final Retail 10/18/2006 22:47:18 211456 bytes
qcap.dll: 6.05.2600.5512 German Final Retail 4/14/2008 08:52:24 192512 bytes
qdv.dll: 6.05.2600.5512 German Final Retail 4/14/2008 08:52:24 279040 bytes
qdvd.dll: 6.05.2600.6169 German Final Retail 11/3/2011 17:28:30 387072 bytes
qedit.dll: 6.05.2600.5512 German Final Retail 4/14/2008 08:52:24 563200 bytes
qedwipes.dll: 6.05.2600.5512 English Final Retail 4/13/2008 23:51:34 733696 bytes
quartz.dll: 6.05.2600.6333 German Final Retail 1/2/2013 08:49:00 1297920 bytes
strmdll.dll: 4.01.0000.3938 German Final Retail 8/26/2009 10:00:21 247326 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 4/14/2008 08:53:08 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 4/14/2008 08:53:08 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 4/14/2008 08:52:14 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 4/14/2008 08:52:14 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 4/14/2008 08:52:14 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 4/14/2008 08:52:14 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 4/14/2008 08:52:14 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 4/14/2008 08:53:08 154624 bytes
mswebdvd.dll: 6.05.2600.5857 German Final Retail 8/5/2009 10:59:36 206336 bytes
ks.sys: 5.03.2600.5512 German Final Retail 4/14/2008 01:46:38 141056 bytes
ksproxy.ax: 5.03.2600.5512 German Final Retail 4/14/2008 08:53:08 129536 bytes
ksuser.dll: 5.03.2600.5512 German Final Retail 4/14/2008 08:52:14 4096 bytes
stream.sys: 5.03.2600.5512 German Final Retail 4/14/2008 01:15:16 49408 bytes
mspclock.sys: 5.03.2600.5512 German Final Retail 4/14/2008 01:09:52 5376 bytes
mspqm.sys: 5.01.2600.5512 German Final Retail 4/14/2008 01:09:52 4992 bytes
mskssrv.sys: 5.03.2600.5512 German Final Retail 4/14/2008 01:09:54 7552 bytes
swenum.sys: 5.03.2600.5512 German Final Retail 4/14/2008 01:09:54 4352 bytes
mstee.sys: 5.03.2600.5512 German Final Retail 4/14/2008 01:09:52 5504 bytes
bdaplgin.ax: 5.03.2600.5512 German Final Retail 4/14/2008 08:53:08 18432 bytes
bdasup.sys: 5.03.2600.5512 English Final Retail 4/14/2008 01:16:22 11776 bytes
msdvbnp.ax: 6.05.2600.5512 English Final Retail 4/14/2008 08:53:08 56832 bytes
psisdecd.dll: 6.05.2600.5512 English Final Retail 4/14/2008 08:52:24 363520 bytes
psisrndr.ax: 6.05.2600.5512 English Final Retail 4/14/2008 08:53:08 33280 bytes
ipsink.ax: 5.03.2600.5512 German Final Retail 4/14/2008 08:53:08 16384 bytes
mpeg2data.ax: 6.05.2600.5512 English Final Retail 4/14/2008 08:53:08 118272 bytes
ndisip.sys: 5.03.2600.5512 English Final Retail 4/14/2008 01:16:24 10880 bytes
mpe.sys: 5.03.2600.5512 English Final Retail 4/14/2008 01:16:24 15232 bytes
streamip.sys: 5.03.2600.5512 English Final Retail 4/14/2008 01:16:22 15232 bytes
msvidctl.dll: 6.05.2600.5512 German Final Retail 4/14/2008 08:52:20 1433088 bytes
slip.sys: 5.03.2600.5512 English Final Retail 4/14/2008 01:16:24 11136 bytes
nabtsfec.sys: 5.03.2600.5512 English Final Retail 4/14/2008 01:16:26 85248 bytes
ccdecode.sys: 5.03.2600.5512 English Final Retail 4/14/2008 01:16:24 17024 bytes
vbisurf.ax: 5.03.2600.5512 English Final Retail 4/14/2008 08:53:08 30208 bytes
msyuv.dll: 5.03.2600.5908 English Final Retail 11/27/2009 19:11:57 17920 bytes
kstvtune.ax: 5.03.2600.5512 German Final Retail 4/14/2008 08:53:08 61952 bytes
ksxbar.ax: 5.03.2600.5512 English Final Retail 4/14/2008 08:53:08 43008 bytes
kswdmcap.ax: 5.03.2600.5512 German Final Retail 4/14/2008 08:53:08 91648 bytes
vfwwdm32.dll: 5.01.2600.5512 German Final Retail 4/14/2008 08:52:32 54272 bytes
wstcodec.sys: 5.03.2600.5512 English Final Retail 4/14/2008 01:16:26 19200 bytes
wstdecod.dll: 5.03.2600.5512 German Final Retail 4/14/2008 08:52:34 51200 bytes
msdv.sys: 5.03.2600.5512 English Final Retail 4/14/2008 01:16:10 51200 bytes
DirectShow Filters
WDM Streaming-VBI-Codecs:
NABTS/FEC VBI-Codec,0x00200000,2,1,,5.03.2600.5512
Untertiteldecoder,0x00200000,2,1,,5.03.2600.5512
WST-Codec,0x00200000,1,1,,5.03.2600.5512
DirectShow Filters:
InterVideo G726Dec DMO,0x00600800,1,1,,
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMA Voice Decoder DMO,0x00600800,1,1,,
WMVideo Advanced Decoder DMO,0x00800001,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
DivX Decoder Filter,0x00800000,1,1,divxdec.ax,6.03.0000.0079
Cyberlink Streamming Filter (PCM4),0x00200000,0,1,CLStream.ax,1.00.0000.1222
HH Video Step Renderer,0x00200000,1,0,hhvrend2.ax,1.00.0000.0000
Nero Audible Decoder,0x00200000,1,1,NeAudible.ax,4.11.0003.0005
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
Canopus ACM Encoder Filter,0x00200000,0,0,acmds.ax,
InterVideo Audio Processor Fx,0x00400000,1,1,Auprocfx.ax,
PP PCM Wrapper,0x00200000,1,1,ppPCMEnc.ax,1.01.0000.0321
PP MPEG-1 Splitter,0x00805000,1,2,ppM1Splter.ax,2.02.0000.1919
Vorbis Decoder,0x00600000,1,1,OggDS.dll,0.09.0009.0005
InterVideo Video Decoder,0x00700000,2,4,IVIVIDEO.ax,6.00.0006.0109
MainConcept H.264 Video Decoder,0x00600000,1,1,mcdsh264.ax,1.01.0000.0004
MainConcept H.264 Encoder,0x00200000,2,1,mcesh264.ax,2.00.1889.0000
Muvee MPEG Decoder,0x00600006,2,3,MuveeMVD.ax,5.00.0000.0929
ffdshow MPEG-4 Video Decoder,0xff800001,2,1,ffdshow.ax,1.00.0002.1997
PP DV Dump Filter,0x00200000,1,0,ppDVDump.ax,2.00.0001.0002
PP CES (Source),0x00200000,0,2,CLEdtKrn.dll,1.00.0000.2226
Canopus HQX Decoder,0x00800000,1,1,csdshowcodc.dll,6.00.0000.0006
CyberLink Video/SP Decoder (PCM4),0x00700000,2,3,CLVSD.ax,6.00.0000.1620
Nero Subpicture Decoder,0x00400000,1,1,NeSubpicture.ax,4.11.0003.0005
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.6333
CoreVorbis Audio Decoder,0x00800000,1,1,CoreVorbis.ax,1.01.0000.0079
Ulead Ogg Parser,0x00600000,1,1,ulOggParserFilter.ax,1.00.0000.0001
CoreAVC Video Decoder,0x00600000,1,1,AVCDX.ax,0.00.0000.0004
Dirac Source,0x00600000,0,0,DiracSplitter.ax,1.00.0000.0000
ffdshow raw video filter,0x00200000,2,1,ffdshow.ax,1.00.0002.1997
RealPlayer Video Filter,0x00200000,1,1,rdsf3260.dll,6.00.0012.1988
Nero Scene Detector 2,0x00200000,2,0,NeSceneDetector.ax,4.11.0003.0005
ffdshow Audio Decoder,0x3fffffff,1,1,ffdshow.ax,1.00.0002.1997
Nero Stream Buffer Sink,0x00200000,0,0,NeSBE.ax,4.11.0003.0005
Nero Subtitle,0x00200000,1,1,NeSubtitle.ax,4.11.0003.0005
Palm MPEG PCM Decode Filter,0x00400000,1,0,palm2.ax,0.90.0041.0000
CyberLink Editing Service (Source),0x00200000,0,2,CLEdtKrn.dll,2.00.0000.1311
Muvee Audio Decoder,0x00601000,1,1,MuveeAud.ax,6.00.0000.0831
PP Video Regulator,0x00200000,1,1,ppResample.ax,2.05.0000.1818
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.5512
CyberLink SBE Filter,0x00200000,0,0,PCMRSBE.ax,1.00.0000.1619
Nero Smart3D Video Effect Filter,0x00200000,1,1,NSG_dxFilter.dll,1.07.0005.0000
CyberLink Audio Encoder (PP2.5),0x00200000,2,0,PdAudEnc.ax,1.00.0000.1419
PP YUY2 Deinterlace,0x00200000,1,1,ppDItlYuY2.ax,2.05.0000.2703
DV Scenes,0x00200000,1,1,NVDV.dll,3.00.0004.0000
PP TL MPEG-2 Splitter,0x00804500,1,2,ppTLM2Splter.ax,2.02.0000.2104
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.6333
CyberLink XDS Codec,0x00200000,1,0,PCMRXDSCodec.ax,1.00.0000.0322
PP MPEG Video Decoder,0x005fff00,2,3,CLMVD.ax,5.00.0000.0929
Ulead Push Source Filter,0x00200000,0,1,ulpushSource.ax,1.00.0000.0000
Ulead IEEE Push Source Filter,0x00200000,0,1,ulIEEEPushSource.ax,1.00.0000.0009
Ulead Sub-Picture Push Source Filter,0x00200000,0,1,ulSubpicPushSource.ax,1.00.0000.0003
WM ASF Reader,0x00400000,0,0,qasf.dll,11.00.5721.5145
Audio Source,0x00200000,0,1,wmprevu.dll,7.01.0000.3055
Canopus DV Decoder,0x00800000,1,1,csdshowcodc.dll,6.00.0000.0006
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,11.00.5721.5145
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.6333
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
CyberLink Audio Effect,0x00200000,1,1,PCMRAudFx.ax,6.00.0000.0805
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.6333
DV V/A Source Filter,0x00400000,0,1,dvsf.ax,7.00.0000.0000
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
PP IDM,0x00200000,1,1,ppIDMF.ax,1.00.0000.2207
CyberLink AudioCD Filter (PDVD6),0x00600000,0,1,CLAudioCD.ax,5.00.0000.2107
Nero FTC,0x00200000,1,1,NeFTC.ax,1.00.0000.0000
RadLight Vorbis Decoder,0x00800001,1,1,RLVorbisDec.ax,1.00.0000.0002
PP DDR,0x00200000,1,0,ppRender.ax,2.00.0002.0026
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
Snell & Wilcox MXF Sequencer,0x00600000,1,1,swdsmxf.dll,1.02.0001.0314
MPEG2 TS Source,0x00200000,0,1,iviMpeg2TsReader.ax,
RealVideo Decoder,0x00400000,1,1,RealMediaSplitter.ax,1.00.0001.0001
PP Video Effect,0x00200000,1,1,ppVidFx.ax,1.00.0000.1008
Palm MPEG Audio Decode Filter,0x00400000,1,0,palm2.ax,0.90.0041.0000
Intervideo 3gFileSource,0x00200000,0,2,Source3g.ax,9.00.0000.0000
Cyberlink TS Information,0x00200000,1,0,ppTSInfo.ax,1.00.0000.1705
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.6333
CyberLink Audio Decoder,0x00602000,1,1,CLAud.ax,6.00.0000.1407
CyberLink Audio Decoder (PCM4),0x00700000,1,1,CLAud.ax,6.00.0000.1514
MainConcept MultiFile Reader,0x00200000,1,0,MCMULT~1.AX,1.01.0000.0001
PP DV Video Decoder,0x00200000,2,3,ppDVVSD.ax,6.00.0000.2130
MACSReaderMP3 Filter,0x00200000,0,1,MACSReaderAVI.ax,1.00.2006.0804
MainConcept MPEG Splitter,0x00600002,1,2,mcspmpeg.ax,1.00.0001.0002
MainConcept MPEG Audio Decoder,0x00600000,1,1,mcdsmpeg.ax,1.00.0000.0071
MainConcept MPEG Video Decoder,0x00600000,1,1,mcdsmpeg.ax,1.00.0000.0071
Cyberlink TS Information,0x00200000,1,0,PCMRTSInfo.ax,1.00.0000.1621
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600.6076
PP Audio Resampler,0x00200000,1,1,ppAuRsmpl.ax,1.00.0000.2625
CyberLink MediaShow Filter (Source),0x00200000,0,2,MS_Source.dll,
Intervideo AMR Decoder,0x00200000,1,1,AmrDec.ax,8.01.0000.0000
Ulead DVD Navigator,0x00000000,0,0,UleadDVDNavigator.ax,1.00.0002.0001
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Audition Audio Null,0x00200000,1,0,VideoDump.ax,1.05.0000.0000
Nero Resize,0x00400000,1,1,NeResize.ax,4.11.0003.0005
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.6333
CyberLink Audio Effect (PDVD6),0x00200000,1,1,claudfx.ax,6.00.0000.1223
RadLight TTA DirectShow Filter,0x00600000,0,1,RLTTADec.ax,1.00.0000.0000
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
CyberLink Audio Effect (PCM4),0x00200000,1,1,claudfx.ax,6.00.0000.0917
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
InterVideo Demultiplexer,0x00200000,1,1,IVIdemux.ax,3.02.0055.0000
PP Dump Dispatch Filter,0x00200000,1,0,PPDumpDispatch.ax,1.02.0001.2412
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
WDM Capture Device,0x00200000,1,0,wmesrcwp.dll,7.01.0000.3055
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.6333
MPEG-2 PSI Reader Filter,0x00200000,0,0,Mpeg2PsiReader.ax,1.00.0000.0004
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.6333
Nero AV Synchronizer,0x00200000,1,1,NeAVSync.ax,4.11.0003.0005
Ulead Video Deinterlace Filter,0x00200000,1,1,deinterlace.ax,1.00.0002.0003
Dump,0x00200000,1,0,dump.ax,9.00.0000.0000
PP File Reader (Async.),0x00200000,0,1,ppReader.ax,2.00.0000.0812
CyberLink MPEG Muxer,0x00200000,2,1,PDMpgMux.ax,4.00.0000.1313
Cyberlink File Reader (Async.),0x00200000,0,1,pdReader.ax,2.00.0000.0812
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
Nero Audio Stream Renderer,0x00200000,1,0,NeRender.ax,4.11.0003.0005
DV V/A ACM Source Filter,0x00400000,0,1,dvsf.ax,7.00.0000.0000
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.6333
PP Snapshot Filter,0x00200000,1,0,ppSnapshot.ax,1.00.0000.0001
Muvee MPEG Muxer,0x00200000,2,1,MuveeMpgMux.ax,4.00.0000.1124
WAV Dest,0x00200000,0,0,wavdest.ax,
AAC Parser,0x00400000,1,1,aac_parser.ax,1.01.0000.0000
Canopus C210 Decoder,0x00800000,1,1,csdshowcodc.dll,6.00.0000.0006
muvee HXImage Filter,0x00200000,1,1,HXImageFilter.ax,3.05.0001.0003
PP Dump Filter,0x00200000,1,0,ppDump.ax,3.00.0000.3322
PP MPEG Video Encoder,0x00200000,1,1,ppMpgVEnc.ax,5.00.0000.1104
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
CyberLink OEMBUILD MPEG Audio Encoder,0x00200000,1,1,MuveeMAEnc.ax,2.05.0000.3526
RadLight APE DirectShow Filter,0x00600000,0,1,RLAPEDec.ax,
Nero Digital AVC Audio Encoder,0x00200000,1,2,NeNDAud.ax,4.11.0003.0005
Nero Digital AVC File Writer,0x00200000,1,0,NeNDMux.ax,4.11.0003.0005
Nero Digital AVC Video Enc,0x00200000,1,2,NeNDVid.ax,4.11.0003.0005
Nero Digital AVC Null Renderer,0x00200000,1,0,NeNDMux.ax,4.11.0003.0005
Nero Digital AVC Muxer,0x00200000,2,1,NeNDMux.ax,4.11.0003.0005
CyberLink Demultiplexer (PCM4),0x00200000,1,0,CLDemuxer.ax,1.00.0000.2208
PP Transform Tee,0x00200000,1,1,ppTee.ax,1.00.0000.1224
DVCPRO HD Decoder,0x00800000,1,1,csdshowcodc.dll,6.00.0000.0006
PP DV Buffer,0x00200000,2,0,ppDVBuffer.ax,1.05.0005.0022
CyberLink DV Buffer,0x00200000,0,1,ppDVDump.ax,2.00.0001.0002
Ligos MPEG Audio Decoder,0x03680001,1,1,lmpgad.ax,3.05.0000.0064
DV Video Source Filter,0x00400000,0,1,dvsf.ax,7.00.0000.0000
Nero QuickTime(tm) Video Decoder,0x00400000,1,1,NeQTDec.ax,4.11.0003.0005
Nero Smart3D Transition Effect Filter,0x00200000,1,1,NSG_dxFilter.dll,1.07.0005.0000
SelfMusicVideo Dump Filter,0x00200000,1,0,TG_Dump0708.DLL,8.01.2008.5200
FLV Splitter,0x00600000,1,1,flvDX.dll,1.00.0000.0001
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.6333
AVS Video Out,0x00200000,0,1,AVSVideoOutFilter3.ax,1.00.0000.0228
CyberLink MP3 Wrapper-PCM,0x00600000,1,1,CLMP3Wrap.ax,1.00.0000.0000
Canopus MPEG2-Intra Decoder,0x00800000,1,1,csdshowcodc.dll,6.00.0000.0006
CyberLink Audio CD Filter,0x00600000,0,1,claudiocd.ax,3.05.0000.0000
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.6333
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,11.00.5721.5145
Nero Digital AVC Subpicture Enc,0x00200000,1,0,NeNDMux.ax,4.11.0003.0005
Nero Format Converter,0x00200000,1,1,NeroFormatConv.ax,4.11.0003.0005
Nero Overlay Mixer,0x00200000,1,1,NeOverlayMixer.ax,4.11.0003.0005
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Nero MP4 Splitter,0x00600000,1,1,NeMP4Splitter.ax,4.11.0003.0005
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.5512
Nero Video Decoder HD,0x00400000,1,2,NeVideoHD.ax,4.11.0003.0005
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
HighMAT and MPV Navigator Filter,0x00200000,0,3,HMNavigator.ax,4.11.0003.0005
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,
CoreFLAC Audio Source,0x00600000,0,0,CoreFLACDecoder.ax,0.04.0000.0046
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
Nero Photo Source,0x00200000,0,1,NePhotoSource.ax,4.11.0003.0005
CyberLink LPCM Filter,0x00600000,0,1,CLLPCM.AX,5.00.0000.0912
Ulead MP3 Encoder,0x00100000,2,1,uleamp3.ax,2.00.0000.0008
CyberLink Demux (PDVD6),0x00200000,1,0,CLDemuxer.ax,1.00.0000.2221
Haali Media Splitter,0x00800001,0,1,splitter.ax,1.11.0096.0014
Haali Media Splitter (AR),0x00400000,1,1,splitter.ax,1.11.0096.0014
PCM MPEG Video Encoder,0x00200000,1,1,PCMRMpgVEnc2.ax,5.00.0000.1206
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
PP M2V Writer,0x00200000,1,0,PPM2VWriter.ax,1.03.0000.0705
Dirac Splitter,0x00600000,1,1,DiracSplitter.ax,1.00.0000.0000
CyberLink Audio Commercial Cut Analyzer,0x00200000,1,1,CLAudCM.ax,1.00.0000.1725
MainConcept (DataBecker) MPEG Splitter,0x00600002,1,2,dbmcspmpeg.ax,1.00.0000.0056
Nero Video Analyzer,0x00200000,2,0,NeVideoAnalyzer.ax,4.11.0003.0005
ProCoder Audio Frame Server,0x00200000,0,0,cmldssrc.ax,
PP DV TCR,0x00200000,1,1,ppDVTCR.ax,1.07.0004.0010
PP Video Regulator,0x00200000,1,1,CLRGL.ax,2.00.0000.2213
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Cyberlink Video Regulator,0x00200000,1,1,PDResample.ax,2.05.0000.1818
Disk Record Queue,0x00200000,1,1,wmedque.dll,9.00.0000.2980
PP TL MPEG-1 Splitter,0x00804500,1,2,ppTLM1Splter.ax,2.02.0000.2104
AC3 Decoder Filter,0x00200000,1,1,ac3dx.ax,1.00.0000.0001
Nero ES Video Reader,0x00600000,0,1,NDParser.ax,4.11.0003.0005
Cyberlink Sub-Picture Filter,0x00200000,1,1,CLSubPic.ax,3.00.0000.0728
CyberLink Line21 Decoder (PDVD6),0x00200000,0,2,CLLine21.ax,4.00.0000.4520
CoreFLAC Audio Decoder,0x00600000,1,1,CoreFLACDecoder.ax,0.04.0000.0046
PP DV Reader Filter,0x00200000,0,1,ppDVMRd.ax,1.02.0009.0021
PP Audio Encoder,0x00200000,2,0,ppAudEnc.ax,2.00.0000.2927
DV Source Filter,0x00400000,0,1,NVDV.dll,3.00.0004.0000
MainConcept AAC Audio Decoder,0x00600000,1,1,mcdaac.ax,1.00.0000.0000
MPEG-2 Stream Reader Filter,0x00200000,0,0,Mpeg2StreamReader.ax,1.04.0000.0000
CyberLink Load Image Filter,0x00200000,0,1,CLImage.ax,2.00.0000.0821
Nero Audio CD Filter,0x00200000,0,1,NeAudCD.ax,4.11.0003.0005
Color Converter,0x00200000,1,1,declrds.ax,9.00.0000.2980
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASX file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5145
NSC file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
Nero Smart3D Text Effect Filter,0x00200000,1,1,NSG_dxFilter.dll,1.07.0005.0000
Xvid MPEG-4 Video Decoder,0x00800000,1,1,xvid.ax,
CyberLink MP3 Wrapper-PCM,0x00600000,1,1,PCMRMP3Wrap.ax,1.00.0000.0000
Nero Video Renderer,0x00200000,1,0,NeVideoRenderer.ax,4.11.0003.0005
PP MPEG Muxer,0x00200000,2,1,ppMpgMux.ax,5.00.0000.1228
PCM Dump Filter,0x00200000,1,0,PCMRDump.ax,4.00.0000.1522
Nero PresentationGraphics Decoder,0x00600000,2,1,NeBDGraphic.ax,4.11.0003.0005
CyberLink Video Effect (PCM4),0x00200000,1,1,CLVidFx.ax,1.00.0000.1008
RadLight OptimFROG DirectShow Filter,0x00600000,0,1,RLOFRDec.ax,1.00.0000.0001
Intervideo H.264 Decoder,0x00808000,1,1,iviH264.dll,2.02.0004.0002
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.6333
PCM MPEG-2 Splitter,0x00805000,1,2,PCMRM2Splter.ax,2.02.0000.2114
CoreAAC Audio Decoder,0x00800000,1,1,CoreAAC.ax,1.02.0000.0575
Windows Media source filter,0x00600000,0,2,wmpasf.dll,11.00.5721.5145
PP TimeStretch Filter (CES),0x00200000,1,1,clauts.ax,1.00.0000.2124
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.6333
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero DVD Navigator,0x00600000,0,14,NeDVD.ax,4.11.0003.0005
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.6076
Ogg Source,0x00600001,0,0,OggSplitter.ax,1.00.0000.0000
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.6169
Nero InteractiveGraphics Decoder,0x00600000,1,1,NeBDGraphic.ax,4.11.0003.0005
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.6333
SmartSound Soundtrack,0x00400000,0,1,DirectQX.dll,3.00.0003.0000
SmartSound SDS Reader,0x00400000,0,1,SDSReader.dll,3.00.0003.0000
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.5512
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.6333
CyberLink Wave Visualization Filter,0x00200000,1,1,CLWaveRender.ax,3.00.0000.1814
CyberLink SBE Source Filter,0x00200000,0,0,PCMRSBESrc.ax,1.00.0000.1619
Elecard MPEG2 Demultiplexer,0x00800100,1,2,mpeg2dmx.ax,2.00.0084.30429
Nero Sound Processor,0x00200000,1,1,NeSoundProc.ax,4.11.0003.0005
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mp4sds32.ax,8.00.0000.0406
Haali Video Renderer,0x00200000,1,0,dxr.dll,
RealMedia Source,0x00600000,0,0,RealMediaSplitter.ax,1.00.0001.0001
Nero Audio Sample Renderer,0x00200000,1,0,NeRender.ax,4.11.0003.0005
CyberLink Audio Spectrum Analyzer (PDVD6),0x00200000,1,1,CLAudSpa.ax,1.00.0000.0924
CyberLink AudioCD Filter (PCM4),0x00600000,0,1,CLAudioCD.AX,5.00.0000.2107
Nero Vcd Navigator,0x00600000,0,2,NeVCD.ax,4.11.0003.0005
PP TL MPEG-1 Splitter,0x00804500,1,2,ppTLM1Splter.ax,2.02.0000.2213
DivX Decoder Filter,0xff800000,1,1,divxdec.ax,6.03.0000.0079
PP TL MPEG-2 Splitter,0x00804500,1,2,ppTLM2Splter.ax,2.02.0000.2213
CyberLink AVI Audio Time Regulator,0x00200000,1,1,PCMRAVI_AudTR.ax,1.00.0001.0213
PCM MPEG Video Encoder,0x00200000,1,1,PCMRMpgVEnc.ax,5.00.0000.1206
HH PlayR Video Renderer,0x00200000,1,0,,
Ulead DVD Video decoder 2,0x00680000,2,2,ulDVDVideo.ax,2.00.0000.0026
WM ASF Writer,0x00400000,0,0,qasf.dll,11.00.5721.5145
CyberLink MPEGV Analyzer,0x00200000,1,1,PCMRMPEGVAnalyzer.ax,1.00.0000.1619
FLV Video Decoder,0x00600000,1,1,flvDX.dll,1.00.0000.0001
InterVideo Audio Decoder,0x00700000,1,1,iviaudio.ax,6.00.0088.0000
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Mpeg2 Encoder,0x00200000,2,1,NeVCR.ax,4.11.0003.0005
PCM Video Regulator,0x00200000,1,1,PCMRResample.ax,4.00.0000.0126
Dib Output,0x00200000,0,1,DibOutput.ax,8.01.0000.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.5512
CyberLink Demultiplexer,0x00400000,1,0,ppDemuxer.ax,1.00.0000.2905
Dib Receive,0x00200000,1,0,DibReceive.AX,8.01.0000.0000
CyberLink Audio Noise Reduction,0x00200000,1,1,PCMRAuNRWrapper.ax,1.00.0000.1318
InterVideo PSIP/SI Filter,0x00200000,0,0,PsiDecod.ax,1.00.0000.0001
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4504
PCM Video Effect,0x00200000,1,1,PCMRVidFx.ax,1.00.0000.1618
Nero Audio Decoder 2,0x00600000,1,1,NeAudio2.ax,4.11.0003.0005
Nero Video Stream Renderer,0x00200000,1,0,NeRender.ax,4.11.0003.0005
DivX Demux,0x00600000,1,0,DivXMedia.ax,0.00.0000.0028
File writer,0x00200000,1,0,qcap.dll,6.05.2600.5512
PP YUY2 Sub-Sampling,0x00200000,1,1,ppSubYUY2.ax,2.05.0000.2628
RadLight MPC DirectShow Filter,0x00600000,0,1,RLMPCDec.ax,
Vorbis Encoder,0x00200000,1,1,OggDS.dll,0.09.0009.0005
Nero FLV Splitter,0x00600000,1,1,NeFLVSplitter.ax,4.11.0003.0005
CyberLink Video/SP Decoder,0x00600000,2,3,CLVSD.ax,6.00.0000.1402
Nero Stream Buffer Source,0x00200000,0,0,NeSBE.ax,4.11.0003.0005
Ogg Multiplexer,0x00400000,1,1,OggDS.dll,0.09.0009.0005
PP MPEG Video Decoder,0x00200000,2,3,ppmmv.ax,6.00.0000.0805
CyberLink Teletext Decoder Filter,0x00200000,0,2,PCMRTTXDec.ax,1.00.0000.1618
Nero PS Muxer,0x00200000,1,1,NePSMuxer.ax,4.11.0003.0005
CyberLink Video Regulator,0x00200000,1,1,CLRGL.ax,2.00.0000.1508
Haali Simple Media Splitter,0x00200000,0,1,splitter.ax,1.11.0096.0014
SpatialStereo Filter,0x00200000,1,1,3DAudio.ax,
PP WAV Dest,0x00200000,0,0,PPWavDest.ax,1.00.0000.0002
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
DirectVobSub,0x00200000,2,1,DVobSub.ax,1.00.0000.0009
CyberLink Demultiplexer,0x00400000,1,0,PCMRDemuxer.ax,1.00.0000.2821
RealAudio Decoder,0x00400000,1,1,RealMediaSplitter.ax,1.00.0001.0001
ProCoder Video Frame Server,0x00200000,0,0,cmldssrc.ax,
PP Byte Counter,0x00200000,1,1,ppByteCounter.ax,1.00.0000.1224
PCM SnapShotTIP Filter,0x00200000,1,1,PCMRSShot.ax,4.00.0000.1011
Avi Splitter,0x00600001,1,1,AviSplitter.ax,1.00.0000.0007
Ulead OggVorbis Encoder,0x00400000,1,1,ulOggVorbisEncoderFilter.ax,1.00.0000.0001
Canopus Lossless Decoder,0x00800000,1,1,csdshowcodc.dll,6.00.0000.0006
DirectVobSub (auto-loading version),0x00800002,2,1,DVobSub.ax,1.00.0000.0009
Ulead MPEG Transcoder,0x00200000,1,1,ulMPGTrans.ax,1.00.0000.0027
WAV Dest,0x00000000,0,0,,
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.6169
CyberLink MPEG Decoder,0x00600006,2,3,CLMVD.ax,5.00.0000.0929
CyberLink DVD Navigator (PDVD6),0x00600000,0,3,CLNavX.ax,6.00.0000.1414
ULead Infinite Pin Tee,0x00200000,1,1,uinftee.ax,1.00.0000.0002
CyberLink TimeStretch Filter (PDVD6),0x00200000,1,1,clauts.ax,1.00.0000.2212
PP MPEG-2 Splitter,0x00805000,1,2,ppM2Splter.ax,2.02.0000.1919
PCM MPEG Muxer,0x00200000,2,1,PCMRMpgMux.ax,5.00.0000.1521
Cyberlink Scene Detect Filter,0x00200000,1,1,ppScnDt.ax,1.00.0000.0813
Ogg Splitter,0x00600001,1,1,OggSplitter.ax,1.00.0000.0000
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.6169
Ulead MPEG-4 Encoder,0x00200000,2,0,ulmp4enc.ax,1.00.0001.0005
Ulead MPEG-4 Splitter,0x00400000,1,3,ulspmp4.ax,1.00.0003.0003
Ulead MPEG-4 Audio Decoder,0x00400000,1,1,uladmp4.ax,2.00.0000.0007
Ulead MPEG-4 Video Decoder,0x00400000,1,1,ulvdmp4.ax,2.00.0000.0009
Ulead AMR Audio Decoder,0x00800000,1,1,uladamr.ax,2.00.0000.0007
Ulead MPEG-4 ASP Video Decoder,0x00400000,1,1,ulaspvdmp4.ax,1.00.0000.0005
Audio Source Filter,0x00400000,0,1,AudioSF.ax,
Cyberlink SubTitle Importor (PDVD6),0x00200000,1,1,CLSubTitle.ax,1.00.0000.1307
Haali Matroska Muxer,0x00200000,1,0,splitter.ax,1.11.0096.0014
RadLight Speex Decoder,0x00600000,1,1,RLSpeexDec.ax,1.00.0000.0000
Nero Splitter,0x00600000,1,3,NeSplitter.ax,4.11.0003.0005
PP Audio Noise Reduction (CES),0x00200000,1,1,CLAuNRWrapper.ax,1.00.0000.1310
JWVidRender,0x00200000,1,0,,
NEDFilter4Samsung Filter,0x00200000,0,1,NEDFilter4Samsung.ax,8.01.0000.0000
Nero Deinterlace,0x00200000,1,1,NeDeinterlace.ax,4.11.0003.0005
CyberLink MPEG Video Encoder,0x00200000,1,1,MpgVEnc.ax,5.00.0000.0726
AC3Filter,0x40000000,1,1,ac3filter.ax,1.00.0001.0000
Ulead AC3 Audio Decoder 2,0x00200000,1,1,ulac32.ax,1.09.0002.0002
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.6333
CyberLink TimeStretch Filter,0x00200000,1,1,PCMRauts.ax,1.00.0000.2108
.RAM file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5145
Muvee MPEG-2 Splitter,0x00805000,1,2,MuveeM2Splter.ax,2.01.0000.2402
muvee Video Analyser,0x00200000,1,0,mvvanalyse.ax,3.05.0001.0003
muvee Music Analyser,0x00200000,1,0,mvmanalyse.ax,3.05.0001.0003
Ulead DVD Audio decoder 2,0x00200001,1,1,ULDVDA~1.AX,2.00.0000.0047
InterVideo Navigator,0x00190000,0,3,Ivinav.ax,6.00.0088.0000
PP Gate Filter,0x00200000,1,1,ppGate.ax,1.00.0000.0001
Nero File Source / Splitter,0x00600000,0,3,NeFSource.ax,4.11.0003.0005
LAME Audio Encoder,0x00100000,2,1,lame_dshow.ax,1.00.0054.50801
CyberLink Line21 Decoder Filter (PCM4),0x00200000,0,2,CLLine21.ax,4.00.0000.4520
PP Audio Encoder,0x00200000,2,0,ppAudEnc.ax,2.00.0000.2221
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Muvee MPEG-1 Splitter,0x00805000,1,2,MuveeM1Splter.ax,2.01.0000.2402
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.6333
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.5512
DVCPRO50 Decoder,0x00800000,1,1,csdshowcodc.dll,6.00.0000.0006
RealPlayer Transcode Filter,0x00600000,0,0,rdsf3260.dll,6.00.0012.1988
Intervideo QT source,0x00200000,0,1,iviQTsource.ax,1.00.0000.0001
DTS/AC3 Source,0x00400000,0,1,dtsac3source.ax,1.00.0000.0000
Cyberlink TS Filter Filter,0x00200000,1,1,PCMRTSFF.ax,1.00.0000.1621
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,11.00.5721.5145
HH-DV-Pin Tee,0x00200000,1,1,,
P3Sourcer,0x00600000,0,1,muzaf1.dll,1.00.0000.60410
ffdshow Audio Processor,0x00200000,1,1,ffdshow.ax,1.00.0002.1997
Screen Capture filter,0x00200000,0,1,wmesrcwp.dll,7.01.0000.3055
Snell & Wilcox MXF Parser,0x00811000,1,1,swdsmxf.dll,1.02.0001.0314
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF URL Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF *****ded stuff Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
DivX Subtitle Decoder,0x00600000,1,1,DivXMedia.ax,0.00.0000.0028
PCM Audio Resampler,0x00200000,1,1,PCMRAuRsmpl.ax,1.00.0000.2304
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Nero Video Processor,0x00200000,1,1,NeroVideoProc.ax,4.11.0003.0005
PCM Audio Encoder,0x00200000,2,0,PCMRAudEnc.ax,2.00.0000.2814
Palm Demux Filter,0x00400000,1,0,palm2.ax,0.90.0041.0000
Nero Video Decoder,0x00600000,2,1,NeVideo.ax,4.11.0003.0005
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
PowerProducer Double Tee,0x00200000,1,2,ppDoubleTee.ax,1.00.0000.1224
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.5512
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.5512
VP7 Decompressor,0x00800000,1,1,vp7dec.ax,7.00.0010.0000
TechSmith File Source,0x00400000,0,1,CamtasiaFilters.dll,5.00.0000.0000
TechSmith SWF Writer,0x00200000,2,0,CamtasiaFilters.dll,5.00.0000.0000
TechSmith WMFSDK Writer,0x00200000,1,0,CamtasiaFilters.dll,5.00.0000.0000
TechSmith Simple PIP,0x00200000,0,0,CamtasiaFilters.dll,5.00.0000.0000
ImageSource,0x00200000,0,0,CamtasiaFilters.dll,5.00.0000.0000
TitleSource,0x00200000,0,0,CamtasiaFilters.dll,5.00.0000.0000
TechSmith Time Adjust,0x00200000,1,1,CamtasiaFilters.dll,5.00.0000.0000
TechSmith Splitter Filter,0x00200000,1,1,CamtasiaFilters.dll,5.00.0000.0000
TechSmith Frame Skip Filter,0x00200000,1,1,CamtasiaFilters.dll,5.00.0000.0000
TechSmith Perf Skip Filter,0x00200000,1,1,CamtasiaFilters.dll,5.00.0000.0000
TechSmith ZoomPIP Filter,0x00200000,2,1,CamtasiaFilters.dll,5.00.0000.0000
TechSmith PushVMR Source,0x00200000,0,1,CamtasiaFilters.dll,5.00.0000.0000
TechSmith PushBitmap Source,0x00200000,0,2,CamtasiaFilters.dll,5.00.0000.0000
TechSmith SimplePushBitmap Source,0x00200000,0,2,CamtasiaFilters.dll,5.00.0000.0000
TechSmith Wave Dest,0x00200000,0,0,CamtasiaFilters.dll,5.00.0000.0000
TechSmith Overlay,0x00200000,1,1,CamtasiaFilters.dll,5.00.0000.0000
TechSmith Wave Buffer,0x00200000,1,0,CamtasiaFilters.dll,5.00.0000.0000
TechSmith ForceColor 8,0x00200000,0,0,CamtasiaFilters.dll,5.00.0000.0000
TechSmith ForceColor 555,0x00200000,0,0,CamtasiaFilters.dll,5.00.0000.0000
TechSmith ForceColor 565,0x00200000,0,0,CamtasiaFilters.dll,5.00.0000.0000
TechSmith ForceColor 24,0x00200000,0,0,CamtasiaFilters.dll,5.00.0000.0000
TechSmith ForceColor 32,0x00200000,0,0,CamtasiaFilters.dll,5.00.0000.0000
TechSmith Force Color32A,0x00200000,0,0,CamtasiaFilters.dll,5.00.0000.0000
SSFileWriter,0x00200000,1,0,CamtasiaFilters.dll,5.00.0000.0000
Nero Sound Switcher,0x00200000,1,1,NeSoundSwitch.ax,4.11.0003.0005
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Sections and Tables,0x005fffff,1,0,mpeg2data.ax,
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Audio CD Navigator,0x00200000,0,1,NeAudCD.ax,4.11.0003.0005
FLV Source,0x00600000,0,0,flvDX.dll,1.00.0000.0001
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2600.6076
Ligos MPEG Splitter,0x00800000,1,2,lmpgspl.ax,3.05.0000.0064
Ligos MPEG Video Decoder,0x00800000,1,1,lmpgvd.ax,3.05.0000.0064
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.5512
Nero Thumbnail Decoder,0x00600000,1,1,NeBDThumbnail.ax,4.11.0003.0005
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.6169
Snell & Wilcox MXF Mux,0x00600000,1,1,swdsmxf.dll,1.02.0001.0314
Nero Scene Detector,0x00200000,1,0,NeSceneDetector.ax,4.11.0003.0005
GPL MPEG-1/2 Decoder,0x00500000,1,1,GplMpgDec.ax,0.01.0002.0000
MuVee MPEG Video Encoder,0x00200000,1,1,MuveeVEnc.ax,4.00.0000.1121
Avi Source,0x00600001,0,0,AviSplitter.ax,1.00.0000.0007
RealPlayer Audio Filter,0x00200000,1,1,rdsf3260.dll,6.00.0012.1988
Nero Stream Control,0x00200000,1,1,NeStreamControl.ax,1.00.0000.0000
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.6333
Ulead MPEG Splitter,0x00400002,1,2,Ulspmpeg.ax,1.00.0000.0098
Ulead MPEG Audio Decoder,0x00400000,1,1,ULDVDA~1.AX,2.00.0000.0047
Ulead MPEG Video Decoder,0x00400000,1,1,Uldsmpeg.ax,1.00.0000.0077
Ulead MPEG Encoder,0x00200000,2,1,Ulesmpeg.ax,1.00.0002.0047
Ulead MPEG Muxer,0x00200000,4,1,Ulmxmpeg.ax,1.00.0001.0112
ULead File Writer,0x00200000,1,0,ULDump.ax,1.00.0000.0002
ULead File Source (Async.),0x00400000,0,1,Ulasync.ax,1.00.0000.0013
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
PP Video Regulator,0x00200000,1,1,CLRGL.ax,2.00.0000.2514
Nero Sample Queue,0x00200000,1,1,NeSampleQueue.ax,1.00.0000.0000
PP SnapShotTIP Filter,0x00200000,1,1,ppSShot.ax,
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.6333
CDXA Reader,0x00400000,0,1,cdxareader.ax,1.00.0000.0001
Magix DS Capture,0x00200000,2,0,,
Morgan Stream Switcher,0x00800001,1,1,,
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.6333
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.6333
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.6333
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.6333
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.6333
XML Playlist,0x00400000,1,0,wmpasf.dll,11.00.5721.5145
Nero File Source,0x00200000,0,1,NeFileSrc.ax,4.11.0003.0005
Palm MPEG Video Decode Filter,0x00400000,1,0,palm2.ax,0.90.0041.0000
Nero QuickTime(tm) Audio Decoder,0x00400000,1,1,NeQTDec.ax,4.11.0003.0005
Dump,0x00200000,1,0,VideoDump.ax,1.05.0000.0000
Nero File Source (Async.),0x00400000,0,1,NeFileSourceAsync.ax,4.11.0003.0005
MainConcept DV Pro Video Decoder,0x00875000,1,1,mcdsdvpro.ax,2.04.0000.0000
MainConcept DV Pro Video Encoder,0x00100000,1,1,mcdsdvpro.ax,2.04.0000.0000
Nero Ogg Splitter,0x00400000,1,1,NeOggSplitter.ax,4.11.0003.0005
CyberLink AVI Audio Time Regulator,0x00200000,1,1,AVI_AudTR.ax,1.00.0000.1515
Video Source,0x00200000,0,1,wmprevu.dll,7.01.0000.3055
Nero DVD Decoder,0x00600000,2,1,NeVideo.ax,4.11.0003.0005
CyberLink 3GPP Splitter (PCM4),0x00400000,1,2,isomsplt.ax,1.00.0000.1223
PCM Video/SP Decoder,0x00600000,2,3,PCMRVSD.ax,6.00.0000.1515
CyberLink Video/SP Decoder (ShEX),0x00600000,2,3,CLImageVSD.ax,6.00.0000.1620
Nero Digital Parser,0x00600000,0,3,NDParser.ax,4.11.0003.0005
RealMedia Splitter,0x00600000,1,1,RealMediaSplitter.ax,1.00.0001.0001
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.5512
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.6333
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.6333
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.6333
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
TechSmith Frame Rate Tuner,0x00200000,1,1,CamtasiaFilters.dll,5.00.0000.0000
Magix WAV Dest,0x00200000,0,0,wavdest.ax,
Nero MP3 Encoder,0x00200000,1,1,NeMp3Encoder.ax,4.11.0003.0005
Ulead Mp3 Decoder,0x00400000,1,1,uldamp3.ax,1.00.0000.0001
MainConcept DV Video Decoder,0x00600000,1,1,mcdsdv.ax,2.04.0000.0002
MainConcept DV Video Encoder,0x00200000,1,1,mcdsdv.ax,2.04.0000.0002
RadLight Theora Decoder,0x00600000,1,1,RLTheoraDec.ax,1.00.0000.0003
CyberLink PTS Regulator,0x00200000,1,1,PCMPTSReg.ax,1.00.0000.0506
Cyberlink Dump Filter,0x00200000,1,0,PDDump.ax,3.00.0000.3322
CyberLink LPCM Filter (PCM4),0x00600000,0,1,CLLPCM.AX,5.00.0000.0912
PCM Audio Decoder,0x00200000,1,1,PCMRaud.ax,6.00.0000.1027
CyberLink TimeStretch Filter (PCM4),0x00200000,1,1,clauts.ax,1.00.0000.2212
Nero Frame Capture,0x00200000,1,1,NeCapture.ax,4.11.0003.0005
CyberLink DVD Navigator (PCM4),0x00600000,0,3,CLNavX.ax,6.00.0000.1328
CyberLink M2V Writer,0x00200000,1,0,CLM2VWriter.ax,1.02.0001.1713
PP Audio Decoder,0x00200000,1,1,claud.ax,6.00.0000.0903
CyberLink PCM Wrapper,0x00200000,1,1,CLPCMEnc.ax,1.01.0000.0321
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
PP MPEG Muxer,0x00200000,2,1,ppMpgMux.ax,5.00.0000.1214
PP Video Effect,0x00200000,1,1,ppVidFx.ax,1.00.0000.0803
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Ogg Splitter,0x00600000,1,1,OggDS.dll,0.09.0009.0005
Ulead DVB Parser,0x00200000,1,0,ulDVBParser.ax,2.00.0000.0006
Nero Video Sample Renderer,0x00200000,1,0,NeRender.ax,4.11.0003.0005
Haali Video Sink,0x00200000,1,0,splitter.ax,1.11.0096.0014
Ulead Audio Dual Channel Filter,0x00200000,1,1,UAudioDCFilter.ax,1.00.0000.0002
MusicCity Audio Decoder,0x00200000,1,1,muzdecode.ax,1.00.0000.60207
CyberLink EPG Decoder,0x00200000,1,1,PCMREPGDec.ax,1.00.0000.1618
Ulead OggVorbis Decoder,0x00400000,1,1,ulOggVorbisDecoderFilter.ax,1.00.0000.0001
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MusicCity MPEG4 Splitter Filter,0x00200000,1,1,muzmp4sp.ax,1.00.0000.60210
Elecard MPEG2 Video Decoder,0x00700000,1,1,mpgdec.ax,2.00.0000.2525
Muvee Dump Filter,0x00200000,1,0,MuveeDump.ax,3.00.0000.3322
Dirac Video Decoder,0x00400000,1,1,DiracSplitter.ax,1.00.0000.0000
HighMAT/MPV Navigator Client Filter,0x00200000,0,0,HMNavigator.ax,4.11.0003.0005
MusicCity Windows Media Splitter,0x00200000,1,1,muzwmts.dll,1.00.0000.60208
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.5512
Nero DV Splitter,0x00200000,1,2,NeDVSplitter.ax,4.11.0003.0005
Canopus HQ Encoder,0x00200000,1,1,csdshowcodc.dll,6.00.0000.0006
PP TimeStretch Filter (CES),0x00200000,1,1,clauts.ax,1.00.0000.2212
Canopus HQ Decoder,0x00800000,1,1,csdshowcodc.dll,6.00.0000.0006
BlueCode Audio Effect,0x00200000,1,1,muzeffect.ax,1.00.0000.60210
MusicCity MPEG Splitter,0x00200000,0,1,muzmpgsp.ax,1.01.0007.0911
Audio Buffer Render,0x00200000,1,0,AudioDF.ax,
BDA MPEG2 Transport Information Filter,0x00200000,1,0,PsisRndr.ax,6.05.2600.5512
MyFree Codec Filter,0x00200000,0,0,MyFree.ax,
InterVideo Subtitle,0x00200000,1,1,IVISubtitle.ax,1.00.0000.0000
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.6333
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.6333
MusicCity OGG Splitter,0x00200000,1,1,muzoggsp.ax,1.00.0000.60207
Cyberlink Dump Dispatch Filter,0x00200000,1,0,CLDumpDispatch.ax,1.02.0001.2412
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
iZotope Vocal Enhancement,0x00200000,1,1,iZotope_VocalEnhancement.dll,1.00.0000.0024
iZotope Consumer Restoration,0x00200000,1,1,iZotope_ConsumerRestoration.dll,1.00.0000.0024
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
Sony MPEG2 TS Splitter,0x00600002,1,2,tssplt.ax,1.00.0000.4202
WDM Streaming-Tee/Splitter-Geräte:
Tee/Sink-to-Sink-Konvertierung,0x00200000,1,1,,5.03.2600.5512
WDM Streaming-Daten-Transforms:
Microsoft Kernel-Echounterdrückung,0x00000000,0,0,,
Microsoft Kernel GS Wavetablesynthesizer,0x00200000,1,1,,5.03.2600.5512
Microsoft Kernel-DLS-Synthesizer,0x00200000,1,1,,5.03.2600.5512
Microsoft Kernel-DRM-Audioentschlüsselung,0x00200000,1,1,,5.03.2600.5512
Video Compressors:
WMVideo Encoder DMO,0x00600800,1,1,,
WMVideo8 Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.5512
ffdshow video encoder,0x00100000,1,1,ffdshow.ax,1.00.0002.1997
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MainConcept DV Pro Video Encoder,0x00200000,1,1,mcdsdvpro.ax,2.04.0000.0000
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.6333
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.5512
DivX® 6.8.5 Codec (2 Logical CPUs),0x00200000,1,1,qcap.dll,6.05.2600.5512
dv50_MainConcept ProDV Codec 3.0.16,0x00200000,1,1,qcap.dll,6.05.2600.5512
MainConcept DV Codec 2.4.16,0x00200000,1,1,qcap.dll,6.05.2600.5512
Helix I420 YUV Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.5512
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel IYUV Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft MPEG-4 Video Codec V2,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft MPEG-4 Video Codec V3,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft MPEG-4 Video Codec V1,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.5512
TechSmith Screen Capture Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
VP70® General Profile,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft Windows Media Video 9,0x00200000,1,1,qcap.dll,6.05.2600.5512
XviD MPEG-4 Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Helix YV12 YUV Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Audio Compressors:
WMA Voice Encoder DMO,0x00600800,1,1,,
BEYONDSOFT MP3 Encoder,0x00600800,1,1,,
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.6333
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.6333
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.6333
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.6333
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.6333
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.6333
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.6333
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.6333
DV Audio -- NTSC,0x00200000,1,1,quartz.dll,6.05.2600.6333
DV Audio -- PAL,0x00200000,1,1,quartz.dll,6.05.2600.6333
MSN Messenger Audio Codec,0x00200000,1,1,quartz.dll,6.05.2600.6333
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.6333
SHARP G.726,0x00200000,1,1,quartz.dll,6.05.2600.6333
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.6333
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.6333
MPEG Audio Layer2,0x00200000,1,1,quartz.dll,6.05.2600.6333
NCT ALF2 CD,0x00200000,1,1,quartz.dll,6.05.2600.6333
AC-3 ACM Decompressor,0x00200000,1,1,quartz.dll,6.05.2600.6333
DTS,0x00200000,1,1,quartz.dll,6.05.2600.6333
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.6333
Audio Capture Sources:
Realtek HD Audio input,0x00200000,0,0,qcap.dll,6.05.2600.5512
713x BDA Analog Audio Capture,0x00200000,0,0,qcap.dll,6.05.2600.5512
713x BDA Analog Audio Capture (,0x00200000,0,0,qcap.dll,6.05.2600.5512
Realtek HD Digital input,0x00200000,0,0,qcap.dll,6.05.2600.5512
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.6333
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.6333
WDM Streaming-Capturegeräte:
Realtek HD Digital input,0x00200000,1,1,,5.03.2600.5512
,0x00000000,0,0,,
713x BDA Analog Capture,0x00200000,6,1,,5.03.2600.5512
713x BDA Analog Audio Capture,0x00200000,2,0,,5.03.2600.5512
,0x00000000,0,0,,
,0x00000000,0,0,,
,0x00000000,0,0,,
,0x00000000,0,0,,
,0x00000000,0,0,,
,0x00000000,0,0,,
,0x00000000,0,0,,
,0x00000000,0,0,,
,0x00000000,0,0,,
,0x00000000,0,0,,
,0x00000000,0,0,,
,0x00000000,0,0,,
WDM Streaming-Wiedergabegeräte:
Realtek HD Audio output,0x00200000,2,1,,5.03.2600.5512
Audials Sound Capturing,0x00200000,1,1,,5.03.2600.5512
Audials Sound Capturing (10),0x00200000,1,1,,5.03.2600.5512
Audials Sound Capturing (11),0x00200000,1,1,,5.03.2600.5512
Audials Sound Capturing (12),0x00200000,1,1,,5.03.2600.5512
Audials Sound Capturing (2),0x00200000,1,1,,5.03.2600.5512
Audials Sound Capturing (3),0x00200000,1,1,,5.03.2600.5512
Audials Sound Capturing (4),0x00200000,1,1,,5.03.2600.5512
Audials Sound Capturing (5),0x00200000,1,1,,5.03.2600.5512
Audials Sound Capturing (6),0x00200000,1,1,,5.03.2600.5512
Audials Sound Capturing (7),0x00200000,1,1,,5.03.2600.5512
Audials Sound Capturing (8),0x00200000,1,1,,5.03.2600.5512
Audials Sound Capturing (9),0x00200000,1,1,,5.03.2600.5512
BDA-Empfängerkomponente:
713x BDA Digital Capture,0x00200000,2,0,,5.03.2600.5512
BDA Slip De-Framer,0x00600000,1,1,,5.03.2600.5512
BDA MPE-Filter,0x00600000,1,1,,5.03.2600.5512
Alles anzeigen
