https://github.com/jb-alvarado/me…dual-files-does
'What The Individual Files Does' -> 'What The Individual Files Do'
media-autobuild_suite
Danke, ist angepasst.
Alles anzeigencompile ffmpeg 32bit ------------------------------------------------------------------------------- remote: Counting objects: 124, done. remote: Compressing objects: 100% (80/80), done. remote: Total 124 (delta 94), reused 74 (delta 44), pack-reused 0 Receiving objects: 100% (124/124), 17.29 KiB | 0 bytes/s, done. Resolving deltas: 100% (94/94), completed with 38 local objects. From https://github.com/FFmpeg/FFmpeg * branch master -> FETCH_HEAD eff72a6..f944aeb master -> origin/master Updating eff72a6..f944aeb Fast-forward configure | 74 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++--- doc/ffmpeg.texi | 20 ++++++++++---------- doc/ffserver.texi | 6 ++++-- doc/fftools-common-opts.texi | 11 +++++++++++ doc/filters.texi | 4 ++-- doc/texi2pod.pl | 4 ++-- libavcodec/cabac.c | 16 +++++++++++----- libavcodec/h264.c | 9 +++++++-- libavcodec/h264.h | 2 +- libavcodec/h264_parser.c | 2 +- libavcodec/h264_ps.c | 7 ++++--- libavcodec/hqx.c | 2 +- libavcodec/libdcadec.c | 7 ++++++- libavcodec/libx265.c | 15 ++++++++++++++- libavdevice/vfwcap.c | 9 ++++++--- libavformat/ffmdec.c | 3 ++- libavformat/flacdec.c | 18 ++++++++++++++++++ libavformat/nsvdec.c | 4 ++-- libavformat/rtpenc_jpeg.c | 4 ++-- libavformat/rtpproto.c | 17 ++++++++--------- libavformat/rtsp.c | 8 ++++++-- libavformat/wtvenc.c | 2 +- libavformat/xwma.c | 2 +- libavutil/mips/intreadwrite.h | 4 ++-- tests/fate-run.sh | 8 +++++++- tests/fate/libavcodec.mak | 5 +++++ 26 files changed, 205 insertions(+), 58 deletions(-) ERROR: x265 not found using pkg-config If you think configure made a mistake, make sure you are using the latest version from Git. If the latest version fails, report the problem to the ffmpeg-user@ffmpeg.org mailing list or IRC #ffmpeg on irc.freenode.net. Include the log file "config.log" produced by configure as this will help solve the problem. sed: can't read config.h: No such file or directory sed: can't read config.h: No such file or directory Makefile:2: config.mak: No such file or directory Makefile:59: /common.mak: No such file or directory Makefile:100: /libavutil/Makefile: No such file or directory Makefile:100: /library.mak: No such file or directory Makefile:102: /doc/Makefile: No such file or directory Makefile:185: /tests/Makefile: No such file or directory make: *** No rule to make target '/tests/Makefile'. Stop. Makefile:2: config.mak: No such file or directory Makefile:59: /common.mak: No such file or directory Makefile:100: /libavutil/Makefile: No such file or directory Makefile:100: /library.mak: No such file or directory Makefile:102: /doc/Makefile: No such file or directory Makefile:185: /tests/Makefile: No such file or directory make: *** No rule to make target '/tests/Makefile'. Stop. sed: can't read /local32/lib/pkgconfig/libavcodec.pc: No such file or directory sed: can't read /local32/lib/pkgconfig/libavdevice.pc: No such file or directory sed: can't read /local32/lib/pkgconfig/libavfilter.pc: No such file or directory sed: can't read /local32/lib/pkgconfig/libavformat.pc: No such file or directory sed: can't read /local32/lib/pkgconfig/libswresample.pc: No such file or directory ------------------------------------------------- build ffmpeg-git failed... delete the source folder under '/build32' and start again, or if you know there is no dependences hit enter for continue it first close the batch window, then the shell window
Ps.: löschen von x265&ffmpeg build Ordner scheint zu helfen,...
Dafür versagt jetzt mkvtoolnix:
Alles anzeigensrc/common/strings/utf8.cpp:21:18: fatal error: utf8.h: No such file or directory #include <utf8.h> ^ compilation terminated. CXX src/common/strings/utf8.cpp src/common/strings/utf8.cpp:21:18: fatal error: utf8.h: No such file or directory #include <utf8.h> ^ compilation terminated. mv: cannot stat ‘/local32/bin-video/mkvtoolnix/share/locale’: No such file or directory mv: cannot stat ‘/local32/bin-video/mkvtoolnix/share/doc/mkvtoolnix/guide’: No such file or directory ------------------------------------------------- Build mkvtoolnix-git failed... Delete the source folder under '/build32' and start again,
das sieht aber nicht aus wie ein Fehler von media-autobuild_suite, oder doch,.. löschen des mkvtoolnix Ordners half -
Habe hier noch keinen neuen checkout von mktoolnix und dort gibt es die utf8.h noch. Ist die bei dir auch noch im Pfad?
Wir sind auch gerade am umstrukturieren, Updates könnten daher gerade Fehler verursachen, haben noch nicht alles getestet. In Zukunft wird es nur noch einen Build Ordner geben um Bandbreite einzusparen.
nvenc habe ich auch mal rein getan, aber auch noch nicht getestet.Bei einem Bestehenden Build System muss die Datei /msys64/etc/fstab manuell angepasst werden um den neuen Pfad zu /build einzutragen und die alten zu löschen.
Ich lösche mal den komplette media-autobuild_suite Ordner und lass dann alles noch mal laufen.
liefert:ZitatCodec 'libnvenc' is not recognized by FFmpeg.
und
scheint auch nichts mit nvenc anzuzeigen.
-> scheint noch nicht zu gehen
(seht auch nirgends das NVIDIA NVENC SDK, welches vermutlich auch gebraucht wird,...)----
Mift, hatte vergessen, dass NVENC ja bei nen non-free Paketen dabei ist.
-> werde ich nachher mal antesten -
harfbuzz, libilbc (eventuell noch mehr) werden jetzt bei jedem Aufruf gebaut, ist das gewollt?
Alles anzeigenbuild fdk-aac-git done... ------------------------------------------------- - From https://github.com/nu774/fdkaac * branch master -> FETCH_HEAD Already up-to-date. checking for a BSD-compatible install... /usr/bin/install -c checking whether build environment is sane... yes checking for a thread-safe mkdir -p... /usr/bin/mkdir -p checking for gawk... gawk checking whether make sets $(MAKE)... yes checking whether make supports nested variables... yes checking for x86_64-w64-mingw32-gcc... gcc checking whether the C compiler works... yes checking for C compiler default output file name... a.exe checking for suffix of executables... .exe checking whether we are cross compiling... no checking for suffix of object files... o checking whether we are using the GNU C compiler... yes checking whether gcc accepts -g... yes checking for gcc option to accept ISO C89... none needed checking whether gcc understands -c and -o together... yes checking for style of include used by make... GNU checking dependency style of gcc... gcc3 checking how to run the C preprocessor... gcc -E checking for grep that handles long lines and -e... /usr/bin/grep checking for egrep... /usr/bin/grep -E checking for ANSI C header files... yes checking for sys/types.h... yes checking for sys/stat.h... yes checking for stdlib.h... yes checking for string.h... yes checking for memory.h... yes checking for strings.h... yes checking for inttypes.h... yes checking for stdint.h... yes checking for unistd.h... yes checking sys/time.h usability... yes checking sys/time.h presence... yes checking for sys/time.h... yes checking localcharset.h usability... yes checking localcharset.h presence... yes checking for localcharset.h... yes checking langinfo.h usability... no checking langinfo.h presence... no checking for langinfo.h... no checking endian.h usability... no checking endian.h presence... no checking for endian.h... no checking byteswap.h usability... no checking byteswap.h presence... no checking for byteswap.h... no checking fdk-aac/aacenc_lib.h usability... yes checking fdk-aac/aacenc_lib.h presence... yes checking for fdk-aac/aacenc_lib.h... yes checking for inline... inline checking whether byte ordering is bigendian... no checking for int16_t... yes checking for int32_t... yes checking for int64_t... yes checking for int8_t... yes checking for size_t... yes checking for uint16_t... yes checking for uint32_t... yes checking for uint64_t... yes checking for uint8_t... yes checking for ptrdiff_t... yes checking for special C compiler options needed for large files... no checking for _FILE_OFFSET_BITS value needed for large files... 64 checking for struct __timeb64... yes checking for _LARGEFILE_SOURCE value needed for large files... no checking for sigaction... no checking for gettimeofday... yes checking for nl_langinfo... no checking for _vscprintf... yes checking for fseeko64... yes checking for getopt_long... yes checking for library containing aacEncOpen... -lfdk-aac checking build system type... x86_64-w64-mingw32 checking host system type... x86_64-w64-mingw32 checking that generated files are newer than configure... done configure: creating ./config.status config.status: creating Makefile config.status: creating config.h config.status: config.h is unchanged config.status: executing depfiles commands make all-am make[1]: Entering directory '/build/bin-fdk-aac-git' depbase=`echo src/aacenc.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\ gcc -DHAVE_CONFIG_H -I. -I/local64/include -D_FORTIFY_SOURCE=2 -D__USE_MINGW_ANSI_STDIO=1 -I/local64/include -mms-bitfields -mthreads -mtune=generic -pipe -MT src/aacenc.o -MD -MP -MF $depbase.Tpo -c -o src/aacenc.o src/aacenc.c &&\ mv -f $depbase.Tpo $depbase.Po depbase=`echo src/main.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\ gcc -DHAVE_CONFIG_H -I. -I/local64/include -D_FORTIFY_SOURCE=2 -D__USE_MINGW_ANSI_STDIO=1 -I/local64/include -mms-bitfields -mthreads -mtune=generic -pipe -MT src/main.o -MD -MP -MF $depbase.Tpo -c -o src/main.o src/main.c &&\ mv -f $depbase.Tpo $depbase.Po gcc -I/local64/include -mms-bitfields -mthreads -mtune=generic -pipe -L/local64/lib -pipe -o fdkaac.exe src/aacenc.o src/caf_reader.o src/extrapolater.o src/limiter.o src/lpc.o src/m4af.o src/main.o src/metadata.o src/parson.o src/pcm_float_converter.o src/pcm_native_converter.o src/pcm_readhelper.o src/pcm_sint16_converter.o src/progress.o src/wav_reader.o src/compat_win32.o -lfdk-aac -lm -lfdk-aac H:/media-autobuild_suite/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/4.9.2/../../../../x86_64-w64-mingw32/bin/ld.exe: i386 architecture of input file `src/caf_reader.o' is incompatible with i386:x86-64 output H:/media-autobuild_suite/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/4.9.2/../../../../x86_64-w64-mingw32/bin/ld.exe: i386 architecture of input file `src/extrapolater.o' is incompatible with i386:x86-64 output H:/media-autobuild_suite/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/4.9.2/../../../../x86_64-w64-mingw32/bin/ld.exe: i386 architecture of input file `src/limiter.o' is incompatible with i386:x86-64 output H:/media-autobuild_suite/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/4.9.2/../../../../x86_64-w64-mingw32/bin/ld.exe: i386 architecture of input file `src/lpc.o' is incompatible with i386:x86-64 output H:/media-autobuild_suite/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/4.9.2/../../../../x86_64-w64-mingw32/bin/ld.exe: i386 architecture of input file `src/m4af.o' is incompatible with i386:x86-64 output H:/media-autobuild_suite/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/4.9.2/../../../../x86_64-w64-mingw32/bin/ld.exe: i386 architecture of input file `src/metadata.o' is incompatible with i386:x86-64 output H:/media-autobuild_suite/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/4.9.2/../../../../x86_64-w64-mingw32/bin/ld.exe: i386 architecture of input file `src/parson.o' is incompatible with i386:x86-64 output H:/media-autobuild_suite/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/4.9.2/../../../../x86_64-w64-mingw32/bin/ld.exe: i386 architecture of input file `src/pcm_float_converter.o' is incompatible with i386:x86-64 output H:/media-autobuild_suite/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/4.9.2/../../../../x86_64-w64-mingw32/bin/ld.exe: i386 architecture of input file `src/pcm_native_converter.o' is incompatible with i386:x86-64 output H:/media-autobuild_suite/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/4.9.2/../../../../x86_64-w64-mingw32/bin/ld.exe: i386 architecture of input file `src/pcm_readhelper.o' is incompatible with i386:x86-64 output H:/media-autobuild_suite/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/4.9.2/../../../../x86_64-w64-mingw32/bin/ld.exe: i386 architecture of input file `src/pcm_sint16_converter.o' is incompatible with i386:x86-64 output H:/media-autobuild_suite/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/4.9.2/../../../../x86_64-w64-mingw32/bin/ld.exe: i386 architecture of input file `src/progress.o' is incompatible with i386:x86-64 output H:/media-autobuild_suite/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/4.9.2/../../../../x86_64-w64-mingw32/bin/ld.exe: i386 architecture of input file `src/wav_reader.o' is incompatible with i386:x86-64 output H:/media-autobuild_suite/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/4.9.2/../../../../x86_64-w64-mingw32/bin/ld.exe: i386 architecture of input file `src/compat_win32.o' is incompatible with i386:x86-64 output src/caf_reader.o:caf_reader.c:(.text+0xbd): undefined reference to `_free' src/caf_reader.o:caf_reader.c:(.text+0x30e): undefined reference to `_malloc' src/caf_reader.o:caf_reader.c:(.text+0x35c): undefined reference to `_strlen' src/caf_reader.o:caf_reader.c:(.text+0x37a): undefined reference to `_strlen' src/caf_reader.o:caf_reader.c:(.text+0x409): undefined reference to `_free' src/caf_reader.o:caf_reader.c:(.text+0x518): undefined reference to `_memcpy' src/caf_reader.o:caf_reader.c:(.text+0x55d): undefined reference to `_memcpy' src/caf_reader.o:caf_reader.c:(.text+0x859): undefined reference to `_calloc' src/caf_reader.o:caf_reader.c:(.text+0x889): undefined reference to `_memcpy' src/caf_reader.o:caf_reader.c:(.text+0x8b9): undefined reference to `_memcpy' src/caf_reader.o:caf_reader.c:(.text+0x8da): undefined reference to `_free' src/caf_reader.o:caf_reader.c:(.text+0x91d): undefined reference to `___moddi3' src/caf_reader.o:caf_reader.c:(.text+0x958): undefined reference to `___divdi3' src/caf_reader.o:caf_reader.c:(.text+0xa02): undefined reference to `___divdi3' src/extrapolater.o:extrapolater.c:(.text+0xde): undefined reference to `_realloc' src/extrapolater.o:extrapolater.c:(.text+0x3b9): undefined reference to `_memset' src/extrapolater.o:extrapolater.c:(.text+0x46f): undefined reference to `_memset' src/extrapolater.o:extrapolater.c:(.text+0x4e9): undefined reference to `__assert' src/extrapolater.o:extrapolater.c:(.text+0x517): undefined reference to `_memcpy' src/extrapolater.o:extrapolater.c:(.text+0x606): undefined reference to `_memcpy' src/extrapolater.o:extrapolater.c:(.text+0x630): undefined reference to `_memcpy' src/extrapolater.o:extrapolater.c:(.text+0x691): undefined reference to `_memset' src/extrapolater.o:extrapolater.c:(.text+0x721): undefined reference to `_memcpy' src/extrapolater.o:extrapolater.c:(.text+0x770): undefined reference to `_memmove' src/extrapolater.o:extrapolater.c:(.text+0x7f8): undefined reference to `_free' src/extrapolater.o:extrapolater.c:(.text+0x806): undefined reference to `_free' src/extrapolater.o:extrapolater.c:(.text+0x811): undefined reference to `_free' src/extrapolater.o:extrapolater.c:(.text+0x83d): undefined reference to `_calloc' src/limiter.o:limiter.c:(.text+0x128): undefined reference to `_realloc' src/limiter.o:limiter.c:(.text+0x71e): undefined reference to `_memmove' src/limiter.o:limiter.c:(.text+0x7c7): undefined reference to `_free' src/limiter.o:limiter.c:(.text+0x7e8): undefined reference to `_free' src/limiter.o:limiter.c:(.text+0x833): undefined reference to `_calloc' src/lpc.o:lpc.c:(.text+0x68): undefined reference to `_malloc' src/lpc.o:lpc.c:(.text+0x79): undefined reference to `_malloc' src/lpc.o:lpc.c:(.text+0x197): undefined reference to `_memset' src/lpc.o:lpc.c:(.text+0x3a8): undefined reference to `_free' src/lpc.o:lpc.c:(.text+0x3b3): undefined reference to `_free' src/lpc.o:lpc.c:(.text+0x3de): undefined reference to `_malloc' src/lpc.o:lpc.c:(.text+0x519): undefined reference to `_lrint' src/lpc.o:lpc.c:(.text+0x537): undefined reference to `_free' src/m4af.o:m4af.c:(.text+0x22): undefined reference to `___mingw_vsprintf' src/m4af.o:m4af.c:(.text+0x166): undefined reference to `_time' src/m4af.o:m4af.c:(.text+0x40f): undefined reference to `_realloc' src/m4af.o:m4af.c:(.text+0x43d): undefined reference to `_memset' src/m4af.o:m4af.c:(.text+0x45a): undefined reference to `_memcpy' src/m4af.o:m4af.c:(.text+0x50d): undefined reference to `_free' src/m4af.o:m4af.c:(.text+0x51b): undefined reference to `_free' src/m4af.o:m4af.c:(.text+0x53c): undefined reference to `_free' src/m4af.o:m4af.c:(.text+0x577): undefined reference to `_free' src/m4af.o:m4af.c:(.text+0x58f): undefined reference to `_free' src/m4af.o:m4af.c:(.text+0x5a7): more undefined references to `_free' follow src/m4af.o:m4af.c:(.text+0x5da): undefined reference to `_memset' src/m4af.o:m4af.c:(.text+0x638): undefined reference to `_free' src/m4af.o:m4af.c:(.text+0x6d0): undefined reference to `_realloc' src/m4af.o:m4af.c:(.text+0x710): undefined reference to `_memcpy' src/m4af.o:m4af.c:(.text+0x80f): undefined reference to `_realloc' src/m4af.o:m4af.c:(.text+0x9bd): undefined reference to `_realloc' src/m4af.o:m4af.c:(.text+0xa21): undefined reference to `_memset' src/m4af.o:m4af.c:(.text+0xcb6): undefined reference to `_realloc' src/m4af.o:m4af.c:(.text+0xd06): undefined reference to `_memcpy' src/m4af.o:m4af.c:(.text+0xe48): undefined reference to `_strcmp' src/m4af.o:m4af.c:(.text+0xec4): undefined reference to `_realloc' src/m4af.o:m4af.c:(.text+0xf32): undefined reference to `_memset' src/m4af.o:m4af.c:(.text+0xf4b): undefined reference to `_strlen' src/m4af.o:m4af.c:(.text+0xf5e): undefined reference to `_realloc' src/m4af.o:m4af.c:(.text+0xf99): undefined reference to `_strcpy' src/m4af.o:m4af.c:(.text+0xfc3): undefined reference to `_strlen' src/m4af.o:m4af.c:(.text+0xfd1): undefined reference to `_strlen' src/m4af.o:m4af.c:(.text+0x102e): undefined reference to `_realloc' src/m4af.o:m4af.c:(.text+0x105c): undefined reference to `_memcpy' src/m4af.o:m4af.c:(.text+0x10dd): undefined reference to `_realloc' src/m4af.o:m4af.c:(.text+0x110b): undefined reference to `_memcpy' src/m4af.o:m4af.c:(.text+0x113d): undefined reference to `_strlen' src/m4af.o:m4af.c:(.text+0x2395): undefined reference to `_strcmp' src/m4af.o:m4af.c:(.text+0x2d17): undefined reference to `_strlen' src/m4af.o:m4af.c:(.text+0x3404): undefined reference to `_malloc' src/m4af.o:m4af.c:(.text+0x3585): undefined reference to `_free' src/main.o:main.c:(.text+0x345): undefined reference to `aacenc_getmainargs' src/main.o:main.c:(.text+0xac0): undefined reference to `aacenc_add_tag_to_store' src/main.o:main.c:(.text+0xc4b): undefined reference to `aacenc_add_tag_to_store' src/main.o:main.c:(.text+0xec4): undefined reference to `m4af_write_sample' src/main.o:main.c:(.text+0xfd7): undefined reference to `aacenc_progress_init' src/main.o:main.c:(.text+0x1004): undefined reference to `pcm_read_frames' src/main.o:main.c:(.text+0x1062): undefined reference to `aacenc_progress_update' src/main.o:main.c:(.text+0x11b4): undefined reference to `aacenc_progress_finish' src/main.o:main.c:(.text+0x1315): undefined reference to `m4af_add_itmf_string_tag' src/main.o:main.c:(.text+0x135b): undefined reference to `aacenc_write_tag_entry' src/main.o:main.c:(.text+0x139a): undefined reference to `aacenc_write_tags_from_json' src/main.o:main.c:(.text+0x13bf): undefined reference to `aacenc_write_tag_entry' src/main.o:main.c:(.text+0x1400): undefined reference to `m4af_finalize' src/main.o:main.c:(.text+0x14aa): undefined reference to `aacenc_basename' src/main.o:main.c:(.text+0x16be): undefined reference to `aacenc_fopen' src/main.o:main.c:(.text+0x1715): undefined reference to `aacenc_fprintf' src/main.o:main.c:(.text+0x1821): undefined reference to `raw_open' src/main.o:main.c:(.text+0x18a2): undefined reference to `wav_open' src/main.o:main.c:(.text+0x191c): undefined reference to `caf_open' src/main.o:main.c:(.text+0x1974): undefined reference to `pcm_open_native_converter' src/main.o:main.c:(.text+0x19a0): undefined reference to `limiter_open' src/main.o:main.c:(.text+0x19b7): undefined reference to `pcm_open_sint16_converter' src/main.o:main.c:(.text+0x19ce): undefined reference to `extrapolater_open' src/main.o:main.c:(.text+0x1c34): undefined reference to `aacenc_fopen' src/main.o:main.c:(.text+0x1c85): undefined reference to `aacenc_fprintf' src/main.o:main.c:(.text+0x1ce2): undefined reference to `m4af_create' src/main.o:main.c:(.text+0x1d08): undefined reference to `m4af_set_num_channels' src/main.o:main.c:(.text+0x1d2a): undefined reference to `m4af_set_decoder_specific_info' src/main.o:main.c:(.text+0x1d4e): undefined reference to `m4af_set_fixed_frame_duration' src/main.o:main.c:(.text+0x1d67): undefined reference to `m4af_set_vbr_mode' src/main.o:main.c:(.text+0x1d7e): undefined reference to `m4af_set_priming_mode' src/main.o:main.c:(.text+0x1d8a): undefined reference to `m4af_begin_write' src/main.o:main.c:(.text+0x1ef7): undefined reference to `m4af_set_priming' src/main.o:main.c:(.text+0x1f63): undefined reference to `m4af_teardown' src/main.o:main.c:(.text+0x1fc8): undefined reference to `aacenc_free_tag_store' src/main.o:main.c:(.text+0x1fe6): undefined reference to `aacenc_free_tag_store' src/main.o:main.c:(.rdata$.refptr.aacenc_translate_generic_text_tag[.refptr.aacenc_translate_generic_text_tag]+0x0): undefined reference to `aacenc_translate_generic_text_tag' src/main.o:main.c:(.rdata$.refptr.aacenc_add_tag_entry_to_store[.refptr.aacenc_add_tag_entry_to_store]+0x0): undefined reference to `aacenc_add_tag_entry_to_store' src/metadata.o:metadata.c:(.text+0x22): undefined reference to `___mingw_vsscanf' src/metadata.o:metadata.c:(.text+0x52): undefined reference to `___mingw_vfprintf' src/metadata.o:metadata.c:(.text+0x82): undefined reference to `___mingw_vsprintf' src/metadata.o:metadata.c:(.text+0xa6): undefined reference to `_strcmp' src/metadata.o:metadata.c:(.text+0xc1): undefined reference to `_strlen' src/metadata.o:metadata.c:(.text+0xcc): undefined reference to `_malloc' src/metadata.o:metadata.c:(.text+0x14a): undefined reference to `_bsearch' src/metadata.o:metadata.c:(.text+0x158): undefined reference to `_free' src/metadata.o:metadata.c:(.text+0x1a6): undefined reference to `__imp___errno' src/metadata.o:metadata.c:(.text+0x1b9): undefined reference to `__imp___iob' src/metadata.o:metadata.c:(.text+0x1ff): undefined reference to `_fseeko64' src/metadata.o:metadata.c:(.text+0x20a): undefined reference to `_ftello64' src/metadata.o:metadata.c:(.text+0x22a): undefined reference to `__imp___iob' src/metadata.o:metadata.c:(.text+0x269): undefined reference to `_fseeko64' src/metadata.o:metadata.c:(.text+0x277): undefined reference to `_malloc' src/metadata.o:metadata.c:(.text+0x2a1): undefined reference to `_fread' src/metadata.o:metadata.c:(.text+0x2c5): undefined reference to `_fclose' src/metadata.o:metadata.c:(.text+0x500): undefined reference to `_strlen' src/metadata.o:metadata.c:(.text+0x52e): undefined reference to `_free' src/metadata.o:metadata.c:(.text+0x583): undefined reference to `_realloc' src/metadata.o:metadata.c:(.text+0x5f4): undefined reference to `_malloc' src/metadata.o:metadata.c:(.text+0x61e): undefined reference to `_memcpy' src/metadata.o:metadata.c:(.text+0x6e7): undefined reference to `_strlen' src/metadata.o:metadata.c:(.text+0x88e): undefined reference to `_strlen' src/metadata.o:metadata.c:(.text+0x9e1): undefined reference to `_strchr' src/metadata.o:metadata.c:(.text+0xa2f): undefined reference to `__imp___iob' src/metadata.o:metadata.c:(.text+0xa7b): undefined reference to `__imp___iob' src/metadata.o:metadata.c:(.text+0xb4c): undefined reference to `_free' src/metadata.o:metadata.c:(.text+0xb5d): undefined reference to `_free' src/metadata.o:metadata.c:(.text+0xba6): undefined reference to `_free' src/metadata.o:metadata.c:(.text+0xbb4): undefined reference to `_free' src/metadata.o:metadata.c:(.text+0xbd0): undefined reference to `_free' src/metadata.o:metadata.c:(.text+0xf50): undefined reference to `_memcmp' src/metadata.o:metadata.c:(.text+0xf78): undefined reference to `_memcmp' src/metadata.o:metadata.c:(.text+0xfa0): undefined reference to `_memcmp' src/metadata.o:metadata.c:(.text+0x1061): undefined reference to `__imp___iob' src/parson.o:parson.c:(.text+0x22): undefined reference to `___mingw_vsscanf' src/parson.o:parson.c:(.text+0x44): undefined reference to `___mingw_strtod' src/parson.o:parson.c:(.text+0x60): undefined reference to `_realloc' src/parson.o:parson.c:(.text+0x93): undefined reference to `_malloc' src/parson.o:parson.c:(.text+0xc7): undefined reference to `_strncpy' src/parson.o:parson.c:(.text+0xe3): undefined reference to `__imp__isxdigit' src/parson.o:parson.c:(.text+0xfd): undefined reference to `__imp__isxdigit' src/parson.o:parson.c:(.text+0x117): undefined reference to `__imp__isxdigit' src/parson.o:parson.c:(.text+0x131): undefined reference to `__imp__isxdigit' src/parson.o:parson.c:(.text+0x190): undefined reference to `_strncmp' src/parson.o:parson.c:(.text+0x1c8): undefined reference to `_strchr' src/parson.o:parson.c:(.text+0x1f9): undefined reference to `_malloc' src/parson.o:parson.c:(.text+0x2d4): undefined reference to `_strlen' src/parson.o:parson.c:(.text+0x3b3): undefined reference to `_strlen' src/parson.o:parson.c:(.text+0x3e5): undefined reference to `_strncmp' src/parson.o:parson.c:(.text+0x438): undefined reference to `_free' src/parson.o:parson.c:(.text+0x473): undefined reference to `_free' src/parson.o:parson.c:(.text+0x481): undefined reference to `_free' src/parson.o:parson.c:(.text+0x48c): undefined reference to `_free' src/parson.o:parson.c:(.text+0x4a0): undefined reference to `_malloc' src/parson.o:parson.c:(.text+0x5d2): undefined reference to `_free' src/parson.o:parson.c:(.text+0x5dd): undefined reference to `_free' src/parson.o:parson.c:(.text+0x5f1): undefined reference to `_malloc' src/parson.o:parson.c:(.text+0x62c): undefined reference to `_free' src/parson.o:parson.c:(.text+0x64a): undefined reference to `_malloc' src/parson.o:parson.c:(.text+0x685): undefined reference to `_free' src/parson.o:parson.c:(.text+0x6a3): undefined reference to `_malloc' src/parson.o:parson.c:(.text+0x6e8): undefined reference to `_malloc' src/parson.o:parson.c:(.text+0x721): undefined reference to `_malloc' src/parson.o:parson.c:(.text+0x75a): undefined reference to `_malloc' src/parson.o:parson.c:(.text+0x903): undefined reference to `_free' src/parson.o:parson.c:(.text+0x991): undefined reference to `_free' src/parson.o:parson.c:(.text+0x9ae): undefined reference to `_free' src/parson.o:parson.c:(.text+0x9e5): undefined reference to `_strlen' src/parson.o:parson.c:(.text+0xa3f): undefined reference to `__imp__isspace' src/parson.o:parson.c:(.text+0xb33): undefined reference to `__imp__isspace' src/parson.o:parson.c:(.text+0xb8f): undefined reference to `__imp__isspace' src/parson.o:parson.c:(.text+0xbef): undefined reference to `_free' src/parson.o:parson.c:(.text+0xc2c): undefined reference to `_free' src/parson.o:parson.c:(.text+0xc37): undefined reference to `_free' src/parson.o:parson.c:(.text+0xc57): undefined reference to `_free' src/parson.o:parson.c:(.text+0xc79): undefined reference to `__imp__isspace' src/parson.o:parson.c:(.text+0xcbc): undefined reference to `__imp__isspace' src/parson.o:parson.c:(.text+0xcf4): undefined reference to `__imp__isspace' src/parson.o:parson.c:(.text+0xdaa): undefined reference to `__imp__isspace' src/parson.o:parson.c:(.text+0xe27): undefined reference to `_free' src/parson.o:parson.c:(.text+0xe5e): undefined reference to `__imp__isspace' src/parson.o:parson.c:(.text+0xea1): undefined reference to `__imp__isspace' src/parson.o:parson.c:(.text+0xed9): undefined reference to `__imp__isspace' src/parson.o:parson.c:(.text+0xf8b): undefined reference to `_strncmp' src/parson.o:parson.c:(.text+0xfc8): undefined reference to `_strncmp' src/parson.o:parson.c:(.text+0x107f): undefined reference to `_strncmp' src/parson.o:parson.c:(.text+0x10b9): undefined reference to `_fopen' src/parson.o:parson.c:(.text+0x10e7): undefined reference to `_fseek' src/parson.o:parson.c:(.text+0x10f2): undefined reference to `_ftell' src/parson.o:parson.c:(.text+0x1100): undefined reference to `_rewind' src/parson.o:parson.c:(.text+0x110e): undefined reference to `_malloc' src/parson.o:parson.c:(.text+0x1122): undefined reference to `_fclose' src/parson.o:parson.c:(.text+0x114a): undefined reference to `_fread' src/parson.o:parson.c:(.text+0x1155): undefined reference to `_fclose' src/parson.o:parson.c:(.text+0x1179): undefined reference to `_free' src/parson.o:parson.c:(.text+0x11cc): undefined reference to `_strlen' src/parson.o:parson.c:(.text+0x12a7): undefined reference to `_strchr' src/parson.o:parson.c:(.text+0x15fd): undefined reference to `_free' src/parson.o:parson.c:(.text+0x161b): undefined reference to `_free' src/pcm_float_converter.o:pcm_float_converter.c:(.text+0x17f): undefined reference to `_free' src/pcm_float_converter.o:pcm_float_converter.c:(.text+0x1ab): undefined reference to `_calloc' src/pcm_float_converter.o:pcm_float_converter.c:(.text+0x1f4): undefined reference to `_memcpy' src/pcm_native_converter.o:pcm_native_converter.c:(.text+0xb6c): undefined reference to `_realloc' src/pcm_native_converter.o:pcm_native_converter.c:(.text+0xc0d): undefined reference to `_free' src/pcm_native_converter.o:pcm_native_converter.c:(.text+0xc18): undefined reference to `_free' src/pcm_native_converter.o:pcm_native_converter.c:(.text+0xc44): undefined reference to `_calloc' src/pcm_native_converter.o:pcm_native_converter.c:(.text+0xc8d): undefined reference to `_memcpy' src/pcm_readhelper.o:pcm_readhelper.c:(.text+0x6dc): undefined reference to `_strpbrk' src/pcm_readhelper.o:pcm_readhelper.c:(.text+0xe58): undefined reference to `_strcpy' src/pcm_readhelper.o:pcm_readhelper.c:(.text+0xeed): undefined reference to `_qsort' src/pcm_sint16_converter.o:pcm_sint16_converter.c:(.text+0x14d): undefined reference to `_realloc' src/pcm_sint16_converter.o:pcm_sint16_converter.c:(.text+0x314): undefined reference to `_free' src/pcm_sint16_converter.o:pcm_sint16_converter.c:(.text+0x31f): undefined reference to `_free' src/pcm_sint16_converter.o:pcm_sint16_converter.c:(.text+0x34b): undefined reference to `_calloc' src/pcm_sint16_converter.o:pcm_sint16_converter.c:(.text+0x394): undefined reference to `_memcpy' src/progress.o:progress.c:(.text+0x22): undefined reference to `___mingw_vfprintf' src/progress.o:progress.c:(.text+0x156): undefined reference to `__imp___iob' src/progress.o:progress.c:(.text+0x18a): undefined reference to `__imp___iob' src/progress.o:progress.c:(.text+0x360): undefined reference to `__imp___iob' src/progress.o:progress.c:(.text+0x373): undefined reference to `_putc' src/progress.o:progress.c:(.text+0x378): undefined reference to `__imp___iob' src/progress.o:progress.c:(.text+0x38f): undefined reference to `__imp___iob' src/progress.o:progress.c:(.text+0x3b3): undefined reference to `__imp___iob' src/progress.o:progress.c:(.text+0x3d2): undefined reference to `__imp___iob' src/progress.o:progress.c:(.text+0x3e9): undefined reference to `__imp___iob' src/progress.o:progress.c:(.text+0x3fc): undefined reference to `_putc' src/progress.o:progress.c:(.text+0x421): undefined reference to `__imp___iob' src/progress.o:progress.c:(.text+0x435): undefined reference to `__imp___iob' src/progress.o:progress.c:(.text+0x454): undefined reference to `__imp___iob' src/progress.o:progress.c:(.text+0x46b): undefined reference to `__imp___iob' src/progress.o:progress.c:(.text+0x48e): undefined reference to `_fwrite' src/progress.o:progress.c:(.text+0x51b): undefined reference to `__imp___iob' src/progress.o:progress.c:(.text+0x54d): undefined reference to `__imp___iob' src/progress.o:progress.c:(.text+0x57b): undefined reference to `__imp___iob' src/progress.o:progress.c:(.text+0x592): undefined reference to `__imp___iob' src/progress.o:progress.c:(.text+0x5a5): undefined reference to `_putc' src/wav_reader.o:wav_reader.c:(.text+0xbd): undefined reference to `_free' src/wav_reader.o:wav_reader.c:(.text+0x47c): undefined reference to `_memcmp' src/wav_reader.o:wav_reader.c:(.text+0x4a4): undefined reference to `_memcmp' src/wav_reader.o:wav_reader.c:(.text+0x700): undefined reference to `_calloc' src/wav_reader.o:wav_reader.c:(.text+0x730): undefined reference to `_memcpy' src/wav_reader.o:wav_reader.c:(.text+0x75a): undefined reference to `_free' src/wav_reader.o:wav_reader.c:(.text+0x7a5): undefined reference to `___moddi3' src/wav_reader.o:wav_reader.c:(.text+0x7e0): undefined reference to `___divdi3' src/wav_reader.o:wav_reader.c:(.text+0x888): undefined reference to `___divdi3' src/wav_reader.o:wav_reader.c:(.text+0x8e9): undefined reference to `_calloc' src/wav_reader.o:wav_reader.c:(.text+0x919): undefined reference to `_memcpy' src/wav_reader.o:wav_reader.c:(.text+0x936): undefined reference to `_memcpy' src/wav_reader.o:wav_reader.c:(.text+0x9b3): undefined reference to `___divdi3' src/compat_win32.o:compat_win32.c:(.text+0x1b): undefined reference to `___mingw_vfprintf' src/compat_win32.o:compat_win32.c:(.text+0x30): undefined reference to `__imp___ftime64' src/compat_win32.o:compat_win32.c:(.text+0x9d): undefined reference to `__imp__MultiByteToWideChar@24' src/compat_win32.o:compat_win32.c:(.text+0xbf): undefined reference to `_malloc' src/compat_win32.o:compat_win32.c:(.text+0xf8): undefined reference to `__imp__MultiByteToWideChar@24' src/compat_win32.o:compat_win32.c:(.text+0x14c): undefined reference to `__imp__WideCharToMultiByte@32' src/compat_win32.o:compat_win32.c:(.text+0x16c): undefined reference to `_malloc' src/compat_win32.o:compat_win32.c:(.text+0x1b5): undefined reference to `__imp__WideCharToMultiByte@32' src/compat_win32.o:compat_win32.c:(.text+0x1da): undefined reference to `_strcmp' src/compat_win32.o:compat_win32.c:(.text+0x1ed): undefined reference to `__imp___iob' src/compat_win32.o:compat_win32.c:(.text+0x1f4): undefined reference to `__imp___iob' src/compat_win32.o:compat_win32.c:(.text+0x205): undefined reference to `__imp___fileno' src/compat_win32.o:compat_win32.c:(.text+0x217): undefined reference to `__imp___setmode' src/compat_win32.o:compat_win32.c:(.text+0x238): undefined reference to `_strchr' src/compat_win32.o:compat_win32.c:(.text+0x24f): undefined reference to `_strchr' src/compat_win32.o:compat_win32.c:(.text+0x2a7): undefined reference to `__imp___wfsopen' src/compat_win32.o:compat_win32.c:(.text+0x2b7): undefined reference to `_free' src/compat_win32.o:compat_win32.c:(.text+0x2c2): undefined reference to `_free' src/compat_win32.o:compat_win32.c:(.text+0x2e4): undefined reference to `_free' src/compat_win32.o:compat_win32.c:(.text+0x2fe): undefined reference to `_free' src/compat_win32.o:compat_win32.c:(.text+0x335): undefined reference to `___wgetmainargs' src/compat_win32.o:compat_win32.c:(.text+0x348): undefined reference to `_malloc' src/compat_win32.o:compat_win32.c:(.text+0x3bf): undefined reference to `_atexit' src/compat_win32.o:compat_win32.c:(.text+0x3d2): undefined reference to `__imp___strdup' src/compat_win32.o:compat_win32.c:(.text+0x3e7): undefined reference to `__imp___fileno' src/compat_win32.o:compat_win32.c:(.text+0x3f1): undefined reference to `__imp___get_osfhandle' src/compat_win32.o:compat_win32.c:(.text+0x401): undefined reference to `__imp__GetFileType@4' src/compat_win32.o:compat_win32.c:(.text+0x44a): undefined reference to `__imp___vscprintf' src/compat_win32.o:compat_win32.c:(.text+0x45d): undefined reference to `_malloc' src/compat_win32.o:compat_win32.c:(.text+0x489): undefined reference to `__imp___vsnprintf' src/compat_win32.o:compat_win32.c:(.text+0x4b3): undefined reference to `_free' src/compat_win32.o:compat_win32.c:(.text+0x4be): undefined reference to `_fflush' src/compat_win32.o:compat_win32.c:(.text+0x4c9): undefined reference to `_wcslen' src/compat_win32.o:compat_win32.c:(.text+0x4f0): undefined reference to `__imp__WriteConsoleW@20' src/compat_win32.o:compat_win32.c:(.text+0x500): undefined reference to `_free' src/compat_win32.o:compat_win32.c:(.text+0x51e): undefined reference to `_strrchr' src/compat_win32.o:compat_win32.c:(.text+0x534): undefined reference to `_strrchr' src/compat_win32.o:compat_win32.c:(.text+0x54a): undefined reference to `_strrchr' collect2.exe: error: ld returned 1 exit status Makefile:510: recipe for target 'fdkaac.exe' failed make[1]: *** [fdkaac.exe] Error 1 make[1]: Leaving directory '/build/bin-fdk-aac-git' Makefile:369: recipe for target 'all' failed make: *** [all] Error 2 gcc -I/local64/include -mms-bitfields -mthreads -mtune=generic -pipe -L/local64/lib -pipe -o fdkaac.exe src/aacenc.o src/caf_reader.o src/extrapolater.o src/limiter.o src/lpc.o src/m4af.o src/main.o src/metadata.o src/parson.o src/pcm_float_converter.o src/pcm_native_converter.o src/pcm_readhelper.o src/pcm_sint16_converter.o src/progress.o src/wav_reader.o src/compat_win32.o -lfdk-aac -lm -lfdk-aac H:/media-autobuild_suite/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/4.9.2/../../../../x86_64-w64-mingw32/bin/ld.exe: i386 architecture of input file `src/caf_reader.o' is incompatible with i386:x86-64 output H:/media-autobuild_suite/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/4.9.2/../../../../x86_64-w64-mingw32/bin/ld.exe: i386 architecture of input file `src/extrapolater.o' is incompatible with i386:x86-64 output H:/media-autobuild_suite/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/4.9.2/../../../../x86_64-w64-mingw32/bin/ld.exe: i386 architecture of input file `src/limiter.o' is incompatible with i386:x86-64 output H:/media-autobuild_suite/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/4.9.2/../../../../x86_64-w64-mingw32/bin/ld.exe: i386 architecture of input file `src/lpc.o' is incompatible with i386:x86-64 output H:/media-autobuild_suite/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/4.9.2/../../../../x86_64-w64-mingw32/bin/ld.exe: i386 architecture of input file `src/m4af.o' is incompatible with i386:x86-64 output H:/media-autobuild_suite/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/4.9.2/../../../../x86_64-w64-mingw32/bin/ld.exe: i386 architecture of input file `src/metadata.o' is incompatible with i386:x86-64 output H:/media-autobuild_suite/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/4.9.2/../../../../x86_64-w64-mingw32/bin/ld.exe: i386 architecture of input file `src/parson.o' is incompatible with i386:x86-64 output H:/media-autobuild_suite/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/4.9.2/../../../../x86_64-w64-mingw32/bin/ld.exe: i386 architecture of input file `src/pcm_float_converter.o' is incompatible with i386:x86-64 output H:/media-autobuild_suite/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/4.9.2/../../../../x86_64-w64-mingw32/bin/ld.exe: i386 architecture of input file `src/pcm_native_converter.o' is incompatible with i386:x86-64 output H:/media-autobuild_suite/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/4.9.2/../../../../x86_64-w64-mingw32/bin/ld.exe: i386 architecture of input file `src/pcm_readhelper.o' is incompatible with i386:x86-64 output H:/media-autobuild_suite/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/4.9.2/../../../../x86_64-w64-mingw32/bin/ld.exe: i386 architecture of input file `src/pcm_sint16_converter.o' is incompatible with i386:x86-64 output H:/media-autobuild_suite/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/4.9.2/../../../../x86_64-w64-mingw32/bin/ld.exe: i386 architecture of input file `src/progress.o' is incompatible with i386:x86-64 output H:/media-autobuild_suite/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/4.9.2/../../../../x86_64-w64-mingw32/bin/ld.exe: i386 architecture of input file `src/wav_reader.o' is incompatible with i386:x86-64 output H:/media-autobuild_suite/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/4.9.2/../../../../x86_64-w64-mingw32/bin/ld.exe: i386 architecture of input file `src/compat_win32.o' is incompatible with i386:x86-64 output src/caf_reader.o:caf_reader.c:(.text+0xbd): undefined reference to `_free' src/caf_reader.o:caf_reader.c:(.text+0x30e): undefined reference to `_malloc' src/caf_reader.o:caf_reader.c:(.text+0x35c): undefined reference to `_strlen' src/caf_reader.o:caf_reader.c:(.text+0x37a): undefined reference to `_strlen' src/caf_reader.o:caf_reader.c:(.text+0x409): undefined reference to `_free' src/caf_reader.o:caf_reader.c:(.text+0x518): undefined reference to `_memcpy' src/caf_reader.o:caf_reader.c:(.text+0x55d): undefined reference to `_memcpy' src/caf_reader.o:caf_reader.c:(.text+0x859): undefined reference to `_calloc' src/caf_reader.o:caf_reader.c:(.text+0x889): undefined reference to `_memcpy' src/caf_reader.o:caf_reader.c:(.text+0x8b9): undefined reference to `_memcpy' src/caf_reader.o:caf_reader.c:(.text+0x8da): undefined reference to `_free' src/caf_reader.o:caf_reader.c:(.text+0x91d): undefined reference to `___moddi3' src/caf_reader.o:caf_reader.c:(.text+0x958): undefined reference to `___divdi3' src/caf_reader.o:caf_reader.c:(.text+0xa02): undefined reference to `___divdi3' src/extrapolater.o:extrapolater.c:(.text+0xde): undefined reference to `_realloc' src/extrapolater.o:extrapolater.c:(.text+0x3b9): undefined reference to `_memset' src/extrapolater.o:extrapolater.c:(.text+0x46f): undefined reference to `_memset' src/extrapolater.o:extrapolater.c:(.text+0x4e9): undefined reference to `__assert' src/extrapolater.o:extrapolater.c:(.text+0x517): undefined reference to `_memcpy' src/extrapolater.o:extrapolater.c:(.text+0x606): undefined reference to `_memcpy' src/extrapolater.o:extrapolater.c:(.text+0x630): undefined reference to `_memcpy' src/extrapolater.o:extrapolater.c:(.text+0x691): undefined reference to `_memset' src/extrapolater.o:extrapolater.c:(.text+0x721): undefined reference to `_memcpy' src/extrapolater.o:extrapolater.c:(.text+0x770): undefined reference to `_memmove' src/extrapolater.o:extrapolater.c:(.text+0x7f8): undefined reference to `_free' src/extrapolater.o:extrapolater.c:(.text+0x806): undefined reference to `_free' src/extrapolater.o:extrapolater.c:(.text+0x811): undefined reference to `_free' src/extrapolater.o:extrapolater.c:(.text+0x83d): undefined reference to `_calloc' src/limiter.o:limiter.c:(.text+0x128): undefined reference to `_realloc' src/limiter.o:limiter.c:(.text+0x71e): undefined reference to `_memmove' src/limiter.o:limiter.c:(.text+0x7c7): undefined reference to `_free' src/limiter.o:limiter.c:(.text+0x7e8): undefined reference to `_free' src/limiter.o:limiter.c:(.text+0x833): undefined reference to `_calloc' src/lpc.o:lpc.c:(.text+0x68): undefined reference to `_malloc' src/lpc.o:lpc.c:(.text+0x79): undefined reference to `_malloc' src/lpc.o:lpc.c:(.text+0x197): undefined reference to `_memset' src/lpc.o:lpc.c:(.text+0x3a8): undefined reference to `_free' src/lpc.o:lpc.c:(.text+0x3b3): undefined reference to `_free' src/lpc.o:lpc.c:(.text+0x3de): undefined reference to `_malloc' src/lpc.o:lpc.c:(.text+0x519): undefined reference to `_lrint' src/lpc.o:lpc.c:(.text+0x537): undefined reference to `_free' src/m4af.o:m4af.c:(.text+0x22): undefined reference to `___mingw_vsprintf' src/m4af.o:m4af.c:(.text+0x166): undefined reference to `_time' src/m4af.o:m4af.c:(.text+0x40f): undefined reference to `_realloc' src/m4af.o:m4af.c:(.text+0x43d): undefined reference to `_memset' src/m4af.o:m4af.c:(.text+0x45a): undefined reference to `_memcpy' src/m4af.o:m4af.c:(.text+0x50d): undefined reference to `_free' src/m4af.o:m4af.c:(.text+0x51b): undefined reference to `_free' src/m4af.o:m4af.c:(.text+0x53c): undefined reference to `_free' src/m4af.o:m4af.c:(.text+0x577): undefined reference to `_free' src/m4af.o:m4af.c:(.text+0x58f): undefined reference to `_free' src/m4af.o:m4af.c:(.text+0x5a7): more undefined references to `_free' follow src/m4af.o:m4af.c:(.text+0x5da): undefined reference to `_memset' src/m4af.o:m4af.c:(.text+0x638): undefined reference to `_free' src/m4af.o:m4af.c:(.text+0x6d0): undefined reference to `_realloc' src/m4af.o:m4af.c:(.text+0x710): undefined reference to `_memcpy' src/m4af.o:m4af.c:(.text+0x80f): undefined reference to `_realloc' src/m4af.o:m4af.c:(.text+0x9bd): undefined reference to `_realloc' src/m4af.o:m4af.c:(.text+0xa21): undefined reference to `_memset' src/m4af.o:m4af.c:(.text+0xcb6): undefined reference to `_realloc' src/m4af.o:m4af.c:(.text+0xd06): undefined reference to `_memcpy' src/m4af.o:m4af.c:(.text+0xe48): undefined reference to `_strcmp' src/m4af.o:m4af.c:(.text+0xec4): undefined reference to `_realloc' src/m4af.o:m4af.c:(.text+0xf32): undefined reference to `_memset' src/m4af.o:m4af.c:(.text+0xf4b): undefined reference to `_strlen' src/m4af.o:m4af.c:(.text+0xf5e): undefined reference to `_realloc' src/m4af.o:m4af.c:(.text+0xf99): undefined reference to `_strcpy' src/m4af.o:m4af.c:(.text+0xfc3): undefined reference to `_strlen' src/m4af.o:m4af.c:(.text+0xfd1): undefined reference to `_strlen' src/m4af.o:m4af.c:(.text+0x102e): undefined reference to `_realloc' src/m4af.o:m4af.c:(.text+0x105c): undefined reference to `_memcpy' src/m4af.o:m4af.c:(.text+0x10dd): undefined reference to `_realloc' src/m4af.o:m4af.c:(.text+0x110b): undefined reference to `_memcpy' src/m4af.o:m4af.c:(.text+0x113d): undefined reference to `_strlen' src/m4af.o:m4af.c:(.text+0x2395): undefined reference to `_strcmp' src/m4af.o:m4af.c:(.text+0x2d17): undefined reference to `_strlen' src/m4af.o:m4af.c:(.text+0x3404): undefined reference to `_malloc' src/m4af.o:m4af.c:(.text+0x3585): undefined reference to `_free' src/main.o:main.c:(.text+0x345): undefined reference to `aacenc_getmainargs' src/main.o:main.c:(.text+0xac0): undefined reference to `aacenc_add_tag_to_store' src/main.o:main.c:(.text+0xc4b): undefined reference to `aacenc_add_tag_to_store' src/main.o:main.c:(.text+0xec4): undefined reference to `m4af_write_sample' src/main.o:main.c:(.text+0xfd7): undefined reference to `aacenc_progress_init' src/main.o:main.c:(.text+0x1004): undefined reference to `pcm_read_frames' src/main.o:main.c:(.text+0x1062): undefined reference to `aacenc_progress_update' src/main.o:main.c:(.text+0x11b4): undefined reference to `aacenc_progress_finish' src/main.o:main.c:(.text+0x1315): undefined reference to `m4af_add_itmf_string_tag' src/main.o:main.c:(.text+0x135b): undefined reference to `aacenc_write_tag_entry' src/main.o:main.c:(.text+0x139a): undefined reference to `aacenc_write_tags_from_json' src/main.o:main.c:(.text+0x13bf): undefined reference to `aacenc_write_tag_entry' src/main.o:main.c:(.text+0x1400): undefined reference to `m4af_finalize' src/main.o:main.c:(.text+0x14aa): undefined reference to `aacenc_basename' src/main.o:main.c:(.text+0x16be): undefined reference to `aacenc_fopen' src/main.o:main.c:(.text+0x1715): undefined reference to `aacenc_fprintf' src/main.o:main.c:(.text+0x1821): undefined reference to `raw_open' src/main.o:main.c:(.text+0x18a2): undefined reference to `wav_open' src/main.o:main.c:(.text+0x191c): undefined reference to `caf_open' src/main.o:main.c:(.text+0x1974): undefined reference to `pcm_open_native_converter' src/main.o:main.c:(.text+0x19a0): undefined reference to `limiter_open' src/main.o:main.c:(.text+0x19b7): undefined reference to `pcm_open_sint16_converter' src/main.o:main.c:(.text+0x19ce): undefined reference to `extrapolater_open' src/main.o:main.c:(.text+0x1c34): undefined reference to `aacenc_fopen' src/main.o:main.c:(.text+0x1c85): undefined reference to `aacenc_fprintf' src/main.o:main.c:(.text+0x1ce2): undefined reference to `m4af_create' src/main.o:main.c:(.text+0x1d08): undefined reference to `m4af_set_num_channels' src/main.o:main.c:(.text+0x1d2a): undefined reference to `m4af_set_decoder_specific_info' src/main.o:main.c:(.text+0x1d4e): undefined reference to `m4af_set_fixed_frame_duration' src/main.o:main.c:(.text+0x1d67): undefined reference to `m4af_set_vbr_mode' src/main.o:main.c:(.text+0x1d7e): undefined reference to `m4af_set_priming_mode' src/main.o:main.c:(.text+0x1d8a): undefined reference to `m4af_begin_write' src/main.o:main.c:(.text+0x1ef7): undefined reference to `m4af_set_priming' src/main.o:main.c:(.text+0x1f63): undefined reference to `m4af_teardown' src/main.o:main.c:(.text+0x1fc8): undefined reference to `aacenc_free_tag_store' src/main.o:main.c:(.text+0x1fe6): undefined reference to `aacenc_free_tag_store' src/main.o:main.c:(.rdata$.refptr.aacenc_translate_generic_text_tag[.refptr.aacenc_translate_generic_text_tag]+0x0): undefined reference to `aacenc_translate_generic_text_tag' src/main.o:main.c:(.rdata$.refptr.aacenc_add_tag_entry_to_store[.refptr.aacenc_add_tag_entry_to_store]+0x0): undefined reference to `aacenc_add_tag_entry_to_store' src/metadata.o:metadata.c:(.text+0x22): undefined reference to `___mingw_vsscanf' src/metadata.o:metadata.c:(.text+0x52): undefined reference to `___mingw_vfprintf' src/metadata.o:metadata.c:(.text+0x82): undefined reference to `___mingw_vsprintf' src/metadata.o:metadata.c:(.text+0xa6): undefined reference to `_strcmp' src/metadata.o:metadata.c:(.text+0xc1): undefined reference to `_strlen' src/metadata.o:metadata.c:(.text+0xcc): undefined reference to `_malloc' src/metadata.o:metadata.c:(.text+0x14a): undefined reference to `_bsearch' src/metadata.o:metadata.c:(.text+0x158): undefined reference to `_free' src/metadata.o:metadata.c:(.text+0x1a6): undefined reference to `__imp___errno' src/metadata.o:metadata.c:(.text+0x1b9): undefined reference to `__imp___iob' src/metadata.o:metadata.c:(.text+0x1ff): undefined reference to `_fseeko64' src/metadata.o:metadata.c:(.text+0x20a): undefined reference to `_ftello64' src/metadata.o:metadata.c:(.text+0x22a): undefined reference to `__imp___iob' src/metadata.o:metadata.c:(.text+0x269): undefined reference to `_fseeko64' src/metadata.o:metadata.c:(.text+0x277): undefined reference to `_malloc' src/metadata.o:metadata.c:(.text+0x2a1): undefined reference to `_fread' src/metadata.o:metadata.c:(.text+0x2c5): undefined reference to `_fclose' src/metadata.o:metadata.c:(.text+0x500): undefined reference to `_strlen' src/metadata.o:metadata.c:(.text+0x52e): undefined reference to `_free' src/metadata.o:metadata.c:(.text+0x583): undefined reference to `_realloc' src/metadata.o:metadata.c:(.text+0x5f4): undefined reference to `_malloc' src/metadata.o:metadata.c:(.text+0x61e): undefined reference to `_memcpy' src/metadata.o:metadata.c:(.text+0x6e7): undefined reference to `_strlen' src/metadata.o:metadata.c:(.text+0x88e): undefined reference to `_strlen' src/metadata.o:metadata.c:(.text+0x9e1): undefined reference to `_strchr' src/metadata.o:metadata.c:(.text+0xa2f): undefined reference to `__imp___iob' src/metadata.o:metadata.c:(.text+0xa7b): undefined reference to `__imp___iob' src/metadata.o:metadata.c:(.text+0xb4c): undefined reference to `_free' src/metadata.o:metadata.c:(.text+0xb5d): undefined reference to `_free' src/metadata.o:metadata.c:(.text+0xba6): undefined reference to `_free' src/metadata.o:metadata.c:(.text+0xbb4): undefined reference to `_free' src/metadata.o:metadata.c:(.text+0xbd0): undefined reference to `_free' src/metadata.o:metadata.c:(.text+0xf50): undefined reference to `_memcmp' src/metadata.o:metadata.c:(.text+0xf78): undefined reference to `_memcmp' src/metadata.o:metadata.c:(.text+0xfa0): undefined reference to `_memcmp' src/metadata.o:metadata.c:(.text+0x1061): undefined reference to `__imp___iob' src/parson.o:parson.c:(.text+0x22): undefined reference to `___mingw_vsscanf' src/parson.o:parson.c:(.text+0x44): undefined reference to `___mingw_strtod' src/parson.o:parson.c:(.text+0x60): undefined reference to `_realloc' src/parson.o:parson.c:(.text+0x93): undefined reference to `_malloc' src/parson.o:parson.c:(.text+0xc7): undefined reference to `_strncpy' src/parson.o:parson.c:(.text+0xe3): undefined reference to `__imp__isxdigit' src/parson.o:parson.c:(.text+0xfd): undefined reference to `__imp__isxdigit' src/parson.o:parson.c:(.text+0x117): undefined reference to `__imp__isxdigit' src/parson.o:parson.c:(.text+0x131): undefined reference to `__imp__isxdigit' src/parson.o:parson.c:(.text+0x190): undefined reference to `_strncmp' src/parson.o:parson.c:(.text+0x1c8): undefined reference to `_strchr' src/parson.o:parson.c:(.text+0x1f9): undefined reference to `_malloc' src/parson.o:parson.c:(.text+0x2d4): undefined reference to `_strlen' src/parson.o:parson.c:(.text+0x3b3): undefined reference to `_strlen' src/parson.o:parson.c:(.text+0x3e5): undefined reference to `_strncmp' src/parson.o:parson.c:(.text+0x438): undefined reference to `_free' src/parson.o:parson.c:(.text+0x473): undefined reference to `_free' src/parson.o:parson.c:(.text+0x481): undefined reference to `_free' src/parson.o:parson.c:(.text+0x48c): undefined reference to `_free' src/parson.o:parson.c:(.text+0x4a0): undefined reference to `_malloc' src/parson.o:parson.c:(.text+0x5d2): undefined reference to `_free' src/parson.o:parson.c:(.text+0x5dd): undefined reference to `_free' src/parson.o:parson.c:(.text+0x5f1): undefined reference to `_malloc' src/parson.o:parson.c:(.text+0x62c): undefined reference to `_free' src/parson.o:parson.c:(.text+0x64a): undefined reference to `_malloc' src/parson.o:parson.c:(.text+0x685): undefined reference to `_free' src/parson.o:parson.c:(.text+0x6a3): undefined reference to `_malloc' src/parson.o:parson.c:(.text+0x6e8): undefined reference to `_malloc' src/parson.o:parson.c:(.text+0x721): undefined reference to `_malloc' src/parson.o:parson.c:(.text+0x75a): undefined reference to `_malloc' src/parson.o:parson.c:(.text+0x903): undefined reference to `_free' src/parson.o:parson.c:(.text+0x991): undefined reference to `_free' src/parson.o:parson.c:(.text+0x9ae): undefined reference to `_free' src/parson.o:parson.c:(.text+0x9e5): undefined reference to `_strlen' src/parson.o:parson.c:(.text+0xa3f): undefined reference to `__imp__isspace' src/parson.o:parson.c:(.text+0xb33): undefined reference to `__imp__isspace' src/parson.o:parson.c:(.text+0xb8f): undefined reference to `__imp__isspace' src/parson.o:parson.c:(.text+0xbef): undefined reference to `_free' src/parson.o:parson.c:(.text+0xc2c): undefined reference to `_free' src/parson.o:parson.c:(.text+0xc37): undefined reference to `_free' src/parson.o:parson.c:(.text+0xc57): undefined reference to `_free' src/parson.o:parson.c:(.text+0xc79): undefined reference to `__imp__isspace' src/parson.o:parson.c:(.text+0xcbc): undefined reference to `__imp__isspace' src/parson.o:parson.c:(.text+0xcf4): undefined reference to `__imp__isspace' src/parson.o:parson.c:(.text+0xdaa): undefined reference to `__imp__isspace' src/parson.o:parson.c:(.text+0xe27): undefined reference to `_free' src/parson.o:parson.c:(.text+0xe5e): undefined reference to `__imp__isspace' src/parson.o:parson.c:(.text+0xea1): undefined reference to `__imp__isspace' src/parson.o:parson.c:(.text+0xed9): undefined reference to `__imp__isspace' src/parson.o:parson.c:(.text+0xf8b): undefined reference to `_strncmp' src/parson.o:parson.c:(.text+0xfc8): undefined reference to `_strncmp' src/parson.o:parson.c:(.text+0x107f): undefined reference to `_strncmp' src/parson.o:parson.c:(.text+0x10b9): undefined reference to `_fopen' src/parson.o:parson.c:(.text+0x10e7): undefined reference to `_fseek' src/parson.o:parson.c:(.text+0x10f2): undefined reference to `_ftell' src/parson.o:parson.c:(.text+0x1100): undefined reference to `_rewind' src/parson.o:parson.c:(.text+0x110e): undefined reference to `_malloc' src/parson.o:parson.c:(.text+0x1122): undefined reference to `_fclose' src/parson.o:parson.c:(.text+0x114a): undefined reference to `_fread' src/parson.o:parson.c:(.text+0x1155): undefined reference to `_fclose' src/parson.o:parson.c:(.text+0x1179): undefined reference to `_free' src/parson.o:parson.c:(.text+0x11cc): undefined reference to `_strlen' src/parson.o:parson.c:(.text+0x12a7): undefined reference to `_strchr' src/parson.o:parson.c:(.text+0x15fd): undefined reference to `_free' src/parson.o:parson.c:(.text+0x161b): undefined reference to `_free' src/pcm_float_converter.o:pcm_float_converter.c:(.text+0x17f): undefined reference to `_free' src/pcm_float_converter.o:pcm_float_converter.c:(.text+0x1ab): undefined reference to `_calloc' src/pcm_float_converter.o:pcm_float_converter.c:(.text+0x1f4): undefined reference to `_memcpy' src/pcm_native_converter.o:pcm_native_converter.c:(.text+0xb6c): undefined reference to `_realloc' src/pcm_native_converter.o:pcm_native_converter.c:(.text+0xc0d): undefined reference to `_free' src/pcm_native_converter.o:pcm_native_converter.c:(.text+0xc18): undefined reference to `_free' src/pcm_native_converter.o:pcm_native_converter.c:(.text+0xc44): undefined reference to `_calloc' src/pcm_native_converter.o:pcm_native_converter.c:(.text+0xc8d): undefined reference to `_memcpy' src/pcm_readhelper.o:pcm_readhelper.c:(.text+0x6dc): undefined reference to `_strpbrk' src/pcm_readhelper.o:pcm_readhelper.c:(.text+0xe58): undefined reference to `_strcpy' src/pcm_readhelper.o:pcm_readhelper.c:(.text+0xeed): undefined reference to `_qsort' src/pcm_sint16_converter.o:pcm_sint16_converter.c:(.text+0x14d): undefined reference to `_realloc' src/pcm_sint16_converter.o:pcm_sint16_converter.c:(.text+0x314): undefined reference to `_free' src/pcm_sint16_converter.o:pcm_sint16_converter.c:(.text+0x31f): undefined reference to `_free' src/pcm_sint16_converter.o:pcm_sint16_converter.c:(.text+0x34b): undefined reference to `_calloc' src/pcm_sint16_converter.o:pcm_sint16_converter.c:(.text+0x394): undefined reference to `_memcpy' src/progress.o:progress.c:(.text+0x22): undefined reference to `___mingw_vfprintf' src/progress.o:progress.c:(.text+0x156): undefined reference to `__imp___iob' src/progress.o:progress.c:(.text+0x18a): undefined reference to `__imp___iob' src/progress.o:progress.c:(.text+0x360): undefined reference to `__imp___iob' src/progress.o:progress.c:(.text+0x373): undefined reference to `_putc' src/progress.o:progress.c:(.text+0x378): undefined reference to `__imp___iob' src/progress.o:progress.c:(.text+0x38f): undefined reference to `__imp___iob' src/progress.o:progress.c:(.text+0x3b3): undefined reference to `__imp___iob' src/progress.o:progress.c:(.text+0x3d2): undefined reference to `__imp___iob' src/progress.o:progress.c:(.text+0x3e9): undefined reference to `__imp___iob' src/progress.o:progress.c:(.text+0x3fc): undefined reference to `_putc' src/progress.o:progress.c:(.text+0x421): undefined reference to `__imp___iob' src/progress.o:progress.c:(.text+0x435): undefined reference to `__imp___iob' src/progress.o:progress.c:(.text+0x454): undefined reference to `__imp___iob' src/progress.o:progress.c:(.text+0x46b): undefined reference to `__imp___iob' src/progress.o:progress.c:(.text+0x48e): undefined reference to `_fwrite' src/progress.o:progress.c:(.text+0x51b): undefined reference to `__imp___iob' src/progress.o:progress.c:(.text+0x54d): undefined reference to `__imp___iob' src/progress.o:progress.c:(.text+0x57b): undefined reference to `__imp___iob' src/progress.o:progress.c:(.text+0x592): undefined reference to `__imp___iob' src/progress.o:progress.c:(.text+0x5a5): undefined reference to `_putc' src/wav_reader.o:wav_reader.c:(.text+0xbd): undefined reference to `_free' src/wav_reader.o:wav_reader.c:(.text+0x47c): undefined reference to `_memcmp' src/wav_reader.o:wav_reader.c:(.text+0x4a4): undefined reference to `_memcmp' src/wav_reader.o:wav_reader.c:(.text+0x700): undefined reference to `_calloc' src/wav_reader.o:wav_reader.c:(.text+0x730): undefined reference to `_memcpy' src/wav_reader.o:wav_reader.c:(.text+0x75a): undefined reference to `_free' src/wav_reader.o:wav_reader.c:(.text+0x7a5): undefined reference to `___moddi3' src/wav_reader.o:wav_reader.c:(.text+0x7e0): undefined reference to `___divdi3' src/wav_reader.o:wav_reader.c:(.text+0x888): undefined reference to `___divdi3' src/wav_reader.o:wav_reader.c:(.text+0x8e9): undefined reference to `_calloc' src/wav_reader.o:wav_reader.c:(.text+0x919): undefined reference to `_memcpy' src/wav_reader.o:wav_reader.c:(.text+0x936): undefined reference to `_memcpy' src/wav_reader.o:wav_reader.c:(.text+0x9b3): undefined reference to `___divdi3' src/compat_win32.o:compat_win32.c:(.text+0x1b): undefined reference to `___mingw_vfprintf' src/compat_win32.o:compat_win32.c:(.text+0x30): undefined reference to `__imp___ftime64' src/compat_win32.o:compat_win32.c:(.text+0x9d): undefined reference to `__imp__MultiByteToWideChar@24' src/compat_win32.o:compat_win32.c:(.text+0xbf): undefined reference to `_malloc' src/compat_win32.o:compat_win32.c:(.text+0xf8): undefined reference to `__imp__MultiByteToWideChar@24' src/compat_win32.o:compat_win32.c:(.text+0x14c): undefined reference to `__imp__WideCharToMultiByte@32' src/compat_win32.o:compat_win32.c:(.text+0x16c): undefined reference to `_malloc' src/compat_win32.o:compat_win32.c:(.text+0x1b5): undefined reference to `__imp__WideCharToMultiByte@32' src/compat_win32.o:compat_win32.c:(.text+0x1da): undefined reference to `_strcmp' src/compat_win32.o:compat_win32.c:(.text+0x1ed): undefined reference to `__imp___iob' src/compat_win32.o:compat_win32.c:(.text+0x1f4): undefined reference to `__imp___iob' src/compat_win32.o:compat_win32.c:(.text+0x205): undefined reference to `__imp___fileno' src/compat_win32.o:compat_win32.c:(.text+0x217): undefined reference to `__imp___setmode' src/compat_win32.o:compat_win32.c:(.text+0x238): undefined reference to `_strchr' src/compat_win32.o:compat_win32.c:(.text+0x24f): undefined reference to `_strchr' src/compat_win32.o:compat_win32.c:(.text+0x2a7): undefined reference to `__imp___wfsopen' src/compat_win32.o:compat_win32.c:(.text+0x2b7): undefined reference to `_free' src/compat_win32.o:compat_win32.c:(.text+0x2c2): undefined reference to `_free' src/compat_win32.o:compat_win32.c:(.text+0x2e4): undefined reference to `_free' src/compat_win32.o:compat_win32.c:(.text+0x2fe): undefined reference to `_free' src/compat_win32.o:compat_win32.c:(.text+0x335): undefined reference to `___wgetmainargs' src/compat_win32.o:compat_win32.c:(.text+0x348): undefined reference to `_malloc' src/compat_win32.o:compat_win32.c:(.text+0x3bf): undefined reference to `_atexit' src/compat_win32.o:compat_win32.c:(.text+0x3d2): undefined reference to `__imp___strdup' src/compat_win32.o:compat_win32.c:(.text+0x3e7): undefined reference to `__imp___fileno' src/compat_win32.o:compat_win32.c:(.text+0x3f1): undefined reference to `__imp___get_osfhandle' src/compat_win32.o:compat_win32.c:(.text+0x401): undefined reference to `__imp__GetFileType@4' src/compat_win32.o:compat_win32.c:(.text+0x44a): undefined reference to `__imp___vscprintf' src/compat_win32.o:compat_win32.c:(.text+0x45d): undefined reference to `_malloc' src/compat_win32.o:compat_win32.c:(.text+0x489): undefined reference to `__imp___vsnprintf' src/compat_win32.o:compat_win32.c:(.text+0x4b3): undefined reference to `_free' src/compat_win32.o:compat_win32.c:(.text+0x4be): undefined reference to `_fflush' src/compat_win32.o:compat_win32.c:(.text+0x4c9): undefined reference to `_wcslen' src/compat_win32.o:compat_win32.c:(.text+0x4f0): undefined reference to `__imp__WriteConsoleW@20' src/compat_win32.o:compat_win32.c:(.text+0x500): undefined reference to `_free' src/compat_win32.o:compat_win32.c:(.text+0x51e): undefined reference to `_strrchr' src/compat_win32.o:compat_win32.c:(.text+0x534): undefined reference to `_strrchr' src/compat_win32.o:compat_win32.c:(.text+0x54a): undefined reference to `_strrchr' collect2.exe: error: ld returned 1 exit status Makefile:510: recipe for target 'fdkaac.exe' failed make: *** [fdkaac.exe] Error 1 ------------------------------------------------- Build bin-fdk-aac failed... Delete the source folder under '/build' and start again, or if you know there is no dependences hit enter for continue it.
fdk-aac bauen schlägt fehl,..
hab jetzt 3mal versucht ob es nicht doch irgendwie geht, aber es passiert immer das Gleiche. -
Die gröbsten Fehler sollten jetzt ausgemerzt sein. Doppeltes Kompilieren sollte jetzt nicht mehr vorkommen und fdk-aac sollte auch wieder gehen. Einige Sicherheitsmaßnamen werden noch reinkommen.
Edit: Sind doch noch einige Fehler drin... Sind weiterhin dran.
Moin,
bin neu hier im Forum und echt begeistert, lese schon eine ganze Weile mit. Nun habe ich mich endlich registriert und auch gleich eine Frage, zu diesem Programm:
1. Ist dieses Programm nur eine Art Installer, um alles wichtige zu haben?
2. Und wenn ich nun alles installiert habe, womit verwende ich das Ganze? Also eine Art erweitertes Codec Paket?
3. Was muss ich alles downloaden, damit ich das Programm benutzen kann? Steige leider auf der Downloadseite nicht ganz durch.Wie ihr seht, bin ich noch ein Grünschnabel auf diesem Gebiet, aber mit eurer Hilfe wird sich das schnell ändern. Danke!
MfG
1. Das media-autobuild_suite ist kein Installer sondern ein Skript was eine Umgebung baut in der einige Programmer kompiliert werden
2. Die gebauten Binaries (.exe Dateien) findet man im media-autobuild_suite\local32 bzw. media-autobuild_suite\local64 Ordner bzw. dessen Unterordnern.
3. Am besten installiert man sich tortoisegit (https://code.google.com/p/tortoisegit/wiki/Download) und cloned das komplette Projekt (damit man sich dann auch immer Updates ziehen kann)
Alternativ kann man auch einfach nur die aktuelle Version https://github.com/jb-alvarado/me…hive/master.zip herunterladen und entpacken.Was man normalerweise macht ist:
1. aktuelles Projekt runterladen (per git oder zip) und falls man nur das .zip archiv runtergeladen hat dieses entpacken
2. die media-autobuild_suite.bat starten, dann wird man gefragt was alles gebaut werden soll und anschließend wird dann die Umgebung zum Bauen und die gewünschten Programme erstellt
3. will man etwas später die neusten Versionen der Programme bauen, startet man wieder die media-autobuild_suite.batCu Selur
:welcome:
Zu 1.: Dieses Skript installiert eine komplette Compiler-Umgebung, lädt Quelltexte von verschiedenen Projekten herunter und übersetzt sie in ausführbare Programme (wenn alles glatt geht, was leider nicht oft der Fall ist). Man muss nicht ganz Software-Entwickler sein, um das alles zu verstehen, aber ein wenig Verständnis auf diesem Gebiet wäre sehr nützlich (vor allem wenn mal nicht alles glatt geht).
Zu 2.: Es werden keine "Codecs" im System installiert, nur eigenständig laufende Programme (EXE-Dateien) erzeugt, die üblicherweise an der Eingabeaufforderung bedient werden müssten (außer man bindet sie in Benutzeroberflächen ein, von denen die dann im Hintergrund benutzt werden). Wer mit CLI-Programmen (wie Encodern, Multiplexern, Analysetools) keine Erfahrung hat, sondern lieber Programme mit Fenstern und Mausbedienung verwendet, wird das Ergebnis eventuell nicht gerade nützlich finden. Am ehesten ist dieses Paket für solche Leute gedacht, denen fertig compilierte Programme von anderen Websites nicht genug Funktionen enthalten (weil EXE-Dateien mit diesen Funktionen wegen der Software-Lizenzen nicht veröffentlicht werden dürfen), oder die immer sofort die allerneuesten Funktionen testen müssen (auch die, die noch fehlerhaft sind).
Danke für eure Antworten. Jetzt bin ich schon mal schlauer geworden. Ich werde dieses dann mal in Angriff nehmen und mal rum probieren.
Könnte jemand ein aktuelles MP4Box x64 build irgendwo hochladen, sind irgendwelche Einschränkungen im Vergleich zu den offiziellen nightly builds bekannt?
Bei mir sagt das Skript 'gpac is already up to date', aber die MP4Box binary ist vom 16.04.2015, falls Interesse besteht kann ich die irgendwo hochladen,...
(hab mal nen Eintrag im Bugtracker diesbezüglich gemacht: https://github.com/jb-alvarado/me…suite/issues/86) -
ja bitte, würde das gerne testen, wenn man beim offiziellen Build noch die zwei benötigten VC++ 2010 DLLs dazu rechnet, dann hat man fast die dreifache Größe.
Hab ich Dir angehängt,..
Danke
edit:
hab kurz mal durch getestet, soweit funktioniert alles.
media-autobuild_suite geht jetzt wieder gegen aktuelle Sourcen, gpac ist von svn (sourceforge) -> git (github) mit den Sourcen umgezogen, was wohl keiner mitbekommen hatte, ist jetzt aber gefixed
-> aktueller build im Anhang -
