Hallo zusammen,
ich poste mal gleich zu Anfang die .logs.
"manuelle" Umwandlung von .DTS zu .Ac3 mit Sonic Audio Decoder
eac3to v3.27command line: eac3to.exe 1.dts 1.ac3 -640------------------------------------------------------------------------------DTS Master Audio, 5.1 channels, 16 bits, 48kHz(core: DTS, 5.1 channels, 16 bits, 1509kbps, 48kHz)The ArcSoft decoder doesn't seem to work, will use Sonic instead.Decoding with DirectShow (Sonic Audio Decoder)...DirectShow reports 5.1 channels, 16 bits, 48kHzRemapping channels...Encoding AC3 <640kbps> with libAften...Creating file "1.ac3"...The original audio track has a constant bit depth of 16 bits.eac3to processing took 26 minutes, 46 seconds.Done.
Nun die gleiche Tonspur mit Arcsoft
eac3to v3.27command line: eac3to.exe 1.dts 1.ac3 -640------------------------------------------------------------------------------DTS Master Audio, 5.1 channels, 16 bits, 48kHz(core: DTS, 5.1 channels, 16 bits, 1509kbps, 48kHz)Decoding with ArcSoft DTS Decoder...Remapping channels...Encoding AC3 <640kbps> with libAften...Creating file "1.ac3"...The original audio track has a constant bit depth of 16 bits.eac3to processing took 11 minutes, 43 seconds.Done.
Und nun das Problem mit Staxrip
eac3to v3.27
command line: "C:\Users\mustermann\Desktop\StaxRip\Applications\eac3to\eac3to.exe" "C:\Users\mustermann\Desktop\film1 temp files\film1 ID1 GER DTS HD - de-German.dts" "C:\Users\mustermann\Desktop\film1 temp files\film1 ID1 GER DTS HD - de-German.wav" -down6 -down16 -resampleTo48000 -simple -progressnumbers -log="C:\Users\mustermann\Desktop\film1 temp files\film1 ID1 GER DTS HD - de-German_Decode.txt"
Writing WAV...
Creating file "C:\Users\mustermann\Desktop\film1 temp files\film1 ID1 GER DTS HD - de-German.wav"...
[B]Caution: The WAV file is bigger than 4GB. <WARNING>
Some WAV readers might not be able to handle this file correctly. <WARNING>[/B]
eac3to processing took 11 minutes, 41 seconds.
Done.
Alles anzeigen
Die .wav ist insgesammt 5,32gb groß hat aber komischerweise nur Ton bis zur 41:06 Minute dann ist Ende.
Eigentlich geht die Originale Tonspur aber 2:45:22.
Bei der Umwandlung zur .ac3 dann ist diese .ac3 Datei nur 186mb groß und geht bis zur minute 40:23.
Also irgendwas haut da ganz und garnicht hin.
Kodiere ich die Tonspur über Eingabeaufforderung mit
"eac3to.exe film1.dts film1.ac3 -640"
ist alles ok und bekomme komischerweise nicht die Fehler/Warnmeldung wegen der über 4gb großen WAV Datei und alles ist in Ordnung.
Diese .ac3 ist dann 757mb groß und geht bis 2:45:22
Meine Frage wäre nun ist das vielleicht ein Fehler in Staxrip oder woran kann das liegen?
Würde ja gerne weiterhin alles über Staxrip laufen lassen aber da scheint sich das Problem mit den über 4gb großén Dateien eingeschlichen zu haben so dass man bei diesen größen doch manuell umwandeln muss mit Eingabeaufforderung und eac3to.
Was ich auch noch nicht so richtig verstehe ist, warum bei Staxrip .wav angefertigt werden bei der Umwandlung von .dts zu .ac3, ich hatte bei der manuellen Erstellung keine .wav im eac3to oder im windows Temp Ordner.
