Wenn ich folgendes übersetze dann müsste ich doch den Haken an der besagten Stelle in VDub abwählen,rausnehmen ?
What the Color Shifts are concerned, there is a Bug in VirtualDub, since Version 1.6 (!). It's the internal Routines and build-in Codecs that need to be disabled in VirtualDub. Go to "Options - Preferences", select "AVI" and disable the Option "Directly Decode Uncompressed YCbCr (YUV) Sources". This disables the internal Codecs of VirtualDub and only the external ones get used. Another Reason for the Color Shifts with UYVY, YUY2 and YVYU is the "msyuv.dll" from Microsoft, there are some buggy Versions out and the last one that i know of, that works fine is the one from DirectX 9.04.
Entnommen aus Beitrag 22
http://forum.videohelp.com/threads/348013…nologies-Codecs
und hier die "besagte Stelle" in VDub
Kann mir jemand Licht ins Dunkle bringen.
