Hallo zusammen!
Seit heute ist ein neues Rippack 0.28.7 von Gordian Knot raus.
ZitatAlles anzeigen
Notes:
contains:
- GK 0.28.7
- DVDDecrypter 3.1.7.0
- vStrip 0.8f CSS
- DVD2AVIdg 1.0.0
- BeSweet 1.5b23
- azidts 0.1
- vsfilter
- KernelDeInt
- DGBod
- Decomb 5.1,
- fluxxmooth
- Convolution3D
- Deen
- TomsMoComp,
- Avisynth 2.53
- VobSub 2.23
- VirtualDubMod CVS 1.5.10.1
- Nandub RC2 lumafix ecffix
- chapterXtractor 0.962
- Robot4Rip 0.5
Changes:
- added support for muxing of mpa files
- GK can be run without admin right on NT-based systems with no problems now
- new deinterlace filter KernelDeInt (Kernel Deinterlace) which replaced Field deinterlace
- auto&smart crop are now producing width mod 4 (to fix TomsMoComp related problems)
- autosplit is improved (audio parameters are properly used when splitting)
- both XviD and DivX pass settings are now correctly picked up from default to avoid resetting when dealing with different version of codecs, like XviD 1.0 for instance (now whatever was saved as default will not be overwritten on encoding window)
- implemeted some registry inserts on startup, so that there is no more need in running nandub & vdubmod at least once after installation
- update tools: VSFilter(non-unicode by deafult), Decomb 5.1, VirtualDubMod 1.5.10.1, BeSweet 1.5b23, Avisynth 2.5.3 (with it's own installer - no more screwups)
- updated installer (new compression - should take less space)
Gibt's hier.
Cu Rippraff
Edit: Ist allerdings fraglich, ob da schon der Bugfix zu VirtualDubMod 1.5.10.1 mit dabei ist, näheres dazu hier.
