Und noch zwei im Normal-Recompression-Modus:
VirtualDubMod kann kein YV12 lesen (Fehler -2): Die Lösung
Darf es noch etwas präzieser sein?
Alles anzeigenLogfile from 13. August 2004, for DVD: Blade_FSK_16 | +---Ripping | \---DVD Decrypter 3.2.3.0 | +---Mode | | IFO | +---Input | | \---VTS_01 | | \---PGC 1 [01:46:18] | | Chapter 6 / Cell 6 [00:02:27] | \---Stream Procesing | \---Enable Stream Processing | Demux 0xE0 Video: MPEG-2 / 720x576 (PAL) / 4:3 -> Filesize = 3.653.626 KB \---Video +---Indexing | \---DGIndex 1.0.12 | +---Video | | +---iDCT Algorithm | | | 64-bit Floating Point | | +---Field Operation | | | None | | \---YUV->RGB | | PC-Scale | \---File | Preview [F5] -> Aspect Ratio = 4:3 / Frame Rate = 25.000 fps / Video Type = PAL / Frame Type = Interlaced (NO artifacts in preview -> progressive) / Info = T (Top Field First) +---Frameserving | \---AviSynth 2.55 Beta (290704-2) | \---Script | LoadPlugin("DGDecode.dll") # Version 1.0.12 | MPEG2Source("DGIndex.d2v") | Crop(10,130,700,316) | LanczosResize(464,192) | Trim(26,1525) +---Writing Application | \---VirtualDubMod 1.5.10.1 build 2439 // VirtualDub 1.5.10 build 18160 | \---VIDEO | | Fast Recompress | \---Compression | XviD MPEG-4 Codec \---Encoder \---XviD MPEG-4 Codec - Koepi's binaries (1.0.1-05062004 Final Release) +---Profile @ Level | \---AS @ L5 -> more | +---Profile | | +---Profile @ Level | | | AS @ L5 | | +---Quantization type | | | H.263 | | +---Adaptive Quantization | | | (x) | | +---Interlaced Encoding | | | ( ) | | +---Quarter Pixel | | | (x) | | +---Global Motion Compensation | | | (x) | | \---B-VOPs | | \---(x) | | +---Max consecutive BVOPs | | | 3 | | +---Quantizer ratio | | | 1.50 | | +---Quantizer offset | | | 0.00 | | +---Packed bitstream | | | ( ) | | \---Closed GOV | | (x) | \---Aspect Ratio | \---Pixel Aspect Ratio | Square (default) +---Encoding type | \---Twopass - 1st pass -> more | +---Stats filename | | A.pass (B.pass for VDub) | +---Full quality first pass | | (x) | \---Discard first pass | (x) +---Encoding type | \---Twopass - 2nd pass -> more | +---Stats filename | | A.pass (B.pass for VDub) | +---intra-frames tuning | | +---I-frame boost | | | 0 | | +---I-frames closer than...(frames) | | | 1 | | \---...are reduced by (%) | | 0 | +---Overflow treatment | | +---Overflow control strength | | | 0 | | +---Max overflow improvement (%) | | | 1 | | \---Max overflow degradation (%) | | 1 | \---Curve compression | +---High bitrate scenes degradation (%) | | 0 | \---Low bitrate scenes improvement (%) | 0 +---Target size (kbytes) | 1547 +---Zones | \---Start frame # | | 0 | +---Rate control | | \---Weight | | 1.00 | \---Static | +---Begin with keyframe | | (x) | +---Greyscale encoding | | ( ) | +---Chroma optimizer enabled | | (x) | \---BVOP sensitivity | 0 \---Advanced Options... +---Motion | +---Motion Precision | | +---Motion search precision | | | 6 - Ultra High | | +---VHQ mode | | | 4 - Wide Search | | +---Use chroma motion | | | (x) | | \---Turbo ;-) | | ( ) | \---Other | +---Frame drop ratio | | 0 | +---Maximum I-frame interval | | 250 | \---Cartoon Mode | ( ) +---Quantization | +---Quantizer restrictions | | +---Min I-frame quantizer | | | 1 | | +---Max I-frame quantizer | | | 31 | | +---Min P-frame quantizer | | | 1 | | +---Max P-frame quantizer | | | 31 | | +---Min B-frame quantizer | | | 1 | | \---Max B-frame quantizer | | 31 | \---Trellis quantization | (x) \---Debug +---Performance optimazions | Automatically detect optimazions +---FourCC used | XVID +---OutputDebugString debug level | 0x0 \---Print debug info on each frame ( )
Samples are identical after offset 1268hex -
Vorbildlich! Bloß der Filmname sollte niemanden interessieren. (Obwohl, man sieht ja den Inhalt...)
Der bisherige Kommentar von Suiryc (alias Cyrius) war irgendwie noch nicht besonders hilfreich, finde ich...
Keine Sorge, die FSK 16 Version von Blade is Region Free und nicht CSS geschützt - den DVD Decrypter habe ich in diesem Fall also eigentlich nur zum Demuxen und Schneiden benutzt - und wegen 1500 Frames in der absichtlich extrem schlechten Qualität sollte es auch keinen Ärger geben.ZitatDer bisherige Kommentar von Suiryc (alias Cyrius) war irgendwie noch nicht besonders hilfreich, finde ich...
Ja, leider - hoffentlich kommt noch was sinnvolles - entlich auf die miese Mod verzichten zu können, wäre schon genial und die zwei Bits im Header kann ich zur Not auch von Hand fixen.Ich bin übrigens weiterhin der Ansicht, daß man bei VirtualDub auch via direct stream copy sehen kann, das wirklich YV12 ausgegeben wird. Denn wenn Du den XviD Decoder via AVISource anweist, RGB32 zu liefern, kommt bei VDub DSC nämlich ein RGB32 AVI raus. Würde VirtualDub also vom Decoder immer >=YUY2 fordern, muß sich selbiges auch bei DSC zeigen.
Mittlerweile sind wir wohl eine Vermutung weiter:
Nicht "VirtualDubMod verarbeitet kein YV12", sondern "VirtualDub verarbeitet wohl auch YV12, obwohl das laut Doku angeblich wieder entfernt wurde"...
Ich fürchte, weitere Tests müssten dann mehrere Generationen von VirtualDub zurückverfolgen. Aber das tue ich mir dann wohl nicht mehr an (obwohl ich noch ein kleines Archiv hätte).
Hallo ihr Lieben,
nach einigen Jahren Pause möchte ich nun wieder anfangen mir von meinen DVD Sicherungskopien mit Gordian Knot zu erstellen.
Also habe ich die neueste Version von GK runtergeladen, installiert und mich an den ersten Film gemacht. Dies hat auch funktioniert, nur war ich mit der Qualität nicht zufrieden (Bei den Audiodateien habe ich einen Fehler gemacht, so das diese zu groß waren und der Film dann zu klein), also habe ich es nochmal versucht, doch leider meldet mir dieses Mal der Virtual Dub den "error Code -2"
Ich kann mich noch erinnern das ich früher dieses Problem schon mal hatte, weiß aber nicht mehr die Lösung. Auch bei der Suche in diesem Forum habe ich nicht wirklich eine Lösung gefunden. Speziell dieser Threat hört sich für mich an wie Chinesisch. Kann mir jemand helfen?
Liebe Grüße
Ganesh -
Sorge dafür, dass es einen VfW-Codec gibt, der die Konvertierung von YV12 übernimmt.
Eigentlich sollten XviD und DivX das tun. Wenn nicht, kann man auch noch den ffdshow-VfW-Codec entsprechend konfigurieren, dass "Raw-Video" verarbeitet wird; zumindest YV12 (oder "planare Formate") sollten dafür aktiviert werden.
Der Kern einer der Ursachen für Fehler -2 liegt darin, dass VirtualDub YV12 im Vorschaufenster anzeigen möchte. Allerdings gibt es noch weitere Ursachen, gegen die dieser Tipp nicht hilft.
Hallo Ligh,
vielen Dank für Deine schnelle Antwort. Ich kann mich erinnern das Du schon vor Jahren hier fleißig erklärt hast.
VFW heißt also: "Video für Windows", im Netz kommt dann die Info das man genau wissen sollte welcher VFW-Codec benötigt wird und man sich "GSPOT" runterladen soll. Dies habe ich getan. Ich weiß zwar nicht wie ich genau damit umgehen soll, allerdings habe ich in der Zwischenzeit meinen Rechner neu gestartet und nochmal GK aufgerufen. Die Fehlermeldung "-2" erscheint jetzt nicht mehr und der Film wurde einwandfrei gesichert. Seltsam! Liegt vieleicht an Vista .Anyway! Nochmals lieben Dank
Ganesh
War da nicht was, dass VfW unter Vista nur noch emuliert wird?
