[font=verdana, arial, helvetica] VERSION HISTORY
1.05 beta
- second audio can be set explicitely to a given type in non-auto modes
- autosplit works correctly with two audio streams
- interlaced detection threshold raised to 2% (to avoid unnecessary deinterlacing)
- updated documentation
- added support for XviD 1.0 which is automatically detected
das ist doch mal nett
grüzi Sill
Edit: ach ja, der Link:
[/font][font=verdana, arial, helvetica]Beta release (1.0 has to be installed) 1.05:
Primary mirror: http://len0xmirror1.serveftp.net/~l...beta.Update.exe
Secondary mirror: http://len0x.btothec.com/AutoGordia...beta.Update.exe
Backup mirror: http://len0x.leffe.dnsalias.com/Aut...beta.Update.exe[/font]
Auto Gordian Knot - aktuelle Version
nachdem am 24.05.04 Auto Gordian Knot v1.25 erschienen ist, heute nun ein nettes Update...
[font=verdana,arial,helvetica]version 1.30 beta
http://len0x.btothec.com/AutoGordianKno…beta.Update.exe
[/font][font=verdana, arial, helvetica] Change log (bigger than ever):
- DUE TO MISUSE OF AUTOGK WITH UNSUPPORTED RIPPING TOOLS, IT'S NO LONGER ABLE TO PARSE IFO FILES, SO ONLY DVDDECRYPTER IN IFO MODE CAN BE USED FROM NOW ON
- AutoGK works now with DGMPGDec 1.0.9
- removed test for alternative field order for PAL sources
- video type and AR is taken from D2V file now
- added support for direct opening of MPEG2 files (VOB/M2V/MPG/MPEG). Enabled by CTRL-F12
- fixed problem of cutting off last few seconds of video during splitting
- installer fixes AVI file association to prevent "Error opening AVI" after comp test
- added option to rip all subtitle streams (only when using external subs)
- message "WinRar is not found" is no longer displayed when internal subs are used
- improved parsing of stream info file
- comp test limit is reduced to 65% for XviD 1.0 (resulting in higher resolution output)
- added more debug info into logs
- indexing/demuxing step has now timeout of 30 min after which job will be aborted to allow the queue to proceed
- subtitle splitting step has now timeout of 5 min after which job will proceed anyway
- bitrate for mono encoding is now always half of the bitrate set on advanced options window
- resizing algorithm changed heavily to accomodate upcoming support for different input sources (ITU standard is no longer applied)
- field order, aspect ratio and resolution is now taken during encoding from D2V file
- possible width is increased to 1920
- max quality and target quality modes are using source input width and not predefined width of 720/704
[/font]
dat is doch mal nett, oder ?!
P.S.: kann mal jemand bitte das "v1.05 beta" aus dem Threadtitel entfernen und nur noch den Namen stehen lassen - danke. Ich hab's versucht aber bin gescheitert... Ey, bin ich Mod oda was -
Themen-Optionen - Thema bearbeiten ... darfst du nicht?
http://len0xmirror1.serveftp.net/~len0x/AutoGor…beta.Update.exe
Der Link funktioniert zumindest bei mir, obiger nicht.
Ist nach eigener Aussage von len0x aber noch mehr Alpha als Beta...
Hier der Thread dazu: http://forum.doom9.org/showthread.php…5541#post505541
mfg
ylfcam -
Version 1.79 beta
[font=verdana, arial, helvetica] - improved handling of DTS and PCM audio tracks
- minimum and maximum width settings are respected during adjustments after first pass[/font] -
[font=verdana, arial, helvetica] 1.82 beta
- 2Gb predefined target size is reduced to accomodate oversize (now its 2040 Mb)
- fixed a bug when custom target size resets itself during minimize/restore action
- fixed a bug when AutoGK cannot write registry settings after a codec was just reinstalled[/font] -
[font=verdana, arial, helvetica] 1.83 beta
- added support for LPCM audio tracks in file mode (by adding new DGIndex)
- added link to FAQ on info window
- lame_enc.dll updated to version 3.96.1[/font] -
[font=verdana, arial, helvetica] 1.84 beta
- fixed subtitles position for half-D1 DVD sources
- debug mode shows complete vcf scripts in the logs
- bundled with XviD 1.0.3 [/font] -
[font=verdana, arial, helvetica] 1.86 beta
- added audio detection for the file mode (no more 'Unknown Audio')
- better handling of PCM audio streams in mpeg/vob files
- video PID is displayed in AutoGK upon loading of a transport stream
- ".audio_id" hidden option is removed (as audio should be properly detected in file mode now)
- AutoGK Asisstant is integrated into AutoGK (still via CTRL-F9)
- minor GUI fixes
- lame_enc.dll is downgraded back due to problems with mono encoding[/font] -
1.87 beta
- fixed some bugs on new hidden option window
- shortcut CTRL-F10 is removed
- for PCM/MPA audio tracks in auto audio mode default bitrate for > 1CD rips is 192kbps now
- BeSweet is replaced by azid/normalize/lame(3.96.1) combo (lots of testing required)
- minimum bitrate for both CBR and VBR modes is lowered to 32kbps
- removed timeout for demuxing operation -
1.88 beta
Updating small bits and pieces. Change log:- intermediate WAV file is deleted after MP3 encoding
- DGMPGDec updated to version 1.1.0
- check for updates improved to detect stable/beta versions (new option will come for stable release) -
Version 1.89 beta is out
A couple of old bugs fixed, improved handling of TS sources and minor cosmetic changes. Full change log:
- fixed audio detection for some configurations in file mode
- AutoGK respects max resolution settings after change of matrix during resizing step
- some new icons (should look OK on non-WinXP systems)
- improved PIDs detection for transport streams
- remove .tstream hidden option
- added .aspect hidden option to override 16:9 vs 4:3 input AR
- input dir (or its parent) are persistent for different AutoGK runs -
1.93 beta
- speedup of denoising for SSE2 & SSE3 capable CPUs (via different versions of RemoveGrain.dll)
- Reduced chance of oversized XviD encode in some cases
- min quantizer is reduced to 1 if undersize of XviD encode is expected
- encoding is aborted after first pass if number of frames was very different from expected (to prevent wasting time during second pass after first pass crashed)
- DGIndex updated to version 1.2.1
- ColorMatrix.dll is updated to version 1.9 -
Stable AutoGK 1.95 is out
- updated tutorial
- new option in the installer to check updates only for stable versions
- auto complete of AVI file name in SaveAs dialog (uses input dir name as the name of avi file)
- minor GUI changes
- demuxed MPA tracks are no longer deleted after audio encoding
- min quality of credits that can be set is now 1%ZitatThis release does contain a separate responsetarget advertizing software (see disclaimer in the installer) as was introduced in latest betas. Search the development forum for more info - it was extensively discussed there.
2.00 beta is out
ZitatAs promised here is first version with AVI input support, plus initial support of new DIVX media format (lets see if it becomes useful). Enjoy.
Version 2.01 beta is out
ZitatOn the way of improving AVI input support. Change log:
- added support for RGB codecs in input AVIs
- added support for manual AR settings for AVI input sources
- fixed procesing of 24fps AVI sources in some cases
- improved duration detection for AVI input sources
- added ability to select 1:1 PAR in hidden options to allow anamorphic encoding -
Version 2.02 beta is out
ZitatOn the way to improving AVI input support. Change log:
- improved accuracy of duration detection for AVI input sources
- fixed duration detection for AVI input sources with wrong AVI header
- forced 4:3 output resolution autodetection is improved and moved to hidden options
- 1:1 AR in hidden options changed to 'Original' to allow proper anamorphic encoding
- fixed a bug when the same subs were put in all current jobs after a preview with subs -
Version 2.05 beta is out
XviD 1.1 beta is finally stable enough to start using it. Also I reworked quite a bit of code in this version, so it is really beta. Change log:
- XviD 1.1 beta 2 is bundled (should be quite stable by now)
- fixed few minor bugs in the log
- M2V input is supported again
- disabled support for DIVX media format for the time being
- DGIndex updated to 1.3.0 beta 5
- audio and subtitles handling code is re-written to make it more flexible (for future versions)
- transport streams with multiple video streams can be processed again -
Version 2.06 beta is out
Release newsThis can be considered as more stable version. Change log:
- removed Maximum Quality mode (use 100% quality instead)
- DV sources can no longer be detected as hybrid
- hybrid AVI input sources can be processed now
- fixed bug when other than first stream of subs could not be displayed (introduced in 2.05)
- "All subtitles" option works again (broken in 2.05)
- XviD 1.1 beta build from 10/04/05 is bundled (may solve the problem with having "bitrate spikes control" option on without ESS support) -
Version 2.07 beta is out
Handful of minor bugfixes. Change log:
- fixed bug when color correction was used on AVI input sources
- XviD installer repackaged to solve install problems on Win9x
- added support for DTS audio in input AVI sources
- fixed bug when 4:3 AR detection was not working properly
- second audio in auto mode is VBR MP3 again -
