Bereits am 30.04. wurde die Version 2.69 des
Cinema Craft Encoders Basic herausgegeben.
Gibts hier:
New features
Change
- Updated encoder engine to 2.69.
Enhancements
- Supported Adobe Premiere Pro. (plug-in version)
- Enabled to output bottom field first stream.
- Added automatic resolution conversion function.
- Added quantization characteristics setting.
- Added de-interlacing function.
- Added blanking function.
- Enabled to save/load template to/from file.
- Enabled to use the last modified parameter setting.
- Enabled to specify file size.
- Enabled to shut down the system when finished encoding.
- Enabled to play a sound file when finished encoding.
Wer von 2.67 auf 2.69 updatet, sollte VORHER unter Video-Settings
das Häkchen bei 'DVD compliant' wegnehmen, sonst fehlen einige
features.
Zitat:
Caution when transferring 2.67 templates and ecl files to 2.69
"DVD" mode was newly added to 2.69 program, and this affects 2.67
templates and ecl files which include "DVD compliant" checked setting.
If you setup 2.69 program without removing 2.67 program, some
parameters will be changed automatically. To avoid this, please clear
"DVD compliant" check in your 2.67 templates and ecl files, then setup
2.69 program.
If your 2.67 templates and ecl files include "DVD compliant" checked,
the parameters below are automatically changed in 2.69:
1. Elementary Stream output settings are changed to "DVD" mode
and the following parameters are changed.
Version.............................|...............2.67...............................|2.69
Audio..................................|...MPEG-1 audio....................|..Wave audio
Sampling frequency | 32000/44100/Default |...48000
Aspect ratio..................|....2.21:1.....................................| 16:9
...............................................|.....SAR 1:1.................................| 4:3
2. Program Stream output settings are to be "MPEG-2" mode.
